  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • pepsonP pepson
    Where i can found good DHT library for this sketch ?
    @pepson how about the library linked from the build page?
    • pepsonP
      pepsonP
      pepson
      sorry i found
      • Jim DanforthJ
        Jim DanforthJ
        Jim Danforth
        Using library linked above
        Getting: no matching function for call to 'DHT::readSensor(bool)'
          This thread contains comments for the article "Air Humidity Sensor - DHT" posted on MySensors.org.
          ramoncarranzaR
          ramoncarranzaR
          ramoncarranza
          @hek
          hi, how do I change the readings from C to F?
          My sensor works fine, by I get the readings I celsius
          mikeSM 1 Reply Last reply
          • ramoncarranzaR ramoncarranza
            @hek
            mikeSM
            mikeSM
            mikeS
            @ramoncarranza
            Change the line in the sketch:
            to
            temperature = dht.toCelsius(temperature);
            probably? I haven't checked it, just looked at the DHT library. You may need to comment the isMetric line earlier in the sketch too. But I think that's how you do it.
            ramoncarranzaR 1 Reply Last reply
            • mikeSM mikeS
              @ramoncarranza
              to
              ramoncarranzaR
              ramoncarranzaR
              ramoncarranza
              @mikeS Thanks so much for your reply, it's working perfectly now.
              • meanmrgreenM
                meanmrgreenM
                meanmrgreen
                @Jim Danforth
                Getting the same, have tried a number of different DHT libraries and cant get it to compile.
                • mikeSM
                  mikeSM
                  mikeS
                  @meanmrgreen The only DHT library that will work is the one from the link before the sketch. If you have used others chances are you need to move or rename those other DHT libraries as that is why the sketch cannot call that function.
                  meanmrgreenM 1 Reply Last reply
                  • mikeSM mikeS
                    meanmrgreenM
                    meanmrgreenM
                    meanmrgreen
                    @mikeS
                    Ive tried to reinstall and start från scratch but i guess i Missed something.
                    • mikeSM
                      mikeSM
                      mikeS
                      @meanmrgreen sometimes windows puts libraries in your documents folder, so they may be located in 2 or more places. Use windows search to find them all. I have 3 DHT libraries, the mysensors one, the adafruit(I think) and another that came with an MQTT based sketch for an ESP board. I just rename them. Incidentally the mysensors DHT library gives me the most accurate results, as much as 2 degrees and 10% out on the same sensor using a different library.
                      Also don't update the DHT library if you are told there is an update!
                      As you can tell I had a few problems myself before I got this working, it almost made me disregard the whole project. Keep trying , it's worth it.
                      • mikeSM mikeS
                        meanmrgreenM
                        meanmrgreenM
                        meanmrgreen
                        @mikeS thanks alot!
                        I'll keep that in mind. Should be getting my "starter kit" order soon from eBay so we'll see how it goes ;)
                        • meanmrgreenM
                          meanmrgreenM
                          meanmrgreen
                          Finaly got it to compile.
                          I tried the library link above but no go, cleared out everything about ardouino on the pc, no go.
                          I finaly stubled onto this:
                          https://github.com/mysensors/MySensorsArduinoExamples
                          Downloaded all the expample libraries, loaded the scetch and it worked!
                          Something is up with the linked library on this page i think
                          • meanmrgreenM meanmrgreen
                            @meanmrgreen the link pointed to a folder on GitHub. If that folder is downloaded, you get the MySensorsExamples. But in that folder, there is also a link to the original DHT library. If that link is followed, the wrong library will be downloaded.
                            Several people have been bitten by this so I have now changed the link to point directly to the MySensorsExamples zip file.
                            • OliO
                              OliO
                              Oli
                              Could someone explain me why "Must be >1000ms for DHT22 and >2000ms for DHT11" when sampling rate is once per sec for DHT11 (once per 1000ms) and twice per sec for DHT22 (once per 500ms)?
                              • AmputA
                                AmputA
                                Amput
                                In Wiring Things Up and screen are used DATA_PIN 3, but in example is wrote #define DHT_DATA_PIN 2 :-) ...please correct it.
                                hekH 1 Reply Last reply
                                • AmputA Amput
                                  @Amput,
                                  Thanks, updated.
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    @hek
                                    No it is not fixed!
                                      ramoncarranzaR
                                      ramoncarranzaR
                                      ramoncarranza
                                      @hek how do I change fro C to F?
                                      • skywatchS skywatch
                                        @hek
                                        No it is not fixed!
                                        @hek I think @skywatch meant that the text is updated, but not the picture. The picture is still using pin 3.
                                          @ramoncarranza set your controller to use non-metric.
