  3. Why don't you write mysensors library for ESP8266 similar to the nRF one ?
23 Posts 11 Posters 10.2k Views 10 Watching
    Use the ESP Gateway sketch.
    Remove the NRF-radio define. Present your sensors and start sending data like in any other example.
    • jopebeJ
      jopebeJ
      jopebe
      Thanks for the short instruction.
      But Im afraid it is too short for me. Nothing else to change in the sketch? Do I realy need a ssid and a password? Im just a beginner and found no further information.
      I`m sorry:
        Yes, you need SSID/Password to connect to your local WLAN.
          Toyman
          wrote on last edited by Toyman
          @hek
          Can you elaborate on this a bit more? I have a "standard" mysensors setup with various nrf24-based nodes and a serial gw.
          How can I add an esp8266 node to this setup? I understand that I need to use the sketch and present the sensors as usual.
          But how the existing serial gw is going to "hear" the ESP node?
          Or I need an Ethernet GW to be able to add esp node?
            How to add another (esp) gateway depends on the controller you're using. It will not join your current serial gateway.
              Toyman
              @hek Domoticz
              • T Toyman
                @hek Domoticz
                @Toyman you add the new gateway just like you added your first. In Setup->Hardware. Just select ethernet or mqtt (depending on which variant you decide to run on your esp) instead of USB.
                • T
                  Toyman
                  Got it, thx. Just to clarify: if I want eg 5 x esp8266 nodes, do I need to add them as 5 gateways, or I add one as a a gateway and other 4 connect to it?
                  korttomaK 1 Reply Last reply
                  • T Toyman
                    korttomaK
                    korttomaK
                    korttoma
                    @Toyman
                    Yes, you add them as 5 gateways.
                    • Tomas
                    • antlombA
                      antlombA
                      antlomb
                      @korttoma said:
                      as 5 gateways.
                      Hello everybody, sorry to step in and to resume an hold thread, but I was reading it and I'm not sure if the initial question was answered, so I will try to rephrase that adding my contribution.
                      Rf nodes communicate between them using a mesh network and using the best route between them to send messages. Now, I suppose the question was: can I create a node using Wifi transport and not RF ? Of course using ESP8266 and not Arduino+RF.
                      Ok, it's clear the ESP can be used as a gateway, and it's also clear we can add sensors to that gateway. But I imagine this is not the solution. Gateways rely on the Access Point they connect to (SSID and PW). If the AP is momentary not available, sensors will go offline. And Wifi connection to AP usually drops, so that's not a rulable solutions to implement nodes.
                      I'm evaluating a similar solution: creating a mess network of sensors using ESP8266. I've looked around the web, and found that a few works are going on on mesh network using the ESP, but none are a definite solution. Expressif has published a a Mesh SDK, (https://espressif.com/sites/default/files/documentation/30a-esp8266_mesh_user_guide_en.pdf), but it doesn't seem to address completely the problem, or by the way could not find sample installations. Another library (https://github.com/Coopdis/easyMesh) has been developed, but development seems now stopped, and the main problem is that each ESP in the mesh publish his different SSID, while a single SSID for all the mesh would be desirable.
                      All that said, I would like to understand if you're going to investigate using the ESP8266 as a node (not a gateway). That would probably require using a low-level network communication between ESP, but I'm not a network expert, so can't really say.
                      It would be really interesting. It would allow to create a complete mesh network of sensors/actuators using only ESP
                      Thanks for attention.
                      Antonio
                      • antlombA antlomb
                        @korttoma said:
                        as 5 gateways.
                        Antonio
                        Toyman
                        @antlomb
                        My personal opinion: when inititial euforia about ESP8266 has ended, people started to realize that the chip is actually not that reliable for solid tasks like home automation.
                        Besides, it has huge problems with deep sleep and even if they are fixed, the module reboots on every wake-up consuming a lot on start up
