  2. Announcements
  3. šŸ’¬ Building an Ethernet Gateway
133 Posts 42 Posters 104.4k Views 35 Watching
  • Sergio Ɓlvarez SanchisS
    Same problem like Reza, same error messages AND I USING ethernet shield, ARDUINO MEGA AND nrf24
      And using ARDUINO 1 the same problem.
      0;255;3;0;9;TSM:INIT
      0;255;3;0;9;!TSM:RADIO:FAIL
      0;255;3;0;9;!TSM:FAILURE
      0;255;3;0;9;TSM:PDT
      0;255;3;0;9;TSM:PDT
      • DallieNLD
        DallieNLD
        DallieNL
        Had lots of issues getting this to work. The issue seems to be with the ethernet part, as I only have an ethernet board attached I removed the lines for the radio and the pin redirection. Still the code kept restarting all the time or just not being able to connect the controller.
        AVR version of the Arduino 1.8.0 kit needs to be downgraded. I had 1.6.16 and downgraded to 1.6.11.
        Open Arduino. Tools > Board: xxxxx > Boards manager... > Click "Arduino AVR Boards" > Select Version > 1.6.11
        Recompile and you are good.
        • D
          David
          wrote on last edited by David
          Hi @DallieNL ,
          thanks for your tips,
          I got the same issue with serial gateway, 1.6.11 is the best.
          David.
          • mppM
            mppM
            mpp
            Would it be possible to build an MQTT gateway using the ESP8266 WiFi Gateway?
            MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
              Yes, the MQTT gateway works on ESP as well.
              mppM 1 Reply Last reply
              • LaMB95L
                LaMB95L
                LaMB95
                Anyone have an instruction to set up a W5500 ethernet gateway?
                  @LaMB95
                  For the moment, i don't think there is an howto regarding w5500 as we're mostly using w5100, but maybe you can find some infos in this topic https://forum.mysensors.org/topic/2901/my-ethernet-gateway-board-w5500
                  • KiwiHC16K
                    KiwiHC16K
                    KiwiHC16
                    Hi All,
                    I have an ethernet gateway base on arduino Pro mini with NRF24L01 radio and Funding ethernet card with W5100 chips. (As per description of this page)
                    All works fine when I'm connected to it with Arduino IDE. Works for hours/days.
                    If I unplug the IDE (disconnect USB) and run it alone it stop working after for minutes or few hours.
                    I have only one sensor (temperature) to test. It send Temperature and battery level every 10s (testing). Led attached to Gateway to show the traffic lit up twice each time it receive the information from the sensor. The LED lit up twice like half a second when everything is fine. Easy to see.
                    When the issue starts, the led lit up time to time but very quickly, and even very difficult to see. Some time I can ping the Gateway, some time not.
                    Any idea from anybody ?
                    • KiwiHC16K
                      KiwiHC16K
                      KiwiHC16
                      additional info: Same situation having //#define MY_DEBUG defined or not.
                      • KiwiHC16K
                        KiwiHC16K
                        KiwiHC16
                        Looks like the issue is related to the power supply. I just plugged a 5V to the USB and It has been working fine for 24h. Need to review the Power supply in place.
                        • Sander StolkS
                          Sander StolkS
                          Sander Stolk
                          The first one will not compile since the #include <SPI.h> is missing
                          • WizarDEADW
                            WizarDEADW
                            WizarDEAD
                            Hello guys,
                            Can anyone help me with modify this to work with W5500 Ethernet module?
                            Please advice us what need to be modified and why it needs to be modified.
                            Thanks you very much.
                            • WizarDEADW WizarDEAD
                              Hello guys,
                              #25
                              @WizarDEAD the information in https://forum.mysensors.org/topic/2901/my-ethernet-gateway-board-w5500 might be useful.
                              • Chucky_69C
                                Chucky_69C
                                Chucky_69
                                Hi Guys,
                                I'm using a Wiznet W5100 Ethernet module.
                                The pins are described as following (I added a numbering myself:
                                0_1487281914650_upload-a05aa788-d1ac-4ef0-b42a-7ad6b28b6e9c
                                The MySensors Gateway uses different terms, am I 'translating' them correctly?
                                0_1487282198655_upload-1949b0d7-52ae-4059-a4e3-e68941dafbe4
                                C 1 Reply Last reply
                                • Chucky_69C Chucky_69
                                  Hi Guys,
                                  C
                                  C
                                  Cansher
                                  @Chucky_69
                                  Looks right!
                                  • fifoF
                                    fifoF
                                    fifo
                                    My WizNET (W5100) Ethernet module had to be connected to 5v pin on arduino as the 3.3v would only allow ping but not function properly.
                                    E 1 Reply Last reply
                                    • AndrewZA
                                      AndrewZA
                                      AndrewZ
                                      wrote on last edited by AndrewZ
                                      #29
                                      Maybe I just overlooked that, but is it possible to statically define netmask and gateway in the sketch? I'm using ENC28J60.
                                      • AndrewZA AndrewZ
                                        @AndrewZ I think you can use
                                        MY_IP_GATEWAY_ADDRESS
                                        MY_IP_SUBNET_ADDRESS
                                        AndrewZA 1 Reply Last reply
                                          AndrewZA
                                          AndrewZA
                                          AndrewZ
                                          #31
                                          @mfalkvidd , yes I also found this in MQTT GW example, thanks.
                                          This seems to be not working on my ENC28J60 - as I can see the the default gateway setting is not taken into account. I will test with W5100.
                                          Edit: I confirm that these settings work properly with W5100, just tested.
                                          With your input, this post could be even better šŸ’—
