  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • skywatchS
    skywatchS
    skywatch
    Hurrah! :)
    Now I can sleep at night again ;)
    Good job!
    F 1 Reply Last reply
      Haha, yeah, good to hear you will get a good nights sleep again.
      • skywatchS skywatch
        Hurrah! :)
        Good job!
        F
        F
        flopp
        @skywatch said:
        Hurrah! :)
        Good job!
        haha, me too :)
        • Pavel LarkinP
          Pavel LarkinP
          Pavel Larkin
          wrote on last edited by gohan
          #56
          Hello. Maybe someone could help :) hopefully..
          I have arduino1 with 1 DHT22, which is over arduinoGW connected to RSPi with latest domoticz.
          when i connect stuff up, after some time i see some strange childids, not related to this arduino1 in no way.
          Lots of unknown!, with V_TEMP values, with V_HUM values, even V_FORECAST, V_PRESSURE and etc. which arduino1 should not send (or no other arduino on my area).
          Illustration:
          <img href="http://www.lstudio.lt/wp-content/uploads/dht22problem.png">
          my code is quite simple (for ex only temperature is shown)
          #define CHILD_DESCR "TEMP3"
          #undef CHILD_ID
          #define CHILD_ID 31
          present(CHILD_ID, S_TEMP, CHILD_DESCR);
          delay(250) ;
          loop:
            temp3=dht3.readTemperature();
          if (temp3 >= 120) {temp3 = lasttemp3;}
          if (temp3 <= -50) {temp3 = lasttemp3;}
          MyMessage msg31(CHILD_ID,V_TEMP);
          send(msg31.set(temp3,1));
          so.. that is basically all
          • Pavel LarkinP Pavel Larkin
            Illustration:
            #undef CHILD_ID
            #define CHILD_ID 31
            delay(250) ;
            loop:
            F
            F
            flopp
            wrote on last edited by flopp
            #57
            @Pavel-Larkin
            I have also seen this, I noticed it last week. Some of my Nodes have those Unknown-child, but it is working correctly anyway.
            DZ 3.5877, MyS 1.5.1, RPi 2
            • GimlurG
              GimlurG
              Gimlur
              i have a problem with this sketch.
              After downloading DTH.h froom Mysensors Examples, i have this error :
              DhtTemperatureAndHumiditySensor:85: error: 'getConfig' was not declared in this scope
              Any Idea of my mistake ?...
                It isn't your mistake, it's ours. The examples hasn't been updated correctly to reflect the most recent change in the api.
                It should say getControllerConfig().isMetric
                • johnecyJ
                  johnecyJ
                  johnecy
                  I have the dht22 sensor hooked up and working on a pro mini on pin 3 I get a normal temp reading but the humidity always stays at 1.0 does not read.
                  • johnecyJ johnecy
                    @johnecy https://forum.mysensors.org/topic/5978/temperature-and-humidity-dht22
                    • D
                      donhuan78p
                      Hello everybody,
                      hope, someone could help a newby :-)
                      I've installed the MQTT - GW and would use the Air/Humidity - sensor. But it doesn't work properly.
                      The Connection to the Gateway seems to be okay. But I get no Air/Humidity - Information.
                      The sensor does not measure anything.
                      I've tried to change the data - pin, I've tried the DHT11 and DHT22 - sensor. No choice.
                      I'm getting mad :-)
                      Thanks a lot.
                        Have you tried the basic arduino sketch that prints data to serial port?
                        • D
                          donhuan78p
                          thanks a lot for your answer.
                          Yes, I did. It produced the Messages as excepted.
                            So you'd better post your code so we can take a look at what is wrong with it.
                            • D
                              donhuan78p
                              ...sorry, Typo.
                              As expected :-)
                              • D
                                donhuan78p
                                #67
                                ...no Problem:
                                 * Version 1.0: Henrik EKblad
                                 * sensor using a DHT11/DHT-22.
                                // Enable debug prints
                                //#define MY_RS485
                                #define DHT_DATA_PIN 2
                                #define SENSOR_TEMP_OFFSET 0
                                static const uint64_t UPDATE_INTERVAL = 30000;
                                #define CHILD_ID_HUM 0
                                #define CHILD_ID_TEMP 1
                                float lastTemp;
                                float lastHum;
                                uint8_t nNoUpdatesTemp;
                                uint8_t nNoUpdatesHum;
                                bool metric = true;
                                DHT dht;
                                  Serial.println("Presentation");
                                  sendSketchInfo("TemperatureAndHumidity", "1.1");
                                  present(CHILD_ID_HUM, S_HUM);
                                  Serial.println("vor Presentation");
                                  Serial.println("loop Anfang");
                                  dht.readSensor(true);
                                  if (isnan(temperature)) {
                                    lastTemp = temperature;
                                    if (!metric) {
                                    // Reset no updates counter
                                    nNoUpdatesTemp = 0;
                                    #ifdef MY_DEBUG
                                    Serial.print("T: ");
                                    nNoUpdatesTemp++;
                                  if (isnan(humidity)) {
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                   #ifdef MY_DEBUG
                                    Serial.print("H: ");
                                    Serial.println(humidity);
                                    nNoUpdatesHum++;
                                  sleep(UPDATE_INTERVAL);
                                • Arnold ŠlepetisA
                                  Arnold ŠlepetisA
                                  Arnold Šlepetis
                                  I am using dht22 outside. Does any one know how to change to whole number not decimal. The temperature outside change a lot. Let say temp 20.2 changed to 20.4 and still sends to getaway . If I do "send(msgTemp.set(temperature, 0));" and still receive both times 20 and 20, and I want only if change to 21 or 19.
                                  • Arnold ŠlepetisA Arnold Šlepetis
                                    #69
                                    @Arnold-Šlepetis change
                                    float lastTemp;
                                    to
                                    signed int lastTemp;
                                    and
                                    to
                                    signed int temperature = dht.getTemperature() + 0.5; // Add 0.5 to get correct rounding
                                    and
                                    to
                                    temperature = dht.toFahrenheit(temperature) + 0.5;
                                    and
                                    to
                                    send(msgTemp.set(temperature));
                                    You might also have to handle the isnan test.
                                    Arnold ŠlepetisA 1 Reply Last reply
                                      float lastTemp;
                                      to
                                      and
                                      to
                                      and
                                      to
                                      and
                                      to
                                      Arnold ŠlepetisA
                                      Arnold ŠlepetisA
                                      Arnold Šlepetis
                                      @mfalkvidd Thanks. It works like a charm
                                      • J
                                        J
                                        jwosnick
                                        wrote on last edited by jwosnick
                                        #71
                                        I've made a bit of an unusual observation in relationship to this script. I am running a fairly stripped-down version of it, but with the "standard" (not MySensors-customized) DHT library and its associated functions.
                                        Here is the code:
                                        //#define MY_RS485
                                        #define MY_NODE_ID 47
                                        #define DHT_DATA_PIN 5
                                        static const uint64_t UPDATE_INTERVAL = 10000;
                                        bool metric = true;
                                        DHT dht(DHT_DATA_PIN, DHT22);
                                        float temperature;
                                        float humidity;
                                          delay(100);
                                          temperature = dht.readTemperature();
                                            send(msgTemp.set(temperature,0));
                                            #ifdef MY_DEBUG
                                          humidity = dht.readHumidity();
                                            Serial.println("Failed reading humidity from DHT!");
                                            send(msgHum.set(humidity,1));
                                            #ifdef MY_DEBUG
                                        I find that if I leave the last line as
                                        then the sensor node ends up sending the same temperature and humidity values, over and over again, even if the actual humidity and temperature change.
                                        However, if I change the last line to
                                        delay(UPDATE_INTERVAL);
                                        then everything works as expected.
                                        This is with known good DHT22 units, so I suspect there is something funny about the sleep() function and the operation of the standard (not customized) DHT library.
                                        It took a lot of poking around to discover this, but is this in fact the reason why the MySensors customized DHT library is required for this script? Is that library necessary to make sleep() and DHT temperature measurements play nicely together?
                                          What libraries versions are you using?
