  3. conecting the radio module on a MEGA 2560 ?? !!
15 Posts 5 Posters 4.8k Views 5 Watching
  • samdelS Offline
    samdelS Offline
    samdel
    i have a problem to make a radio NRF24L01 working on a MEGA 2560 to create a sensor node
    i am using the standard mysensor connection (its working for me on a nano)
    but when i use the same connection on the mega it is not working at all
    i select the good board type before uploading .....
    serial is giving me this message :
    Starting repeater (RNNRA-, 2.0.0)
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    the radio moduleis working correctly on an other node.....
    is there anithing i dont know to use a MEGA....
    is the connection the same than on a nano
    PS sorry for my bad english
    • samdelS samdel
      TSM:INIT
      !TSM:RADIO:FAIL
      !TSM:FAILURE
      TSM:PDT
      @samdel the mega uses different pins. follow the instructions for mega linked from https://www.mysensors.org/build/connect_radio
      • E Offline
        E Offline
        executivul
        You have to use the correct pins for MISO,MOSI,SS,SCK and Pin 2 for the interrupt. You can get them here:
        https://lynx2015.files.wordpress.com/2015/08/arduino-mega-pinout-diagram.png
        You also have to modify the Arduino Mysensors in Library, inside Drivers/RFM69/RFM69.h you must specify interrupt number 4 for the mega 2560 (it's 0 for the 328).
        #if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega88) || defined(__AVR_ATmega8__) || defined(__AVR_ATmega88__)
          #define RF69_IRQ_PIN          2
          #define RF69_IRQ_NUM          0
        #elif defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284P__)
          #define RF69_IRQ_NUM          2
        #elif defined(__AVR_ATmega32U4__)
          #define RF69_IRQ_PIN          3
        #elif defined(__arm__)//Use pin 10 or any pin you want
          #define RF69_IRQ_PIN          10
          #define RF69_IRQ_NUM          10
        #define RF69_IRQ_NUM          4
        PS. I've tried using the #define MY_RF69_IRQ_NUM inside the main sketch but I couldn't get it to work.
        Y 1 Reply Last reply
        • samdelS Offline
          samdelS Offline
          samdel
          i used Mfalkvidd advices ......
          its working better but stil not recognised from the gateway
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          • E executivul
            Y Offline
            Y Offline
            @executivul The OP is using an nrf24 radio, not rfm69. Let's not give him wrong advise :wink:
            • samdelS samdel
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              @samdel great work. Could you post the log from the gateway?
              • samdelS Offline
                samdelS Offline
                samdel
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                IP: 192.168.1.19
                0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:BC
                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
                0;255;3;0;9;TSP:MSG:GWL OK
                0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
                0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
                0;255;3;0;9;TSP:MSG:READ 14-14-255 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                0;255;3;0;9;TSP:MSG:READ 0-14-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                • samdelS Offline
                  samdelS Offline
                  samdel
                  befor was the serial monitor of the gateway and below is the sketch i an using in the mega :
                  #define SN "RelayButtonArray"
                  #define SV "1.0"
                  // Pin Confuguration for Arduino Mega
                  #define MY_RF24_CE_PIN 40
                  #define MY_RF24_CS_PIN 53
                  #define RELAY_ON 0 // switch around for ACTIVE LOW / ACTIVE HIGH relay
                  #define RELAY_OFF 1
                  #define noRelays 8 //2-4
                  const int relayPin[] = {2, 4, 6, 8, 10, 12, 14, 16}; // switch around pins to your desire
                  const int buttonPin[] = {3, 5, 7, 9, 11, 13, 15, 17}; // switch around pins to your desire
                  class Relay // relay class, store all relevant data (equivalent to struct)
                  public:
                  int buttonPin; // physical pin number of button
                  int relayPin; // physical pin number of relay
                  boolean relayState; // relay status (also stored in EEPROM)
                  Relay Relays[noRelays];
                  Bounce debouncer[noRelays];
                  MyMessage msg[noRelays];
                  void before() {
                  pinMode(pin, OUTPUT);
                  wait(100);
                  for (int i = 0; i < noRelays; i++) {
                  Relays[i].buttonPin = buttonPin[i]; // assign physical pins
                  msg[i].sensor = i; // initialize messages
                  msg[i].type = V_LIGHT;
                  wait(100);
                  Relays[i].relayState = loadState(i); // retrieve last values from EEPROM
                  digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                  send(msg[i].set(Relays[i].relayState ? true : false)); // make controller aware of last status
                  wait(50);
                  debouncer[i] = Bounce(); // initialize debouncer
                  debouncer[i].interval(30);
                  wait(50);
                  sendSketchInfo(SN, SV);
                  wait(100);
                  present(i, S_LIGHT); // present sensor to gateway
                  wait(100);
                  for (byte i = 0; i < noRelays; i++) {
                  if (debouncer[i].update()) {
                    if ( value == LOW) {
                      // save sensor state in EEPROM (location == sensor number)
                      saveState( i, Relays[i].relayState );
                  //wait(20);
                  if (message.sensor < noRelays) { // check if message is valid for relays..... previous line [[[ if (message.sensor <=noRelays){ ]]]
                  digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                  saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                  wait(20);
                  • samdelS samdel
                    #define SV "1.0"
                    #define RELAY_OFF 1
                    public:
                    void before() {
                    wait(100);
                    wait(100);
                    wait(50);
                    wait(50);
                    wait(100);
                    wait(100);
                    //wait(20);
                    wait(20);
                    @samdel the gateway receives the request for parens and replies, but the sensor does not "hear" the reply.
                    See https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help for information on how to troubleshoot range and power issues.
                    • samdelS Offline
                      samdelS Offline
                      samdel
                      i double (triple) checked connections all ok
                      i checkes power suplies ; all ok
                      i have condansators installed on each nrf24
                      and i am testing it on my desk so no long distance to travel...
                      i tried to assigne a node id ;
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:OK (ID=44)
                      TSM:FPAR
                      TSP:MSG:SEND 44-44-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      gateway ;
                      IP: 192.168.1.19
                      0;255;3;0;9;TSP:MSG:READ 44-44-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=44)
                      0;255;3;0;9;!TSP:MSG:SEND 0-0-44-44 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                      0;255;3;0;9;TSP:MSG:READ 61-61-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
                      0;255;3;0;9;TSP:MSG:READ 61-61-0 s=0,c=1,t=1,pt=7,l=5,sg=0:33.3
                      • samdelS samdel
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        gateway ;
                        IP: 192.168.1.19
                        @samdel does it start working if you move the sensor and the gateway further apart? There have been several cases where people have had trouble when the nodes are too close.
                        • hekH Offline
                          hekH Offline
                          The 3v3 line on mega was super noisy when I used it. I had to put a step down from the 5V rail.
                          • samdelS Offline
                            samdelS Offline
                            samdel
                            2 metres away stillthe same result
                            i also tried to load an other sketch asthe one i was using was tuned by me....
                            still the same
                            i finaly tried using an other arduinoboard (original one) and it is working good......
                            the one who was not working correctly was this one ;
                            https://www.amazon.fr/gp/product/B00OPO44UE/ref=ox_sc_act_title_32?ie=UTF8&psc=1&smid=A21548PJTFXT87
                            di i have to put it to trash or is there a way to test it or to make it working ???
                            • samdelS Offline
                              samdelS Offline
                              samdel
                              hi Hek
                              how do you measur the noisyness?? with a fluck in AC ?? what are the limits .?
                              • hekH Offline
                                hekH Offline
                                Empirically, I just couldn't get it working.
