  3. Home Assistant
  4. MQTT raspberry pi gateway with HA, can't seem to find sensors.
22 Posts 2 Posters 7.9k Views 2 Watching
  • kostaaK
    kostaaK
    kostaa
    After enabling debug logging for mysensors.mysensors I see that I get MQTT publishes from the gateway , but when I login into HA I can't see the sensors.
    Here is the log from HA.
    16-12-28 03:32:00 mysensors.mysensors: Receiving 1;4;0;0;7;
    16-12-28 03:32:00 mysensors.mysensors: Node 1 is unknown
    16-12-28 03:32:00 mysensors.mysensors: Requesting new presentation for node 1
    16-12-28 03:32:00 mysensors.mysensors: Node 1 is unknown, will not add child 4.
    16-12-28 03:32:00 mysensors.mysensors: Publishing 1;255;3;0;19;
    16-12-28 03:32:08 mysensors.mysensors: Receiving 1;255;3;0;12;1.0
    16-12-28 03:32:08 mysensors.mysensors: Node 1 is unknown
    16-12-28 03:32:08 mysensors.mysensors: Requesting new presentation for node 1
    16-12-28 03:32:08 mysensors.mysensors: Publishing 1;255;3;0;19;
    16-12-28 03:32:08 mysensors.mysensors: Receiving 1;255;0;0;17;2.0.0
    16-12-28 03:32:10 mysensors.mysensors: Receiving 1;255;3;0;11;Soil Moisture Sensor Reve
    16-12-28 03:32:10 mysensors.mysensors: Receiving 1;4;0;0;7;
    16-12-28 03:32:10 mysensors.mysensors: Subscribing to: mysensors-out/1/4/1/+/+
    16-12-28 03:32:10 mysensors.mysensors: Subscribing to: mysensors-out/1/4/2/+/+
    16-12-28 03:32:10 mysensors.mysensors: Subscribing to: mysensors-out/1/+/4/+/+
    16-12-28 03:32:16 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:32:16 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:32:18 mysensors.mysensors: Receiving 1;4;1;0;37;5
    16-12-28 03:32:23 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:32:23 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:32:25 mysensors.mysensors: Receiving 1;4;1;0;37;10
    16-12-28 03:32:31 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:32:31 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:32:33 mysensors.mysensors: Receiving 1;4;1;0;37;7
    16-12-28 03:32:39 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:32:39 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:32:41 mysensors.mysensors: Receiving 1;4;1;0;37;3
    16-12-28 03:32:46 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:32:46 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:32:54 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:02 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:33:02 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:04 mysensors.mysensors: Receiving 1;4;1;0;37;9
    16-12-28 03:33:09 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:33:09 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:11 mysensors.mysensors: Receiving 1;4;1;0;37;8
    16-12-28 03:33:17 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:33:17 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:19 mysensors.mysensors: Receiving 1;4;1;0;37;10
    16-12-28 03:33:24 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:33:24 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:26 mysensors.mysensors: Receiving 1;4;1;0;37;-5
    16-12-28 03:33:32 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:40 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:33:40 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:47 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:33:47 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:55 mysensors.mysensors: Receiving 1;4;1;0;37;1
    16-12-28 03:33:55 mysensors.mysensors: Receiving 1;4;2;0;2;
    16-12-28 03:33:57 mysensors.mysensors: Receiving 1;4;1;0;37;14
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Hi!
      Please also enable debug logging for the mysensors component in home assistant and post mysensors and mqtt related lines after home assistant start.
      kostaaK 1 Reply Last reply
      • kostaaK
        kostaaK
        kostaa
        Config directory: /home/pi/.homeassistant
        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=reload_core_config, domain=homeassistant>
        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=create, domain=persistent_notification>
        INFO:homeassistant.bootstrap:Home Assistant core initialized
        INFO:homeassistant.loader:Loaded history from homeassistant.components.history
        INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
        INFO:homeassistant.loader:Loaded http from homeassistant.components.http
        INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
        INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
        INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
        INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
        INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
        INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
        INFO:homeassistant.loader:Loaded mqtt from homeassistant.components.mqtt
        INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
        INFO:homeassistant.loader:Loaded api from homeassistant.components.api
        INFO:homeassistant.loader:Loaded websocket_api from homeassistant.components.websocket_api
        INFO:homeassistant.loader:Loaded tts from homeassistant.components.tts
        INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
        INFO:homeassistant.loader:Loaded logger from homeassistant.components.logger
        INFO:homeassistant.bootstrap:Setting up recorder
        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
        INFO:homeassistant.bootstrap:Setting up logger
        DEBUG:mysensors.mysensors:Subscribing to: mysensors-out/1/4/1/+/+
        DEBUG:mysensors.mysensors:Subscribing to: mysensors-out/1/4/2/+/+
        DEBUG:mysensors.mysensors:Subscribing to: mysensors-out/1/+/4/+/+
        INFO:mysensors.mysensors:Setting up initial MQTT topic subscription
        DEBUG:mysensors.mysensors:Subscribing to: mysensors-out/+/+/0/+/+
        DEBUG:mysensors.mysensors:Subscribing to: mysensors-out/+/+/3/+/+
        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;1
        DEBUG:mysensors.mysensors:Receiving 1;4;2;0;2;
        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;5
        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;0
          Hi!
          kostaaK
          kostaaK
          kostaa
          This is my logger config
          logger:
          default: critical
          logs:
          mysensors: debug
          mqtt: debug
          This is the result:
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            You need to specify full package/module path in logger component. Try this:
            logger:
              default: warning
              logs:
                homeassistant.components.mqtt: info
                homeassistant.components.mysensors: debug
                mysensors.mysensors: debug
            mysensors:
              debug: true
            • kostaaK
              kostaaK
              kostaa
              Thank you.
              DEBUG:homeassistant.components.mysensors:Update persistence: node 1
              DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;10
              DEBUG:homeassistant.components.mysensors:Update sensor_update: node 1
              • martinhjelmareM
                martinhjelmareM
                martinhjelmare
                I'd like to see mysensors platform setup too, sorry.
                logger:
                  default: info
                  logs:
                mysensors:
                  debug: true
                • kostaaK
                  kostaaK
                  kostaa
                    logger:
                      default: info
                      logs:
                    mysensors:
                      debug: true
                    kostaaK
                    kostaaK
                    kostaa
                    wrote on last edited by kostaa
                    • martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      Please don't post sensitive information, like passwords and URL to your host. Sorry if I was not clear. You should change your password now.
                      I'd just like to see a log with default info level so I can see that all mysensors platforms are setup ok after start. Then you can also restart the arduino sensor after starting home assistant, so that we can see what happens when the sensor runs through presentation etc.
                      • kostaaK
                        kostaaK
                        kostaa
                        Thank you for the warning :)
                        DEBUG:mysensors.mysensors:Receiving 1;255;3;0;12;1.0
                        DEBUG:mysensors.mysensors:Receiving 1;4;0;0;7;
                        WARNING:mysensors.mysensors:child_id 4 already exists in children of node 1, cannot add child
                        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;15
                        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;-8
                        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;7
                        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;2
                        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;6
                        DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;-2
                        • martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          Please check that logger component has info as default level in your home assistant config, as in my latest example above. We're missing expected lines about setup after logger component is loaded.
                            kostaaK
                            kostaaK
                            kostaa
                            pi@pi3:~/.homeassistant $ hass
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logger>
                            INFO:homeassistant.bootstrap:Setting up http
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                            INFO:homeassistant.loader:Loaded tts.google from homeassistant.components.tts.google
                            INFO:homeassistant.bootstrap:Setting up tts
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=tts, service=google_say>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=tts, service=clear_cache>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=tts>
                            INFO:homeassistant.bootstrap:Setting up discovery
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                            INFO:homeassistant.bootstrap:Setting up api
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                            INFO:homeassistant.bootstrap:Setting up websocket_api
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=websocket_api>
                            INFO:homeassistant.bootstrap:Setting up frontend
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                            INFO:homeassistant.bootstrap:Setting up logbook
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=logbook, service=log>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                            INFO:homeassistant.bootstrap:Setting up conversation
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                            INFO:homeassistant.bootstrap:Setting up mysensors
                            INFO:homeassistant.bootstrap:Setting up mqtt
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=mqtt, service=publish>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mqtt>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                            INFO:homeassistant.bootstrap:Setting up updater
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                            INFO:homeassistant.loader:Loaded sensor.yr from homeassistant.components.sensor.yr
                            INFO:homeassistant.bootstrap:Setting up sensor
                            INFO:homeassistant.components.sensor:Setting up sensor.yr
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png, friendly_name=yr Symbol @ 2016-12-28T00:18:50.127080-05:00>, old_state=None, entity_id=sensor.yr_symbol>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.yr_symbol=1; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=1;content_type=image/png, friendly_name=yr Symbol @ 2016-12-28T00:18:51.077805-05:00>, old_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png, friendly_name=yr Symbol @ 2016-12-28T00:18:50.127080-05:00>, entity_id=sensor.yr_symbol>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                            INFO:homeassistant.bootstrap:Setting up history
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                            INFO:homeassistant.bootstrap:Setting up sun
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; friendly_name=Sun, azimuth=0, next_setting=2016-12-28T22:35:27+00:00, elevation=0, next_rising=2016-12-28T12:41:37+00:00 @ 2016-12-28T00:18:51.192205-05:00>, old_state=None, entity_id=sun.sun>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: platform=mysensors, service=load_platform.sensor, discovered=>
                            INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                            INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                            INFO:homeassistant.bootstrap:Setting up switch
                            INFO:homeassistant.components.sensor:Setting up sensor.mysensors
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=toggle>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: platform=mysensors, service=load_platform.switch, discovered=>
                            INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                            INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                            INFO:homeassistant.bootstrap:Setting up light
                            INFO:homeassistant.components.switch:Setting up switch.mysensors
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=mysensors_send_ir_code>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=toggle>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: platform=mysensors, service=load_platform.light, discovered=>
                            INFO:homeassistant.loader:Loaded binary_sensor from homeassistant.components.binary_sensor
                            INFO:homeassistant.loader:Loaded light.mysensors from homeassistant.components.light.mysensors
                            INFO:homeassistant.bootstrap:Setting up binary_sensor
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=binary_sensor>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: platform=mysensors, service=load_platform.binary_sensor, discovered=>
                            INFO:homeassistant.loader:Loaded climate from homeassistant.components.climate
                            INFO:homeassistant.components.light:Setting up light.mysensors
                            INFO:homeassistant.loader:Loaded binary_sensor.mysensors from homeassistant.components.binary_sensor.mysensors
                            INFO:homeassistant.bootstrap:Setting up climate
                            INFO:homeassistant.components.binary_sensor:Setting up binary_sensor.mysensors
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=climate, service=set_away_mode>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=climate, service=set_aux_heat>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=climate, service=set_temperature>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=climate, service=set_humidity>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=climate, service=set_fan_mode>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=climate, service=set_operation_mode>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=climate, service=set_swing_mode>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=climate>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: platform=mysensors, service=load_platform.climate, discovered=>
                            INFO:homeassistant.loader:Loaded cover from homeassistant.components.cover
                            INFO:homeassistant.loader:Loaded climate.mysensors from homeassistant.components.climate.mysensors
                            INFO:homeassistant.bootstrap:Setting up cover
                            INFO:homeassistant.components.climate:Setting up climate.mysensors
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=set_cover_position>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=close_cover>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=open_cover_tilt>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=set_cover_tilt_position>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=stop_cover_tilt>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=close_cover_tilt>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=open_cover>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=cover, service=stop_cover>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=cover>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: platform=mysensors, service=load_platform.cover, discovered=>
                            INFO:homeassistant.loader:Loaded cover.mysensors from homeassistant.components.cover.mysensors
                            INFO:homeassistant.components.cover:Setting up cover.mysensors
                            INFO:homeassistant.core:Starting Home Assistant core loop
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
                            INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                            INFO:homeassistant.core:Timer:starting
                            INFO:homeassistant.core:Bus:Handling <Event mqtt_message_received[L]: payload=4, qos=0, topic=mysensors-out/1/4/1/0/37>
                            DEBUG:mysensors.mysensors:Receiving 1;4;1;0;37;4
                            INFO:netdisco.service:Scanning
                            INFO:homeassistant.components.http:Serving /api/websocket to 192.168.1.1 (auth: False)
                            INFO:homeassistant.components.http:Serving /api/bootstrap to 192.168.1.1 (auth: True)
                            INFO:homeassistant.core:Bus:Handling <Event mqtt_message_received[L]: payload=, qos=0, topic=mysensors-out/1/4/0/0/7>
                            INFO:homeassistant.core:Bus:Handling <Event mqtt_message_received[L]: payload=, qos=0, topic=mysensors-out/1/4/2/0/2>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; friendly_name=Sun, azimuth=338.22, next_setting=2016-12-28T22:35:27+00:00, elevation=-78.36, next_rising=2016-12-28T12:41:37+00:00 @ 2016-12-28T00:18:51.192205-05:00>, old_state=<state sun.sun=below_horizon; friendly_name=Sun, azimuth=0, next_setting=2016-12-28T22:35:27+00:00, elevation=0, next_rising=2016-12-28T12:41:37+00:00 @ 2016-12-28T00:18:51.192205-05:00>, entity_id=sun.sun>
                            INFO:homeassistant.core:Bus:Handling <Event mqtt_message_received[L]: payload=0, qos=0, topic=mysensors-out/1/4/1/0/37>
                            INFO:homeassistant.core:Bus:Handling <Event mqtt_message_received[L]: payload=1, qos=0, topic=mysensors-out/1/4/1/0/37>
                            INFO:homeassistant.core:Bus:Handling <Event mqtt_message_received[L]: payload=0, qos=0, topic=mysensors-out/1/255/3/0/21>
                            DEBUG:mysensors.mysensors:Receiving 1;255;3;0;21;0
                            • martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              I think I see a problem with your sensor value type that is used. You have presented a humidity sensor (7), but you report with a level type (37). You should use subtype 1 when setting the value of the humidity child sensor. Sorry for not noticing this from the beginning.
                              Home assistant is picky about child/value combinations. You can see allowed types in the docs for mysensors at home-assistant.io.
                              Specifically here:
                              https://home-assistant.io/components/sensor.mysensors/
                              • kostaaK
                                kostaaK
                                kostaa
                                Thank you so much, and I am sorry I am a complete noob at this, where is the level type and subtype set? I searched on this page
                                and found very little.
                                https://home-assistant.io/components/mysensors/
                                • martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  See this:
                                  And also this:
                                  https://www.mysensors.org/download/serial_api_20
                                  Usually you decide in the beginning of your sensor sketch what message type you will use when reporting values. Alternatively this can be done dynamically before sending the value. Look at the example sketch for humidity sensor here:
                                  https://www.mysensors.org/build/humidity
                                    See this:
                                    And also this:
                                    kostaaK
                                    kostaaK
                                    kostaa
                                    @martinhjelmare
                                    Thank you!
                                    Ok so in the beginning of the default sketch in here:
                                    https://www.mysensors.org/build/moisture
                                    The line :
                                    MyMessage msg(CHILD_ID, V_LEVEL);
                                    Is the problem
                                    It should be:
                                    MyMessage msg(CHILD_ID, V_HUM);
                                    You were absolutely right.
                                    Thank you for being so quick and amazing, and if you can please ask someone to fix the example.
                                    • martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      No problem, glad to help!
                                      Actually the moisture sensor should be presented as S_MOISTURE. The message type V_LEVEL is correct for the moisture sensor. :smile:
                                        kostaaK
                                        kostaaK
                                        kostaa
                                        @martinhjelmare
                                        Then this is a problem?
                                        sendSketchInfo("Soil Moisture Sensor Reverse Polarity", "1.0");
                                        present(CHILD_ID, S_HUM);
                                        • martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          Yes, exactly. Change S_HUM to S_MOISTURE.
                                          kostaaK 2 Replies Last reply
                                          12.5k
