  3. Still not going well for me.
24 Posts 7 Posters 8.3k Views 7 Watching
  • CoffeesnobC
    CoffeesnobC
    Coffeesnob
    @mfalkvidd thanks for your reply. I was going to try and contact you about this very thing. If its ok can I PM you will suggestions, I completely get what you’re talking about, I know this problem very well. But there is a way you can provide the information required that is not so in your face which I agree can be an issue.
    I would also like to develop a test Sketch that can be used to prove that all the hardware is working independent of anything in the API. This would have made my experience that much easier because I was not actually able to determine where the issue was until I had first proven that it was not the radio or the two different boards I am using (which was suggested in this post as well as in the troubleshooting guide). Are we able to perhaps have a chat via email or something about how to facilitate that?
    • CoffeesnobC Coffeesnob
      @Coffeesnob Great, thanks!
      PM is ok if you don't want to discuss it in a forum thread.
        @petewill, you sir are a star... this was the information I was missing and it is now working as expected. below is the serial monitor trace from both the Mega and the Uno.
        First the Mega
        0;255;3;0;9;MCO:BGN:STP
        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        0;255;3;0;9;TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;TSM:INIT:TSP OK
        0;255;3;0;9;TSM:INIT:GW MODE
        and this is the Uno...
        8994 TSF:MSG:SEND,10-10-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
        9000 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
        9006 MCO:SLP:TPD
        I have literally spent hours on this. I think the documentation in terms of getting started needs to be expanded on considerably. I get this is a huge task but if you don't know much about Arduino or know where to look you pretty much screwed.
        petewillP
        petewillP
        petewill
        @Coffeesnob Sorry for the delayed reply. I was in the mountains the last few days. I'm glad you got it working! There are a lot of different factors at play when designing your own sensors and learning something new can take time but I think you are over the biggest hurdle now.
        @mfalkvidd thanks for updating the documentation. You are awesome!
        • CoffeesnobC
          CoffeesnobC
          Coffeesnob
          @petewill, appreciate it. I'm very happy with the outcome, for the most part. However, I now have a new challenger. I am using a relay module and I can happily turn relays on using MYSController but can't seem to figure out how to turn them off. I know you know a little about this product so I wonder if you can point me in the right direction.
          I have also connected to my gateway serially using HomeGenie and it can't turn either on or off. but I haven't had time to do any further fault finding there yet.
          As soon as I have time, I will provide promised doc. i then need to know where to send them.
          petewillP 1 Reply Last reply
          • CoffeesnobC
            CoffeesnobC
            Coffeesnob
            @mfalkvidd, I can post here no problem. but I also want to provide a how-to of sorts that will help newbies like me to rule out anything that is Mysensors related. I just thought this would require me a to PM you
              petewillP
              petewillP
              petewill
              @Coffeesnob said in Still not going well for me.:
              Can't you just send a 0 instead of a 1? I don't ever use MYSController for controlling devices. Only for monitoring traffic. All my control is done with Vera. That being said though you should only need to send a 0 to turn off the relay.
              • CoffeesnobC
                CoffeesnobC
                Coffeesnob
                @petewill, yep you would think that would do it... however, it doesn't seem to work. what is interesting is if I send a 1 it also doesn't turn on the relay, only sending an empty message turns it on. I think I might post in the MYSController forum to see if they have any ideas.
                tekkaT 1 Reply Last reply
                  tekkaT
                  tekkaT
                  tekka
                  @Coffeesnob hmm, can you post your sketch and the debug logs, I assume something must be wrong the way you process incoming messages.
                  • CoffeesnobC
                    CoffeesnobC
                    Coffeesnob
                    @tekka, will do. I have had a hardware related issue that is unrelated to this directly. (i bricked my Nano trying to flush the eprom) but it means that until I get this fixed or get new hardware I am not going to be able to do anymore. Im hoping that Im getting close because this is really getting pretty frustrating.
                    • CoffeesnobC
                      CoffeesnobC
                      Coffeesnob
                      @mfalkvidd, I have finally had the opportunity to reply to your question from a week back “Could you list the top 3-5 things that would have helped you the most, and where you would have expected to find that information? That would be great input.”
                      Ok so I think the big thing is there is not a lot of detail in troubleshooting. Clearly the radios are the most problematic part and not being able to get access to how they actually work makes it very frustrating. The table that peterwill provided is very helpful but this also requires you to have some background information.
                      I understand that you are trying to limit the amount of detail so as not to scare people away but I personally believe that having optional reference material would be extremely helpful. For example a diagram which explains how all the different liberties link together, this would have helped me to determine how the SPI components are setup.
                      It would have been extremely helpful if in your initial radio setup guide you had a reference to how the SPI components of the radios work. This would be an optional reference that people could look at if they wanted to. At the moment, the way these radios work is very much black magic, and because I am new to the whole Arduino thing I was unable to determine if you are using the standard SPI features of the Arduino or if you had created your own. An example of a reference might be https://www.arduino.cc/en/reference/SPI however it is also important to explain that Mysensors is using its own SPI library, you could (should) go into more detail about how the SPI library is setup from the Mysensors point of view, because if you have to work it out your self this is very chanalgin because there is no common reference to understand how Arduino default SPI relates to mysensors SPI
                      And finally, something which would make things oh so much easier, is a sample sketch that will just allow you to test the radios, i.e you type the number 1 into the serial monitor on the gateway and you will see a message on the node if the radios are all working. And vice versa. I am willing to take this on as a project as I am already working on it however I would ideally like it to use all the Mysensors library’s. In other words, it should behave like any other sensor network would. But I really need a lot more information to work out how to do this. In the meantime, once I get my radios back up and running again I will post a very quick and dirty version and let you have a look at it.
                      I hope this all makes sense. I am a huge fan of the work the my sensors team have done here. I want to do what I can to help make it better.
                      • CoffeesnobC
                        CoffeesnobC
                        Coffeesnob
                        Ok, so the new hardware has finally arrived and I have been pulling my hair out trying to get it working. It appears like there is something wrong in the way the node and the gateway are setting up. I didn't have this problem a couple of weeks ago but since I have upgraded to v2.1.1 the problem has manifested. I have seen that there are a number of posts that appear to have similar issues but not exactly the same. Perhaps somebody can shed some light.
                        The setup is still exactly the same as I have described earlier in this post. I have a Mega and a Nano both with NRF24L01, I have a 10uf Cap across the power supplies of both radios, and I am 100% sure that the radios and the Arduinos are all working because I have built a NON Mysensor test sketch to prove this is all fine. Aside from that you can also see from the log transcript below that the units are actually talking. They just don’t seem to be able to complete the negotiation.
                        So here is what I am seeing. in the log transcript below you can see that the two devices are talking to each other. the Bold text are the messages being sent from the gateway and the normal text is the messages being sent from the Node.
                        0;255;0;0;18;2.1.1
                        0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                        3 MCO:BGN:BFR
                        5 TSM:INIT
                        6 TSF:WUR:MS=0
                        12 TSM:INIT:TSP OK
                        14 TSM:FPAR
                        16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSF:MSG:BC
                        0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
                        0;255;3;0;9;TSF:CKU:OK,FCTRL
                        0;255;3;0;9;TSF:MSG:GWL OK
                        0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                        89 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        94 TSF:MSG:FPAR OK,ID=0,D=1
                        2023 TSM:FPAR:OK
                        2024 TSM:ID
                        2025 TSM:ID:REQ
                        2027 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                        0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
                        255;255;3;0;3;
                        4035 TSM:ID
                        4036 TSM:ID:REQ
                        4038 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                        255;255;3;0;3;
                        4035 TSM:ID
                        4036 TSM:ID:REQ
                        255;255;3;0;3;
                        4035 TSM:ID
                        4036 TSM:ID:REQ
                        255;255;3;0;3;
                        10066 !TSM:ID:FAIL
                        10067 TSM:FAIL:CNT=1
                        10070 TSM:FAIL:PDT
                        What you can clearly see here is that the initial node setup takes place, the request from the node to the gateway is received by the gateway and it reply’s. the node receives the reply and then it sends its reply, the Gateway receives the reply and then try to send an acknowledgment, but the node never gets the message. I suspect this is because the message being sent from the gateway is incomplete for some reason.
                        For example the Node sends
                        The gateway responds with
                        Which in and of its self doesn’t look exactly right to me, but as I am not the expert in this I am probably wrong.
                        The gateway then prints 255;255;3;0;3; with nothing else in the line, this looks to me like its trying to send something but the message is empty.
                        What are your thoughts? @mfalkvidd and @petewill I am hoping you guys can shed some light here.
                        Thanks in advance.
                          Which controller do you have setup with your gateway to answer the id requests from the node?
                          • petewillP
                            petewillP
                            petewill
                            @Coffeesnob I didn't look at your logs in too much detail (I still don't have the codes memorized) but like @hek is noticing you may not be getting a node id back. You could also try assigning a static node ID like this:
                            #define MY_NODE_ID 1
                            Also, try adding a 40uF or 100uF capacitor to the radio. The new 2.1.1 library is much more efficient and can use more power in shorter periods (because it can transmit faster).
                            • CoffeesnobC
                              CoffeesnobC
                              Coffeesnob
                              Thanks heaps @Hek and @petewill I didn't realise that without the controller running I will not get a node id. I thought incorrectly the node id came from the gateway. I booted up MYSController and it now works as expected. thanks for pointing me in the right direction..
                              cheers until next time.
