  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 144.4k Views 5 Watching
  • A
    Arielpod
    I've installed Pidome on my Pi yesterday and everything seems to work, then I plugged in my Arduino nano clone with gateway sketch installed and nRF connected to it. Using python I communicated with it without any problems. But then I opened the Peripheral setting in Pidome to add the device and it doesn't see a thing... Don't know what I'm doing wrong. Seems like Pidome doesn't have enough rights. My user is in dialout group just as it was explained in PiDome installation guide. Can anybody help?
    BTW, this is my first post on this forum so I'd like to say hi to everyone.
    • FrancoisF
      FrancoisF
      Francois
      @Arielpod what gateway are you using Serial or MQTT?
      • A
        Arielpod
        Wow, you're quick! I'm using serial gateway, haven't installed any usb drivers or plugins to PiDome.
        • JohnJ
          JohnJ
          John
          wrote on last edited by John
          #59
          It is possible that clones are not working because currently there is no web interface to ask if you are sure you want to use a specific device and how to use it. It is part of a security mechanism built in the server for this read on:
          We support a range of USB device types like USB-HID, USB-RAW and USB-[FILL_IN_EMULATOR] (Emulators like serial ports etc...). I have came across USB devices reporting multiple interface types which is very strange, so in the known peripherals database only the real thing has been flagged as a known peripheral and what it does.
          There is code present in the sever (locally on my workstation) which can identify these devices and the anomalies but is not 50% stable yet, i can include this code with the next or follow up release so also cloned devices which correctly report their USB capabilities will show up in the interface.
          Gimme a day of three for this because the web interface module for this has to be created.
          [EDIT]You do not need to install any drivers etc... because for serial based devices it already is integrated in the server[/EDIT]
          • A
            Arielpod
            Ok, thanks! I'll reinstall it in the meantime just to find out if that would help. BTW, in lsusb, the device appears as 'qinheng electronics hl-340 usb-serial adapter'.
            Patiently waiting for some news then. Cheers!
            • JohnJ
              JohnJ
              John
              Would you by accident also have the vid and pid from this device?
              • A
                Arielpod
                • A
                  Arielpod
                  wrote on last edited by Arielpod
                  #63
                  I'll check that when I get home.
                  • JohnJ
                    JohnJ
                    John
                    That would be cool, it then could be included as a default "considered good and save to use" device if it performs as it should. The interface will also be added though, but in a later stage
                    • A
                      Arielpod
                      Ok, it's 1a86:7523
                      JohnJ 1 Reply Last reply
                      • JohnJ
                        JohnJ
                        John
                        Thanks, i will add this one to the safe list (for the time being). I will notify you when it is available.
                        • A Arielpod
                          Ok, it's 1a86:7523
                          JohnJ
                          JohnJ
                          John
                          @Arielpod said:
                          Ok, it's 1a86:7523
                          I have included the mentioned device in the latest build. I do have to say that this is a quick build for testing purposes so some functionalities may be broken.
                          The build for now is only available on the build server at: http://builder.pidome.org/job/PiDome Server platform snapshot build/lastSuccessfulBuild/
                          This build does require a clean installation though, but is update safe so when newer builds are available you won't loose any data.
                          • A
                            Arielpod
                            #68
                            I'm not quite sure what you meant by "clean installation" but I just removed the directory of the previous installation and downloaded the one you've given the link to. Every time I connect the device I get an error:
                            • JohnJ
                              JohnJ
                              John
                              Resolved on the build server and available in the link posted above.
                              • A
                                Arielpod
                                Great, it's working! Thanks a lot.
                                • J
                                  J
                                  jonnyfishman
                                  Hi, looking for some advice on connecting sensor to PiDome. Think I've followed the instructions correctly but when connecting sensor under 'Devices' I get this message 'New device: Possible new address: 1 if not occupied before adding (Restart node after assigning).' and nothing to choose.
                                  My custom device settings are as follows with the Arduino CHILD_ID set to 1. Is there something obvious I've missed or is S_MOTION not included yet?
                                  Thanks, Jon
                                  • JohnJ
                                    JohnJ
                                    John
                                    @jonnyfishman
                                    If you use S_MOTION in the Arduino code then the group id should be 1 and the data control should correspond with the V_ value used in the Arduino code.
                                    With the motion detection you can use the boolean data type (the integers 1 and 0 will be correctly handled). This will make it easier in triggers and automation rules where you can select "true" or "false" from a drop down instead of filling in the 1 or 0.
                                    By clicking on the "Add sensor node" you will get a popup where you can choose the device created in the device editor.
                                    • J
                                      J
                                      jonnyfishman
                                      Thanks for the reply. I have checked the settings and changed the Group ID to 1 and the Data field ID to V_TRIPPED, using the Boolean option.
                                      The problem I have is that when I click 'Add sensor node' I get the message 'Done (no choice of device)' and nothing is added in devices and the error log shows the following:
                                      10-10-2014 21:59:53 0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=1,st=fail:1
                                      10-10-2014 21:57:50 Trying assigning address '1' to a new node
                                      Thanks, Jon
                                      • JohnJ
                                        JohnJ
                                        John
                                        Do you see the device back in the "New nodes presentation" with an address when you restart the node? this would mean that the node did not got it's address assigned. I have understood from @hek that the line:
                                        does not say if that it has failed or succeeded.
                                        The system needs a Node with an address before it can be added, the reason why there is no device selection is because of the above line can not guarantee a success or a failure. So after "Add sensor node" you have to restart the node, because only then the address is known. I should change the name of the button though to "Assign address" for making it more obvious.
                                        • J
                                          J
                                          jonnyfishman
                                          Awesome, that sorted it! Thanks. Think I was leaving to long a time (or to short) between restarting the node. Really enjoying the Server interface, the macros and automation rules are really powerful (just need to get some more nodes to really have a play).
                                          I saw on one of your posts that battery monitoring is a to do, has that happened or is it still in the pipeline. Also is there a way to trigger an email as I don't have a SMS dongle (thinking I could do it with a sensor set as RelayActuator on a GPIO pin on the pi that would trigger a PHP mail function but there's probably a more efficient way to do it).
                                          Sorry for all the questions...
