  3. Fire pit RGB striplight controller
12 Posts 7 Posters 7.6k Views 13 Watching
  • Boots33B
    Boots33B
    Boots33
    I built a fire pit in our back yard using an old crusher mantle.
    I wanted the area to look nice so added some led strip lighting to the underside of the railings
    There are some clear led garden lights as well. Together the make a very inviting place to entertain friends.
    and a very comfy place to relax on the cooler nights
    So now it is time to bring the lighting under Mysensors control. This is a work in progress and I will post wiring etc as I go but thought i would throw the sketch up for a start.
    This node will control the RGB strip as well as separate switch for the white garden lights. In Domoticz the RGB controller looks like this. It can be used to set the brightness and colour of the strip. I will be using mosfet's to control all of the lights.
    The current sketch is working well on a breadboard prototype using a single RGB led . I will probably add some form of colour cycling as well as I progress.
    RGB LED Node for 12v common anode rgb strip,
    Also has a standard on/off switch to control an extra set of garden lights
    PWM pins (3, 5, 6, 9, 10, or 11).
    #define MY_NODE_ID 200  // I use 200 for my test nodes I will remove this line when it is installed
    #define RGB_CHILD_ID 1  // the rbg device includes a dimmer and on/off switch as well
    #define CHILD_ID_LIGHT_B 2
     const int controlPinA = 7;  //used to turn of rgb Power pin
     const int controlPinB = 8;  //used to switch off other garden lights
     const int redPin = 3;     //pin used to switch the red mosfet
     const int greenPin = 5;  //pin used to switch the green mosfet
     const int bluePin = 6;  //pin used to switch the blue mosfet
     long RGB_values[3] = {0,0,0};  //array used to hold the three rgb colours
     int dimSet = 0;                 // holder for the current dimmer setting
    // int dimHolder = 0;
      pinMode(controlPinA, OUTPUT);    //|
      pinMode(controlPinB, OUTPUT);    //|
      pinMode(redPin, OUTPUT);         //| setup pins as outputs
      pinMode(greenPin, OUTPUT);       //|
      pinMode(bluePin, OUTPUT);        //|
      setColor(0,0,0);                 // make sure lights are off when first booted
    void presentation()  {
      // Present sketch (name, version)
      sendSketchInfo("RGB Node", "1.0");
      // Register sensors (id, type, description, ack back)
       present(RGB_CHILD_ID, S_RGB_LIGHT,"Firepit RGB Control");
       present(CHILD_ID_LIGHT_B, S_LIGHT,"Firepit Lights");
      //nothing needed in here
    /*-----------------Start of functions---------------------*/
    /*----------- function to display LED colour as well as set brightness------------*/
    void setColor(int red, int green, int blue){
    if (dimSet != 0){
     analogWrite(redPin, round(red*dimSet/100));          //|
     analogWrite(greenPin, round(green*dimSet/100));      //| change the three rgb colours and adjust brightness
     analogWrite(bluePin, round(blue*dimSet/100));        //|
    else{                                                // if dimmer setting is 0 then set all colours to 0
      analogWrite(redPin, dimSet);
      analogWrite(greenPin, dimSet);
      analogWrite(bluePin, dimSet);
    #ifdef MY_DEBUG            //Print debug info if enabled
      Serial.print("RED = ");
      Serial.println(red);
      Serial.print("BLUE = ");
      Serial.println(blue);
      Serial.print("GREEN = ");
      Serial.println(green);
     if (message.type==V_RGB) {             //check for RGB message type
          /*   process the RGB hex code    */
        String rgbHexString = message.getString();                      //Load the hex color code into a string
        long number = (long) strtol( &rgbHexString[0], NULL, 16);
        RGB_values[0] = number >> 16;
        RGB_values[1] = number >> 8 & 0xFF;
        RGB_values[2] = number & 0xFF;
        setColor(RGB_values[0],RGB_values[1],RGB_values[2]);            // call the setColor function to update the LED's
         Serial.print("HEX RGB " );
         Serial.println(rgbHexString);
         Serial.print("long number " );
         Serial.println(number);
     if (message.type==V_DIMMER) {                                        //check for dimmer message type
        dimSet = message.getInt();                                        // Load the dimmer setting into dimSet
        setColor(RGB_values[0],RGB_values[1],RGB_values[2]);              // call the setColor function to update the LED's. new dimmer setting
         Serial.print("dimmer setting " );
         Serial.println(dimSet);
     if (message.type==V_LIGHT) {                                     //check for incoming  light switch message type
        switch (message.sensor) {
          case 1:                                                     //message is for sensor 1 (RGB switch)
            digitalWrite(controlPinA, message.getBool() ? 1 : 0);
          case 2:                                                     //message is for sensor 2 (garden lights)
            digitalWrite(controlPinB, message.getBool() ? 1 : 0);
        #ifdef MY_DEBUG
          Serial.print("Light switch setting " );
      Beautiful!
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        wow. that looks great!!
        Home Automation Tinkerer
        www.CrankyCoder.net
        Gateway: MQTTClientGateway
        MySensors: 2.3
        • R
          R
          r-nox
          Nice work, looks fantastic!
          • Boots33B
            Boots33B
            Boots33
            Found a nice routine for the colour cycling, it gives a very smooth fade between colours.
            Sketch below
            and a standard on/off switch to select colour cycling
            colour cycling routine from https://gist.github.com/jamesotron/766994
            #define CYCLE_SWITCH_ID 3
             const int controlPinA = 7;  //used to turn on/off rgb Power pin
             const int controlPinB = 8;  //used to switch on/off other garden lights
             int cycleSpeed = 20;    // this sets the speed of the colour cycling
             bool cycleState = 0;    // used to check if colour cycling is turned on
            MyMessage msg(CYCLE_SWITCH_ID, V_STATUS);
               present(CHILD_ID_LIGHT_B, S_LIGHT,"Firepit Garden Lights");
               present(CYCLE_SWITCH_ID, S_LIGHT,"Cycle Switch");
            if (cycleState == 1){  // check to see is colour cycling is turned on
              cyclecolor();
            if (dimSet != 0){
            /*------------------process incoming messages--------------------*/
                 if(cycleState == 1){                                     // new incoming colour change, turn off cycling if it is on
                 send(msg.set(false));
                 cycleState = 0;
                  case 3:                                                     // message is for sensor 3 (colour cycle switch)
                    cycleState = message.getBool() ? 1: 0;
                #ifdef MY_DEBUG                                            //print some degug info if enabled
            /*---------------function to cycle colours-----------------------*/
            void cyclecolor(){
            /*Start off with red*/
              RGB_values[0] = 255;
              RGB_values[1] = 0;
              RGB_values[2] = 0;
              /* Choose the colours to increment and decrement.*/
              for (int decColour = 0; decColour < 3; decColour += 1) {
                int incColour = decColour == 2 ? 0 : decColour + 1;
              /* cross-fade the two colours*/
              for(int i = 0; i < 255; i += 1) {
               RGB_values[decColour] -= 1;
               RGB_values[incColour] += 1;
               analogWrite(redPin, RGB_values[0]);
               analogWrite(greenPin, RGB_values[1]);
               analogWrite(bluePin, RGB_values[2]);
               if (cycleState == 0){                 // If colour cycling is turned off break out to main loop
               wait(cycleSpeed);   // this controls the speed of the colour cycling
            • TigroenotT
              TigroenotT
              Tigroenot
              wrote on last edited by Tigroenot
              @Boots33
              Looks awesome!
              I have a question. I took your sketch and it works great, but is it possible not to use the separate V_LIGHT to turn it on/off? What I mean is that I don't want to put a rele or a MOSFET to control the RGB power but to start/stop dimming by using just one RGB icon in domoticz. And turn it off by either setting dimmer value to 0 or pressing the off button in domoticz RGB switch. Is it possible?
              Boots33B 1 Reply Last reply
              • TigroenotT Tigroenot
                @Boots33
                Looks awesome!
                Boots33B
                Boots33B
                Boots33
                wrote on last edited by Boots33
                Hi @Tigroenot The reason i used the xtra mosfet was mainly so the leds would just resume with whatever they were previously set to when the rgb switch was turned back on and also as this node is powered all the time wanted to make sure it turned off completely. I can see no reason why you could not do away with the IRF4905 and just set the three channels to 0.
                You would need to save the current state to the arduino eeprom if you wanted to have it resume with the same colour etc when the switch is turned back on.
                In fact part of the code does set all the channels to 0 already if the dim level is set to 0.
                You can see below that if dimSet = 0 then the else statement is executed , setting all the channels to 0
                if (dimSet != 0){
                You would also need to change the code where it reacts to the incoming message from the RGB switch.
                Instead of
                        digitalWrite(controlPinA, message.getBool() ? 1 : 0);     // change state of RGB power switch
                you would need to try something like the code below. It is untested so you may need to tweak it a bit.
                       // digitalWrite(controlPinA, message.getBool() ? 1 : 0);     // change state of RGB power switch
                        if (message.getBool()== 0){
                         setColor(0,0,0);                 // turn lights off
                         cycleState = 0;                  // turn off colour cycling
                        else{
                          setColor(200,0,0);     // turn lights red when first turned on
                • Boots33B
                  Boots33B
                  Boots33
                  I have been distracted from this project with other things but intend to finish it off soon. I am posting the current wiring diagram which I have tested with a 5m RGB strip. I can confirm the mosfets do not heat up at all, even without heatsinks so all looks good.
                  I am thinking of changing the clear garden lights from a mosfet to a relay as they are powered by 12AC so will need to rectify that or switch the AC with a relay. still a work in progress
                  The circuit
                  • Boots33B
                    Boots33B
                    Boots33
                    So I decided to leave the garden lights running on 12v AC as this may offer less voltage drop and wire corrosion than if I were to switch to DC.
                    I had a double relay module on hand so have added an extra switch to the sketch. this node now controls the RGB Strip as well as the two relays. The relay modules need to be switched high to turn off so I have also modified the sketch to suit.
                    I think the sketch and diagram below will be the ones I use.
                    Also has two standard on/off switches to control  extra  garden lights
                    #define CHILD_ID_LIGHT_1 2            //garden lights 1
                    #define CYCLE_SWITCH_ID 3             // colour cycle switch
                    #define CHILD_ID_LIGHT_2 4            // garden lights 2
                    const int controlPinA = 7;                          //pin used to turn on/off rgb Power
                    const int controlPin1 = 8;                          //pin used to switch on/off  garden lights 1
                    const int controlPin2 = 4;                          //pin used to switch on/off garden lights 2
                    bool cycleState = 0;                                // used to check if colour cycling is turned on. 0 means it will be off when node starts up
                    bool onceOnly = 0;                                  //used to excecute some code once at startup
                    MyMessage rgbmsgA(RGB_CHILD_ID, V_PERCENTAGE);
                    MyMessage gardenlightmsg1(CHILD_ID_LIGHT_1, V_STATUS);
                    MyMessage gardenlightmsg2(CHILD_ID_LIGHT_2, V_STATUS);
                    pinMode(controlPin1, OUTPUT);    //|
                    pinMode(controlPin2, OUTPUT);    //|
                    setColor(0,0,0);                 // make sure RGB lights are off at startup
                    digitalWrite(controlPin1,HIGH);   // make sure garden lights are off at startup. relay module swithces High to turn off
                    digitalWrite(controlPin2,HIGH);   // make sure garden lights are off at startup. relay module swithces High to turn off
                    sendSketchInfo("RGB Node", "0.1");
                     present(CHILD_ID_LIGHT_1, S_LIGHT," Garden Lights 1");
                     present(CYCLE_SWITCH_ID, S_LIGHT,"RGB Cycle Switch");
                     present(CHILD_ID_LIGHT_2, S_LIGHT," Garden Lights 2");
                    if (onceOnly == 0){                     // this code only exectutes once at startup to make sure controller knows switch settings are off
                     send(msg.set(false));                // send message to switch off colour cycling
                     send(rgbmsgA.set(0));                // send message to switch off RGB lights
                     send(gardenlightmsg1.set(false));    // send message to switch off garden lights relay 1
                     send(gardenlightmsg2.set(false));    // send message to switch off garden lights relay 2
                     onceOnly = 1;
                    cyclecolor();
                    if (dimSet != 0){
                    switch (message.type) {
                    case V_LIGHT:                                                //message is for a light switch (2)
                        case 2:                                                     //message is for sensor 2 (garden lights switch 1)
                          digitalWrite(controlPin1, message.getBool() ? 0 : 1);     //change state of garden light switch
                          cycleState = message.getBool() ? 1: 0;                    // change state of colour cycle
                        case 4:                                                     //message is for sensor 4 (garden lights switch 2)
                          digitalWrite(controlPin2, message.getBool() ? 0 : 1);     //change state of garden light switch
                    case V_PERCENTAGE:                                                  //check for dimmer message type (3)
                       cycleState = 0;
                    case V_RGB:                                                       //check for RGB message type (40)
                    void cyclecolor(){
                    RGB_values[1] = 0;
                    RGB_values[2] = 0;
                      MikeF
                      Be careful powering the Nano from 12V - there are reports elsewhere on this forum of some versions getting fried at this voltage!
                      • M MikeF
                        Boots33B
                        Boots33B
                        Boots33
                        Thanks @MikeF as you say they can get quite hot when run at the higher end of their voltage tolerance. .
                        I have never had a nano fail on me at 12v though and as this is an outside node located where it can do no harm if it fails I am happy to avoid the extra voltage regulator.
                        If it was a node to be situated inside the house then I always try and keep to 9v or less just to make sure it all runs cool.
                        micahM 1 Reply Last reply
                        • Boots33B Boots33
                          micahM
                          micahM
                          micah
                          @Boots33
                          I've fried a couple pro mini's and a nano running 12v to the vin/raw... actually in one case it might have been up to 15v .... oops.
                          But I've since learned my lesson.... I now use a Linear Voltage Regulator between the source and the arduino for all my builds that have a higher voltage power source (i.e.: builds that run lights). Typically a L7805CV or L7809CV or L7810CV (or other) depending on the voltage of my source and what I want to send to the arduino.
                          Here is an example L7809CV from AliExpress
