  3. Boiler control from MAX! Cube to Drayton Boiler via Raspberry Pi/Vera/Mysensors.
113 Posts 22 Posters 81.6k Views 24 Watching
  • T
    twisted
    I'm having a small issue, and I can't see why. I had to reload and now every time I try to load it I get the following before it terminates. This is from fresh install.
    File "main.py", line 204, in <module>
    Main()
    File "main.py", line 96, in init
    self.doLoop()
    File "main.py", line 111, in doLoop
    buttonCheckHeat("main")
    File "/home/pi/PiHeating/heatinggpio.py", line 173, in buttonCheckHeat
    MaxInterface().checkHeat(0)
    File "/home/pi/PiHeating/max.py", line 56, in checkHeat
    self.switchHeat()
    File "/home/pi/PiHeating/max.py", line 486, in switchHeat
    roomTemps = CreateUIPage().createRooms()
    File "/home/pi/PiHeating/webui.py", line 224, in createRooms
    actualTemp, roomOpen, roomMode)
    UnboundLocalError: local variable 'roomOpen' referenced before assignment
      Stuart Middleton
      That error suggests you don't have a settings file?
        Stuart Middleton
        @stephenmhall - I'm getting a lot of issues that seem to plague the MAX system (not your excellent software of course :) ) where the cube forgets the valves randomly or updating timings don't get sent to the valves. I also hate that the realtime temp isn't reported.
        With this said, I was wondering if you (or anyone else) had seen the BlueTooth version of the valves that they sell. And if so, has anyone taken a peek at the messages to see if the temp is reported? I'd rather control the whole thing via BT than go via the dodgy cube! :)
        • Maciej JablonskiM
          Maciej JablonskiM
          Maciej Jablonski
          wrote on last edited by Maciej Jablonski
          #72
          Looks eq-3 at least have plans for eq-3 MAX! compatible boiler/hot water controller, the manual is already there, just cannot see the product anywhere.
          http://www.eq-3.de/Downloads/eq3/downloads_produktkatalog/max/bda/en/BC-TS-Sw2-WM_UM_E_eQ-3_160420.pdf
          betzaalB 1 Reply Last reply
            A Former User
            wrote on last edited by [[global:former-user]]
            #73
            For anyone looking in having a setup like above, theres a way without extra buying the cube or the ccu2 when using homematic thermostats. Please have a look at https://www.homegear.eu , which eliminates the need of those boxes as it runs on a raspberry pi which most of us already have. You will have to add a CUL or better build yourself a NanoCUL (arduino nano + CC1101 ). Homegear does all the pairing and communication (also scripts) and best of all its converting and outputs all the communication via MQTT, so you can use Node Red.
              stephenmhall
              Damn, just weeks after I changed to a Honeywell system. Talk about bad timing.
              • T
                twisted
                FYI, I bought a CC1101 connected it up to an RPI, setup openhab, homegear, the homeatic binding, and within minutes I had all of the devices listed and complete control over them all. Well I can say that is where it has ended, I am struggling to either find pre-written logic or writing my own to control everything. The issue isn't so much writing it as such, but choosing which system should host it. This dilemma exists, as I have everything else in my vera, I am getting into node-red, and now also have openhab/homegear in the loop, I don't want to fracture my set up too much from a control interface point. I like the idea of keeping the WAF where it is, so I will probably still need to have some sort of control via the vera and therefore one of the apps that the other half is still happy with.
                  Stuart Middleton
                  I've got a CC1101 on its way from China. I'm hoping it'll be here soon. My plan was to rewrite the excellent Python code from this page to talk to them directly rather than through the cube. Currently, I don't have an off the shelf home system. I'm kind of writing it all myself as I go (maybe a mistake, I know). I'll let you know how I get on when mine arrives.
                  • S Stuart Middleton
                    twisted
                    @Stuart-Middleton Although I mentioned my difficulties, I would suggest that you at least have a look at homegear and openhab (or the openhabian bundle to make it easier) as it does give great access to the devices and opens up very easy use of MQTT.
                      Stuart Middleton
                      Thanks. I'll take a look at that first.
                        twisted
                        @Stuart-Middleton attached is an example of the items that get loaded when connected to openhab2 via homegear and the homematic binding.0_1484525182006_Rad1-Paper UI.png 0_1484525185963_Rad2-PaperUI.png 0_1484525188699_Thermostat-PaperUI.png
                          Stuart Middleton
                          That pretty much covers all the settings. When my radio arrives I'll hopefully be able to get it working quickly and I may come to you for help with setting it up with openhab so I can at least see a working system before I start playing with the code. Thanks
                          • betzaalB
                            betzaalB
                            betzaal
                            For a beginner, what shall I read (links) to understand what it means to do this. I have MAX cube and 3 actuators and I need a boiler control device. I called eq-3 and they reply they are not selling boiler controller device BC-TS-Sw2-WM (The MAX! boiler controller has been withdrawn from the market due to poor customer uptake. We do not believe there to be any devices available in the sales channel.) Thanks a lot !
                            • Maciej JablonskiM Maciej Jablonski
                              betzaalB
                              betzaalB
                              betzaal
                              @Maciej-Jablonski
                              They are not selling any more this. (Their answer: The MAX! boiler controller has been withdrawn from the market due to poor customer uptake. We do not believe there to be any devices available in the sales channel.)
                                Stuart Middleton
                                It depends on how much of a beginner you are. If you're OK with very basic electronics, happy to install some software on a Raspberry Pi and can connect a mains voltage wire to your boiler without killing yourself, then it's pretty simple.
                                At a minimum, you'll need a Raspberry Pi PC, a mains relay board controllable from the Pi (very cheap on eBay) and some cable.
                                  betzaalB
                                  betzaalB
                                  betzaal
                                  @Stuart-Middleton
                                  Thanks. Of course, I can do these. I have Raspberry Pi B and other required things. What I need to know is a schematic of connections and what software to install (on PC, on Raspberry Pi...)
                                  Again, Thanks a lot !
                                    Stuart Middleton
                                    The software is all written in python and is linked somewhere near the top of this post. There are instructions of how to install and use it included if I remember right.
                                    The wiring is very simple. The boiler on output pin is defined in the software, so just change it to any GPIO pin that you want and connect your relay (3.3v I believe) to the pin and GND. I used a solid state 250v AC relay that accepts 3.3v input. Then just connect the "call for heat" wire on your boiler to the mains side of the relay. This is on your boiler schemaic, but is usually just the two wired to your wall thermostat.
                                    I've got a combi boiler so just set it to be on all the time and let the Pi contol the heating.
                                    • betzaalB
                                      betzaalB
                                      betzaal
                                      Thank you a lot! I will try it and let you now the progress. I need some time to do it...
                                        stephenmhall
                                        if you need any help with my software let me know, I have swapped to a Honywell system myself so no longer use it but if I can help I will.
                                          Stuart Middleton
                                          @twisted It's arrived! I've got a CC1101 module! I presume It's just connected to the Pi via SPI? I think there's a wiring diagram on the website. I'll dig out a spare Pi and let you know what happens. :)
