  3. 💬 OH MySensors RGBW Controller
mysensorspcbrgbwcontroller
106 Posts 18 Posters 59.4k Views 19 Watching
  • L
    L
    LastSamurai
    Oh thats just a naming issue. Rename the "RGBWController-Edge.cuts.gm1" to .gml in the zip file and it should work just fine.
    • peerkersezuukerP
      peerkersezuukerP
      peerkersezuuker
      Just got the v1.3 pcb's from OSH Park, just waiting for some components, and the we go. It will be an exciting christmas ;-)
      Domoticz / My Sensors / Z-Wave
      https://www.kermisbuks.nl
      • J
        J
        Jan Gatzke
        I got my v1.3 pcbs from Smart Prototyping. Quality is good. The controller works fine BUT the sketch version in your github repo is broken. Seems like the non linear fading part never got finished. I am now using linear fading and the sketch is working. :)
        peerkersezuukerP 1 Reply Last reply
        • J Jan Gatzke
          peerkersezuukerP
          peerkersezuukerP
          peerkersezuuker
          @Jan-Gatzke
          Hi can you please post your adjusted sketch for further reference?
          J 1 Reply Last reply
          • peerkersezuukerP peerkersezuuker
            @Jan-Gatzke
            J
            J
            Jan Gatzke
            @peerkersezuuker
            You have to fix the following part:
            for (int i = 0; i < NUM_CHANNELS; i++) {
                if (isOn) {
                  // normal fading
                  //analogWrite(channels[i], dimming / 100.0 * values[i]);
                  // non linear fading, idea from https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
                  analogWrite(channels[i], pow (2, (dimming / R)) - 1);
                  analogWrite(channels[i], 0);
            Corrected Version
                if (isOn) {
                  // normal fading
                  //analogWrite(channels[i], pow (2, (dimming / R)) - 1);
            Or else all channels are set to the Value of dimming. The sketch on openhardware.io is broken, too.
            • J Jan Gatzke
              @peerkersezuuker
                  if (isOn) {
                    // normal fading
              Corrected Version
                  if (isOn) {
                    // normal fading
              peerkersezuukerP
              peerkersezuukerP
              peerkersezuuker
              @Jan-Gatzke
              Thank you for your post.
              I hope the Mosfet's are comming in today, then i can build it up and play with it.
              • L
                L
                LastSamurai
                @Jan-Gatzke Thank you for correcting it ;) I never got around to making the fading part work a 100% so I reverted back to my normal linear fading for my controllers. Seems like I forgot to correct that in my git repo :frowning: Sorry for that, I will fix it after christmas.
                Great to hear that others are using the controllers too! Have fun with them and update me if you change something or build some (other) cool thing with them!
                • peerkersezuukerP
                  peerkersezuukerP
                  peerkersezuuker
                  A little question, the v1.3 is this the one with the corrected mosfet placement ?
                  I build and programmed one now, but i only get a bright white light, and no response when i switch the node. So now i am in doubt...
                  With regards
                  Peer
                    With regards
                    Peer
                    J
                    J
                    Jan Gatzke
                    @peerkersezuuker
                    The node always starts with white on. This is normal behaviour.
                    • J Jan Gatzke
                      @peerkersezuuker
                      peerkersezuukerP
                      peerkersezuukerP
                      peerkersezuuker
                      @Jan-Gatzke
                      Thank you, i see it in the code now ...
                      I tested it with setting the RGB levels one by one to 255, and this works, so the channels are responding to the initialisation code.
                      And because it is rebuild to version 2.0, i forgot one void to adjust...
                      void incomingMessage(
                      should be
                      void receive(
                      Problem solved, thank you very much.
                      With regards
                      Peer van Hoek
                        @Jan-Gatzke
                        should be
                        void receive(
                        With regards
                        Peer van Hoek
                        J
                        J
                        Jan Gatzke
                        @peerkersezuuker
                        Great.Can you post the complete 2.0 sketch, please? I am going to upgrade and this would be a good starting point.
                        • J Jan Gatzke
                          @peerkersezuuker
                          peerkersezuukerP
                          peerkersezuukerP
                          peerkersezuuker
                          @Jan-Gatzke
                          Sure, no problem.
                          But it is not 100% clean, i am just a coppier and paste'r....
                          If you can clean it up that would be nice.
                          Based on the MySensors Project: http://www.mysensors.org
                          This sketch controls a (analog)RGBW strip by listening to new color values from a (domoticz) controller and then fading to the new color.
                          Version 1.0 - Changed pins and gw definition
                          Version 0.9 - Oliver Hilsky
                          TODO
                          safe/request values after restart/loss of connection
                          #define SN   "RGBW 01"
                          #define SV   "1.0"
                          // change the pins to free up the pwm pin for led control
                          #define MY_RF24_CE_PIN 4 //<-- NOTE!!! changed, the default is 9
                          #define MY_RF24_CS_PIN 10 // default is 10
                          #define MY_REPEATER_FEATURE
                          #define MY_NODE_ID 6
                          // Load mysensors library
                          // Load Serial Peripheral Interface library
                          // Arduino pin attached to driver pins
                          #define RED_PIN 3
                          #define WHITE_PIN 9
                          #define GREEN_PIN 5
                          #define BLUE_PIN 6
                          #define NUM_CHANNELS 4 // how many channels, RGBW=4 RGB=3...
                          #define CHILD_ID 1
                          // Smooth stepping between the values
                          #define STEP 1
                          #define INTERVAL 10
                          const int pwmIntervals = 255;
                          float R; // equation for dimming curve
                          // Stores the current color settings
                          byte channels[4] = {RED_PIN, GREEN_PIN, BLUE_PIN, WHITE_PIN};
                          byte values[4] = {0, 0, 0, 255};
                          byte target_values[4] = {0, 0, 0, 255};
                          // stores dimming level
                          byte dimming = 100;
                          byte target_dimming = 100;
                          // tracks if the strip should be on of off
                          boolean isOn = true;
                          // time tracking for updates
                          unsigned long lastupdate = millis();
                            // Initializes the sensor node (with callback function for incoming messages)
                            //begin(incomingMessage);	// 123 = node id for testing
                            // Set all channels to output (pin number, type)
                              pinMode(channels[i], OUTPUT);
                            // set up dimming
                            R = (pwmIntervals * log10(2))/(log10(255));
                            // get old values if this is just a restart
                            request(CHILD_ID, V_RGBW);
                            // init lights
                            updateLights();
                            // debug
                            if (isOn) {
                              Serial.println("RGBW is running...");
                            Serial.println("Waiting for messages...");
                          void presentation()  {
                            sendSketchInfo(SN, SV);
                            // Register this device as Waterflow sensor
                            present(CHILD_ID, S_RGBW_LIGHT, SN, true);
                            // Process incoming messages (like config and light state from controller) - basically keep the mysensors protocol running
                          //  process();
                            // and set the new light colors
                            if (millis() > lastupdate + INTERVAL) {
                              updateLights();
                          // callback function for incoming messages
                            Serial.print("Got a message - ");
                            Serial.print("Messagetype is: ");
                            Serial.println(message.type);
                            // acknoledgment
                            if (message.isAck())
                             	Serial.println("Got ack from gateway");
                            // new dim level
                            else if (message.type == V_DIMMER) {
                                Serial.println("Dimming to ");
                                target_dimming = message.getByte();
                                // a new dimmer value also means on, no seperate signal gets send (by domoticz)
                              isOn = true;
                            // on / off message
                            else if (message.type == V_STATUS) {
                              Serial.print("Turning light ");
                              isOn = message.getInt();
                              if (isOn) {
                                Serial.println("on");
                                Serial.println("off");
                            // new color value
                            else if (message.type == V_RGBW) {
                              const char * rgbvalues = message.getString();
                              inputToRGBW(rgbvalues);
                              // a new color also means on, no seperate signal gets send (by domoticz); needed e.g. for groups
                              isOn = true;
                          // this gets called every INTERVAL milliseconds and updates the current pwm levels for all colors
                          void updateLights() {
                            // update pin values -debug
                            //Serial.println(greenval);
                            //Serial.println(redval);
                            //Serial.println(blueval);
                            //Serial.println(whiteval);
                            //Serial.println(target_greenval);
                            //Serial.println(target_redval);
                            //Serial.println(target_blueval);
                            //Serial.println(target_whiteval);
                            //Serial.println("+++++++++++++++");
                            // for each color
                            for (int v = 0; v < NUM_CHANNELS; v++) {
                              if (values[v] < target_values[v]) {
                                values[v] += STEP;
                                if (values[v] > target_values[v]) {
                                  values[v] = target_values[v];
                                values[v] -= STEP;
                            // dimming
                            if (dimming < target_dimming) {
                              dimming += STEP;
                              if (dimming > target_dimming) {
                                dimming = target_dimming;
                              dimming -= STEP;
                            // debug - new values
                            // set actual pin values
                              if (isOn) {
                                // normal fading
                          // converts incoming color string to actual (int) values
                          // ATTENTION this currently does nearly no checks, so the format needs to be exactly like domoticz sends the strings
                          void inputToRGBW(const char * input) {
                            Serial.print("Got color value of length: ");
                            Serial.println(strlen(input));
                            if (strlen(input) == 6) {
                              Serial.println("new rgb value");
                              target_values[0] = fromhex (& input [0]);
                              target_values[1] = fromhex (& input [2]);
                              target_values[2] = fromhex (& input [4]);
                              target_values[3] = 0;
                            } else if (strlen(input) == 9) {
                              Serial.println("new rgbw value");
                              target_values[0] = fromhex (& input [1]); // ignore # as first sign
                              target_values[1] = fromhex (& input [3]);
                              target_values[2] = fromhex (& input [5]);
                              target_values[3] = fromhex (& input [7]);
                              Serial.println("Wrong length of input");
                            Serial.print("New color values: ");
                            Serial.println(input);
                              Serial.print(target_values[i]);
                              Serial.print(", ");
                            Serial.println("");
                            Serial.print("Dimming: ");
                            Serial.println(dimming);
                          // converts hex char to byte
                          byte fromhex (const char * str)
                            char c = str [0] - '0';
                            if (c > 9)
                              c -= 7;
                            int result = c;
                            c = str [1] - '0';
                            if (c > 9)
                              c -= 7;
                            return (result << 4) | c;
                            @Jan-Gatzke
                            Sure, no problem.
                            TODO
                            #define SV   "1.0"
                            #define RED_PIN 3
                            #define WHITE_PIN 9
                            #define GREEN_PIN 5
                            #define BLUE_PIN 6
                            #define CHILD_ID 1
                            #define STEP 1
                            #define INTERVAL 10
                            byte dimming = 100;
                              // set up dimming
                              // init lights
                              updateLights();
                              // debug
                              if (isOn) {
                            //  process();
                                updateLights();
                              // acknoledgment
                              // new dim level
                                isOn = true;
                              // on / off message
                                if (isOn) {
                              // new color value
                                isOn = true;
                              // for each color
                                  values[v] += STEP;
                                  values[v] -= STEP;
                              // dimming
                                dimming += STEP;
                                dimming -= STEP;
                                if (isOn) {
                                  // normal fading
                                Serial.print(", ");
                              Serial.println("");
                              if (c > 9)
                                c -= 7;
                              int result = c;
                              c = str [1] - '0';
                              if (c > 9)
                                c -= 7;
                            J
                            J
                            Jan Gatzke
                            @peerkersezuuker
                            If I find the time, I will clean it up. I want to have a look at the non linear fading. IMHO the initial settings need to be customized, too. Instead of switching the white LEDs on the node could request the values from the controller (if possible) or from eeprom.
                            • J
                              J
                              Jan Gatzke
                              wrote on last edited by Jan Gatzke
                              #25
                              As promised I had a look at the sketch. The node can now save and restore values for rgbw, dimming and status to/from the controller. I had a look at the non linear fading, too. I got it partially working and refreshed my math knowledge a lot. :)
                              In the end I removed the code for it because it made the sketch much more complicated and I didn't like the results. The formula from the original sketch was ok for fading a single LED from 0% to 100%. It didn't cover other starting values and the combination of the colors. IMHO only the dimming can be done non linear without problems. For this I would use a static table of PWM values and percent values. Doing the log calculations on the pro mini seems to be too slow for a smooth fading. I saw massive flickering.
                              Here is the sketch:
                                Version 1.1 - Added save/restore of values to/from controller, removed non linear fading code
                              #define SV   "1.1"
                              //Uncomment to enable repeater mode
                              //#define MY_REPEATER_FEATURE
                              //Uncomment to assign static node ID
                              //#define MY_NODE_ID 9
                              #define RED_PIN 3
                              #define WHITE_PIN 9
                              #define GREEN_PIN 5
                              #define BLUE_PIN 6
                              #define CHILD_ID 1
                              #define STEP 1
                              #define INTERVAL 10
                              MyMessage lastvalueMsg(CHILD_ID, V_VAR1);
                              MyMessage lastisonMsg(CHILD_ID, V_VAR2);
                              MyMessage lastdimmMsg(CHILD_ID, V_VAR3);
                              byte values[4] = {0, 0, 0, 0};
                              byte target_values[4] = {0, 0, 0, 0};
                              byte dimming = 100;
                              boolean isOn = false;
                              // tracks if the strip's last status was off. This overrides isOn at startup
                              boolean wasOff = true;
                              //tracks if the old values have bben requested from the controller. This prevents the request from being send multipßle times in the main loop.
                              boolean valuesrequested = false;
                                // debug
                                if (isOn) {
                                if (!valuesrequested) {
                                  Serial.println("Requesting old values...");
                                  //Request RGBW values
                                  request( CHILD_ID, V_VAR1 );
                                  wait(200);
                                  //Request Status
                                  request( CHILD_ID, V_VAR2 );
                                  wait(200);
                                  //Request dimm level
                                  request( CHILD_ID, V_VAR3 );
                                  valuesrequested = true;
                                // set the new light colors
                                  updateLights();
                                // acknoledgment
                                // new dim level
                                else if (message.type == V_DIMMER or message.type == V_VAR3) {
                                  send(lastdimmMsg.set(target_dimming));
                                  if (!wasOff) {
                                    isOn = true;
                                    send(lastisonMsg.set(isOn));
                                // on / off message
                                else if (message.type == V_STATUS or message.type == V_VAR2) {
                                  if (isOn) {
                                    wasOff = false;
                                // new color value
                                else if (message.type == V_RGBW or message.type == V_VAR1) {
                                  send(lastvalueMsg.set(rgbvalues));
                                  if (!wasOff) {
                                    isOn = true;
                                // for each color
                                    values[v] += STEP;
                                    values[v] -= STEP;
                                // dimming
                                  dimming += STEP;
                                  dimming -= STEP;
                                  if (isOn) {
                                    // normal fading
                                  Serial.print(", ");
                                Serial.println("");
                                if (c > 9)
                                  c -= 7;
                                int result = c;
                                c = str [1] - '0';
                                if (c > 9)
                                  c -= 7;
                              • L
                                L
                                LastSamurai
                                @Jan-Gatzke Good job! I have a working 2.0 Version but it lacks your new features. I will take the time and add yours to the code in my git repo :)
                                • L LastSamurai
                                  J
                                  J
                                  Jan Gatzke
                                  @LastSamurai
                                  Thx. Those new features, however, are kind of a workaround. It would have been better if the node could request the V_RGBW value directly. MySensors supports this, but domoticz doesn't seem to. I have testet this and domoticz always returned "0" as value. And because you and me are both using domoticz, I decided to implement this feature using V_VAR1-3.
                                  I am still thinking about the fading. I think we could get better colors if we could compensate the non linear dimming of the LEDs. With the actual sketch colors composed of mid range values could be wrong because every PWM value above 150 or so looks like almost full power. So 00AAFF almost looks like 00FFFF. AA has a value of 170 where FF is 255. This should make a big difference.
                                  AWIA 1 Reply Last reply
                                  • J
                                    J
                                    Jan Gatzke
                                    I have tried to get some kind of non linear fading by calculating the values for 256 steps using Excel and putting them in an array. The result is pretty good. Please test and share your opinion. ;)
                                    #define SV   "1.1"
                                    #define RED_PIN 3
                                    #define WHITE_PIN 9
                                    #define GREEN_PIN 5
                                    #define BLUE_PIN 6
                                    #define CHILD_ID 1
                                    #define STEP 1
                                    #define INTERVAL 10
                                    //Stores corrected values for each step from 0 to 255. See https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
                                    byte converted_values[256] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,3,3,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,5,5,5,5,5,5,5,5,6,6,6,6,6,6,7,7,7,7,7,7,8,8,8,8,8,9,9,9,9,9,10,10,10,10,11,11,11,11,12,12,12,13,13,13,13,14,14,14,15,15,15,16,16,17,17,17,18,18,19,19,20,20,20,21,21,22,22,23,23,24,24,25,26,26,27,27,28,29,29,30,31,31,32,33,34,34,35,36,37,38,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,54,55,56,57,58,60,61,62,64,65,67,68,70,71,73,75,76,78,80,81,83,85,87,89,91,93,95,97,99,101,104,106,108,111,113,116,118,121,123,126,129,132,135,138,141,144,147,150,154,157,161,164,168,171,175,179,183,187,191,195,200,204,209,213,218,223,228,233,238,243,249,255};
                                    byte dimming = 100;
                                      // debug
                                      if (isOn) {
                                        wait(200);
                                        //Request Status
                                        wait(200);
                                        updateLights();
                                      // acknoledgment
                                      // new dim level
                                        if (!wasOff) {
                                          isOn = true;
                                      // on / off message
                                        if (isOn) {
                                          wasOff = false;
                                      // new color value
                                        if (!wasOff) {
                                          isOn = true;
                                      int convertedvalue=0;
                                      // for each color
                                          values[v] += STEP;
                                          values[v] -= STEP;
                                      // dimming
                                        dimming += STEP;
                                        dimming -= STEP;
                                        if (isOn) {
                                          // normal fading
                                          //Fading with corrected values see https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
                                          analogWrite(channels[i], dimming / 100.0 * converted_values[values[i]]);
                                        Serial.print(", ");
                                      Serial.println("");
                                      if (c > 9)
                                        c -= 7;
                                      int result = c;
                                      c = str [1] - '0';
                                      if (c > 9)
                                        c -= 7;
                                    AWIA L 2 Replies Last reply
                                    • J Jan Gatzke
                                      @LastSamurai
                                      AWIA
                                      AWIA
                                      AWI
                                      wrote on last edited by AWI
                                      #29
                                      @Jan-Gatzke for Domoticz you can use V_TEXT. You can request a value and manipulate it in Lua. Also Domoticz is terrible with rgb as it only allows saturated colors.
                                      • J Jan Gatzke
                                        #define SV   "1.1"
                                        #define RED_PIN 3
                                        #define WHITE_PIN 9
                                        #define GREEN_PIN 5
                                        #define BLUE_PIN 6
                                        #define CHILD_ID 1
                                        #define STEP 1
                                        #define INTERVAL 10
                                        byte dimming = 100;
                                          // debug
                                          if (isOn) {
                                            wait(200);
                                            //Request Status
                                            wait(200);
                                            updateLights();
                                          // acknoledgment
                                          // new dim level
                                            if (!wasOff) {
                                              isOn = true;
                                          // on / off message
                                            if (isOn) {
                                              wasOff = false;
                                          // new color value
                                            if (!wasOff) {
                                              isOn = true;
                                          // for each color
                                              values[v] += STEP;
                                              values[v] -= STEP;
                                          // dimming
                                            dimming += STEP;
                                            dimming -= STEP;
                                            if (isOn) {
                                              // normal fading
                                            Serial.print(", ");
                                          Serial.println("");
                                          if (c > 9)
                                            c -= 7;
                                          int result = c;
                                          c = str [1] - '0';
                                          if (c > 9)
                                            c -= 7;
                                        AWIA
                                        AWIA
                                        AWI
                                        @Jan-Gatzke the FastLED library allows for very fast math with color values. Also some very educational stuff for color manipulation in the code and documentation.
                                        • AWIA AWI
                                          J
                                          J
                                          Jan Gatzke
                                          @AWI
                                          Thx for the info. This comes 24 hours to late. :joy:
                                          12.5k
