  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • cimba007C
    cimba007C
    cimba007
    Are these new boards compatible to the old footprint? I think the layout of the "high power"-rf24 versions did not change in the past coulpe of years and I can't rely on the "small"-boards .. got a solid home with conrete falls :D
    Nca78N 1 Reply Last reply
    • cimba007C cimba007
      @cimba007 the footprint is different.
      I think I have finished the new version now, I changed the regulator from RAW to VCC to put an AMS1117 so you will be able to use high power version of the NRF24 if you want. They exist in SMD version (so, with the same footprint than I use on this board) and they are of better quality than the cheap "through hole" versions, in addition to beeing much more compact with their ceramic antennas.
      From my experience even the non pa/lna nrf24 has better radio performance than the cheap through hole version. With addition of not having any connectors/part of board below the antenna (like on the jModule) maybe it could be enough for some of your sensors at home.
      I have 30cm thick concrete walls in my appartments and no problem with the signal on the sensors using SMD version, while it was not so stable when using the through hole version. Probably my appartment is smaller than your home and I think the signal just "turns around" walls here, but you should give it a try ;)
      • cimba007C
        cimba007C
        cimba007
        wrote on last edited by cimba007
        #58
        I currently have 5 modules of the "old"-jboard and still 2-3 spare "high"-power modules left. I just recently noticed that most of my communication problems apparently came from RF24_PA_MAX settings. Currently running with RF24_PA_MIN I am very satisfied with the "high"-power modules. Was just inrested int he latest developement.
        My recent focus switched over to make some nice housings for my nodes. Having a board+sensors is only half of the work ;-)
          @cimba007 if you are not using amp on the modules then the SMD version will give you better results I'm sure.
          If you want to use nice housings you should appreciate the little extras that will come together with the board ;)
          • K
            K
            kted
            What about the NRF decoupling capacitor? Is there a provision for it?
            In the previous version there were holes for one. Is it SMD now?
            Any other details on the new features? My fingers are itching for an order....
            • Nca78N
              Yes I switched to SMD because the purpose of the board is to be very compact. With SMD everything is on one side and the board can be on the pro mini bottom without any gap.
              But the board stays easy to solder too as I have put a 1206 SMD size. If you can solder the SMD nrf24 you can solder a 1206 capacitor. If you can't, keep using the jmodule, but really it's not very difficult :)
              I'll detail the board in another thread, I think I've hijacked this one enough :D
              I'm making additional sensor boards in a hurry to send to dirty PCB and get them before lunar new year. When everything is sent I will upload to GitHub and post on openhardware.io. But it will need a few more weeks for me to receive and test the boards before before I advise you to order.
              K 1 Reply Last reply
              • Nca78N Nca78
                K
                K
                kted
                @Nca78 So, the capacitor is on the other side of the board, it just doesn't show in the photos. No problem with the SMD components, they are large enough if you are a bit careful.
                You are wasting precious time writing in the forums. Get back to work! :-)
                • H
                  H
                  hiddenuser
                  Hey I have followed https://www.mysensors.org/build/battery and removed the onboard LED and 3.3 VDC regulator. I have powered using VCC pin. Do I need to external power the nrf module ?
                  • H hiddenuser
                    K
                    K
                    kted
                    @SubodhChettri Since you have removed the regulator, you should power the mini with 3.3V.
                    This is provided either by the jmodule's LDO which is capable to power the NRF, or directly by the battery (2xAA).
                    If you are using batteries, you dont need the LDO, so you bridge the Vin& Vout, and the 3.3V that feed the Mini go also to to the NRF.
                    • Nca78N
                      Panels with "NModule" and sensor shields finally arrived :D
                      Cliff KarlssonC 1 Reply Last reply
                      • Nca78N Nca78
                        Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        @Nca78 is it possible to buy them somewhere?
                          @Cliff-Karlsson said in 💬 jModule:
                          I'm not sure it's a good idea to share the dirtypcb link yet:
                          • they are not tested
                          • I don't even have all the scripts ready
                          • they need a bit of documentation to be usable
                          I will do my best to test them and share on openhardware.io next week.
                          • julissesJ
                            julissesJ
                            julisses
                            jBoard2 arrived............jModule2 is coming
                            • D
                              dakipro
                              Great, what are the improvements over the v1?
                              julissesJ 1 Reply Last reply
                              • C cabat
                                @ted Hello! Can you share the Eagle file of your version of pcb? I mean this one: http://dirtypcbs.com/view.php?share=19651&accesskey=2e5e31a83bf6fe21510c3bc438e12df7
                                ted
                                wrote on last edited by ted
                                #70
                                @cabat said in 💬 jModule:
                                Sorry for the extreme late response. I've busy with work in the past half year. Hope you still find the attached file useful.
                                https://dl.dropboxusercontent.com/u/13998152/modified_jBoard-panalize_4x4_hole.brd
                                • T ted
                                  C
                                  C
                                  cabat
                                  @ted Big thanks!
                                  • D dakipro
                                    julissesJ
                                    julissesJ
                                    julisses
                                    @dakipro
                                    The improvements:
                                    • 2 build options
                                    • no SMD elements (AMS1117 replaced by LE33 - TO92 package)
                                    • smaller size: the jModule and the jBoard
                                    • output pins in a one row
                                    • Nca78N Nca78
                                      Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      @Nca78 Sorry for the nagging, but are you any closer to releasing it to dirtypcbs or similar?
                                      • julissesJ julisses
                                        @dakipro
                                        The improvements:
                                        • 2 build options
                                        ted
                                        #74
                                        @julisses
                                        Switching to TO92 elements is a great idea and will make soldering much easier to do. However, LE33 still has 0.5 mA supply current and will not be a good choice for battery powered sensors. The TO92 package will always be ON per spec sheet: http://www.st.com/content/ccc/resource/technical/document/datasheet/98/09/12/54/6e/d1/45/36/CD00000545.pdf/files/CD00000545.pdf/jcr:content/translations/en.CD00000545.pdf
                                        The modification I made previously used XC6206 regulator that only requires 1uA supply current. It works pretty well for my battery powered sensors. However, it does not offer a TO92 package. It will be great if someone can suggest an ultra-low supply current voltage regulator in TO92 package.
                                        AWIA 1 Reply Last reply
                                        • T ted
                                          @julisses
                                          AWIA
                                          AWIA
                                          AWI
                                          wrote on last edited by AWI
                                          #75
                                          @ted The lm-2936z could do the job (15 uA Q, 200mV drop-out ) or the mcp-1702 (2 uA Q, 525 mV drop-out). Both are significantly lower priced than the LE33 (at least where I get them ;-) )
