  3. Repeater
Repeater
8 Posts 4 Posters 4.3k Views 2 Watching
  • D
    Dragon
    How do i do a repeater node? I cant found it in the code anymore?
    • D Dragon
      @Dragon the instructions on https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes should be all you need - have you seen it?
      D 1 Reply Last reply
        Dragon
        @mfalkvidd thanks i missed that. So i only need to write this in the code #define MY_REPEATER_FEATURE
        • D Dragon
          @Dragon yes, and no sleeping because a sleeping node can not receive messages.
            Dragon
            @mfalkvidd Thanks
            • ร
              ร
              รอเรือ
              Then I guess the following code will do just fine.
              #define NODE_ID 7 // Set node ID here
              #define SKETCH_NAME "Repeater Node"
              #define SKETCH_VERSION "1.1"
                //Send the sensor node sketch version information to the gateway
              • ร รอเรือ
                manutremo
                @รอเรือ I think some things are missing in that code. This is the one I'm using.
                #define MY_NODE_ID 2 // Set node ID here, or remove for Auto
                #define SKETCH_VERSION "2.1.1"
                #define CHILD_ID 1
                //Set other radio options here if needed
                  present(CHILD_ID, S_ARDUINO_REPEATER_NODE);
                ร 1 Reply Last reply
                • M manutremo
                  #define CHILD_ID 1
                  ร
                  ร
                  รอเรือ
                  thank You @manutremo :blush:
