  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • AndurilA
    AndurilA
    Anduril
    @tiana well you could simply calibrate the value you get in your sketch for every DHT on it's own. But you have to do a calibraton, meaning measure all of them at multiple temperatures and humidities.
    If it's only a offset you can also use
    #define SENSOR_TEMP_OFFSET 0
    to correct for this, otherwise you have to implement your calibration function on your own.
    • tianaT
      tianaT
      tiana
      For some sensors is possible to make with offset, but some of the sensors changing their values 2 times in minute with + - 2 degree Celsius some times show more sometimes show less.
      • AndurilA
        AndurilA
        Anduril
        well I think this kind of noise can not be calibrated. I thought they all have different values, but with offset, linear oder squared function for deviation.
        • tianaT
          tianaT
          tiana
          I read datasheet for DHT11 and 2 degree deviation is ok for them. Now i playing with DHT22 I try this #define SENSOR_TEMP_OFFSET -1.3, but nothing is changed the sensor still give me same value.
          • tianaT tiana
            @tiana try setting SENSOR_TEMP_OFFSET to a really big value, for example -30.8 to make sure that the change is large enough to be noticeable.
            • pepsonP
              pepsonP
              pepson
              Where i can found good DHT library for this sketch ?
              • pepsonP pepson
                @pepson how about the library linked from the build page?
                • pepsonP
                  pepsonP
                  pepson
                  sorry i found
                  • Jim DanforthJ
                    Jim DanforthJ
                    Jim Danforth
                    Using library linked above
                    Getting: no matching function for call to 'DHT::readSensor(bool)'
                      This thread contains comments for the article "Air Humidity Sensor - DHT" posted on MySensors.org.
                      ramoncarranzaR
                      ramoncarranzaR
                      ramoncarranza
                      @hek
                      hi, how do I change the readings from C to F?
                      My sensor works fine, by I get the readings I celsius
                      mikeSM 1 Reply Last reply
                      • ramoncarranzaR ramoncarranza
                        @hek
                        mikeSM
                        mikeSM
                        mikeS
                        @ramoncarranza
                        Change the line in the sketch:
                        to
                        temperature = dht.toCelsius(temperature);
                        probably? I haven't checked it, just looked at the DHT library. You may need to comment the isMetric line earlier in the sketch too. But I think that's how you do it.
                        ramoncarranzaR 1 Reply Last reply
                        • mikeSM mikeS
                          @ramoncarranza
                          to
                          ramoncarranzaR
                          ramoncarranzaR
                          ramoncarranza
                          @mikeS Thanks so much for your reply, it's working perfectly now.
                          • meanmrgreenM
                            meanmrgreenM
                            meanmrgreen
                            @Jim Danforth
                            Getting the same, have tried a number of different DHT libraries and cant get it to compile.
                            • mikeSM
                              mikeSM
                              mikeS
                              @meanmrgreen The only DHT library that will work is the one from the link before the sketch. If you have used others chances are you need to move or rename those other DHT libraries as that is why the sketch cannot call that function.
                              meanmrgreenM 1 Reply Last reply
                              • mikeSM mikeS
                                meanmrgreenM
                                meanmrgreenM
                                meanmrgreen
                                @mikeS
                                Ive tried to reinstall and start från scratch but i guess i Missed something.
                                • mikeSM
                                  mikeSM
                                  mikeS
                                  @meanmrgreen sometimes windows puts libraries in your documents folder, so they may be located in 2 or more places. Use windows search to find them all. I have 3 DHT libraries, the mysensors one, the adafruit(I think) and another that came with an MQTT based sketch for an ESP board. I just rename them. Incidentally the mysensors DHT library gives me the most accurate results, as much as 2 degrees and 10% out on the same sensor using a different library.
                                  Also don't update the DHT library if you are told there is an update!
                                  As you can tell I had a few problems myself before I got this working, it almost made me disregard the whole project. Keep trying , it's worth it.
                                  • mikeSM mikeS
                                    meanmrgreenM
                                    meanmrgreenM
                                    meanmrgreen
                                    @mikeS thanks alot!
                                    I'll keep that in mind. Should be getting my "starter kit" order soon from eBay so we'll see how it goes ;)
                                    • meanmrgreenM
                                      meanmrgreenM
                                      meanmrgreen
                                      Finaly got it to compile.
                                      I tried the library link above but no go, cleared out everything about ardouino on the pc, no go.
                                      I finaly stubled onto this:
                                      https://github.com/mysensors/MySensorsArduinoExamples
                                      Downloaded all the expample libraries, loaded the scetch and it worked!
                                      Something is up with the linked library on this page i think
                                      • meanmrgreenM meanmrgreen
                                        @meanmrgreen the link pointed to a folder on GitHub. If that folder is downloaded, you get the MySensorsExamples. But in that folder, there is also a link to the original DHT library. If that link is followed, the wrong library will be downloaded.
                                        Several people have been bitten by this so I have now changed the link to point directly to the MySensorsExamples zip file.
                                        • OliO
                                          OliO
                                          Oli
                                          Could someone explain me why "Must be >1000ms for DHT22 and >2000ms for DHT11" when sampling rate is once per sec for DHT11 (once per 1000ms) and twice per sec for DHT22 (once per 500ms)?
