  3. DHT22 on Arduino Pro Mini 8Mhz 3.3V - Failed
23 Posts 4 Posters 10.7k Views 3 Watching
  • Puneit ThukralP
    Puneit ThukralP
    Puneit Thukral
    I changed the powersupply and tried again. Also, I checked for any loose connections.
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=fail:TemperatureAndHumidity
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=ok:1.1
    TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
    !TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=fail:
    Request registration...
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=ok:2
    TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=1, parent=0, distance=1, registration=1
    Failed reading temperature from DHT!
    Failed reading humidity from DHT
    I am still stuck. Should I try another arduino and radio and sensor?
    • Puneit ThukralP
      Puneit ThukralP
      Puneit Thukral
      I tried again with a new arduino pro mini - no luck. Then I replicated the node on an Arduino Uno and same result "Failed to read". There must be something I must be doing wrong which I can't see.
      • mfalkviddM
        Strange.
        I just looked through the sketch and it looks fine to me.
        The st=fail during presentation is worrisome.
        What is the distance between the node and the gateway? Does moving the sensor further away (>2m) or closer help?
        If you can, trying another radio and sensor might be the easiest way to pinpoint the problem.
        Puneit ThukralP 1 Reply Last reply
          Strange.
          Puneit ThukralP
          Puneit ThukralP
          Puneit Thukral
          @mfalkvidd Thanks for vetting the sketch.
          For troubleshooting I brought the gateway and the node to the close to me (read centimeters between them).
          Also, on the node on which I first discovered the error, serial print occurs at baud 230400 and on other nodes (arduinos running same sketch ) serial print occurs at baud 115200. I understand that the serial debug print should occur at 115200. Is it unexpected or odd that one arduino prints at 230400 while others are printing at 115200?
          I will moving the nodes closer and away and report.
          I bought 10 pro minis all 3.3v. So, for now, I think I should start something very simple. How about door close sensors? They should be pretty simple, right? If even these don't work, then either the hardware is bad or I am. Anyway, thanks a lot for your time. This is a great forum and resource and I hope I am able to foray into this amazing world of IoT.
          • Puneit ThukralP Puneit Thukral
            @Puneit-Thukral if the baud rate is wrong, the Arduino runs at a different speed than was is selected in the Arduino IDE. Maybe you got a 5V 16Mhz instead of 3.3V 8Mhz? That could explain why the node doesn't get enough power.
              Puneit ThukralP
              Puneit ThukralP
              Puneit Thukral
              @mfalkvidd And the way to test that would be to input 9 v at RAW and measure the VCC, right? While I added 3.3 v to my ebay cart, the boards have 8Mhz 16 Mhz 3.3V 5V printed on them. This is what you get in India over ebay and Amazon. I trust that the seller picked and packed them correctly. I will (tomorrow) test the VCC after inputting 9 V at RAW and see if that changes anything.
                @Puneit-Thukral good plan. That's probably the easiest way to test. It might also be possible to read the text on the regulator, but reading the small text is usually pretty hard.
                  Puneit ThukralP
                  Puneit ThukralP
                  Puneit Thukral
                  @mfalkvidd
                  The diagnosis solved the issue. The Arduino pro mini 3.3V 8 MHz sold to me was actually a 5v 16 MHz. No more Failed reading temperature from DHT!. However, there are still a few st:fail during initialisation but later goes away.
                  Should I work towards eliminating these or would it be fine. The Openhab2 still is not reading from this node and shows NaN (even though the sensor is online).
                  Thanks for your continued help.
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=1)
                  TSM:UPL
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
                  !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=2,st=fail:TemperatureAndHumidity
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=ok:1.1
                  TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                  Node registration=1
                  TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:24.6
                  T: 24.60
                  TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.9
                  H: 41.90
                  TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:42.0
                  H: 42.00
                    @mfalkvidd
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=1)
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    Node registration=1
                    T: 24.60
                    H: 41.90
                    H: 42.00
                    @Puneit-Thukral Great work!
                    The failed presentation could be preventing OpenHab2 from displaying the node correctly.
                    Have you switched to a "real" 3.3V pro mini now or are you using the 5V? If 5V, do you use a regulator to 3.3V for the nrf?
                      Puneit ThukralP
                      Puneit ThukralP
                      Puneit Thukral
                      @mfalkvidd Yes, I connected the 3.3v regulator to VCC of the radio. I will continue to debug tonight. Maybe now something is amiss at the gateway side. The gateway radio is connected via dupont cables on the Uno and I am not very happy with dupont. I should solder the radio to Uno.
                      • Puneit ThukralP
                        Puneit ThukralP
                        Puneit Thukral
                        I believe I have been able to eliminate all the errors between node and gateway.Here is the output
                        TSM:INIT
                        TSM:RADIO:OK
                        TSP:ASSIGNID:OK (ID=2)
                        TSM:FPAR
                        TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                        TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=2)
                        TSM:UPL
                        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                        TSP:MSG:READ 0-0-2 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        TSP:CHKUPL:OK
                        TSM:UPL:OK
                        TSM:READY
                        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                        TSP:MSG:SEND 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                        TSP:MSG:READ 0-0-2 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:TemperatureAndHumidity
                        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                        TSP:MSG:SEND 2-2-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                        TSP:MSG:SEND 2-2-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                        TSP:MSG:READ 0-0-2 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        Node registration=1
                        Init complete, id=2, parent=0, distance=1, registration=1
                        TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.5
                        T: 22.50
                        TSP:MSG:SEND 2-2-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:39.2
                        H: 39.20
                        TSP:MSG:SEND 2-2-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:38.7
                        H: 38.70
                        TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.7
                        T: 22.70
                        TSP:MSG:SEND 2-2-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:36.6
                        H: 36.60
                        While, the node is detected at Openhab2, it remains offline. What am I missing now?
                        This is what I changed now
                        1. Re-created (fresh solder) the node on a 8Mhz 3.3V arduino pro mini
                        2. Changed the gateway from arduino Uno connected serial to raspberry pi gateway (mysensorsgateway). Now gateways connected as MySesnorsEthernet.
                          Please help!
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=2)
                          TSM:UPL
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          Node registration=1
                          T: 22.50
                          H: 39.20
                          H: 38.70
                          T: 22.70
                          H: 36.60
                            Please help!
                          TimO
                          @Puneit-Thukral Please do a restart of OH2 after discovery of a new thing, there is a bug that prevents the thing from coming online.
                          • T TimO
                            Puneit ThukralP
                            Puneit ThukralP
                            Puneit Thukral
                            @TimO Thanks, it's finally working! Time to add more nodes.
