  3. Gateway to hands out node ID's
11 Posts 4 Posters 3.6k Views 4 Watching
    Mickey
    Hi
    Is it even possible to implement that Gateway will hands out node ID's ?(something simple like store the assigned id's in eeprom and hand out what is not assigned...)
    • tbowmoT
      tbowmoT
      tbowmo
      This is not implemented in the gateway code, as it's "always" been the job of the attached controller.
      • tbowmoT tbowmo
        Mickey
        I know it's "always" been the job of the attached controller but I have a scenario that the mqtt gateway will send directly to a cloud broker and an app that will receive it without any controller on the way. one problem I facing is the nodes id handing...so my question is if I would like to implement this in the GatewayESP8266MQTTClient.ino file is it possible?(check for incoming id request and 255 id number and saving current id handed in gateway eeprom etc...)
        • M Mickey
          sundberg84S
          sundberg84S
          @Mickey - What happens if you fix a static node-id for each node?
          • sundberg84S sundberg84
            Mickey
            @sundberg84 it's need to be automatic. Fix id is easy to implement but because there will be an unknown number of nodes than I cannot use fix id's...
              Internal messages does not get exposed in the receive() function of the sketch.
              To archive this you would have to modify the core somewhere here:
              https://github.com/mysensors/MySensors/blob/development/core/MyTransport.cpp#L706
                Mickey
                Thanks for answer.
                I tried to figure where I change the internal msg type to be exposed to GW in the MyTransport.cpp around line 706 but can't seems to find it...
                  Why pass it to the sketch? You could implement the id-handout directly in core (I pointed out the area where internal messages directed to the node is processed).
                    Mickey
                    To mess with core as little as I could so it can be easy upgradable in future (I already altered the MyGatewayTransportMQTTClient.cpp to support using dynamic connection parameters instead hard coded , I don't want to alter a lot of core files but if it necessary I will...)
                      Mickey
                      wrote on last edited by Mickey
                      So I went and change the MyTransport.cpp file and added a few lines around line 740:
                      		uint8_t currentID;
                      		#if defined(MY_GATEWAY_FEATURE)
                      			if (type == I_ID_REQUEST) {
                      				currentID = hwReadConfig(0X123); //Read first byte of free conf eeprom space
                      				if(currentID==0xFF)//check to see if it was never changed (255)...
                      				{currentID = 1;}
                      				_msg.set(currentID);
                      				if(transportSendWrite(0xFF,_msg))
                      				hwWriteConfig(0X123,currentID+1)
                      			// Hand over message to controller
                      But the sensor still requesting an ID without getting it...
                        You can see at how incoming PING requests sends a message back to the requesting node.
                        So... something like this:
                        (void)transportRouteMessage(build(_msgTmp, sender, NODE_SENSOR_ID, C_INTERNAL,
                        					                                  I_ID_RESPONSE).set(currentID));
