  3. 💬 ESP-LINK ESP8266 WeMos D1 Mini Adapter Board
arduinoadapterwemosesp8266pro miniinterstitialesp-linkd1miniserial wi-fi
83 Posts 9 Posters 47.8k Views 6 Watching
    @kalle
    The deep sleep is good enough. What ruins the whole thing, though, is the fairly long re-acquaintance with the wi-fi router once it wakes up. That's where most of the power drain happens. If we could just drive the radio directly, then that problem goes away.
    #56
    OK, I just noticed that it supports wi-fi direct (https://www.itead.cc/psf-a85.html), so perhaps that could accomplish it, since that doesn't require the lengthy wi-fi router dance.
    The other strange thing is that Itead says its module supports 2x1 MIMO, and yet I see only one antenna port on it.
    Nca78N 1 Reply Last reply
      @kalle
      K
      K
      kalle
      @NeverDie To connect to the router take only 1-2 seconds for my wemos devices (static IP), but ok - maybe this is to long.
      I think for a switch, it can be run all the time - or do I misunderstand something
      • K kalle
        #58
        @kalle
        Yeah, 1-2 seconds is correct, but there's a consensus that for battery operation, because of the high current drain, that's actually 2 to 3 orders of magnitude too long. Think of a typical temp-rh sensor that updates every 5 minutes, for example. It adds up quickly.
          wrote on last edited by Nca78
          #59
          @NeverDie said:
          No it doesn't. That's a claim that has been made by Espressif in the ESP8266 specs. But it has never been implemented...
          Wearable ESP8266 (or 8285) is also a bold claim by iTead. The lowest power mode for radio transmit draws around 120mA, it's already over 50mA in receive mode. And if you use PWM, i2C (and I fail to see the use of wearable without them) or anything like that even when disabling the radio it will consume 15mA.
          I have better hopes for the ESP32 as it's supposed to have some kind of very low power (for real) coprocessor to handle small tasks while the main cores will sleep. But it's still in development on the SDK side, and as seen with the "wifi direct" claim on the ESP8266 we should not take every promised feature from Espressif at face value ;)
          K 1 Reply Last reply
          • Nca78N Nca78
            @NeverDie said:
            K
            K
            kalle
            @Nca78 Thanks for the explanation - and yes, I'm also still waiting for the ESP32
              #61
              Hmm.. at Mysensors Team we already have our ESP32 LORA board :stuck_out_tongue_winking_eye:
              This is a LIPO charger, LORA board i did for ESP32 evaluation. With a nice LDO, I added a neopixel, and prefer bigger tactile switch :) same width as Nano32 but 1cm longer, so one row available on each side for breadboarding. ESP32 is a nice little beast :)
              I have other stuff coming for esp32. i'll release ;)
              • scalzS scalz
                #62
                @scalz
                Will the ESP32 be capable of "ultra low power" in a real sense? Have you run any measurements?
                  #63
                  imho, ultra low power is sub uA. Above, it's very low power :)
                  So, i'm not sure for ultra low power (depends also on strategy..), but very low power yes. I've not run any power consumption tests, focused on other parts. And the SDK is still not complete including the low power aspects. Some stuff is missing in ESP-IDF, but ready in Arduino, and vice versa. Docs are not complete yet, but looks good.
                  That said, ESP32 team is doing a great work! And Espressif is working on a revision of their sillicon die (there is an errata)...
                  • scalzS scalz
                    @scalz
                    In that case, what's your definition of "very low power"?
                      #65
                      lol, my very personal view, for battery operated devices:
                      • ultra low power : <= 1uA
                      • very low power : < 10uA
                      • low power : 100uA, not sure for this one :)
                      The same for the efficiency ;)
                        #66
                        Will the ESP32 be able to remember its state (including all variable values) just prior to sleeping, like an atmega328p can, or like the ESP8266 do you have to explicitly store the state in flash before sleeping and then restore it upon waking up?
                          for more infos, easier to have a look at their docs but it's a lot smarter than esp8266.
                          • scalzS scalz
                            #68
                            @scalz
                            Fair enough. It's just that it's hard to know, as Nca78 points out, what parts of their documentation can be believed, and what parts are pure fantasy.
                              @scalz
                              #69
                              I notice Seeed Studio was selling the esp32 for $6.95, but it's presently backordered: https://www.seeedstudio.com/ESP-32S-Wifi-Bluetooth-Combo-Module-p-2706.html
                              Other seller are selling either the esp32 or the esp32 with an adapter board for 2-3x that amount. So, it's still early days until supply catches up with demand.
                              A few other things impress me about it:
                              1. it comes with Bluetooth Low Eenrgy,
                              2. 520kByte of SRAM.
                              3. Built in hardware support for 10 capacitive touch channels.
                              4. Apparently it comes with an RTC built-in
                              5. 240Mhz processor clock frequency
                              6. Two 10-bit DAC's. Quite a few 12-bit ADC's.
                              Sounds interesting!
                                Sounds interesting!
                                Which of the esp32 boards is the best one to buy? What I like about the Wemos board for the ESP8266 is that I can download a sketch without having to press any buttons on the board itself. Is there an esp32 board that works like that also?
                                  #71
                                  yeah, it has nice specs ;)
                                  which board to order ? Mine :stuck_out_tongue_winking_eye:
                                  I'm kidding, I don't really have idea on this. I made mine..and am waiting for different pcb variant now :)
                                  But I firstly ordered a Nano32 which I like. You can have pinheader on each side of the board when breadboarding. You can't with the official Espressif board which is too large.
                                  There is lot of esp32 board released. But all have the first ic revision of course.
                                  • scalzS scalz
                                    Uh, "first ic revision"? I haven't followed esp32 at all, obviously. Was there later a second ic revision? i.e. are all the boards currently out there saddled with obsolete ic's?
                                      yes Espressif has released an Errata doc, some issues related to silicon die ic. Minor issue, depending of doing what with it.
                                      I read the fixed version should be available at beginning of next year.
                                      • scalzS scalz
                                        @scalz
                                        Thanks! , I see that the next revision of the silicon is scheduled for February 2017: http://esp32.de/eco_and_workarounds_for_bugs_in_esp32_en.pdf
                                        I'm in no rush. I'll wait until it's deemed ready for prime-time.
                                          I've tested the board, and it works fine.
