  3. 💬 ESP-LINK ESP8266 WeMos D1 Mini Adapter Board
arduinoadapterwemosesp8266pro miniinterstitialesp-linkd1miniserial wi-fi
83 Posts 9 Posters 47.8k Views 6 Watching
    I notice Seeed Studio was selling the esp32 for $6.95, but it's presently backordered: https://www.seeedstudio.com/ESP-32S-Wifi-Bluetooth-Combo-Module-p-2706.html
    Other seller are selling either the esp32 or the esp32 with an adapter board for 2-3x that amount. So, it's still early days until supply catches up with demand.
    A few other things impress me about it:
    1. it comes with Bluetooth Low Eenrgy,
    2. 520kByte of SRAM.
    3. Built in hardware support for 10 capacitive touch channels.
    4. Apparently it comes with an RTC built-in
    5. 240Mhz processor clock frequency
    6. Two 10-bit DAC's. Quite a few 12-bit ADC's.
    Sounds interesting!
    Which of the esp32 boards is the best one to buy? What I like about the Wemos board for the ESP8266 is that I can download a sketch without having to press any buttons on the board itself. Is there an esp32 board that works like that also?
      #71
      yeah, it has nice specs ;)
      which board to order ? Mine :stuck_out_tongue_winking_eye:
      I'm kidding, I don't really have idea on this. I made mine..and am waiting for different pcb variant now :)
      But I firstly ordered a Nano32 which I like. You can have pinheader on each side of the board when breadboarding. You can't with the official Espressif board which is too large.
      There is lot of esp32 board released. But all have the first ic revision of course.
      • scalzS scalz
        Uh, "first ic revision"? I haven't followed esp32 at all, obviously. Was there later a second ic revision? i.e. are all the boards currently out there saddled with obsolete ic's?
          yes Espressif has released an Errata doc, some issues related to silicon die ic. Minor issue, depending of doing what with it.
          I read the fixed version should be available at beginning of next year.
          • scalzS scalz
            @scalz
            Thanks! , I see that the next revision of the silicon is scheduled for February 2017: http://esp32.de/eco_and_workarounds_for_bugs_in_esp32_en.pdf
            I'm in no rush. I'll wait until it's deemed ready for prime-time.
              I've tested the board, and it works fine.
                I added some photos of the lateset board version.
                This project is now finished. :smile:
                  In case anyone is interested, I received my D1 Mini's directly from Wemos, and they are now marked directly on them as version 2.1.0:
                  fetsF 1 Reply Last reply
                    fetsF
                    fetsF
                    fets
                    @NeverDie did you opened a dispute regarding your false wemos D1 V2 on aliexpress cause I have the same situation with the same seller.
                    Did you solve the issue ?
                    Nca78N 1 Reply Last reply
                      #79
                      No. I've had more important things to do that took precedence. I think the lesson is: buy only direct from Wemos.
                      • fetsF fets
                        @fets it's easy to win the dispute in this case. Make side by side pictures of the board you received and the real wemos as advertised by the seller with title "real wemos" / "received from [seller name]" and put some big red arrows to point the differences.
                        In the text explain the differences and insist on cheaper esp8266 version with lower antenna performance. Explain you want full refund because the price of items is not worth the time and money to send them back.
                        The best is if you can make the seller admit in private message that he is not selling genuine boards but copies. Then screen capture of conversation is your quick ticket for full refund.
                        Should take you less than 15mns.
                        Be careful about vicious sellers trying to make you cancel dispute withe empty promises, or proposal of resolution with nice comment talking about refund/resend but choice of solution in the list selected as "no resend, no refund" or "refund" with value 0$ :D
                        • Nca78N Nca78
                          fetsF
                          fetsF
                          fets
                          @Nca78 thanks, I'll try it
                          korttomaK 1 Reply Last reply
                          • fetsF fets
                            korttomaK
                            korttomaK
                            korttoma
                            Hi @All I built a GW node with local sensors without radio from a WeMos D1 mini Pro and I have one issue with it.
                            It seems like it shuts down the WiFi part if there is no communication. If I constantly ping it it will keep working but if I leave it alone for 30min it will no longer respond to ping and my controllers have lost the connection. I see from the serial debug that it is still working and processing the code related to the local "sensor" but WiFi is dead.
                            AVR Boards version 1.6.11
                            esp8266 version 2.3.0
                            MySensors Lib version 2.1.1
                            • Tomas
                            • korttomaK
                              korttomaK
                              korttoma
                              #83
                              I think I found the problem. I think it misbehaved because of an illegal character in the "HOSTNAME". Changed the hostname yesterday and It was still alive this morning even if I have not pinged it.
                              • Tomas
