  2. Announcements
  • H hausinger
    @marceloaqno said:
    @hausinger Have you checked if /dev/ttyUSB0 is receiving any data?
    Thank you for your answer. I don't know, how to check that? The wiring to my nodes is correct, the serial port is correct (dmesg says that).
    Could you confirm, that my configuration from my last post is correct?
    marceloaqno
    Code Contributor
    wrote on last edited by marceloaqno
    #128
    @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
    It should be:
    ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
    H 1 Reply Last reply
    • M marceloaqno
      It should be:
      H
      H
      hausinger
      It should be:
      Hi @marceloaqno
      Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
      Did this configuration work on your System?
      Are you sure, that my configuration is ok? (with the "--")
      Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
      I'm now not at home (Business trip), if I get home, i will try your "Screen" command
      • jmmorgan83J
        jmmorgan83J
        jmmorgan83
        I followed the instruction above to make a mysgw file, but no file was generated.
        • jmmorgan83J jmmorgan83
          #131
          @jmmorgan83 do you think there is any information you can share might help us help you?
          • jmmorgan83J
            jmmorgan83J
            jmmorgan83
            I reset everything and ran it again. It did generate the file this time. Thanks, - Now to test it.
            • jmmorgan83J
              jmmorgan83J
              jmmorgan83
              Has anyone gotten the raspberry pi gateway to work with Openhab on the same raspberry pi? I have both the virtual and mqtt gateways working, but I can get either one to communicate with Openhab.
              • H hausinger
                It should be:
                Hi @marceloaqno
                H
                H
                hausinger
                @hausinger said:
                It should be:
                Hi @marceloaqno
                So I'm at home today and make some Test.
                The screen comand gives me some strange characters, thats ok I think.
                But if i start the Gateway, I only get the same messages as shown in my other post.
                Here are 2 Pics that show you, how it look like.
                I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
                • PureGrainP
                  PureGrainP
                  PureGrain
                  Has anyone been able to get this to successfully work with a Vera?
                  • RogerB68R
                    RogerB68R
                    RogerB68
                    Have been running MySensors for some time now with a EthernetGW running on Arduino. To clean-up the installation, I'm trying to get the Gateway running on my Raspberry instead but something stops the make process.
                    pi@raspberrypi ~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24                       [SECTION] Detecting target machine.
                    [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
                    [OK] init system detected: sysvinit
                    [OK] Finished.
                    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                    cc1: error: bad value (cortex-a7) for -mtune switch
                    Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
                    Any hints what I have done wrong ?
                    TigroenotT 1 Reply Last reply
                    • RogerB68R
                      RogerB68R
                      RogerB68
                      Issue solved, manual update of compiler from 4.6,3 -> 4.7.2 enables the make process. Similar problem also reported in post.
                      Using
                      • sudo apt-get update
                      • sudo apt-get upgrade
                      does not upgrade compiler. I used instruction according to How to upgrade GCC to 4.7+.
                      • RogerB68R RogerB68
                        [OK] Finished.
                        TigroenotT
                        TigroenotT
                        Tigroenot
                        @RogerB68 I had the same situation. I have removed the mtune parameter from the config file and compilation went fine. I don't know what it affects though. :)
                        • jmmorgan83J
                          jmmorgan83J
                          jmmorgan83
                          I created a virtual serial port using this ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway. I can see the port in the dev folder, but when I run dmesg I do not see it listed and therefore my openhab can not find it. How can I fix this?
                          • H hausinger
                            @hausinger said:
                            It should be:
                            Hi @marceloaqno
                            marceloaqno
                            Code Contributor
                            @hausinger After the command:
                            sudo ./bin/mysgw -d
                            It wasn't supposed to go back to bash, the gateway would wait for new messages.
                            I'm not sure what's going on with your setup because I tested your configuration options here and it worked.
                              marceloaqno
                              Code Contributor
                              @jmmorgan83 You may need another name for the port, such as
                              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                              jmmorgan83J 1 Reply Last reply
                              • M marceloaqno
                                jmmorgan83J
                                jmmorgan83J
                                jmmorgan83
                                @marceloaqno
                                Unfortunately, no luck:(.
                                • M marceloaqno
                                  sudo ./bin/mysgw -d
                                  H
                                  H
                                  hausinger
                                  sudo ./bin/mysgw -d
                                  Thank you for your answer. What can I do now? Can I check, that this port is unused? And how can I check this?
                                  Or is there another problem?
                                  • jmmorgan83J
                                    jmmorgan83J
                                    jmmorgan83
                                    FYI: I do not think the Rpi gateway works with Openhab on the same unit. I have tried both the virtual serial port and mqtt, and neither will work with Openhab 1.83.
                                    • G
                                      G
                                      gtortone
                                      • G
                                        G
                                        gtortone
                                        • skywatchS
                                          skywatchS
                                          skywatch
                                          Hi all,
                                          So I built this and all seems to be well. But.....how do I test it properly?
                                          I also installed pidome and have that able to 'see' the MSYGW, but it advises to only add it if it is working.
                                          So how to know if mysgw is working OK? Is there somewhere a step-by-step way to do this?
