  3. [Tutorial] Raspberry Pi NRF24l01 direct connection
raspberry pinrf24l01
56 Posts 32 Posters 94.6k Views 24 Watching
    Mediacj
    I'am trying to get this working on my Raspberry Pi 2 B with Raspbian but when using the setup.sh command I get this error:
    bcm2835.c: In function ‘bcm2835_init’:
    bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1208:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1209:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1210:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1211:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1212:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1213:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1214:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1228:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1232:81: error: invalid suffix "x" on integer constant
    bcm2835.c:1236:81: error: invalid suffix "x" on integer constant
    bcm2835.c:1239:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1242:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1246:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1249:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1253:79: error: invalid suffix "x" on integer constant
    Makefile:52: recipe for target 'bcm2835.o' failed
    make: *** [bcm2835.o] Error 1
    Any idea what is going wrong? Thanks in advance!
    W 1 Reply Last reply
    • M Mediacj
      W
      W
      wergeld
      @Mediacj I too had this error. The only way I was ever to solve this was to take a fresh image of Wheezy and start from scratch there. No sudo apt-get updated/upgrade until after I built the lib.
        Mediacj
        Thanks for your answer, I am going to try that this weekend.
        • T
          tbully
          Hello everyone! Great work here! I see this is still running the 1.4 protocol, is that right? I was able to get this working but only my temp sensors would respond. Anything where I had to send data wouldn't work.
          Any chance of moving to 1.5 in the near future?
          • A
            ArieKanarie
            It might be a stupid question, but I've been staring at my screen for hours now, and can't find the solution.
            How do i install/ connect this gatewatay in domoticz?
            I have a Raberry Pi (2) with domoticz installed, followd this tutorial and connected the NRF24l01 directly to the gpio, and according to the printout everything works.
            So took a Arduino Uno, connected a magnetic doorsensor and a NRF24l01 and uploaded the right sketch, all ok and it even seems that the Raspberry is receiveing the data
            But what kind of gateway do I select in Domoticz?
            When I select Mysensors USB gateway I can't choose a serial port (seem legit since there is no usb connected), what hardware do I select??
            • mfalkviddM
              @ArieKanarie Mysensors USB gateway is correct. I think you need to perform the steps mentioned in section "Enable the gateway for use with Domoticz" at http://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway?page=1
              T A 2 Replies Last reply
                tbully
                @mfalkvidd said in Step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway.:
                @Eawo Yes, it should work. I ran Domoticz and MySensors Gateway on my Raspberry Pi 1 when I first tried MySensors. If I remember correctly I had to connect CE to pin 15 instead of 22 but I am not sure why. Try using the same connections as on your Raspberry Pi 2 first, and switch CE pin if you get "check wires". Please report back here how it goes, so I can add the necessary information to the original post.
                For what it's worth, this is correct. I'm currently running on a Pi 1 and put CE on 15.
                I followed these instructions and it worked perfectly with no fuss: http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                  ArieKanarie
                  @mfalkvidd Thanks you very much sir!
                  • jerseyguy1996J
                    jerseyguy1996J
                    jerseyguy1996
                    make file has changes and there is no more librf24-bcm. Refer to the readme on the git and follow them
                    • t481T
                      t481T
                      t481
                      Hello all,
                      I hope someone can help with this.
                      Is there any way to run the generated ./PiGatewaySerial application in the background? I've got mine to work perfectly but only if I SSH into my Pi and execute the app using "sudo ./PiGatewaySerial". I'm looking to run this as a background service/application. Whichever is easier.
                      Thanks in advance
                      • L
                        L
                        lasicmk2
                        Hi
                        the easiest way is to run directly in background:
                        nohup sudo python script.py &
                        or - run script as a service and use it as other services, but above is the easiest.
                        Adam
                        • Fat FlyF
                          Fat FlyF
                          Fat Fly
                          This is working with latest mysensors library ?
                            @Fat-Fly
                            MySensors is now natively supported to run on Raspberry. See here for instruction on how to build:
                            https://www.mysensors.org/build/raspberry
