  3. Boiler control from MAX! Cube to Drayton Boiler via Raspberry Pi/Vera/Mysensors.
113 Posts 22 Posters 81.6k Views 24 Watching
  • Maciej JablonskiM
    Maciej JablonskiM
    Maciej Jablonski
    wrote on last edited by Maciej Jablonski
    #72
    Looks eq-3 at least have plans for eq-3 MAX! compatible boiler/hot water controller, the manual is already there, just cannot see the product anywhere.
    http://www.eq-3.de/Downloads/eq3/downloads_produktkatalog/max/bda/en/BC-TS-Sw2-WM_UM_E_eQ-3_160420.pdf
    betzaalB 1 Reply Last reply
      A Former User
      wrote on last edited by [[global:former-user]]
      #73
      For anyone looking in having a setup like above, theres a way without extra buying the cube or the ccu2 when using homematic thermostats. Please have a look at https://www.homegear.eu , which eliminates the need of those boxes as it runs on a raspberry pi which most of us already have. You will have to add a CUL or better build yourself a NanoCUL (arduino nano + CC1101 ). Homegear does all the pairing and communication (also scripts) and best of all its converting and outputs all the communication via MQTT, so you can use Node Red.
        stephenmhall
        Damn, just weeks after I changed to a Honeywell system. Talk about bad timing.
        • T
          twisted
          FYI, I bought a CC1101 connected it up to an RPI, setup openhab, homegear, the homeatic binding, and within minutes I had all of the devices listed and complete control over them all. Well I can say that is where it has ended, I am struggling to either find pre-written logic or writing my own to control everything. The issue isn't so much writing it as such, but choosing which system should host it. This dilemma exists, as I have everything else in my vera, I am getting into node-red, and now also have openhab/homegear in the loop, I don't want to fracture my set up too much from a control interface point. I like the idea of keeping the WAF where it is, so I will probably still need to have some sort of control via the vera and therefore one of the apps that the other half is still happy with.
            Stuart Middleton
            I've got a CC1101 on its way from China. I'm hoping it'll be here soon. My plan was to rewrite the excellent Python code from this page to talk to them directly rather than through the cube. Currently, I don't have an off the shelf home system. I'm kind of writing it all myself as I go (maybe a mistake, I know). I'll let you know how I get on when mine arrives.
            • S Stuart Middleton
              twisted
              @Stuart-Middleton Although I mentioned my difficulties, I would suggest that you at least have a look at homegear and openhab (or the openhabian bundle to make it easier) as it does give great access to the devices and opens up very easy use of MQTT.
                Stuart Middleton
                Thanks. I'll take a look at that first.
                  twisted
                  @Stuart-Middleton attached is an example of the items that get loaded when connected to openhab2 via homegear and the homematic binding.0_1484525182006_Rad1-Paper UI.png 0_1484525185963_Rad2-PaperUI.png 0_1484525188699_Thermostat-PaperUI.png
                    Stuart Middleton
                    That pretty much covers all the settings. When my radio arrives I'll hopefully be able to get it working quickly and I may come to you for help with setting it up with openhab so I can at least see a working system before I start playing with the code. Thanks
                    • betzaalB
                      betzaalB
                      betzaal
                      For a beginner, what shall I read (links) to understand what it means to do this. I have MAX cube and 3 actuators and I need a boiler control device. I called eq-3 and they reply they are not selling boiler controller device BC-TS-Sw2-WM (The MAX! boiler controller has been withdrawn from the market due to poor customer uptake. We do not believe there to be any devices available in the sales channel.) Thanks a lot !
                      • Maciej JablonskiM Maciej Jablonski
                        betzaalB
                        betzaalB
                        betzaal
                        @Maciej-Jablonski
                        They are not selling any more this. (Their answer: The MAX! boiler controller has been withdrawn from the market due to poor customer uptake. We do not believe there to be any devices available in the sales channel.)
                          Stuart Middleton
                          It depends on how much of a beginner you are. If you're OK with very basic electronics, happy to install some software on a Raspberry Pi and can connect a mains voltage wire to your boiler without killing yourself, then it's pretty simple.
                          At a minimum, you'll need a Raspberry Pi PC, a mains relay board controllable from the Pi (very cheap on eBay) and some cable.
                            betzaalB
                            betzaalB
                            betzaal
                            @Stuart-Middleton
                            Thanks. Of course, I can do these. I have Raspberry Pi B and other required things. What I need to know is a schematic of connections and what software to install (on PC, on Raspberry Pi...)
                            Again, Thanks a lot !
                              Stuart Middleton
                              The software is all written in python and is linked somewhere near the top of this post. There are instructions of how to install and use it included if I remember right.
                              The wiring is very simple. The boiler on output pin is defined in the software, so just change it to any GPIO pin that you want and connect your relay (3.3v I believe) to the pin and GND. I used a solid state 250v AC relay that accepts 3.3v input. Then just connect the "call for heat" wire on your boiler to the mains side of the relay. This is on your boiler schemaic, but is usually just the two wired to your wall thermostat.
                              I've got a combi boiler so just set it to be on all the time and let the Pi contol the heating.
                              • betzaalB
                                betzaalB
                                betzaal
                                Thank you a lot! I will try it and let you now the progress. I need some time to do it...
                                  stephenmhall
                                  if you need any help with my software let me know, I have swapped to a Honywell system myself so no longer use it but if I can help I will.
                                    Stuart Middleton
                                    @twisted It's arrived! I've got a CC1101 module! I presume It's just connected to the Pi via SPI? I think there's a wiring diagram on the website. I'll dig out a spare Pi and let you know what happens. :)
                                    • marogM
                                      marogM
                                      marog
                                      I use a diagram from homegear to connect it and it is working. No problem with connection.
                                      • T
                                        twisted
                                        I believe I used this one: [https://forum.homegear.eu/t/CC1101-no-physical-device-found/921/2]
                                          Stuart Middleton
                                          OK, so I've got my module, connected it to my Pi and installed homegear (used the Rasbian version with homegear and openhad installed). I connected to the Pi, ran homegear -r, families select 0, pairing on and started pairing on a device. However, I don't see anything in the peers list.
                                          So, any ideas or obvious things I'm missing?
