  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.5k Views 40 Watching
  • DiverAlphaD
    DiverAlphaD
    DiverAlpha
    Hy all,
    Thanks for your help. Unfortunately it didn't solved the problem :-(.
    I tried it with putting the NODE_ID's om static but that didn't help. MY_PARENT_NODE_IS_STATIC is totally not recognized in the Arduino IDE...
    I tried just what @palande.vaibhav mentioned with the code he posted. The only adjustment is that I had to change the CE and CS pin on the sensot because I'm using a Adruino Micro. Further the code was just copy-paste but the same result in the serial communication as I posted earlier. (Except now the ID was 1 in stead of 105...)
    palande.vaibhavP 1 Reply Last reply
    • DiverAlphaD DiverAlpha
      Hy all,
      palande.vaibhavP
      palande.vaibhavP
      palande.vaibhav
      @DiverAlpha
      I tried it on my setup. The node shows the output with BC (st=bc) when I only have the node connected in that is powered ON. But when I power ON my gateway in they start communicating and I get st=ok.
      Here is the node without gateway connected:
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=1)
      TSM:FPAR
      TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      After I power ON the gateway I get following output:
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
      TSP:MSG:PAR OK (ID=0, dist=1)
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=1)
      TSM:UPL
      TSP:PING:SEND (dest=0)
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
      TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
      TSP:MSG:PONG RECV (hops=1)
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      SHT31 test
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
      TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:Temperature and switch
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
      TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
      Request registration...
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
      TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
      Node registration=1
      Init complete, id=1, parent=0, distance=1, registration=1
      TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.0
      Temp *C = 21.32
      TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.32
      Hum. % = 75.48
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:75.48
      Basically you need to have at least one node and a gateway working for MySensors to run properly.
      Here is the thread I started when I had the same problem: https://forum.mysensors.org/topic/4941/problem-getting-the-code-to-run-with-mysensors-library-2-0/35
      Read last few comments, you will get the idea of what I am saying. You can also try the fix for this suggested by ayo in the comment #35.
      • G gvorster
        @mfalkvidd said:
        @gvorster 868 is the default so you don't need to do anything. If you want to change it, add
        #define MY_RFM69_FREQUENCY
        Great, thanks!
        G
        G
        gvorster
        Great, thanks!
        I have a RFM69HCW and was getting a terrible connection from 5 meters through two thin walls.
        After using:
        #define IS_RFM69HW
        The connection and range is incredible!
        I live in an appartment 3rd floor, put a node in my mailbox which is 15 meters below and still got sensor data.
        This did not work for me before using NRF24L01+
        • pepsonP
          pepsonP
          pepson
          Hi
          how long is real range on radio RFM69HW ? It is better than NRF24L01 ?
          G 1 Reply Last reply
            Yes, generally, lower frequency -> longer range (but also lower transmission speed).
            • pepsonP
              pepsonP
              pepson
              But speed RFM69HW is too slow ? For use it to relay switch and some sensors... ? What is better to home automation ? RFM69HW or NRF24L01 ?
              • pepsonP pepson
                Hi
                G
                G
                gvorster
                wrote on last edited by gvorster
                #29
                @pepson said:
                Hi
                This post has some more info on this: Which is better: RFM69 or NRF24L01+
                I want to use these radio's indoors and need to have a good connection through a couple of thin walls. My impression is that the RFM69 has at least better wall penetration. I'm using the RFM69HCW 868Mhz with only a 82mm wire connected to the ANT pin.
                I tested the Mock sketch and enabled a few mock sensors. Throughout my appartment I have no problem having a good connection.
                But, there are fake NRF24L01+ chips out there which might be the cause of my penetration connections errors.
                I'm buying my RFM69 radio's from a reliable distributor in the Netherlands http://webshop.ideetron.nl/HopeRF
                • pepsonP
                  pepsonP
                  pepson
                  When uusing RFM69HW i must also use Capacitor as for NRF24L01 ?
                  korttomaK 1 Reply Last reply
                  • pepsonP pepson
                    korttomaK
                    korttomaK
                    korttoma
                    @pepson
                    I do not think that the RFM69HW is as sensitive as the NRF24L01 but adding a Capacitor will not hurt.
                    It also depends on how clean your power source is. If the power is clean you do not need to filter it using Capacitor.
                    • Tomas
                      A Former User
                      Hi guys!
                      I'd like to ask you about a problem. When I use RFM69 radios on my nodes, they are working fine, but when I try to use the NRFs everything is falling apart and that's driving me crazy. I can't find the solution to use NRFs (I've got 20 of them). I tried everything, read the forum a hundred times, but can't find the solution. Poer sources are perfect, every NRF has it's own 3.3v source and after a few hours or a few days perfect working, the nodes disappear (not all and not in the same time). I'm using Domoticz as controller on a RPI 2. I saw the node's L13 led's blinking is much lighter after the node disappears. When it's working okay, the led is blinking on full.
                      Thank you for the suggestions, and have a nice day
                      mfalkviddM palande.vaibhavP 2 Replies Last reply
                      • ? A Former User
                        Hi guys!
                        @ZsoltZombori what does the serial debug output of the nodes say?
                        ? 1 Reply Last reply
                        • ? A Former User
                          Hi guys!
                          palande.vaibhavP
                          palande.vaibhavP
                          palande.vaibhav
                          @ZsoltZombori
                          I had a problem of the LED on pin 13 glowing dim after some time of system running fine when I had 2 sensors connected to the Arduino and sensors had their own separate 5V power supply. So, I had a 5V power supply separate from the Arduino's 5V and that was supplying current to those sensors.
                          I had the sensor's data pins connected to Arduino but I didn't have GND of power supply and Arduino connected. I solved the problem by connecting the GND of power supply to the GND of the Arduino.
                          See if that is the case with you.
                          Hope this helps.
                            A Former User
                            @mfalkvidd I put the node on serial for the night and everything works fine now. No errors occured, I'm still waiting.
                            @palande-vaibhav The GNDs are always connected in my circuits to prevent GND problems. Thanks for the tip.
                            • ? A Former User
                              palande.vaibhavP
                              palande.vaibhavP
                              palande.vaibhav
                              wrote on last edited by palande.vaibhav
                              #36
                              @ZsoltZombori
                              Exactly that was a problem with my system too. When I had it connected to the computer using the serial cable everything would just run fine but as soon as I removed the serial cable from computer and let it run on its own with the power supply connected with a DC jack, everything would just fall apart the LED's would go dim and that's when I discovered the problem of the ground but you already have all the grounds connected so I'm out of clues here.
                              I would suggest you to check the power supply connections again with a multimeter to make sure that everything is connected properly.
                              • palande.vaibhavP palande.vaibhav
                                @ZsoltZombori
                                A Former User
                                wrote on last edited by [[global:former-user]]
                                #37
                                @palande.vaibhav I double checked everything and the PCB is perfect. Still waiting for a failure, but it's working now. I'm wondering what was the problem for weeks with the NRFs. The RFMs are working like a charm. Anyway, thank you for the ideas :)
                                Edit: there were two fails in ~21hrs, I attach the debug code:
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:ASSIGNID:OK (ID=3)
                                TSM:FPAR
                                TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:CHKID:OK (ID=3)
                                TSM:UPL
                                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                TSP:MSG:READ 0-0-3 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                TSP:MSG:READ 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
                                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                                TSP:MSG:SEND 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                Node registration=1
                                Init complete, id=3, parent=0, distance=1, registration=1
                                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.6
                                !TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.6
                                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:22.6
                                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.5
                                !TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.5
                                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:22.5
                                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.4
                                • pepsonP
                                  pepsonP
                                  pepson
                                  How i must change sketch Gateway and node to use radio RFM69HW ? In sketch i see only for simple RFM69 not RFM69HW.
                                    for using RFM69HW, you just need to use the common rfm69 defines and add this
                                    #define MY_IS_RFM69HW
                                    rmtuckerR korttomaK 2 Replies Last reply
                                    • scalzS scalz
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      @scalz
                                      Do you add the rfm69hw def to the gateway sketch or to the myconfig.h?
                                      • scalzS scalz
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        #41
                                        @rmtucker
                                        You add the #define to your sketch
                                        Hi @scalz ,
                                        Will a RFM69HW work without the "#define MY_IS_RFM69HW" ?
                                        What exactly does this #define do for the HW version?
                                        Have only used RFM69W so far but have ordered some HW now also.
                                        • Tomas
                                          #42
                                          to your GW sketch.
                                          Also, for using RFM69H you need this define,else the radio can't work properly. This allow us to set the right Radio power level registers in lib.
                                          @korttoma just curious :) Have you tried my rfm69 repo?
