  3. Gas Meter Reading Using a Magnetometer
77 Posts 10 Posters 40.2k Views 12 Watching
    Sorry for the question, but why would you need a magnetometer to have better resolution in the measurements when you only need to count pulses? Given of course that the reed switch provides accurate readings, because if it doesn't then I understand why to use the magnetometer
    dpcrD
    dpcrD
    dpcr
    @gohan I had to use a magnetometer because my meter did not have a magnet in it. I tried a reed switch but it never actuated and my meter is outside. So I was stuck using a magnetometer which I mounted in a water proof plastic box. The issue I had was getting the sine wave to create a pulse that was usable for MySensors. I did look at using an inverse sine, or as someone else mentioned, use an exponential moving average of the data but they both failed. When the gas stops flowing, a pilot light as an example as seen in the attached picture, there is little to no gas flowing so the angle doesn't change much. It looks like no gas is flowing when it actually is. I decided to go with dividing the wave or meter movement into separate divisions to create a more accurate way of measuring the gas flow in all flow situations.
    I haven't had a chance to test the accuracy of my math against the gas meter but I will at some point. The issue I'm currently having is that the bellows inside of the meter that the magnetometer is reading do not move at the same rate at all times. This causes the FLOW output to change when I know the gas is flowing at a steady rate. The VOLUME doesn't seem to be effected too much. So what I did was to take a moving average of the last three FLOW readings. This helps a little.
    The hardware and ideas were done by me but the coding was done by my 24 year old son. I always enjoy a challenge. Please feel free to comment.
      Ok, now it makes sense. If you plot the data with the pilot using the gas, don't you still see a sine wave but with, of course, a longer period?
      YveauxY dpcrD 2 Replies Last reply
        @gohan I assume you do. By interpreting the sine and thereby increasing the resolution you might be able to see there's gas flowing, even if the rate is very low.
          good luck with the math then, I am calling myself out! :sweat_smile:
          Back in high school I was quite good at math, but now... :D
            dpcrD
            dpcrD
            dpcr
            @gohan Yes you do, but what about the times when there is gas flowing. If I remember correctly there was about 20 or 25 minutes for full sine wave when only the pilot was running. That SEND_FREQUENCY (1500000) was too large when the gas was actually flowing to get an accurate measurement. I just wanted to get an accurate reading of the gas flow at all flow rates. Am I missing something?
            Here are some screenshots from Domoticz for the past week:
            1_1486917738604_Screenshot from 2017-02-12 11-40-09.png 0_1486917738603_Screenshot from 2017-02-12 11-40-26.png )
              ThomasDrT
              ThomasDrT
              ThomasDr
              @gohan Hello,
              My thought is simpler.
              The original sensor is too expensive.
              With a Reedcontact I must find the right position.
              The magnetometer I could simply attach somewhere in the proximity.
              regards
              ThomasD
              gohanG 1 Reply Last reply
              • ThomasDrT ThomasDr
                @gohan Hello,
                regards
                ThomasD
                @ThomasDr
                I see your point, but you pay the simplicity with a more complex coding ;-)
                  here my sketch to form a puls:
                    This is a library example for the HMC5883 magnentometer/compass
                    Designed specifically to work with the Adafruit HMC5883 Breakout
                    http://www.adafruit.com/products/1746
                    *** You will also need to install the Adafruit_Sensor library! ***
                    These displays use I2C to communicate, 2 pins are required to interface.
                    Adafruit invests time and resources providing this open source code,
                    please support Adafruit andopen-source hardware by purchasing products
                    from Adafruit!
                    Written by Kevin Townsend for Adafruit Industries with some heading example from
                    Love Electronics (loveelectronics.co.uk)
                   This program is free software: you can redistribute it and/or modify
                   it under the terms of the version 3 GNU General Public License as
                   published by the Free Software Foundation.
                   This program is distributed in the hope that it will be useful,
                   but WITHOUT ANY WARRANTY; without even the implied warranty of
                   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                   GNU General Public License for more details.
                   You should have received a copy of the GNU General Public License
                   along with this program.  If not, see <http://www.gnu.org/licenses/>.
                  #include <Adafruit_Sensor.h>
                  #include <Adafruit_HMC5883_U.h>
                  /* Assign a unique ID to this sensor at the same time */
                  Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
                  unsigned long t = 0;
                  unsigned long counter = 0;
                  bool trigger = 0;
                  float out = 0.0;
                  void setup(void)
                    //Serial.println("HMC5883 Magnetometer Test"); Serial.println("");
                    /* Initialise the sensor */
                    if(!mag.begin())
                      /* There was a problem detecting the HMC5883 ... check your connections */
                      Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
                      while(1);
                    /* Display some basic information on this sensor */
                    // displaySensorDetails();
                  void loop(void)
                    /* Get a new sensor event */
                    sensors_event_t event;
                    mag.getEvent(&event);
                    /* Display the results (magnetic vector values are in micro-Tesla (uT)) */
                    out = event.magnetic.y;
                    if (out > -0.7 && trigger == 0)
                    trigger = 1;
                    Serial.println(trigger);
                    if (out < -110.5 && trigger == 1)
                    trigger = 0;
                    counter++;
                    if (millis() > (t+5000))
                     t = millis();
                    delay(250);
                  And here the Output, 1 Puls is 0.001 m3, first at slow flow and then with my max.
                  regards
                  ThomasD
                  dpcrD
                  dpcrD
                  dpcr
                  @ThomasDr Sorry not to get back to you when I saw your post, your project looks interesting. Does the HMC5983 magnetometer output something similar to the HMC5883L? I just used the HMC5883L magnetometer because I found it useful, I didn't run across it during my research.
                  • dpcrD
                    dpcrD
                    dpcr
                    Ran into a problem. The magnetism value changes when the outside air temperature changes which causes many incorrect readings. So my initial sketch that finds the TOP and BOTTOM of the wave is having problems so I'm in the process of trying to find another way to get some useful data out of the magnetometer. Any ideas?
                      wrote on last edited by gohan
                      #22
                      If you find a correlation between temperature and change of magnetic field, maybe you could add a thermistore and use it to compute a correction coefficient.
                      Or maybe even a second magnetometer with a fixed magnet to use as reference 🤔
                      dpcrD 1 Reply Last reply
                        dpcrD
                        dpcrD
                        dpcr
                        @gohan Thanks, that was what I thought initially but the changes in the magnetic forces were all over the place but did seem to coincide with the outdoor temperature. They were relatively small in comparison to the total but enough the cause problems. It was almost like the meter itself was doing this?? Since we rely so heavily on the Top and Bottom magnetic readings to not only find the top and the bottom of the "wave" but to also calculate the intervals, we made some updates to the sketch. It now calculates a new top and bottom on its own. It has been running for 12 hours and so far so good. For now we are writing the top and bottom values to EEPROM, but once I get some memory we'll store the values there.
                        I did have a question that I can't seem to find a answer to - what length I2C bus can be used with out pull up resistors? The current bus being used is about 2 meters without pull up resistors and there doesn't seem to be too much noise compared to when it was only several inches . I would like to make it a little longer if possible.
                          Have you noticed if the magnetic forces are really temperature affected or if it is the actual rotating counter that could have other magnets (like one each group of colored digits???) ?
                          About the I2C bus I think I read it could reach 5-6 meters (of course depending on external factors)
                            dpcrD
                            dpcrD
                            dpcr
                            @gohan We have had large outside temperature changes around here in the last month. Two weeks ago it was 20 DegF now it is 53 DegF. The bottom magnetic reading when it was 20 degrees outside was around 380 and things seemed to work OK. Now the bottom is 495 and problems started when it warmed up. The top doesn't seem to change as much. Not sure if this has anything to do with it, but our meter (Rockwell or Sensus does have what they call a "temperature compensation element". I assume it adjusts itself to make the meter more accurate due to temperature changes. Thanks for the info on the I2C bus.
                              markcame
                              Dear All,
                              I've tried to make a gas meter sensor using the magnetometer because I've started only few weeks ago approaching mysensor setup so be patient with me...
                              I've now two problems , the first is regarding the accuracy of the measure, it seems that after I've count the number of cycles Vs the gas measured of the meter and found the value of vpp (I've used the scketch posted by dpcr) afther a while the values measured drift from the real
                              The second problem is that I'm not able to measure the flow... it gave me values very high (1249225088.00 l/min)
                              Someone have ideas what's happen ?
                              Thanks a lot
                              • M markcame
                                Dear All,
                                Thanks a lot
                                dpcrD
                                dpcrD
                                dpcr
                                @markcame Updated sketch:
                                It sounds like your pulse count is not correct, this could probably be due to your top and bottom values being incorrect.
                                One hardware change was to add some memory because the EEPROM can only handle so many cycles. I used Adafruit I2C FRAM but you can use whatever you like. This sketch uses Adafruit I2C FRAM, what I had.
                                There have been many changes since the last sketch. We found that the magnetism values were changing due to changing outside air temperatures (the top and bottom values are very important). When the arduino is turned on for the very first time (top and bottom values are not in memory) it will run for a period of 2 minutes where it will find the top and bottom values, so the gas has to be flowing during that time (turn the stove on). It then stores those values in memory. Going forward we calculate the top and bottom values on the fly to keep them updated as the magnetism values change with the outside air temperature. If not it would go through a 'auto program' every time there was a reset. The gas has to be flowing during the 'auto program' and if its summer and no gas is flowing your top and bottom values will be incorrect. During testing I powered the arduino with the serial connector to get the serial data. It is currently powered with a separate 3.3 v wall wart.
                                We removed several bugs and updated the way it calculates pulses and put a smoothing on the FLOW output.The smoothing help keep the FLOW values going down to 0 but doesn't stop it at all times.
                                I uploaded this to the Arduino to first verify the correct vector. I could have use a total vector calculation (square root of x2+y2+z2) but this would have just amplified some of the noise. Using a chosen vector worked fine but took a little more work. After finding the correct vector (sorry - first build and mount the magnetometer on the meter), download the sketch below.
                                /*This version is different in several ways.
                                 * first is is using some memory (Adafruit I2C FRAM) memory to store the top and bottom. This is used to keep the top and bottom
                                 * values after a restart. I guess we could have put them on the controller but can't remember why we didn't.
                                 * second it will only calculate the top and bottom if the values are not in memory.
                                 * third it auto calculates the top and bottom values as it is running.
                                 * the only settings that should be changed are vpp, SEND_FREQUENCY, and metric. However I am currently using
                                 * Domoticz as my controller and it doesn't seem to accept English units well so for not I'm using Metric.
                                //#define MY_DEBUG_VERBOSE
                                #include <Wire.h>                       //I2C communications library
                                #include <Adafruit_FRAM_I2C.h>          //Adafruit FRAM memory library
                                #define CHILD_ID 1                      //ID of the sensor child
                                #define SLEEP_MODE false                //prevent sensor from sleeping
                                #define address 0x1E                    //0011110b, I2C 7bit address of HMC5883 magnetometer
                                int top = 0;                            //highest magnetic field registered from meter (Ga)Initialize low if using autoDetectMaxMin
                                int bottom = 0;                         //lowest magnetic field registered from meter (Ga) Initialize high if using autoDetectMaxMin
                                int tol = 50;
                                unsigned long SEND_FREQUENCY = 30000;   // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                                bool metric = true;                     //sets units to Metric or English TODO: move to void setup()
                                bool pcReceived = false;                //whether or not the gw has sent us a pulse count
                                bool autoDetect = false;                //true if the program is auto detecting Top and Bottom
                                bool rising = true;                     //whether or not a pulse has been triggered
                                bool safe = false;                      //whether or not it is safe to switch directions
                                unsigned long pulsecount = 0;           //total number of pulses measured ever
                                unsigned long oldPulseCount = 0;        //old total
                                double vpp = metric ? 0.160891193181 : 0.00568124219857;//Volume of gas per pulse
                                unsigned long lastSend = 0;             //time since last transmission - msec
                                double volume = 0;                      //Cumulative amount of gas measured
                                const int len = 3;                      //number of flow rate measurements to save
                                double flow [len];                      //array of previous gas flow rate measurements
                                double avgFlow = 0;                     //average of all elements in flow array
                                double oldAvgFlow = 0;                  //previous average flow
                                int y = 0;                              //magnetic field reading
                                int oldy = 0;                           //previous magnetic field reading
                                int newTop = -9000;                         //potential new Top
                                int newBottom = 9000;                  //potential new Bottom
                                int totDividers = 10;                   //Number of dividers
                                int increment = 0;                      //space b/w dividers
                                int counter = 0;                        //used to count pulses over periods longer than SEND_FREQUENCY
                                int topAddr = 0;                        //address of TOP in FRAM
                                int bottomAddr = topAddr + 2;           //address of BOTTOM in FRAM
                                MyMessage flowMsg(CHILD_ID,V_FLOW);
                                MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                                MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                                Adafruit_FRAM_I2C fram = Adafruit_FRAM_I2C();
                                void setup(){
                                  //Initialize Serial, I2C, and FRAM communications
                                  Serial.begin(9600);
                                  Wire.begin();
                                  fram.begin();
                                  request(CHILD_ID, V_VAR1);
                                  //Put the HMC5883 IC into the correct operating mode
                                  Wire.beginTransmission(address); //open communication with HMC5883
                                  Wire.write(0x02); //select mode register
                                  Wire.write(0x00); //continuous measurement mode
                                  Wire.endTransmission();
                                  //get Top and Bottom from FRAM. addresses are hard-coded seeing as there are only 2
                                  newTop = readInt(topAddr);
                                  newBottom = readInt(bottomAddr);
                                  updateBounds();
                                  //WARNING: MAKE SURE GAS IS RUNNING ON FIRST RUNNING OF THIS PROGRAM!!!
                                  if(top == 0 && bottom == 0){
                                    autoDetect = true;
                                    newTop = -9000;
                                    newBottom = 9000;
                                    //determine max and min magnetic field strength over a few minutes
                                    Serial.println("FRAM has been cleared. Auto-detecting max and min magnetic field reading.");
                                    Serial.println("WARNING: MAKE SURE GAS IS RUNNING!!");
                                    lastSend = millis();
                                    while(millis() - lastSend < 120000){
                                      y = readMag();
                                      detectMaxMin();
                                      //display details
                                      Serial.print("y: ");
                                      Serial.print(y);
                                      Serial.print("  Top: ");
                                      Serial.print(newTop);
                                      Serial.print("  Bottom: ");
                                      Serial.print(newBottom);
                                      unsigned long remainingTime = 120000 + lastSend - millis();
                                      Serial.print("  Time remaining: ");
                                      Serial.print(remainingTime / 60000);
                                      Serial.print(":");
                                      remainingTime = (remainingTime % 60000) / 1000;
                                      if(remainingTime >= 10){
                                        Serial.println(remainingTime);
                                      else{
                                        Serial.print("0");
                                    updateBounds();
                                    autoDetect = false;
                                  y = readMag();
                                  oldy = readMag();
                                  while(abs(y - oldy) < increment / 2){ //wait until difference b/w y and oldy is greater than half an increment
                                    y = readMag();
                                  rising = (y > oldy);
                                  Serial.println(rising ? "Magnetic field is rising" : "Magnetic field is falling");
                                    sendSketchInfo("Gas Meter", "0.6 (2/24/17)");
                                    // Register this device as Gas sensor
                                    present(CHILD_ID, S_GAS);
                                void loop(){
                                  if (!pcReceived) {
                                    //Last Pulsecount not yet received from controller, request it again
                                    return;
                                  //detecting magnetic pulses - variable boundary method
                                  while(millis() - lastSend < SEND_FREQUENCY){
                                    //check if the signal has significantly increased/decreased
                                    if(abs(oldy - y) > increment){
                                      pulsecount ++;
                                      //increment or decrement oldy by one increment based on direction
                                      oldy += rising ? increment : -1 * increment;
                                      safe = false;             //reset safe now that oldy has updated
                                    //check if the signal has recently switched directions
                                    else if(safe){                  //first make sure y has moved a significant distance from oldy
                                      if((rising && y <= oldy) || (!rising && y >= oldy)){
                                        pulsecount ++;              //add one extra pulse
                                        rising = !rising;           //update direction
                                        safe = false;
                                    //take another reading
                                    y = readMag();
                                    //check if y has moved a significant distance from oldy
                                    if(abs(y - oldy) > tol / 2){
                                      safe = true;
                                    //update newTop and newBottom
                                    detectMaxMin();
                                  //shift all flow array elements to the right by 1, ignore last element
                                  for(int idx = len - 1; idx > 0; idx--){
                                    flow[idx] = flow[idx - 1];
                                  //calculate newest flow reading and store it as first element in flow array
                                  flow[0] = (double)(pulsecount - oldPulseCount) * (double)vpp * 60000.0 / (double)SEND_FREQUENCY;
                                  //display flow array state
                                  Serial.print("Flow Array State: [");
                                  for(int idx = 0; idx < len - 1; idx++){
                                    Serial.print(flow[idx]);
                                    Serial.print("|");
                                  Serial.print(flow[len - 1]);
                                  Serial.println("]");
                                  //calculate average flow
                                  avgFlow = 0;                                //reset avgFlow
                                  for(int idx = 0; idx < len; idx++){         //calculate weighted sum of all elements in flow array
                                    avgFlow += (flow[idx] * (len - idx));
                                  avgFlow /= (len * (len + 1) / 2);           //divide by triangle number of elements to get linear weighted average
                                  Serial.print("Average flow: ");             //display average flow
                                  Serial.println(avgFlow);
                                  //send flow message if avgFlow has changed
                                  if(avgFlow != oldAvgFlow){
                                    oldAvgFlow = avgFlow;
                                    send(flowMsg.set(avgFlow, 2));
                                  //send updated cumulative pulse count and volume data, if necessary
                                  if(pulsecount != oldPulseCount){
                                    //calculate volume
                                    volume = (double)pulsecount * (double)vpp / (metric ? 1000.0 : 1);
                                    //send pulse count and volume data to gw
                                    send(lastCounterMsg.set(pulsecount));
                                    send(volumeMsg.set(volume, 3));
                                    counter += (pulsecount - oldPulseCount);      //update counter
                                    if(counter >= ((totDividers + 1) * 2)){
                                      updateBounds();                 //update bounds if at least 1 cycle has been read
                                      counter = 0;                    //reset counter
                                    oldPulseCount = pulsecount;              //update old total
                                  if (message.type==V_VAR1) {
                                    unsigned long gwPulseCount=message.getULong();
                                    pulsecount = gwPulseCount;
                                    Serial.print("Received last pulse count from gw:");
                                    Serial.println(pulsecount);
                                    pcReceived = true;
                                    //set magnetic field starting point
                                    oldy = readMag();
                                    y = readMag();
                                void updateBounds(){
                                  if(((top + tol) != newTop) && ((bottom - tol) != newBottom)){   //check if anything has actually changed
                                    //lock in Top and Bottom
                                    top = newTop - tol;
                                    bottom = newBottom + tol;
                                    //recalculate increment to match new top and bottom
                                    increment = (top - bottom) / totDividers;
                                    //reset newTop and newBottom
                                    newTop = -9000;
                                    newBottom = 9000;
                                    //store updated Top and Bottom in FRAM
                                    writeInt(topAddr,top);
                                    writeInt(bottomAddr,bottom);
                                    newTop = -9000;
                                    newBottom = 9000;
                                    //display new bounds
                                    Serial.println("NEW BOUNDARIES SET:");
                                    Serial.print("Top = ");
                                    Serial.println(top);
                                    Serial.print("Bottom = ");
                                    Serial.println(bottom);
                                    Serial.print("Increment = ");
                                    Serial.println(increment);
                                void detectMaxMin(){
                                  if(y > newTop){
                                        newTop = y;                    //update newTop if new max has been detected
                                  else if(y < newBottom){
                                    newBottom = y;                     //update newBottom if new min has been detected
                                void writeInt(int addr, int val){       //write an int value to memory
                                  byte b = highByte(val);
                                  fram.write8(addr,b);
                                  b = lowByte(val);
                                  fram.write8(addr + 1,b);
                                int readInt(int addr){                  //read an int value from memory
                                  int result = 0;
                                  result += (int)fram.read8(addr);
                                  result = result << 8;
                                  result += (int)fram.read8(addr + 1);
                                  return result;
                                int readMag(){
                                  int x = 0, z = 0;
                                  //Tell the HMC5883 where to begin reading data
                                  Wire.write(0x03); //select register 3, X MSB register - was called Wire.send but the compiler had an error and said to rename to to Wire.write
                                  //Read data from each axis, 2 registers per axis
                                  Wire.requestFrom(address, 6);
                                  if(6<=Wire.available()){
                                    x = Wire.read()<<8; //X msb
                                    x |= Wire.read(); //X lsb
                                    z = Wire.read()<<8; //Z msb
                                    z |= Wire.read(); //Z lsb
                                    y = Wire.read()<<8; //Y msb
                                    y |= Wire.read(); //Y lsb
                                  if(!autoDetect){
                                    //show real-time magnetic field, pulse count, and pulse count total
                                    Serial.print(y);
                                    Serial.print(rising ? "  Rising, " : "  Falling, ");
                                    Serial.print("next pulse at: ");
                                    Serial.print(rising ? oldy + increment : oldy - increment);
                                    Serial.print("  Current Number of Pulses: ");
                                    Serial.print(pulsecount - oldPulseCount);
                                    Serial.print("  Last Total Pulse Count Sent to GW: ");
                                    Serial.println(oldPulseCount);
                                  return y;
                                I still have not verified the vpp with the meter but I know it's close. When the water heater is on it Domoticz says I'm flowing enough gas for 30,500 BTU/H. The water heater has an input rating of 28,000 BTU/H.
                                Hope this helps, please let me know if you have any questions. I will try to add some pics.
                                • dpcrD dpcr
                                  int tol = 50;
                                  void setup(){
                                    Serial.begin(9600);
                                    Wire.begin();
                                    fram.begin();
                                    updateBounds();
                                      autoDetect = true;
                                      newTop = -9000;
                                      newBottom = 9000;
                                        y = readMag();
                                        detectMaxMin();
                                        //display details
                                        Serial.print(y);
                                        Serial.print(":");
                                        else{
                                          Serial.print("0");
                                      updateBounds();
                                      autoDetect = false;
                                    y = readMag();
                                    oldy = readMag();
                                      y = readMag();
                                  void loop(){
                                    if (!pcReceived) {
                                      return;
                                        pulsecount ++;
                                          safe = false;
                                      y = readMag();
                                        safe = true;
                                      detectMaxMin();
                                      Serial.print("|");
                                      //calculate volume
                                      pcReceived = true;
                                      oldy = readMag();
                                      y = readMag();
                                      top = newTop - tol;
                                      newTop = -9000;
                                      newBottom = 9000;
                                      newTop = -9000;
                                      newBottom = 9000;
                                    if(y > newTop){
                                    b = lowByte(val);
                                    int result = 0;
                                    return result;
                                  int readMag(){
                                    int x = 0, z = 0;
                                    if(!autoDetect){
                                      Serial.print(y);
                                    return y;
                                  markcame
                                  wrote on last edited by markcame
                                  #28
                                  @dpcr I've tried the sketch but seems something is wrong, I've modified it for using my controller to store the top and bottom values and this function very well I'm able to check on the serial that the values are correctly retrieved and stored, but during the running after some cycles start counting pulse at every reading of magnetic field
                                  M dpcrD 2 Replies Last reply
                                  • M markcame
                                    markcame
                                    I've try to analyze the program on the old sketch everything are good except the flow rate, I've found an error when you perform the shift of the element on an index this is the reason because the number reported wrong to the gateway.
                                    I want to use the new sketch but i have two question, the first is that i didn't understand the pulse count
                                         pulsecount ++;
                                         //increment or decrement oldy by oInsert Code Herene increment based on direction
                                           safe = false;
                                       y = readMag();Insert Code Here
                                       if(abs(y - oldy) > tol / 2){Insert Code Here
                                         safe = true;Insert Code Here
                                       detectMaxMin();
                                    and the second is about the initialization of variables retrieved from the FRAM , i i have understand to start the "calibration" you need to put 50 and -50 on the memory otherwise the right condition was not triggered right ?
                                    i didn't use the FRAM but I've coded to retrieve form the controller
                                     //get Top and Bottom from controller***********************
                                     Serial.println("Ask for top value @ controller");
                                     //Get Last top
                                     request(CHILD_ID, V_VAR2);
                                     Serial.println("Ask for bottom value @ controller");
                                     //Get Last bottom
                                     request(CHILD_ID, V_VAR3);
                                     wait(2000, 2, V_VAR1);
                                     wait(2000, 2, V_VAR2);
                                     wait(2000, 2, V_VAR3);
                                     Serial.println("Variables Succesfully Retrived from GW");
                                    • M markcame
                                      dpcrD
                                      dpcrD
                                      dpcr
                                      @markcame Not sure if I understand you. It still sounds like your not finding your top and bottom values. It works and still is working on my set up. The reason the top and bottom values are so important is the sketch takes those values and divides the difference into sections (totDividers). Those calculated values must be in the range of what the magnetometer is reading. If they don't the pulse counts will be all over the place or none at all. What are your top and bottom values and what are you top and bottom values received from the magnetometer?
                                      • dpcrD dpcr
                                        markcame
                                        @dpcr They find corect top and bottom, and start to pulse but after first recalculation of bounds they statrs to count a pulse for every readings.
                                        • M markcame
                                          dpcrD
                                          dpcrD
                                          dpcr
                                          @markcame what is the "next pulse at" reading? This happened to me as well when I was testing it but we changed a few this and it worked OK.
