  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/318/Sonoff-relay-using-MySensors-ESP8266-wifi-or-mqtt-gateway
      Great! Added to the main site now.
      • AndrewZA
        AndrewZA
        AndrewZ
        Sorry, but what's the use case here?
        With Sonoff it's either hard or impossible to add a radio or rs485 transport, so I don't see it as a real gateway.
        If one wants to use it as a pure client and control it with MQTT - there is a great working solution available already: https://github.com/arendst/Sonoff-MQTT-OTA-Arduino
          The use case is that you can use the sonoff with all controllers that support mysensors.
          AndrewZA 1 Reply Last reply
            AndrewZA
            AndrewZA
            AndrewZ
            With all my respect to the project and people behind it I believe that MQTT is more widely used than MySensors. So for me it would be more logical to add another MQTT client to the network rather than introduce any additional gateway. Just my 2¢.
            J 1 Reply Last reply
            • AndrewZA AndrewZ
              J
              J
              Jan Gatzke
              @AndrewZ
              This is not really a gateway. You can use the esp8266 gateway sketch, disable the nrf24 / rfm69 and directly attach sensors. So basically it's an relay actuator which is configured as a mysensors gateway.
                I think what's throwing everybody off is applying the word "gateway" to this sonoff device. Wouldn't it make more sense to have it remain a relay actuator (i.e. just a node) and to have the mysensors gateway be something else (of which there are many examples on this website)? i.e. it makes more sense to have it be a mysensors node (or MQTT node if that's your architecture) than to have it be a mysensors gateway. Wouldn't it?
                • EfflonE
                  EfflonE
                  Efflon
                  This is not listed as a gateway but under sensors & actuators but maybe a "s/and/relay using" would be a fix of the headline. I selected the mqtt gateway example just because I have a few other NodeMCU's working as just MYS sensors with no radio but it's trivial to just re-use code for any of the other gateways, as you all know. I choose the mqtt addition just for fun and know there are other mqtt examples but nothing working out of the box with my HASS + MYS + mqtt setup. Regarding the gateway naming, at least I don't know any other way of using MYS and ESP8266 than using the gateway sketches with a disabled radio. What should they be called, just node? At the same time, adding a radio to the Sonoff and it's a gateway...
                  • danbiD
                    danbiD
                    danbi
                    Maybe a good solution to the node/gateway dilemma is adding WiFi transport for nodes to MySensors? Then defining one or more WiFi gateways to connect sensors to. You could then use WiFi enabled devices, such as ESP8266 as sensor nodes. You could use these as radio interfaces to Arduino nodes, with their original serial-to-WiFi firmware and treat it much like the RS485 transport.
                    NeverDieN gohanG 2 Replies Last reply
                    • danbiD danbi
                      @danbi
                      Yup. It's either that or do the MQTT thing (which, personally, I favor, though right now it's a minority opinion) like AndrewZ said.
                      • J
                        J
                        Jan Gatzke
                        I don't see the problem here. An direct ip connection between the controller and the node is perfect for critical nodes as less components mean less things that can fail. I have flashed a Sonoff Touch switch with the esp8266 gateway sketch and it is running just fine. Or am I missing something?
                        EfflonE 1 Reply Last reply
                        • J Jan Gatzke
                          EfflonE
                          EfflonE
                          Efflon
                          @Jan-Gatzke What code modifications have you done to get the touch buttons to work or do they work like "normal" buttons? I really like the built-in form factor and was thinking about ordering a few.
                          • EfflonE Efflon
                            J
                            J
                            Jan Gatzke
                            @Efflon
                            All the touch stuff is handheld by an ic. You can use it like an normal button, active low. It is connected to pin 0. I have made a two way switch of it. With a long press I cycle through multiple scenes which control the color of my tv's led light. With a even longer press I can switch the tv light off. I can share the code when I found the time to clean it up.
                            I like the OTA update function of the esp very much. It's much simpler than the rf24/ Arduino solution. My sketch provides a browser based update function with just 5 lines of code. This was important to me because I don't want to get my switches out off the wall for every update. For the eu version of the sonoff this is mandatory because the programming header does not fit when the device is mounted.
                            • J Jan Gatzke
                              @Efflon
                              EfflonE
                              EfflonE
                              Efflon
                              @Jan-Gatzke Excelletn info, thanks! Yes, please share your code , the state doesn't matter for me at least :D
                              • EfflonE Efflon
                                J
                                J
                                Jan Gatzke
                                @Efflon
                                Ok, I just wiped out (hopefully) all my passwords and IP information. :D
                                   REVISION HISTORY
                                   Version 1.0 - Henrik EKblad
                                   Contribution by a-lurker and Anticimex,
                                   Contribution by Norbert Truchsess <norbert.truchsess@t-online.de>
                                   Contribution by Ivo Pullens (ESP8266 support)
                                   DESCRIPTION
                                   The EthernetGateway sends data received from sensors to the WiFi link.
                                   The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
                                   VERA CONFIGURATION:
                                   Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                                   E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                                   LED purposes:
                                   - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
                                   - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                                   - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                                   - ERR (red) - fast blink on error during transmission error or recieve crc error
                                   See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                                   nRF24L01+  ESP8266
                                   VCC        VCC
                                   CE         GPIO4
                                   CSN/CS     GPIO15
                                   SCK        GPIO14
                                   MISO       GPIO12
                                   MOSI       GPIO13
                                   GND        GND
                                   Not all ESP8266 modules have all pins available on their external interface.
                                   This code has been tested on an ESP-12 module.
                                   The ESP8266 requires a certain pin configuration to download code, and another one to run code:
                                   - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch')
                                   - Connect GPIO15 via 10K pulldown resistor to GND
                                   - Connect CH_PD via 10K resistor to VCC
                                   - Connect GPIO2 via 10K resistor to VCC
                                   - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch')
                                    Inclusion mode button:
                                   - Connect GPIO5 via switch to GND ('inclusion switch')
                                   Hardware SHA204 signing is currently not supported!
                                   Make sure to fill in your ssid and WiFi password below for ssid & pass.
                                #define MY_BAUD_RATE 9600
                                //#define MY_RADIO_NRF24
                                #define MY_GATEWAY_ESP8266
                                #define MY_ESP8266_SSID "MySSID"
                                #define MY_ESP8266_PASSWORD "MyPSK"
                                // Enable UDP communication
                                //#define MY_USE_UDP
                                // #define MY_ESP8266_HOSTNAME "sensor-gateway"
                                #define MY_IP_ADDRESS 192,168,1,200
                                #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
                                #define MY_PORT 5003
                                // Enable inclusion mode
                                // #define MY_INCLUSION_BUTTON_FEATURE
                                // Flash leds on rx/tx/err
                                // #define MY_LEDS_BLINKING_FEATURE
                                // Set blinking period
                                // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                                #if defined(MY_USE_UDP)
                                #include <WiFiUDP.h>
                                #include <ESP8266WiFi.h>
                                #include <WiFiClient.h>
                                #include <ESP8266WebServer.h>
                                #include <ESP8266mDNS.h>
                                #include <ESP8266HTTPUpdateServer.h>
                                #define RELAY_1_Pin  12
                                #define LED_1_Pin 13
                                #define TOUCH_1_Pin 0
                                #define RELAY_1  1
                                #define TOUCH_1 3
                                #define TOUCH_2 4
                                boolean relayon = false;
                                int activescene = 1;
                                volatile unsigned long LastChange = 0;
                                volatile boolean RelayToggleRequired = false;
                                volatile boolean SceneSwitchRequired = false;
                                volatile boolean SceneSwitchTriggeredByTimeout = false;
                                volatile boolean SceneSwitchTriggeredByTimeout2 = false;
                                MyMessage msg(RELAY_1, V_LIGHT);
                                MyMessage msg1(TOUCH_1, V_SCENE_ON);
                                MyMessage msg2(TOUCH_2, V_LIGHT);
                                ESP8266WebServer httpServer(80);
                                ESP8266HTTPUpdateServer httpUpdater;
                                const char* host = "sonofftouch1";
                                const char* location = "Couch";
                                char* update_username = "admin";        //Benutzername zum login für die OTA-Programmierung
                                char* update_password = "MyPassword";      //Passwort
                                String webPage = "";
                                unsigned long lastheartbeat = 0;
                                void buttonChangeCallback() {
                                  if (digitalRead(TOUCH_1_Pin) == 1) {
                                    //LED off for feedback
                                    digitalWrite(LED_1_Pin, 1);
                                    //Button has been released, trigger one of the two possible options.
                                    if (millis() - LastChange > 500) {
                                      //Long Press
                                      if (!SceneSwitchTriggeredByTimeout) {
                                        SceneSwitchRequired = true;
                                    else if (millis() - LastChange > 50) {
                                      //Short press at least 50 ms for debounce
                                      RelayToggleRequired = true;
                                    else {
                                      //Too short to register as a press
                                  else {
                                    //LED on for feedback
                                    digitalWrite(LED_1_Pin, 0);
                                    //Just been pressed - do nothing until released.
                                  LastChange = millis();
                                  webPage += "<h1>ESP8266 Web Server</h1>";
                                  webPage += "<br><h1>";
                                  webPage += host;
                                  webPage += "</h1>";
                                  webPage += location;
                                  webPage += "</h1>";
                                  webPage += "<br><a href=/update>Click here to update</a>";
                                  pinMode(TOUCH_1_Pin, INPUT_PULLUP);      // sets the digital pin as output
                                  pinMode(RELAY_1_Pin, OUTPUT);
                                  pinMode(LED_1_Pin, OUTPUT);
                                  //LED off
                                  MDNS.begin(host);
                                  httpUpdater.setup(&httpServer, "/update", update_username, update_password);
                                  httpServer.begin();
                                  MDNS.addService("http", "tcp", 80);
                                  httpServer.on("/", []() {
                                    httpServer.send(200, "text/html", webPage);
                                  Serial.println("Enabling touch switch interrupt");
                                  attachInterrupt(digitalPinToInterrupt(TOUCH_1_Pin), buttonChangeCallback, CHANGE);
                                  sendSketchInfo("Sonoff Touch Mysensors", "1.0");
                                  present(RELAY_1, S_LIGHT, "single click/onboard relay");
                                  present(TOUCH_1, S_SCENE_CONTROLLER, "double click/scene controller");
                                  present(TOUCH_2, S_LIGHT, "long press virtuel switch");
                                  httpServer.handleClient();
                                  if (millis() - lastheartbeat > 30000) {
                                    //sendHeartbeat();
                                    sendBatteryLevel(90);
                                    lastheartbeat = millis();
                                  if (RelayToggleRequired) {
                                    ToggleRelay();
                                  if (SceneSwitchRequired) {
                                    SwitchScene();
                                  if (millis() - LastChange > 600) {
                                    if (digitalRead(TOUCH_1_Pin) == 0) {
                                      if (SceneSwitchTriggeredByTimeout == false) {
                                        SceneSwitchTriggeredByTimeout = true;
                                        SwitchScene();
                                  if (millis() - LastChange > 3000) {
                                      if (SceneSwitchTriggeredByTimeout2 == false) {
                                        SceneSwitchTriggeredByTimeout2 = true;
                                        SwitchSceneOff();
                                    // Change relay state
                                    if (message.sensor == RELAY_1) {
                                      digitalWrite(RELAY_1_Pin, message.getBool() ? 1 : 0);
                                      relayon = message.getBool() ? 1 : 0;
                                void ToggleRelay() {
                                  Serial.println("Single Click");
                                  if (relayon) {
                                    digitalWrite(RELAY_1_Pin, 0);
                                    relayon = false;
                                  else {
                                    digitalWrite(RELAY_1_Pin, 1);
                                    relayon = true;
                                  send(msg.set(relayon ? 1 : 0));
                                void SwitchScene() {
                                  //Domoticz does not like 1 as scene. So we start with scene 2.
                                  Serial.println("Long press");
                                  activescene += 1;
                                  if (activescene > 6) {
                                    activescene = 2;
                                  Serial.print("Activating Scene ");
                                  Serial.println(activescene);
                                  send(msg1.set(activescene));
                                void SwitchSceneOff() {
                                  Serial.println("3sec Long Press");
                                  send(msg1.set(7));
                                • danbiD danbi
                                  @danbi
                                  Configuring it as a gateway allows you to directly add it to the controller even it is isn't routing anything else than it's local I/O, making it very straightforward
                                  • J Jan Gatzke
                                    @Efflon
                                       REVISION HISTORY
                                       DESCRIPTION
                                       VERA CONFIGURATION:
                                       LED purposes:
                                       nRF24L01+  ESP8266
                                       VCC        VCC
                                       CE         GPIO4
                                       CSN/CS     GPIO15
                                       SCK        GPIO14
                                       MISO       GPIO12
                                       MOSI       GPIO13
                                       GND        GND
                                    #define RELAY_1  1
                                    #define TOUCH_1 3
                                    #define TOUCH_2 4
                                          //Long Press
                                        else {
                                      else {
                                      webPage += host;
                                      webPage += "</h1>";
                                      webPage += "</h1>";
                                      //LED off
                                      MDNS.begin(host);
                                      httpServer.begin();
                                        //sendHeartbeat();
                                        ToggleRelay();
                                        SwitchScene();
                                            SwitchScene();
                                            SwitchSceneOff();
                                      if (relayon) {
                                        relayon = false;
                                      else {
                                        relayon = true;
                                      activescene += 1;
                                        activescene = 2;
                                      send(msg1.set(7));
                                    EfflonE
                                    EfflonE
                                    Efflon
                                    @Jan-Gatzke Thanks! A Interesting and inspiring code example. Did you think about using the arduinoOTA option instead of the httpUpdater?
                                    • EfflonE Efflon
                                      J
                                      J
                                      Jan Gatzke
                                      @Efflon
                                      Yes, I thought about that. But during my tests the web updater was just most reliable and easiest to use. Arduino ota needs extensions to the IDE and sometimes the node was not found. Web updater works out of the box and never made any problems.
                                      • J Jan Gatzke
                                        @Efflon
                                        EfflonE
                                        EfflonE
                                        Efflon
                                        @Jan-Gatzke Great to know!
                                        • BrydenB
                                          BrydenB
                                          Bryden
                                          This sketch is awesome, First MySensors sketch I have used that worked straight off the bat.
                                          The details page does need a few extra bits of info....
                                          3.3v FTDI tool needed
                                          Hold down the button on the Sonoff when you power it up to enter flash mode.
