  3. What does !TSP:MSG:PVER mismatch mean?
12 Posts 5 Posters 6.6k Views 5 Watching
    https://ci.mysensors.org/job/Verifiers/job/MySensorsArduino/branch/development/Doxygen_HTML/group__MyTransportgrp.html
    You seem to have some serious problems with your radio the data in the log looks corrupted. I.e. t=101...
    • TmasterT
      TmasterT
      Tmaster
      It happens to me with an amplified version of nrf24. i change the module and works fine
      i'm a arduino fan .Even sometimes don't undestanding how to use it :P
      • Martin TellblomM
        Martin TellblomM
        Martin Tellblom
        I restarted the sensor and it now works like a charm, haven't done anything to it.
        I have to wait another two weeks to see if it happens again
        Thanks @hek for the link ( I was looking for that the other day)
        MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
        • Martin TellblomM
          Martin TellblomM
          Martin Tellblom
          0;255;3;0;9;TSP:MSG:READ 101-101-101 s=101,c=5,t=101,pt=3,l=12,sg=1:25957
          0;255;3;0;9;!TSP:MSG:PVER mismatch
          This started today again and if I read the values correctly its a sensor with ID 101?
          What I can find I can decode this:
          TSF:MSG:READ,sender-last-destination,s=%d,c=%d,t=%d,pt=%d,l=%d,sg=%d:%s
          s=sensor ID
          c=command
          t=msg type
          pt=payload type
          l=length
          sg=signing flag
          But I can't find what the values mean.
          The other problem is that I do not have a sensor with id 101! I think this is something else that is messing with my radio.
            The radio looks seriously broken or underpowered. I've seen similar results when trying to use an amplified radio (with high PA level) and supplying it with too little power.
            • Martin TellblomM
              Martin TellblomM
              Martin Tellblom
              You mean the gateway I suppose? The radio is a NFR24L01+ with PA and LNA. a cap (right now the UNO is power by a computer USB port)
                Try lowering pa -level
                or
                #define MY_RF24_PA_LEVEL RF24_PA_MIN
                • Martin TellblomM
                  Martin TellblomM
                  Martin Tellblom
                  Thanks, I try it
                  • Daniel ErikssonD
                    Daniel ErikssonD
                    Daniel Eriksson
                    I am having exactly the same issue with 2.0, works fine with 1.5.
                    Using Arduino Mini Pro 5v - I do not have a Decoupling-Capacitor cause it hasnt been needed for 1.5 will that really be needed with 2.0?
                    • Daniel ErikssonD Daniel Eriksson
                      Yes. Decoupling was needed for 1.5 as well, but in some cases people were lucky and it happened to work anyway. Being lucky can work with 2.0 as well, but relying on luck for your home automation is not recommended.
                      Daniel ErikssonD 1 Reply Last reply
                        Daniel ErikssonD
                        Daniel ErikssonD
                        Daniel Eriksson
                        @mfalkvidd Ah ok, then I just have to wait for the stuff :) Thanks!
