  3. interrupt mystery with sensebender micro
17 Posts 6 Posters 5.4k Views 4 Watching
  • ikkeTI
    ikkeTI
    ikkeT
    I used pins 3 and 4 for the interruptible input from sensors. What does D2 have to do with this in my case, if none of the code is using it for interrupts?
    I brought d2 and d3 up because some sample codes for sensors mentioned that only those can be used for interrupts. But I assume now this is not the case for SB, thanks to the pic above.
      The CHANGE interrupt can only be used on pin 2,3 of the Atmeta328
      https://www.arduino.cc/en/Reference/AttachInterrupt
      There are other ways of trigger wakeup on all pins, but they are not supported by the MySensors sleep function and requires out to keep track of which pin that was triggered manually.
      ikkeTI 1 Reply Last reply
        +1 on what said @Hek ;)
        there is Pin change Int for other pins but you'll need to use raw registers stuff. There exists a lib for this but not supported by MYS sleep. And it's more efficient for memory consumption to use only what you need :)
        I will publish soon my multisensor sketch where I use D2/int0,D3/int1 and two others pinchange int but in case you will find everything you need for this here : : http://www.gammon.com.au/forum/?id=11497
          ikkeTI
          ikkeTI
          ikkeT
          @hek thanks, this clears the topic. I'll try cutting off the D2 and reuse that. I'll report back...
          • ikkeTI
            ikkeTI
            ikkeT
            Good news and bad news... I got change based interrupts to work by moving the motion to D2. That required cutting off the radio IRQ. Naturally I lost one radio there cutting too much....
            So now it works initially. But after some rounds the serial text gets garbled, and it stops sending anything quite soon then.
            isMetric: 1
            TempDiff :127.31
            HumDiff  :151.00
            T: 27.31
            H: 51
            TempDiff :0.01
            HumDiff  :0.00
            Door  :0
            Motion:1
            TempDiff :0.01
            HumDiff  :0.00
            Door  :0
            Motion:0
            TempDiff :0.07
            HumDiff  :0.00
            Door  :0
            Motion:1
            TempDiff :0.10
            HumDiff  :0.00
            Door  :0
            Motion:0
            x00�����x00�����x00�x00x00��x00��x00x00�x00x00�x00x00x00�x00x00x00x00�x00�x00x00x00x00��x00x00�x00x00x00���������```
            the last line contines for long. Any ideas what could cause it? Some trick I missed with interrupts?
            Again, the fixed code is here, it's almost the original SB Micro sample:
            https://github.com/ikke-t/sensebender/blob/master/SenseBender/SenseBender.ino
            • ikkeTI
              ikkeTI
              ikkeT
              wrote on last edited by ikkeT
              Solved the scrambled test. I removed the interrupts, and made it loop faster. It always got screwed after five rounds, so it seemed to be due the clock speed change in the template:
              #ifndef MY_OTA_FIRMWARE_FEATURE
                  highfreq = false;
              Removing that takes it further. I suppose the sample code is missing something to fix the serial speed after prescaler change. I also wonder if the radio would require some reconfig after clock speed change?
              • ikkeTI
                ikkeTI
                ikkeT
                But weird still. If I set the sleep time to 10 secs, without interrupts it works just fine. If interrupts are enabled, it stops always in less than ten rounds. So could it be the interrupts break the radio part somehow? E.g. if interrupt comes during transmit? Are interrupts safe in arduino, or should there be some lock set or disable interrupts for time of radio transmit?
                • ikkeTI ikkeT
                  @ikkeT Have a look at the other pin interrupt related post: https://forum.mysensors.org/topic/4999/solved-latest-git-snapshot-causes-freezes/38
                  I fixed an issue that might also bother you.
                  • YveauxY Yveaux
                    ikkeTI
                    ikkeTI
                    ikkeT
                    @Yveaux Thanks, I was following the thread. I confirm, the change fixed my problem too, excellent.
                    • rborerR
                      rborerR
                      rborer
                      @ikkeT, I've used the PIN 3 with a door sensor, it work perfectly, just enable the mode INPUT_PULLUP on the setup.
                      pinMode(DOOR_PIN, INPUT_PULLUP);
