  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 144.4k Views 5 Watching
  • A
    Arielpod
    wrote on last edited by Arielpod
    #68
    I'm not quite sure what you meant by "clean installation" but I just removed the directory of the previous installation and downloaded the one you've given the link to. Every time I connect the device I get an error:
    • JohnJ
      JohnJ
      John
      Resolved on the build server and available in the link posted above.
      • A
        Arielpod
        Great, it's working! Thanks a lot.
        • J
          J
          jonnyfishman
          Hi, looking for some advice on connecting sensor to PiDome. Think I've followed the instructions correctly but when connecting sensor under 'Devices' I get this message 'New device: Possible new address: 1 if not occupied before adding (Restart node after assigning).' and nothing to choose.
          My custom device settings are as follows with the Arduino CHILD_ID set to 1. Is there something obvious I've missed or is S_MOTION not included yet?
          Thanks, Jon
          • JohnJ
            JohnJ
            John
            @jonnyfishman
            If you use S_MOTION in the Arduino code then the group id should be 1 and the data control should correspond with the V_ value used in the Arduino code.
            With the motion detection you can use the boolean data type (the integers 1 and 0 will be correctly handled). This will make it easier in triggers and automation rules where you can select "true" or "false" from a drop down instead of filling in the 1 or 0.
            By clicking on the "Add sensor node" you will get a popup where you can choose the device created in the device editor.
            • J
              J
              jonnyfishman
              Thanks for the reply. I have checked the settings and changed the Group ID to 1 and the Data field ID to V_TRIPPED, using the Boolean option.
              The problem I have is that when I click 'Add sensor node' I get the message 'Done (no choice of device)' and nothing is added in devices and the error log shows the following:
              10-10-2014 21:59:53 0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=1,st=fail:1
              10-10-2014 21:57:50 Trying assigning address '1' to a new node
              Thanks, Jon
              • JohnJ
                JohnJ
                John
                Do you see the device back in the "New nodes presentation" with an address when you restart the node? this would mean that the node did not got it's address assigned. I have understood from @hek that the line:
                does not say if that it has failed or succeeded.
                The system needs a Node with an address before it can be added, the reason why there is no device selection is because of the above line can not guarantee a success or a failure. So after "Add sensor node" you have to restart the node, because only then the address is known. I should change the name of the button though to "Assign address" for making it more obvious.
                • J
                  J
                  jonnyfishman
                  Awesome, that sorted it! Thanks. Think I was leaving to long a time (or to short) between restarting the node. Really enjoying the Server interface, the macros and automation rules are really powerful (just need to get some more nodes to really have a play).
                  I saw on one of your posts that battery monitoring is a to do, has that happened or is it still in the pipeline. Also is there a way to trigger an email as I don't have a SMS dongle (thinking I could do it with a sensor set as RelayActuator on a GPIO pin on the pi that would trigger a PHP mail function but there's probably a more efficient way to do it).
                  Sorry for all the questions...
                  • JohnJ
                    JohnJ
                    John
                    Sorry for the late response, had a meeting with my (hardware) development partner in crime this weekend...
                    Yes this still is in the pipeline, i think it has slipped between all the other work currently going on, as the same is with the email notification. You would help me a lot if you would make a feature request for the both above at: https://bitbucket.org/pidome/pidome-server/issues?status=new&status=open (via the create issue link). It is our main global to do list ;).
                    No problem, all questions are welcome!
                    • F
                      F
                      fogsvans
                      First of all - great work with PiDome!
                      I've been trying to create a Custom device with a color picker but I always get following message:
                      and in appLog this appears:
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #78
                        Tried to use the xbmc 13 media plugin, but after enabling it, it shows up as XBMC 12 in media plugins. Also my XBMC box tells me that a version 12 client is connecting to it.
                        Also, I noticed that it only shows "playing" state, when I'm watching a movie from local storrage. If I watch live tv, or use a streaming plugin, it seems that pidome doesn't know about it. Is this because of lack of functionality in xbmc protocol?
                        / Thomas
                        • JohnJ
                          JohnJ
                          John
                          wrote on last edited by John
                          #79
                          The above both are correct, As long as the server is an Alpha version all supplied downloads are automated this also means any test build is also supplied.
                          The color picker error is due to the fact the color picker is currently being modified to support different color schemes and color set possibilities. It was set to only accept hex parameters. This is being changed to HEX, RGB, HSB and Kelvin with color modes: HSB, HSL, CIE and RGB. So this control is currently heavily being overhauled and also in snapshot state.
                          The functionalities of XBMC 12 and 13 regarding exposed for base XBMC 12/13 functionalities are the same. It is correct that the streams and live TV are not included yet. I have created a request at: https://bitbucket.org/pidome/pidome-server/issue/133/extend-xbmc-plugin-func to extend the features. The build server does have an updated version where correct plugin usage is shown.
                          I do suggest to keep an eye on http://builder.pidome.org/view/Snapshot builds/job/PiDome Server platform snapshot build/ and report bugs/issues found not related to MySensors on https://bitbucket.org/pidome/pidome-server/issues?status=new&status=open
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @John
                            I tried the "latest" snapshot (downloaded today at 20:30 CET).
                            After starting pidome up, went to the peripherals page, I then connected the mysensors gateway (arduino nano with the default serial gateway sketch) to my raspberry. Nothing happens in pidome at all..
                            Shouldn't it popup with something about the new peripheral that was attached?
                            Regards
                            Thomas
                            JohnJ 1 Reply Last reply
                            • tbowmoT tbowmo
                              @John
                              Regards
                              Thomas
                              JohnJ
                              JohnJ
                              John
                              @Thomas-Bowman-Mørch
                              Hi Thomas, Yes it should, also security has been tightened in the server which in some cases causes the real time web interface updating to fail. Does clicking the peripheral pages again show the nano? Also is the nano a clone or the real thing?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @John
                                Yeah, did also notice that it asks for user/password when opening the PiDome admin interface now. Nice thing :)
                                Tried to reload the page, etc.but it didn't help.
                                The gateway is a clone, with a PL2303 as usb->serial gateway.. I noticed that the real nano is using a ftdi chip.
                                Does PiDome check the VID/PID of the usb device, in order to figure out what it is?
                                / Thomas
                                • tbowmoT tbowmo
                                  @John
                                  / Thomas
                                  JohnJ
                                  JohnJ
                                  John
                                  Hi Thomas, yes it does. A feature build in is that users won't have to do anything if a specific device is connected via USB. It will then give the user the possibility to choose a driver based on the vid/pid in this example usb-serial so you should get the option to set serial options.
                                  An example: When a specific RFXCOM device is supported with fixed settings and connected to usb the server will autoload everything for this device and the end-user would only have to add devices.
                                  There is an interface on it's way that when an vid/pid is not recognized the server will check what kind of usb device it is and present the possible options for this device. You can then set the appropriate driver type and this then will be stored on the server. So every time this specific device is connected you will be presented with the correct device options. Also in the future we will build a webservice which will be capable of sharing vid/pid driver types and download appropiate drivers if the user wishes to do so.
                                  To make a long story short, what vid/pid is it using so it can be added as default known?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @John
                                    Thanks John...
                                    The usb vid/pid is as follows
                                    idVendor 0x067b Prolific Technology, Inc.
                                    idProduct 0x2303 PL2303 Serial Port
                                    taken from lsusb -v
                                    / Thomas
                                    • JohnJ
                                      JohnJ
                                      John
                                      @Thomas-Bowman-Mørch It wil be included in the next build (411, current is 410). This one will be build tomorrow, let me know how the device handles.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        I patched the database in my install, by taking the sql update file you created for my device, and changing the db schema.
                                        I can now add mysensors to pidome! Yahoo! :)
                                        Next step is to get something usefull done with it
                                        / Thomas
                                        • JohnJ
                                          JohnJ
                                          John
                                          #87
                                          Good! Did you do this manual or just stopped, overwritten and restarted the server? The latter would have precedence ;). Updating happens automatically.
                                          If you did this manual make sure to execute
                                          PRAGMA user_version=4;
                                          in the SQL editor to make sure the DB is consistent with the configuration file otherwise the server will keep on trying update the database. To check the version you can run "PRAGMA user_version;" without the "=4" to see which version it currently is.
                                          Report any findings you have so i can make the plugin better!
