  3. Invert the relay in the sketch
18 Posts 3 Posters 5.0k Views 2 Watching
  • derksuhD
    derksuhD
    derksuh
    Hello all,
    I used the sketch below to control a fan and to read the humidity and temperature from a sensor.
    Now when i start up the sensor in Pimatic it says it is off, but the relay is activated. Can i somehow invert it?
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 1
    #define DHT_DATA_PIN 6
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_RLAY 2
    #define RELAY_PIN  3
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    bool state = false;
    bool initialValueSent = false;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    MyMessage msgRlay(CHILD_ID_RLAY, V_STATUS);
    DHT dht;
      sendSketchInfo("TempHumidRelay", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_RLAY, S_BINARY);
      //sleep(dht.getMinimumSamplingPeriod());
      pinMode(RELAY_PIN, OUTPUT);
        if (!initialValueSent) {
        Serial.println("Sending initial value");
        send(msgRlay.set(state?RELAY_ON:RELAY_OFF),2);
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID_RLAY, V_STATUS);
        wait(2000, C_SET, V_STATUS);
      if (debouncer.update()) {
        if (debouncer.read()==LOW) {
          state = !state;
          // Send new state and request ack back
          send(msgRlay.set(state?RELAY_ON:RELAY_OFF), true);
      dht.readSensor(true);
      if (isnan(temperature)) {
      else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
        lastTemp = temperature;
        if (!metric) {
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        // Reset no updates counter
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
     wait(2000);
      if (message.isAck()) {
          Serial.println("Receiving initial value from controller");
          initialValueSent = true;
        // Change relay state
        state = (bool)message.getInt();
        send(msgRlay.set(state?RELAY_ON:RELAY_OFF,2));
    mfalkviddM blaceyB 2 Replies Last reply
    • derksuhD derksuh
      Hello all,
      #define RELAY_PIN  3
      #define RELAY_ON 1
      #define RELAY_OFF 0
      bool state = false;
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
            state = !state;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
       wait(2000);
      @derksuh yes. Switch these two:
      #define RELAY_ON 1
      #define RELAY_OFF 0
      • derksuhD
        derksuhD
        derksuh
        @mfalkvidd is it nescessary to clear the eeprom before uploading the changef sketch?
        • derksuhD derksuh
          @derksuh no, no need to clear the eeprom
          • derksuhD derksuh
            Hello all,
            #define RELAY_PIN  3
            #define RELAY_ON 1
            #define RELAY_OFF 0
            bool state = false;
            float lastTemp;
            float lastHum;
            bool metric = true;
            DHT dht;
                  state = !state;
                if (!metric) {
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                nNoUpdatesTemp++;
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                nNoUpdatesHum++;
             wait(2000);
            blaceyB
            blaceyB
            blacey
            wrote on last edited by blacey
            @derksuh I see a couple of potential problems:
            1. In setup(), you are attempt to turn the relay off before setting the pin mode. You need to reverse the following two lines.
            1. What are you debouncing()? You never attach debouncer to a pin to read (e.g. debouncer.attach())?
            2. I actually see a number of other issues but it would be better to understand your use case/requirements. Can you describe what you want to happen when you first power up the node and, while the node is in steady state, and any interactions/control with the relay on the node. For example (hypothetical).
            Startup:
            1. Set relay status to last known gateway state (on/off)
            2. Send current temperature and humidity to gateway
            Steady state:
            1. Send temperature and humidity to gateway ever xx seconds/minutes
            2. Allow gateway to turn fan on/off (e.g. scene to turn on fan when humidity is high, off when low, manual user control, etc.)
            I saw potential requirements conflicts hence my question regarding your view of the requirements/envisioned behavior.
            • derksuhD
              derksuhD
              derksuh
              @blacey
              I reversed the lines and changed the values of relay off and relay on but that did not do the trick.
              This sketch i copied from a other project so i don't really know why debouncing is implemented.
              The example you scribed is exactly how it should work.
              blaceyB 1 Reply Last reply
              • derksuhD derksuh
                @blacey
                blaceyB
                blaceyB
                blacey
                @derksuh Ok, I took a shot at refactoring your sketch. I didn't have much time and I only ensured that it compiles so your MMV... This could probably be simplified even more but you know the old saying, "If I had more time, I would write less code" ;)
                #define RELAY_PIN  3
                #define RELAY_ON 1
                #define RELAY_OFF 0
                #define TEMP 0
                #define HUMI 1
                byte state = 0;
                bool metric = true;
                typedef struct {
                  float last;
                  uint8_t nNoUpdates;
                } sensorState_t;
                sensorState_t dhtState[2];
                DHT dht;
                  // Ask the gateway for the units of measure to use
                  // Initialize the Temperature & Humidity sensor, first reading will be sent from loop()
                  if (UPDATE_INTERVAL >= dht.getMinimumSamplingPeriod()) {
                    dht.setup(DHT_DATA_PIN); // set data pin of DHT sensor and model (e.g. DHT_22, DHT_11)
                    Serial.println("Increase UPDATE_INTERVAL and re-upload sketch...");
                  // Request the latest relay status from the gateway
                  // Sleep until next valid interal to read temperature and humidity
                  wait(UPDATE_INTERVAL);
                  // Read current temperature & humidity from DHT22
                  // Only send temperature if it has changed since the last measurement or if we didn't send an update for n times
                  if (temperature != dhtState[TEMP].last || dhtState[TEMP].nNoUpdates >= FORCE_UPDATE_N_READS) {
                    dhtState[TEMP].last = temperature;
                    temperature = metric ? temperature : dht.toFahrenheit(temperature);
                    #ifdef MY_DEBUG
                    dhtState[TEMP].nNoUpdates = 0;
                  else if (isnan(temperature)) {
                    dhtState[TEMP].nNoUpdates++;
                  // Retrieve the current humidity
                  if (humidity != dhtState[HUMI].last || dhtState[HUMI].nNoUpdates >= FORCE_UPDATE_N_READS) {
                    dhtState[HUMI].last = humidity;
                    #ifdef MY_DEBUG
                    dhtState[HUMI].nNoUpdates = 0;
                  } else if (isnan(humidity)) {
                    dhtState[HUMI].nNoUpdates++;
                  Serial.println("Received message...");
                    state = message.getByte();
                    digitalWrite(RELAY_PIN, state);
                    send(msgRlay.set(state));
                • derksuhD
                  derksuhD
                  derksuh
                  @blacey
                  The sketch works, but i still need the relay output inverted.
                  Changing the values from relay_on and relay_off does not do the trick
                  • derksuhD derksuh
                    @blacey
                    blaceyB
                    blaceyB
                    blacey
                    @derksuh Is the relay working the way you want it to and you just want to invert the display in PiMatic? If so, you can do the following in the receive() method:
                        send( msgRlay.set(state == 0 ? 1 : 0) );
                    • derksuhD
                      derksuhD
                      derksuh
                      @blacey
                      The node is working. The problem
                      Is that when it is connected to the gateway then the relay gets turned on but The status in pimatic does say it is turned off.
                      • derksuhD
                        derksuhD
                        derksuh
                        @blacey where should i put the code in your post?
                        • derksuhD derksuh
                          blaceyB
                          blaceyB
                          blacey
                          As I said in my last post, you can put it in the receive() method of your node sketch. Basically, this will invert the relay state sent to PiMac only...
                          • derksuhD
                            derksuhD
                            derksuh
                            @blacey
                            I did not get it working the way i would like. I now used a different sketch.
                            here i had the same problem but i just set the relay_OFF from 0 to 1, and the Relay_ON from 1 to 0
                            And with this sketch it worked fine.
                            // Enable debug prints
                            #define CHILD_ID_HUM 1
                            #define CHILD_ID_TEMP 2
                            #define HUMIDITY_SENSOR_DIGITAL_PIN 6
                            unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                            boolean metric = true;
                                pinMode(pin, OUTPUT);
                              sendSketchInfo("Badkamer", "1.3");
                                present(sensor, S_LIGHT);
                              boolean needRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
                              if (needRefresh)
                                  lastRefreshTime = millis();
                                    if (!metric) {
                                      lastHum = humidity;
                              if (message.type==V_LIGHT) {
                                 // Store state in eeprom
                            • derksuhD derksuh
                              @blacey
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                                if (needRefresh)
                                      if (!metric) {
                                        lastHum = humidity;
                              blaceyB
                              blaceyB
                              blacey
                              Your new sketch looks much better, glad you figured it out! :+1: You might want to remove the saveState() from your receive() method because the "saved -state" is not being used and this will prevent unnecessary writes to EEPROM which has a limited lifespan. Also, you might want to request the relay status from the gateway in setup() so the node will set the relay status to that of they gateway (i.e. the response to a request() sent in setup() will be handled by your existing receive() method).
                              • derksuhD
                                derksuhD
                                derksuh
                                @blacey You mean like this?
                                 * Version 1.0 - Henrik EKblad
                                 * This sketch provides an example how to implement a humidity/temperature
                                 * sensor using DHT11/DHT-22
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                  request(RELAY_1, V_STATUS);
                                  if (needRefresh)
                                        if (!metric) {
                                          lastHum = humidity;
                                • derksuhD derksuh
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                    if (needRefresh)
                                          if (!metric) {
                                            lastHum = humidity;
                                  blaceyB
                                  blaceyB
                                  blacey
                                  @derksuh Exactly - good job! So, is it working as expected? For example, if you turn the relay on and then reboot the node, does the node come up, ask for the relay status, receive relay on and then try to turn the relay on? You should be able to see this in the messaging sequence on the node.
                                  • derksuhD
                                    derksuhD
                                    derksuh
                                    No it doesn't do that. If i switch on the relay in pimatic then it goes on.
                                    if i then rebot the node the relay stays off but the status in pimatic also changes to off.
                                    • derksuhD derksuh
                                      blaceyB
                                      blaceyB
                                      blacey
                                      @derksuh Sorry to hear but your sketch looks good. Are you using the MySensors development branch? If not, doing so will probably fix the behavior because there was a bug in the 2.0 release that prevented messages from being sent (i.e. the request()) in the setup() method of a sketch.
                                      Once you upgrade to the MySensors development branch, if it still doesn't behave properly, please post the messages logged by the node, with #MY_DEBUG enabled.
