  3. conecting the radio module on a MEGA 2560 ?? !!
15 Posts 5 Posters 4.9k Views 5 Watching
  • E executivul
    You have to use the correct pins for MISO,MOSI,SS,SCK and Pin 2 for the interrupt. You can get them here:
    https://lynx2015.files.wordpress.com/2015/08/arduino-mega-pinout-diagram.png
    You also have to modify the Arduino Mysensors in Library, inside Drivers/RFM69/RFM69.h you must specify interrupt number 4 for the mega 2560 (it's 0 for the 328).
    #if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega88) || defined(__AVR_ATmega8__) || defined(__AVR_ATmega88__)
      #define RF69_IRQ_PIN          2
      #define RF69_IRQ_NUM          0
    #elif defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284P__)
      #define RF69_IRQ_NUM          2
    #elif defined(__AVR_ATmega32U4__)
      #define RF69_IRQ_PIN          3
    #elif defined(__arm__)//Use pin 10 or any pin you want
      #define RF69_IRQ_PIN          10
      #define RF69_IRQ_NUM          10
    #define RF69_IRQ_NUM          4
    PS. I've tried using the #define MY_RF69_IRQ_NUM inside the main sketch but I couldn't get it to work.
    @executivul The OP is using an nrf24 radio, not rfm69. Let's not give him wrong advise :wink:
    • samdelS samdel
      i used Mfalkvidd advices ......
      its working better but stil not recognised from the gateway
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      @samdel great work. Could you post the log from the gateway?
      • samdelS
        samdelS
        samdel
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:RADIO:OK
        0;255;3;0;9;TSM:GW MODE
        0;255;3;0;9;TSM:READY
        IP: 192.168.1.19
        0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSP:MSG:BC
        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
        0;255;3;0;9;TSP:MSG:GWL OK
        0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
        0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
        0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
        0;255;3;0;9;TSP:MSG:READ 14-14-255 s=255,c=3,t=8,pt=1,l=1,sg=0:1
        0;255;3;0;9;TSP:MSG:READ 0-14-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        • samdelS
          samdelS
          samdel
          befor was the serial monitor of the gateway and below is the sketch i an using in the mega :
          #define SN "RelayButtonArray"
          #define SV "1.0"
          // Pin Confuguration for Arduino Mega
          #define MY_RF24_CE_PIN 40
          #define MY_RF24_CS_PIN 53
          #define RELAY_ON 0 // switch around for ACTIVE LOW / ACTIVE HIGH relay
          #define RELAY_OFF 1
          #define noRelays 8 //2-4
          const int relayPin[] = {2, 4, 6, 8, 10, 12, 14, 16}; // switch around pins to your desire
          const int buttonPin[] = {3, 5, 7, 9, 11, 13, 15, 17}; // switch around pins to your desire
          class Relay // relay class, store all relevant data (equivalent to struct)
          public:
          int buttonPin; // physical pin number of button
          int relayPin; // physical pin number of relay
          boolean relayState; // relay status (also stored in EEPROM)
          Relay Relays[noRelays];
          Bounce debouncer[noRelays];
          MyMessage msg[noRelays];
          void before() {
          pinMode(pin, OUTPUT);
          wait(100);
          for (int i = 0; i < noRelays; i++) {
          Relays[i].buttonPin = buttonPin[i]; // assign physical pins
          msg[i].sensor = i; // initialize messages
          msg[i].type = V_LIGHT;
          wait(100);
          Relays[i].relayState = loadState(i); // retrieve last values from EEPROM
          digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          send(msg[i].set(Relays[i].relayState ? true : false)); // make controller aware of last status
          wait(50);
          debouncer[i] = Bounce(); // initialize debouncer
          debouncer[i].interval(30);
          wait(50);
          sendSketchInfo(SN, SV);
          wait(100);
          present(i, S_LIGHT); // present sensor to gateway
          wait(100);
          for (byte i = 0; i < noRelays; i++) {
          if (debouncer[i].update()) {
            if ( value == LOW) {
              // save sensor state in EEPROM (location == sensor number)
              saveState( i, Relays[i].relayState );
          //wait(20);
          if (message.sensor < noRelays) { // check if message is valid for relays..... previous line [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
          wait(20);
          • samdelS samdel
            #define SV "1.0"
            #define RELAY_OFF 1
            public:
            void before() {
            wait(100);
            wait(100);
            wait(50);
            wait(50);
            wait(100);
            wait(100);
            //wait(20);
            wait(20);
            @samdel the gateway receives the request for parens and replies, but the sensor does not "hear" the reply.
            See https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help for information on how to troubleshoot range and power issues.
            • samdelS
              samdelS
              samdel
              i double (triple) checked connections all ok
              i checkes power suplies ; all ok
              i have condansators installed on each nrf24
              and i am testing it on my desk so no long distance to travel...
              i tried to assigne a node id ;
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=44)
              TSM:FPAR
              TSP:MSG:SEND 44-44-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              gateway ;
              IP: 192.168.1.19
              0;255;3;0;9;TSP:MSG:READ 44-44-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
              0;255;3;0;9;TSP:MSG:FPAR REQ (sender=44)
              0;255;3;0;9;!TSP:MSG:SEND 0-0-44-44 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
              0;255;3;0;9;TSP:MSG:READ 61-61-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
              0;255;3;0;9;TSP:MSG:READ 61-61-0 s=0,c=1,t=1,pt=7,l=5,sg=0:33.3
              • samdelS samdel
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                gateway ;
                IP: 192.168.1.19
                @samdel does it start working if you move the sensor and the gateway further apart? There have been several cases where people have had trouble when the nodes are too close.
                  The 3v3 line on mega was super noisy when I used it. I had to put a step down from the 5V rail.
                  • samdelS
                    samdelS
                    samdel
                    2 metres away stillthe same result
                    i also tried to load an other sketch asthe one i was using was tuned by me....
                    still the same
                    i finaly tried using an other arduinoboard (original one) and it is working good......
                    the one who was not working correctly was this one ;
                    https://www.amazon.fr/gp/product/B00OPO44UE/ref=ox_sc_act_title_32?ie=UTF8&psc=1&smid=A21548PJTFXT87
                    di i have to put it to trash or is there a way to test it or to make it working ???
                    • samdelS
                      samdelS
                      samdel
                      hi Hek
                      how do you measur the noisyness?? with a fluck in AC ?? what are the limits .?
                        Empirically, I just couldn't get it working.
