  3. Vera
  4. Energy meter not updating watts.
17 Posts 4 Posters 8.2k Views 1 Watching
  • I
    I
    integlikewhoa
    Well I found out meter will read the kW in 2 decimal points. It was reading around 4.3kW with the ac running. Reading the serial seeing what it was outputting vs what the meter was reading I started adjusting the sketch then uploading then reseting the sensor and re reading the serial. I got it reading about spot on with 105000 flash per KWH.
    The. I shut off the AC kW reading on Meter went down to around 1.3 ish but the serial was showing 3,011 watts or something. So it didn't change in perportion. I do know the flashes slowed down but didn't recount yet to see just how much. Maybe 1 flash ever 2 seconds now. It definitely didn't cut it into quarters from 4kw to 1kw.
    • korttomaK
      korttomaK
      korttoma
      nice to see you have worked out some of your issues.
      Seems to be tricky to get a pulse from the ITRON usually it says like 1000 imp/kwh or something similar beside the led on the meter and this should be pretty accurate.
      • Tomas
      I 1 Reply Last reply
      • korttomaK korttoma
        I
        I
        integlikewhoa
        @korttoma it sure doesn't seem like if fixed much.
        I'll include some pictures but I don't see anything anywhere on the meter that might give an indication of the pulses. And def. nothing around the IR. I'm also confused now how even when I got it reading right at higher usage. It didn't drop down much after I cut the usage and was still given a high reading.
        • JohnJ
          JohnJ
          John
          wrote on last edited by John
          It looks like the calculation is off in the example sketch:
          Your meter is providing Kh, which renders the below calculation wrong (I think)
          watt = (3600000000.0 /interval) / ppwh;
          Your calculation should be
          watt = (3600000000.0 * ppwh) / interval;
          3600 (one hour) times the unit (1.0 Kh) devided by the time between two blinks.
          I could be wrong though because it is quick plain from the head.
          • JohnJ John
            I
            I
            integlikewhoa
            @John so I'm a bit lost (not surprised) at your formula. Can you throw some numbers in your new formula based on my information above (or fictitious numbers for an example) and give me an idea of what it should look like.
            • JohnJ
              JohnJ
              John
              @integlikewhoa
              Ok, let's say there are 4 seconds between each pulse, you would then have a formula like:
              (3600 * 1.0) / 4 = 900 WATT
              An example if a blink takes 0.91 seconds
              (3600 * 1.0) / 0.91 = 3956 WATT
              But like i said, i could be wrong ;)
              • JohnJ John
                @integlikewhoa
                I
                I
                integlikewhoa
                Well i put the Pulse count back to 1000 then I changed the formula above and now I'm getting some wierd up and down readings even tho the meter was fairly stable during this time.
                sensor started, id 2
                send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=3,st=ok:1.4
                send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                read: 0-0-2 s=255,c=3,t=6,pt=0,l=2:I
                send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Energy Meter
                send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                send: 2-2-0-0 s=1,c=0,t=13,pt=0,l=3,st=ok:1.4
                send: 2-2-0-0 s=1,c=2,t=24,pt=0,l=3,st=ok:1.4
                read: 0-0-2 s=1,c=1,t=24,pt=0,l=6:81287
                Received last pulse count from gw:81287
                Watt:3609
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81316
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.3160
                Watt:268656
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81351
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.3510
                Watt:264861
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81389
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.3890
                Watt:272975
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81415
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.4150
                Watt:141464
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81421
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.4210
                Watt:10582
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81448
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.4480
                Watt:12944
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81471
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.4710
                Watt:7069
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81473
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.4740
                Watt:1215
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81479
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.4790
                Watt:21161
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81510
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.5100
                Watt:5983
                send: 2-2-0-0 s=1,c=1,t=24,pt=5,l=4,st=ok:81529
                send: 2-2-0-0 s=1,c=1,t=18,pt=7,l=5,st=ok:81.5290
                • I
                  I
                  integlikewhoa
                  i'm so lost on this. I can read the screen on the meter. I got my meter holding down to around 1.31kW according to the meter read out. I set the timer for a minute and counted the flashes on the LM393 LED. It flashed around 26 times in that min. So 60 min in an hour that's 1,560 flashes per around 1.31kWh..
                  Next I kicked on the AC and let the Kw reading on the meter level out around 3.10kW and then I set the timer and counted 54 pulses per min. x 60 for 3,240 per hour.
                  Everything looks per proportional and right along with what I found on the internet for this meter.
                  1,000 blinks per kWh.
                  Using the factory settings should put me right there is what I keep thinking. But that gets me showing 300,000 watts
                  using your above formula and pulses still at 1000 it still gets me in the 300,000 range.
                  If i change my pluse per KWh to 100,000 then it gets me into the right area at 3000 watts when my ac is on which is in the ball park but if I turn the AC off and kW drop to 1.3 ish
                  The serial is still showing 3,000 range in watts it wont drop to the 1,000 so watts it should be.
                  • I
                    I
                    integlikewhoa
                    Hoping can jump in and shed some new light on this. BUMP!
                      http://efundies.com/electricity/how_to_read_power_meter.htm
                        I
                        I
                        integlikewhoa
                        Thanks for that info, it seems to only confirms that the meter is working right and that my problem is in the sktech. LOL
                        I really need help finding out why the example sketch with the "1000 blinks per kWh" set doesn't work anywhere close to where it should be.
                        I'm using the example sketch and my meter has 1.0kH tag on the front.
