  3. MH-Z14A CO2 sensor
MH-Z14A CO2 sensor
25 Posts 5 Posters 19.3k Views 6 Watching
  • inky14I Offline
    inky14I Offline
    inky14
    wrote on last edited by inky14
    Re: MH-Z14A CO2 sensor
    I need to use this sensor but there is very little documentation on the flying lead header pitch. i need to use a connector that will securely fit the flying wire off of the sensor board to my PCB. but i don't know the pitch it is using, from pictures it looks like either the 1.27mm pitch or 1.5mm pitch. Can someone who has this sensor please help me?
    I would also be very interested in what each colour of the flying wire corresponds to which signal.
    cheers,
    • mfalkviddM Offline
      Let's bring this thread to @alexsh1's attention
      • inky14I Offline
        inky14I Offline
        inky14
        This has all the information i need:
        1.25mm pitch (i'm assuming for 7pins it should be interchangeable with a 1.27mm pitch)
        also from left to right: PWM, Tx, Rx, VCC, GND, AOUT, HD
        https://web.opendrive.com/api/v1/download/file.json/NDVfMzUyMzMyM18?inline=0
        • alexsh1A Offline
          alexsh1A Offline
          alexsh1
          I am glad you work it out yourself
          I think when it comes to this sensor everything is well documented or available in the Internet
          • F Offline
            F Offline
            FotoFieber
            wrote on last edited by FotoFieber
            The sensor is really simple to use, when attached via serial-ttl (3.3V) and powered with 5 volt.
            https://www.youtube.com/watch?v=Vk4oQpy98sc
            You get the values directly from the sensor and don't need to make calculations. Here is what I use:
               DESCRIPTION
                MH-Z14 CO2 sensor via rx/tx serial
            //#define MY_RADIO_NRF24
            #define MY_RADIO_RFM69
            #define MY_RFM69_FREQUENCY RF69_868MHZ
            #define MY_RFM69_NETWORKID 13
            #define MY_RFM69_ENABLE_ENCRYPTION
            #define MY_IS_RFM69HW
            #include <SoftwareSerial.h>
            #include "Adafruit_HTU21DF.h"
            SoftwareSerial mySerial(A0, A1); // RX, TX соответственно
            Adafruit_HTU21DF htu = Adafruit_HTU21DF();
            byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
            char response[9];
            #define CHILD_ID_AIQ 0
            #define CHILD_ID_TEMP  1
            #define CHILD_ID_HUM   2
            unsigned long SLEEP_TIME = 30 * 1000; // Sleep time between reads (in milliseconds)
            unsigned int TEMP_HUM_ROUNDS = 5; // wait 5 rounds for sending TEMP_HUM
            unsigned int loop_round = 0;
            boolean preheat = true;  // wait TEMP_HUM_ROUNDS for preheat
            int lastppm = 0;
            MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
            MyMessage msg2(CHILD_ID_AIQ, V_UNIT_PREFIX);
            boolean isMetric = true;
              mySerial.begin(9600);
              isMetric = getConfig().isMetric;
              if (!htu.begin()) {
                Serial.println("Couldn't find sensor htu21!");
              sendSketchInfo("AIQ Sensor CO2 MH-Z14 Serial, HTU21 Temp Hum", "1.0");
              present(CHILD_ID_AIQ, S_AIR_QUALITY);
              send(msg2.set("ppm"));
              present(CHILD_ID_HUM, S_HUM);
              mySerial.write(cmd, 9);
              mySerial.readBytes(response, 9);
              int responseHigh = (int) response[2];
              int responseLow = (int) response[3];
              int ppm = (256 * responseHigh) + responseLow;
              if ((loop_round == 0) || (abs(ppm - lastppm) >= 10)) {
                if (!preheat) {
                  send(msg.set(ppm));
                  lastppm = ppm;
              if (loop_round == 0) {
                float temp = htu.readTemperature();
                if (!isMetric) {
                  temp = temp * 9 / 5 + 32; // convert to farenheit
                send(msgTemp.set(temp, 1));
                float hum = htu.readHumidity();
                send(msgHum.set(hum, 1));
              loop_round++;
              if (loop_round >= TEMP_HUM_ROUNDS) {
                loop_round = 0;
                preheat = false;
              // Power down the radio.  Note that the radio will get powered back up
              // on the next write() call.
              sleep(SLEEP_TIME); //sleep for: sleepTime
            • K Offline
              K Offline
              korttoma
              Thanks @FotoFieber for providing the information how to read the MH-Z14 via serial communication.
              Works like a charm.
              • Tomas
              • K Offline
                K Offline
                korttoma
                Seems like my MH-Z14 sensor is faulty after all. My problem was that the sensor reported the value 562 like 80% of the time. I was hoping I could solve this by using the serial method to read the value from the sensor but I stil had the same problem. Luckily I just received another MH-Z14 so I could replace it. Now it seems to work better.
                • Tomas
                F 1 Reply Last reply
                • K korttoma
                  F Offline
                  F Offline
                  FotoFieber
                  @korttoma
                  It is working like a charme for me. Important is, to have 5V for voltage and 3.3 V on the logical level. Here is a graf, the green "Badezimmer" line is the mysensors sensor with MH-Z14A, the others are from netatmo. The mysensors sensor is in the bathroom and therefore it will have usually less CO2.
                  K 1 Reply Last reply
                  • F FotoFieber
                    @korttoma
                    K Offline
                    K Offline
                    korttoma
                    @FotoFieber My new sensor is giving me the exact same behaivour. Could it be that the problem is that I'm using a 5V Pro Mini?
                    • Tomas
                    • F Offline
                      F Offline
                      FotoFieber
                      Yes. You have to use a 3.3V arduino and power the sensor with 5V (seperate voltage). The sensor may break with a 5V arduino. I use a 3.3V 8 MHz pro mini.
                      • F FotoFieber
                        K Offline
                        K Offline
                        korttoma
                        @FotoFieber
                        So the symptom I see as the sensor constantly reporting the value 562 could be because it is already broken?
                        Or would a broken sensor just stop communicating via serial?
                        • Tomas
                        • K korttoma
                          @FotoFieber
                          F Offline
                          F Offline
                          FotoFieber
                          @korttoma
                          As I do not have a broken sensor, I can not tell you.
                          If I were you, I would try to fix the voltage issues and check, if it is working then.
                          The sensor requires a preheat. Have you used my sketch from above?
                          • F FotoFieber
                            @korttoma
                            K Offline
                            K Offline
                            korttoma
                            @FotoFieber I swapped out the 5V Pro Mini with a 3.3V Pro Mini yesterday and I'm afraid it did not help at all. If the Sensor would have had a problem with the 5V on the serial pins I bet it would no longer communicate.
                            I used some parts of your sketch but since I use an Si7021 and a different radio I had to do some modifications:
                             *  MH-Z14 CO2 sensor
                             *  Wiring:
                             *   Pad 1, Pad 5: Vin (Voltage input 4.5V-6V)
                             *   Pad 2, Pad 3, Pad 12: GND
                             *   Pad 6: PWM output ==> pin 6
                             *  From: http://davidegironi.blogspot.fr/2014/01/co2-meter-using-ndir-infrared-mh-z14.html
                             *    MH-Z14 has a PWM output, with a sensitivity range of 0ppm to 2000ppm CO2, an accurancy of ±200ppm.
                             *    The cycle is 1004ms±5%, given the duty cicle Th (pulse high), Tl is 1004-Th, we can convert it to CO2 value using the formula:
                             *    CO2ppm = 2000 * (Th - 2ms) /(Th + Tl - 4ms)
                             *  From: http://airqualityegg.wikispaces.com/Sensor+Tests
                             *    - response time is less than 30 s
                             *   - 3 minute warm up time
                             *  datasheet:
                            * Contributor: epierre
                            #define MY_NODE_ID  6
                            #define SN "AIQ CO2 MH-Z14 TxRx"
                            #define SV "2.1"
                            #define MY_BAUD_RATE  9600
                            #include <MyConfig.h>
                            #include <SI7021.h>
                            #include <RunningAverage.h>
                            // Define a static node address, remove if you want auto address assignment
                            SoftwareSerial mySerial(6, 7); // RX, TX
                            char response[9];
                            // Child sensor ID's
                            #define CHILD_ID_AIQ 1
                            #define CHILD_ID_TEMP  3
                            //#define AIQ_SENSOR_ANALOG_PIN 5
                            #define AVERAGES 2
                            float valAIQ =0.0;
                            float lastAIQ =0.0;
                            int lastppm = 0;
                            SI7021 humiditySensor;
                            // Global settings
                            float lastTemperature = -100;
                            int lastHumidity = -100;
                              humiditySensor.begin();
                              sleep(SLEEP_TIME);
                              //pinMode(AIQ_SENSOR_ANALOG_PIN, INPUT);
                              Serial.print(F("isMetric: ")); Serial.println(isMetric);
                              raHum.clear();
                                 wait(200);
                              sendSketchInfo(SN, SV);
                              present(CHILD_ID_TEMP,S_TEMP);
                              present(CHILD_ID_HUM,S_HUM);
                              wait(200);
                              int co2ppm = (256 * responseHigh) + responseLow;
                              Serial.print(F("c02ppm :"));Serial.println(co2ppm);
                              if ( (abs(co2ppm - lastppm) >= 10)) {
                                  send(msg.set(co2ppm));
                                  lastppm = co2ppm;
                              raHum.addValue(data.humidityPercent);
                              float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                              Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                              Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                              if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
                                float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                                Serial.print("T: ");Serial.println(temperature);
                                send(msgTemp.set(temperature,1));
                              if (diffHum > HUMI_TRANSMIT_THRESHOLD) {
                                Serial.print("H: ");Serial.println(humidity);
                                send(msgHum.set(humidity));
                                lastHumidity = humidity;
                              //Serial.println();
                            I hope I made a mistake in the sketch since I'm running out of ideas and I don't want the sensors to be broken.
                            From where did you buy your sensor? I got them from aliexpress...
                            • Tomas
                            • F Offline
                              F Offline
                              FotoFieber
                              @korttoma
                              Where is the preheat logic in your sketch?
                              Values in the preheat time could be wrong....
                              • F FotoFieber
                                @korttoma
                                K Offline
                                K Offline
                                korttoma
                                @FotoFieber Yeah, I don't have preheat logic but that would only account for values when I first plug it in. I get the strange values even if it has been running for weeks. I will try to get a graph of what I see this evening so you can see what I mean. I'm seriously considering to just exclude the value 562 from being sent to the controller.
                                • Tomas
                                alexsh1A 1 Reply Last reply
                                • K korttoma
                                  alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  @korttoma Sounds like you have a faulty sensor. Did you try analogue output? This is just to make sure the sensor is working.
                                  There are PWM or UART.
                                  Did you try both of them? I am using 5V Arduino Nano with no problem.
                                  The digital pins communicate via PWM or UART. Output (and input for UART) of these ports work on 3.3 Volts - this means you should change the ARef of your Arduino - or rescale your values
                                  • K Offline
                                    K Offline
                                    korttoma
                                    • Tomas
                                    • alexsh1A Offline
                                      alexsh1A Offline
                                      alexsh1
                                      @korttoma try to put it outside for some time to recalibrate. If it does not help, you may need to calibrate it.
                                      Or you just got a bad one.
                                      • alexsh1A alexsh1
                                        K Offline
                                        K Offline
                                        korttoma
                                        @alexsh1 Will the sensor really recalibrate by itself if I put it outside?
                                        I could send a "zero calibration" command via serial but then I would need to "input Nitrogen gas for 5 minutes when make zero calibration. "
                                        Instead of exposing it to nitrogen gas could I just like you said put it outside and then send the "zero calibration" command?
                                        To do the " span calibration" I would need to know what kind of values to send to it and I have no idea.
                                        btw, here are some values I read now via serial at the office (I do not get the 562 value so far) but does these values seem reasonable for a well ventilated office?
                                        HiResp :3
                                        LoResp :-21
                                        Tem.channel :63
                                        c02ppm :747
                                        HiResp :3
                                        LoResp :124
                                        Tem.channel :63
                                        c02ppm :892
                                        HiResp :3
                                        LoResp :21
                                        Tem.channel :63
                                        c02ppm :789
                                        HiResp :2
                                        LoResp :-57
                                        Tem.channel :63
                                        c02ppm :455
                                        HiResp :2
                                        LoResp :-110
                                        Tem.channel :63
                                        c02ppm :402
                                        HiResp :2
                                        LoResp :99
                                        Tem.channel :63
                                        c02ppm :611
                                        HiResp :2
                                        LoResp :51
                                        Tem.channel :63
                                        c02ppm :563
                                        HiResp :2
                                        LoResp :20
                                        Tem.channel :63
                                        c02ppm :532
                                        HiResp :1
                                        LoResp :-2
                                        Tem.channel :63
                                        c02ppm :254
                                        HiResp :1
                                        LoResp :-32
                                        Tem.channel :63
                                        c02ppm :224
                                        HiResp :1
                                        LoResp :-55
                                        Tem.channel :63
                                        c02ppm :201
                                        HiResp :1
                                        LoResp :-68
                                        Tem.channel :63
                                        c02ppm :188
                                        HiResp :1
                                        LoResp :-75
                                        Tem.channel :63
                                        c02ppm :181
                                        HiResp :1
                                        LoResp :-79
                                        Tem.channel :63
                                        c02ppm :177
                                        HiResp :1
                                        LoResp :-98
                                        Tem.channel :63
                                        c02ppm :158
                                        HiResp :1
                                        LoResp :-102
                                        Tem.channel :63
                                        c02ppm :154
                                        HiResp :1
                                        LoResp :-109
                                        Tem.channel :63
                                        c02ppm :147
                                        HiResp :1
                                        LoResp :-116
                                        Tem.channel :63
                                        c02ppm :140
                                        HiResp :1
                                        LoResp :-125
                                        Tem.channel :63
                                        c02ppm :131
                                        HiResp :1
                                        LoResp :-124
                                        Tem.channel :63
                                        c02ppm :132
                                        HiResp :1
                                        LoResp :111
                                        Tem.channel :63
                                        c02ppm :367
                                        HiResp :1
                                        LoResp :115
                                        Tem.channel :63
                                        c02ppm :371
                                        HiResp :1
                                        LoResp :121
                                        Tem.channel :63
                                        c02ppm :377
                                        HiResp :1
                                        LoResp :114
                                        Tem.channel :63
                                        c02ppm :370
                                        HiResp :1
                                        LoResp :-62
                                        Tem.channel :63
                                        c02ppm :194
                                        HiResp :1
                                        LoResp :-7
                                        Tem.channel :63
                                        c02ppm :249
                                        HiResp :1
                                        LoResp :-53
                                        Tem.channel :63
                                        c02ppm :203
                                        HiResp :1
                                        LoResp :-68
                                        Tem.channel :63
                                        c02ppm :188
                                        HiResp :1
                                        LoResp :-96
                                        Tem.channel :63
                                        c02ppm :160
                                        HiResp :1
                                        LoResp :-111
                                        Tem.channel :63
                                        c02ppm :145
                                        HiResp :1
                                        LoResp :-121
                                        Tem.channel :63
                                        c02ppm :135
                                        HiResp :1
                                        LoResp :-127
                                        Tem.channel :63
                                        c02ppm :129
                                        HiResp :1
                                        LoResp :-124
                                        Tem.channel :63
                                        c02ppm :132
                                        HiResp :1
                                        LoResp :-126
                                        Tem.channel :63
                                        c02ppm :130
                                        HiResp :1
                                        LoResp :-126
                                        Tem.channel :63
                                        c02ppm :130
                                        HiResp :1
                                        LoResp :-110
                                        Tem.channel :63
                                        c02ppm :146
                                        HiResp :1
                                        LoResp :-110
                                        Tem.channel :63
                                        c02ppm :146
                                        HiResp :1
                                        LoResp :-60
                                        Tem.channel :63
                                        c02ppm :196
                                        HiResp :1
                                        LoResp :-69
                                        Tem.channel :63
                                        c02ppm :187
                                        HiResp :1
                                        LoResp :-101
                                        Tem.channel :63
                                        c02ppm :155
                                        HiResp :1
                                        LoResp :-104
                                        Tem.channel :63
                                        c02ppm :152
                                        HiResp :1
                                        LoResp :-114
                                        Tem.channel :63
                                        c02ppm :142
                                        HiResp :1
                                        LoResp :-128
                                        Tem.channel :63
                                        c02ppm :128
                                        HiResp :1
                                        LoResp :-122
                                        Tem.channel :63
                                        c02ppm :134
                                        HiResp :1
                                        LoResp :122
                                        Tem.channel :63
                                        c02ppm :378
                                        HiResp :1
                                        LoResp :119
                                        Tem.channel :63
                                        c02ppm :375
                                        HiResp :1
                                        LoResp :-128
                                        Tem.channel :63
                                        c02ppm :128
                                        HiResp :1
                                        LoResp :-86
                                        Tem.channel :63
                                        c02ppm :170
                                        HiResp :1
                                        LoResp :-110
                                        Tem.channel :63
                                        c02ppm :146
                                        HiResp :1
                                        LoResp :-123
                                        Tem.channel :63
                                        c02ppm :133
                                        HiResp :1
                                        LoResp :-101
                                        Tem.channel :63
                                        c02ppm :155
                                        HiResp :1
                                        LoResp :-75
                                        Tem.channel :63
                                        c02ppm :181
                                        HiResp :1
                                        LoResp :-92
                                        Tem.channel :63
                                        c02ppm :164
                                        HiResp :1
                                        LoResp :-101
                                        Tem.channel :63
                                        c02ppm :155
                                        HiResp :1
                                        LoResp :-123
                                        Tem.channel :63
                                        c02ppm :133
                                        HiResp :1
                                        LoResp :-114
                                        Tem.channel :63
                                        c02ppm :142
                                        HiResp :1
                                        LoResp :-127
                                        Tem.channel :63
                                        c02ppm :129
                                        HiResp :1
                                        LoResp :-120
                                        Tem.channel :63
                                        c02ppm :136
                                        HiResp :1
                                        LoResp :126
                                        Tem.channel :63
                                        c02ppm :382
                                        HiResp :1
                                        LoResp :118
                                        Tem.channel :63
                                        c02ppm :374
                                        HiResp :1
                                        LoResp :-127
                                        Tem.channel :63
                                        c02ppm :129
                                        HiResp :1
                                        LoResp :118
                                        Tem.channel :63
                                        c02ppm :374
                                        HiResp :1
                                        LoResp :120
                                        Tem.channel :63
                                        c02ppm :376
                                        HiResp :1
                                        LoResp :118
                                        Tem.channel :63
                                        c02ppm :374
                                        HiResp :1
                                        LoResp :115
                                        Tem.channel :63
                                        c02ppm :371
                                        HiResp :1
                                        LoResp :124
                                        Tem.channel :63
                                        c02ppm :380
                                        HiResp :1
                                        LoResp :120
                                        Tem.channel :63
                                        c02ppm :376
                                        HiResp :1
                                        LoResp :-119
                                        Tem.channel :63
                                        c02ppm :137
                                        HiResp :1
                                        LoResp :-126
                                        Tem.channel :63
                                        c02ppm :130
                                        HiResp :1
                                        LoResp :-127
                                        Tem.channel :63
                                        c02ppm :129
                                        HiResp :1
                                        LoResp :-124
                                        Tem.channel :63
                                        c02ppm :132
                                        HiResp :1
                                        LoResp :121
                                        Tem.channel :63
                                        c02ppm :377
                                        HiResp :1
                                        LoResp :114
                                        Tem.channel :63
                                        c02ppm :370
                                        HiResp :1
                                        LoResp :108
                                        Tem.channel :63
                                        c02ppm :364
                                        HiResp :1
                                        LoResp :108
                                        Tem.channel :63
                                        c02ppm :364
                                        HiResp :1
                                        LoResp :119
                                        Tem.channel :63
                                        c02ppm :375
                                        HiResp :1
                                        LoResp :-110
                                        Tem.channel :63
                                        c02ppm :146
                                        HiResp :1
                                        LoResp :124
                                        Tem.channel :63
                                        c02ppm :380
                                        HiResp :1
                                        LoResp :127
                                        Tem.channel :63
                                        c02ppm :383
                                        HiResp :1
                                        LoResp :-43
                                        Tem.channel :63
                                        c02ppm :213
                                        HiResp :1
                                        LoResp :-72
                                        Tem.channel :63
                                        c02ppm :184
                                        HiResp :1
                                        LoResp :-77
                                        Tem.channel :63
                                        c02ppm :179
                                        HiResp :1
                                        LoResp :-63
                                        Tem.channel :63
                                        c02ppm :193
                                        HiResp :1
                                        LoResp :-92
                                        Tem.channel :63
                                        c02ppm :164
                                        HiResp :1
                                        LoResp :-105
                                        Tem.channel :63
                                        c02ppm :151
                                        HiResp :1
                                        LoResp :-116
                                        Tem.channel :63
                                        c02ppm :140
                                        HiResp :2
                                        LoResp :41
                                        Tem.channel :63
                                        c02ppm :553
                                        HiResp :2
                                        LoResp :47
                                        Tem.channel :63
                                        c02ppm :559
                                        HiResp :2
                                        LoResp :26
                                        Tem.channel :63
                                        c02ppm :538
                                        HiResp :2
                                        LoResp :-107
                                        Tem.channel :63
                                        c02ppm :405
                                        HiResp :2
                                        LoResp :-76
                                        Tem.channel :63
                                        c02ppm :436
                                        HiResp :2
                                        LoResp :-97
                                        Tem.channel :63
                                        c02ppm :415
                                        HiResp :2
                                        LoResp :-109
                                        Tem.channel :63
                                        c02ppm :403
                                        HiResp :2
                                        LoResp :106
                                        Tem.channel :63
                                        c02ppm :618
                                        HiResp :2
                                        LoResp :-96
                                        Tem.channel :63
                                        c02ppm :416
                                        HiResp :2
                                        LoResp :80
                                        Tem.channel :63
                                        c02ppm :592
                                        HiResp :2
                                        LoResp :69
                                        Tem.channel :63
                                        c02ppm :581
                                        HiResp :2
                                        LoResp :40
                                        Tem.channel :63
                                        c02ppm :552
                                        HiResp :2
                                        LoResp :84
                                        Tem.channel :63
                                        c02ppm :596
                                        HiResp :2
                                        LoResp :45
                                        Tem.channel :63
                                        c02ppm :557
                                        HiResp :2
                                        LoResp :3
                                        Tem.channel :63
                                        c02ppm :515
                                        HiResp :1
                                        LoResp :-30
                                        Tem.channel :63
                                        c02ppm :226
                                        HiResp :1
                                        LoResp :-62
                                        Tem.channel :63
                                        c02ppm :194
                                        HiResp :1
                                        LoResp :-73
                                        Tem.channel :63
                                        c02ppm :183
                                        HiResp :1
                                        LoResp :-75
                                        Tem.channel :63
                                        c02ppm :181
                                        HiResp :1
                                        LoResp :-96
                                        Tem.channel :63
                                        c02ppm :160
                                        HiResp :1
                                        LoResp :-89
                                        Tem.channel :63
                                        c02ppm :167
                                        HiResp :1
                                        LoResp :-101
                                        Tem.channel :63
                                        c02ppm :155
                                        HiResp :1
                                        LoResp :-112
                                        Tem.channel :63
                                        c02ppm :144
                                        HiResp :1
                                        LoResp :-107
                                        Tem.channel :63
                                        c02ppm :149
                                        HiResp :1
                                        LoResp :-112
                                        Tem.channel :63
                                        c02ppm :144
                                        HiResp :1
                                        LoResp :-110
                                        Tem.channel :63
                                        c02ppm :146
                                        HiResp :1
                                        LoResp :-124
                                        Tem.channel :63
                                        c02ppm :132
                                        HiResp :1
                                        LoResp :-120
                                        Tem.channel :63
                                        c02ppm :136
                                        HiResp :1
                                        LoResp :-75
                                        Tem.channel :63
                                        c02ppm :181
                                        Some of the values seem a bit low to me. Especially while the HiResp is 1 or the LoResp is negative.
                                        I will do this test again at home when I get the chance.
                                        • Tomas
                                        • F Offline
                                          F Offline
                                          FotoFieber
                                          @korttoma
                                          In the technical specification I only find the calibration with nitrogen. I don't think, that putting it outside, will help, as it is usually at around 400 ppm at the moment. (AFAIK netatmo sets the lowest measured value in the last one or two weeks to 400 for calibration).
                                          12.1k
