  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
    Tried to follow the history on the humidity file back in time on github.
    At some point (2.0 release) the example was switched from HumiditySensor.ino (using pin 3) to DhtTemperatureAndHumiditySensor.ino (pin 2) created by @mozzbozz.
    Not sure why the pin was switched, but you can run without the radio/IRQ-pin connection as long as not activating the MY_RX_MESSAGE_BUFFER_FEATURE.
    F
    F
    flopp
    @hek
    All other examples are using PIN 3. Wouldn't it be easier to use PIN 3 for all examples? Maybe we shall wait and see if mozzbozz know why he changed to PIN 2.
      wrote on last edited by hek
      #52
      Ok, updated the example on github and instructions on the page back to pin 3.
      • skywatchS
        skywatchS
        skywatch
        Hurrah! :)
        Now I can sleep at night again ;)
        Good job!
        F 1 Reply Last reply
          Haha, yeah, good to hear you will get a good nights sleep again.
          • skywatchS skywatch
            Hurrah! :)
            Good job!
            F
            F
            flopp
            @skywatch said:
            Hurrah! :)
            Good job!
            haha, me too :)
            • Pavel LarkinP
              Pavel LarkinP
              Pavel Larkin
              wrote on last edited by gohan
              #56
              Hello. Maybe someone could help :) hopefully..
              I have arduino1 with 1 DHT22, which is over arduinoGW connected to RSPi with latest domoticz.
              when i connect stuff up, after some time i see some strange childids, not related to this arduino1 in no way.
              Lots of unknown!, with V_TEMP values, with V_HUM values, even V_FORECAST, V_PRESSURE and etc. which arduino1 should not send (or no other arduino on my area).
              Illustration:
              <img href="http://www.lstudio.lt/wp-content/uploads/dht22problem.png">
              my code is quite simple (for ex only temperature is shown)
              #define CHILD_DESCR "TEMP3"
              #undef CHILD_ID
              #define CHILD_ID 31
              present(CHILD_ID, S_TEMP, CHILD_DESCR);
              delay(250) ;
              loop:
                temp3=dht3.readTemperature();
              if (temp3 >= 120) {temp3 = lasttemp3;}
              if (temp3 <= -50) {temp3 = lasttemp3;}
              MyMessage msg31(CHILD_ID,V_TEMP);
              send(msg31.set(temp3,1));
              so.. that is basically all
              • Pavel LarkinP Pavel Larkin
                Illustration:
                #undef CHILD_ID
                #define CHILD_ID 31
                delay(250) ;
                loop:
                F
                F
                flopp
                wrote on last edited by flopp
                #57
                @Pavel-Larkin
                I have also seen this, I noticed it last week. Some of my Nodes have those Unknown-child, but it is working correctly anyway.
                DZ 3.5877, MyS 1.5.1, RPi 2
                • GimlurG
                  GimlurG
                  Gimlur
                  i have a problem with this sketch.
                  After downloading DTH.h froom Mysensors Examples, i have this error :
                  DhtTemperatureAndHumiditySensor:85: error: 'getConfig' was not declared in this scope
                  Any Idea of my mistake ?...
                    It isn't your mistake, it's ours. The examples hasn't been updated correctly to reflect the most recent change in the api.
                    It should say getControllerConfig().isMetric
                    • johnecyJ
                      johnecyJ
                      johnecy
                      I have the dht22 sensor hooked up and working on a pro mini on pin 3 I get a normal temp reading but the humidity always stays at 1.0 does not read.
                      • johnecyJ johnecy
                        @johnecy https://forum.mysensors.org/topic/5978/temperature-and-humidity-dht22
                        • D
                          donhuan78p
                          Hello everybody,
                          hope, someone could help a newby :-)
                          I've installed the MQTT - GW and would use the Air/Humidity - sensor. But it doesn't work properly.
                          The Connection to the Gateway seems to be okay. But I get no Air/Humidity - Information.
                          The sensor does not measure anything.
                          I've tried to change the data - pin, I've tried the DHT11 and DHT22 - sensor. No choice.
                          I'm getting mad :-)
                          Thanks a lot.
                            Have you tried the basic arduino sketch that prints data to serial port?
                            • D
                              donhuan78p
                              thanks a lot for your answer.
                              Yes, I did. It produced the Messages as excepted.
                                So you'd better post your code so we can take a look at what is wrong with it.
                                • D
                                  donhuan78p
                                  ...sorry, Typo.
                                  As expected :-)
                                  • D
                                    donhuan78p
                                    #67
                                    ...no Problem:
                                     * Version 1.0: Henrik EKblad
                                     * sensor using a DHT11/DHT-22.
                                    // Enable debug prints
                                    //#define MY_RS485
                                    #define DHT_DATA_PIN 2
                                    #define SENSOR_TEMP_OFFSET 0
                                    static const uint64_t UPDATE_INTERVAL = 30000;
                                    #define CHILD_ID_HUM 0
                                    #define CHILD_ID_TEMP 1
                                    float lastTemp;
                                    float lastHum;
                                    uint8_t nNoUpdatesTemp;
                                    uint8_t nNoUpdatesHum;
                                    bool metric = true;
                                    DHT dht;
                                      Serial.println("Presentation");
                                      sendSketchInfo("TemperatureAndHumidity", "1.1");
                                      present(CHILD_ID_HUM, S_HUM);
                                      Serial.println("vor Presentation");
                                      Serial.println("loop Anfang");
                                      dht.readSensor(true);
                                      if (isnan(temperature)) {
                                        lastTemp = temperature;
                                        if (!metric) {
                                        // Reset no updates counter
                                        nNoUpdatesTemp = 0;
                                        #ifdef MY_DEBUG
                                        Serial.print("T: ");
                                        nNoUpdatesTemp++;
                                      if (isnan(humidity)) {
                                        lastHum = humidity;
                                        nNoUpdatesHum = 0;
                                       #ifdef MY_DEBUG
                                        Serial.print("H: ");
                                        Serial.println(humidity);
                                        nNoUpdatesHum++;
                                      sleep(UPDATE_INTERVAL);
                                    • Arnold ŠlepetisA
                                      Arnold ŠlepetisA
                                      Arnold Šlepetis
                                      I am using dht22 outside. Does any one know how to change to whole number not decimal. The temperature outside change a lot. Let say temp 20.2 changed to 20.4 and still sends to getaway . If I do "send(msgTemp.set(temperature, 0));" and still receive both times 20 and 20, and I want only if change to 21 or 19.
                                      • Arnold ŠlepetisA Arnold Šlepetis
                                        #69
                                        @Arnold-Šlepetis change
                                        float lastTemp;
                                        to
                                        signed int lastTemp;
                                        and
                                        to
                                        signed int temperature = dht.getTemperature() + 0.5; // Add 0.5 to get correct rounding
                                        and
                                        to
                                        temperature = dht.toFahrenheit(temperature) + 0.5;
                                        and
                                        to
                                        send(msgTemp.set(temperature));
                                        You might also have to handle the isnan test.
                                        Arnold ŠlepetisA 1 Reply Last reply
                                          float lastTemp;
                                          to
                                          and
                                          to
                                          and
                                          to
                                          and
                                          to
                                          Arnold ŠlepetisA
                                          Arnold ŠlepetisA
                                          Arnold Šlepetis
                                          @mfalkvidd Thanks. It works like a charm
