  3. Vera
  4. UI5 Mysensors library 2.0 gateway issues
73 Posts 8 Posters 25.1k Views 8 Watching
    Yes, of course @martinhjelmare , you're right. It's this that kicks in:
    https://github.com/mysensors/MySensors/blob/934ccf30b205afad2086c908a367c4205ce580cd/core/MySensorsCore.cpp#L285
    Hmm.. Wonder why the Vera plugin isn't sending I_VERSION like it should then...
    • BartEB
      BartEB
      BartE
      @hek andf @martinhjelmare i did some debugging this evening and came to the following findings
      My previous comment on start-up behavior was based on a stand alone GW (so disconnected from the Vera Controller)
      And i found out that the Library version is NOT pushed by the gateway but requested by the controller on plugin startup.
      And this part (on GW side is working) --> Sending "0;0;0;3;0;2;Get Version" to the GW is being answered with "0;255;3;0;2;2.0.0"
      So it must be the Vera plugin and then i found this line in my Vera box
      02      07/30/16 23:23:43.694   luup_log:64: Arduino: Incoming internal command '0;255;3;0;2;2.0.0' discarded for child: nil <0x6c14>
      So the MySensors v2.0.0 GW responses with alt-id 0;255 i.s.o 0;0
      By updating this line https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L370 by... auhm what is already in the current git version it works.
      So the final conclusion: just update the Vera plugin with the development branch and it works...
      • rchampR
        rchampR
        rchamp
        wrote on last edited by rchamp
        Note. i left the plugin in place, and was able to enroll the node after some time.
        I have a feeling it just took Vera / plugin longer than I expected to detect the USB serial connection to the GW.
        node ID's seem to come in fine and libversion displays as 2.0.0 for the node. the 2 nodes (+ the updated GW) all appear to be running stable. if i run into another issue i will go for the development branch for the plugin
        • stofakillerS
          stofakillerS
          stofakiller
          Im on UI7 and have the same issue, on the github development all files are many many months old, the should be newer than like 8 months???
          Regards,
          Jan
          BartEB 1 Reply Last reply
          • stofakillerS stofakiller
            Regards,
            Jan
            BartEB
            BartEB
            BartE
            @stofakiller no the 8 month old files where OK for me (UI5)
            ramoncarranzaR 1 Reply Last reply
            • ramoncarranzaR
              ramoncarranzaR
              ramoncarranza
              Hi, I have the same issue. I installed the plugin and serial Gateway with no apparent issues, but can't add any sensors. I have triple-checked the wiring on the sensors and gateway with no success. One thing I have notice some of the Arduino LUUP Files on Vera display the following message when you open/view them.
              This page contains the following errors:
              error on line 1 at column 1: Document is empty
              Below is a rendering of the page up to the first error.
              • BartEB BartE
                ramoncarranzaR
                ramoncarranzaR
                ramoncarranza
                @BartE
                Hi, my plugin still shows version 1.5 even though I am using Version 2.0, I have not been able to include a single sensor. I have created 3 of them and not one can be found by the Plugin after the Inclusion button is pressed, any input would be greatly appreciated.
                  wrote on last edited by hek
                  The vera plugin still has version 1.5. It does not correlate to MySensors Arduino library versions.
                  https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L20
                  Are you on UI7 or UI5?
                  When pressing inclusion mode button, does anything happen in the UI? (the text changes in the device to "found devices...")
                  • ramoncarranzaR
                    ramoncarranzaR
                    ramoncarranza
                    hi, I am using UI5. After pressing the Start button it indicates that "0 devices found"
                      Ok, so at least you have a contact with the gateway.
                      After starting inclusion mode, do you restart the wireless node? It usually only sends its presentation messages during startup.
                      • ramoncarranzaR
                        ramoncarranzaR
                        ramoncarranza
                        Yes, I start by having the sensor unplugged, that right after the Start button is pressed I plug in the sensor. One thing I noticed though, is that if I go to the LUUP files and try to "view" them, som of them display the folling message:
                        but if I download the same LUUP file and open it in Notepad the file is there
                          Just to verify. You mean that you plug in the wireless sensor (with a radio)? Not the gateway?
                          If so, you should have a look in the serial log of the gateway (Serial Monitor in Arduino IDE) while it is connected to your computer. Restart the (wireless) node an capture the log.
                          • ramoncarranzaR
                            ramoncarranzaR
                            ramoncarranza
                            yes the wireless sensor with radio, not the Gateway. The gateway is plugged in on the Vera's USB port. Ok will do.
                              ramoncarranzaR
                              ramoncarranzaR
                              ramoncarranza
                              @hek ok the serial monitor comes up blank, with this in the upper left corner:
                              "1Öyô¹¹q0"
                              nothing happens after the wireless sensor is powered.....
                                Did you set the correct baudrate?
                                https://www.mysensors.org/build/debug
                                • ramoncarranzaR
                                  ramoncarranzaR
                                  ramoncarranza
                                  after switching to 115200 baud, the following poped up:
                                  0;255;3;0;9;TSM:INIT
                                  0;255;3;0;9;TSM:RADIO:OK
                                  0;255;3;0;9;TSM:GW MODE
                                  0;255;3;0;9;TSM:READY
                                  0;255;0;0;18;2.0.0
                                  no changed occurred when wireless sensor was re-started
                                    Ok, so your communication is not working.
                                    • ramoncarranzaR
                                      ramoncarranzaR
                                      ramoncarranza
                                      should I wire up a new radio, should I wire up a complete gateway with radio (or both)?
                                        You should probably look at the nodes log.
                                          ramoncarranzaR
                                          ramoncarranzaR
                                          ramoncarranza
                                          @hek ok, I plugged in the Motion Sensor to check the Serial log and nothing came up. I opened the sketch on wordpad and noticed that there is no entry on Baud rate whatsoever (I no nothing about code so I don't know if that means anything).
                                          in regards to my other Sensor which is a Temp/Humidity Sensor, the sketch is not on my Library it was not included on the downloaded Zip file, so I downloaded it from here:
                                          https://www.mysensors.org/build/humidity
                                          but the downloaded copy does not have any entry for the radio and the baud rate is set 9600 so that's why the Gateway cant communicate with them,,I think.
