  3. Gas Meter Reading Using a Magnetometer
77 Posts 10 Posters 40.3k Views 12 Watching
    good luck with the math then, I am calling myself out! :sweat_smile:
    Back in high school I was quite good at math, but now... :D
      Ok, now it makes sense. If you plot the data with the pilot using the gas, don't you still see a sine wave but with, of course, a longer period?
      dpcrD
      dpcrD
      dpcr
      @gohan Yes you do, but what about the times when there is gas flowing. If I remember correctly there was about 20 or 25 minutes for full sine wave when only the pilot was running. That SEND_FREQUENCY (1500000) was too large when the gas was actually flowing to get an accurate measurement. I just wanted to get an accurate reading of the gas flow at all flow rates. Am I missing something?
      Here are some screenshots from Domoticz for the past week:
      1_1486917738604_Screenshot from 2017-02-12 11-40-09.png 0_1486917738603_Screenshot from 2017-02-12 11-40-26.png )
        Sorry for the question, but why would you need a magnetometer to have better resolution in the measurements when you only need to count pulses? Given of course that the reed switch provides accurate readings, because if it doesn't then I understand why to use the magnetometer
        ThomasDrT
        ThomasDrT
        ThomasDr
        @gohan Hello,
        My thought is simpler.
        The original sensor is too expensive.
        With a Reedcontact I must find the right position.
        The magnetometer I could simply attach somewhere in the proximity.
        regards
        ThomasD
        gohanG 1 Reply Last reply
        • ThomasDrT ThomasDr
          @gohan Hello,
          regards
          ThomasD
          @ThomasDr
          I see your point, but you pay the simplicity with a more complex coding ;-)
            here my sketch to form a puls:
              This is a library example for the HMC5883 magnentometer/compass
              Designed specifically to work with the Adafruit HMC5883 Breakout
              http://www.adafruit.com/products/1746
              *** You will also need to install the Adafruit_Sensor library! ***
              These displays use I2C to communicate, 2 pins are required to interface.
              Adafruit invests time and resources providing this open source code,
              please support Adafruit andopen-source hardware by purchasing products
              from Adafruit!
              Written by Kevin Townsend for Adafruit Industries with some heading example from
              Love Electronics (loveelectronics.co.uk)
             This program is free software: you can redistribute it and/or modify
             it under the terms of the version 3 GNU General Public License as
             published by the Free Software Foundation.
             This program is distributed in the hope that it will be useful,
             but WITHOUT ANY WARRANTY; without even the implied warranty of
             MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
             GNU General Public License for more details.
             You should have received a copy of the GNU General Public License
             along with this program.  If not, see <http://www.gnu.org/licenses/>.
            #include <Adafruit_Sensor.h>
            #include <Adafruit_HMC5883_U.h>
            /* Assign a unique ID to this sensor at the same time */
            Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
            unsigned long t = 0;
            unsigned long counter = 0;
            bool trigger = 0;
            float out = 0.0;
            void setup(void)
              //Serial.println("HMC5883 Magnetometer Test"); Serial.println("");
              /* Initialise the sensor */
              if(!mag.begin())
                /* There was a problem detecting the HMC5883 ... check your connections */
                Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
                while(1);
              /* Display some basic information on this sensor */
              // displaySensorDetails();
            void loop(void)
              /* Get a new sensor event */
              sensors_event_t event;
              mag.getEvent(&event);
              /* Display the results (magnetic vector values are in micro-Tesla (uT)) */
              out = event.magnetic.y;
              if (out > -0.7 && trigger == 0)
              trigger = 1;
              Serial.println(trigger);
              if (out < -110.5 && trigger == 1)
              trigger = 0;
              counter++;
              if (millis() > (t+5000))
               t = millis();
              delay(250);
            And here the Output, 1 Puls is 0.001 m3, first at slow flow and then with my max.
            regards
            ThomasD
            dpcrD
            dpcrD
            dpcr
            @ThomasDr Sorry not to get back to you when I saw your post, your project looks interesting. Does the HMC5983 magnetometer output something similar to the HMC5883L? I just used the HMC5883L magnetometer because I found it useful, I didn't run across it during my research.
            • dpcrD
              dpcrD
              dpcr
              Ran into a problem. The magnetism value changes when the outside air temperature changes which causes many incorrect readings. So my initial sketch that finds the TOP and BOTTOM of the wave is having problems so I'm in the process of trying to find another way to get some useful data out of the magnetometer. Any ideas?
                wrote on last edited by gohan
                #22
                If you find a correlation between temperature and change of magnetic field, maybe you could add a thermistore and use it to compute a correction coefficient.
                Or maybe even a second magnetometer with a fixed magnet to use as reference 🤔
                dpcrD 1 Reply Last reply
                  dpcrD
                  dpcrD
                  dpcr
                  @gohan Thanks, that was what I thought initially but the changes in the magnetic forces were all over the place but did seem to coincide with the outdoor temperature. They were relatively small in comparison to the total but enough the cause problems. It was almost like the meter itself was doing this?? Since we rely so heavily on the Top and Bottom magnetic readings to not only find the top and the bottom of the "wave" but to also calculate the intervals, we made some updates to the sketch. It now calculates a new top and bottom on its own. It has been running for 12 hours and so far so good. For now we are writing the top and bottom values to EEPROM, but once I get some memory we'll store the values there.
                  I did have a question that I can't seem to find a answer to - what length I2C bus can be used with out pull up resistors? The current bus being used is about 2 meters without pull up resistors and there doesn't seem to be too much noise compared to when it was only several inches . I would like to make it a little longer if possible.
                    Have you noticed if the magnetic forces are really temperature affected or if it is the actual rotating counter that could have other magnets (like one each group of colored digits???) ?
                    About the I2C bus I think I read it could reach 5-6 meters (of course depending on external factors)
                      dpcrD
                      dpcrD
                      dpcr
                      @gohan We have had large outside temperature changes around here in the last month. Two weeks ago it was 20 DegF now it is 53 DegF. The bottom magnetic reading when it was 20 degrees outside was around 380 and things seemed to work OK. Now the bottom is 495 and problems started when it warmed up. The top doesn't seem to change as much. Not sure if this has anything to do with it, but our meter (Rockwell or Sensus does have what they call a "temperature compensation element". I assume it adjusts itself to make the meter more accurate due to temperature changes. Thanks for the info on the I2C bus.
                        markcame
                        Dear All,
                        I've tried to make a gas meter sensor using the magnetometer because I've started only few weeks ago approaching mysensor setup so be patient with me...
                        I've now two problems , the first is regarding the accuracy of the measure, it seems that after I've count the number of cycles Vs the gas measured of the meter and found the value of vpp (I've used the scketch posted by dpcr) afther a while the values measured drift from the real
                        The second problem is that I'm not able to measure the flow... it gave me values very high (1249225088.00 l/min)
                        Someone have ideas what's happen ?
                        Thanks a lot
                        • M markcame
                          Dear All,
                          Thanks a lot
                          dpcrD
                          dpcrD
                          dpcr
                          @markcame Updated sketch:
                          It sounds like your pulse count is not correct, this could probably be due to your top and bottom values being incorrect.
                          One hardware change was to add some memory because the EEPROM can only handle so many cycles. I used Adafruit I2C FRAM but you can use whatever you like. This sketch uses Adafruit I2C FRAM, what I had.
                          There have been many changes since the last sketch. We found that the magnetism values were changing due to changing outside air temperatures (the top and bottom values are very important). When the arduino is turned on for the very first time (top and bottom values are not in memory) it will run for a period of 2 minutes where it will find the top and bottom values, so the gas has to be flowing during that time (turn the stove on). It then stores those values in memory. Going forward we calculate the top and bottom values on the fly to keep them updated as the magnetism values change with the outside air temperature. If not it would go through a 'auto program' every time there was a reset. The gas has to be flowing during the 'auto program' and if its summer and no gas is flowing your top and bottom values will be incorrect. During testing I powered the arduino with the serial connector to get the serial data. It is currently powered with a separate 3.3 v wall wart.
                          We removed several bugs and updated the way it calculates pulses and put a smoothing on the FLOW output.The smoothing help keep the FLOW values going down to 0 but doesn't stop it at all times.
                          I uploaded this to the Arduino to first verify the correct vector. I could have use a total vector calculation (square root of x2+y2+z2) but this would have just amplified some of the noise. Using a chosen vector worked fine but took a little more work. After finding the correct vector (sorry - first build and mount the magnetometer on the meter), download the sketch below.
                          /*This version is different in several ways.
                           * first is is using some memory (Adafruit I2C FRAM) memory to store the top and bottom. This is used to keep the top and bottom
                           * values after a restart. I guess we could have put them on the controller but can't remember why we didn't.
                           * second it will only calculate the top and bottom if the values are not in memory.
                           * third it auto calculates the top and bottom values as it is running.
                           * the only settings that should be changed are vpp, SEND_FREQUENCY, and metric. However I am currently using
                           * Domoticz as my controller and it doesn't seem to accept English units well so for not I'm using Metric.
                          //#define MY_DEBUG_VERBOSE
                          #include <Wire.h>                       //I2C communications library
                          #include <Adafruit_FRAM_I2C.h>          //Adafruit FRAM memory library
                          #define CHILD_ID 1                      //ID of the sensor child
                          #define SLEEP_MODE false                //prevent sensor from sleeping
                          #define address 0x1E                    //0011110b, I2C 7bit address of HMC5883 magnetometer
                          int top = 0;                            //highest magnetic field registered from meter (Ga)Initialize low if using autoDetectMaxMin
                          int bottom = 0;                         //lowest magnetic field registered from meter (Ga) Initialize high if using autoDetectMaxMin
                          int tol = 50;
                          unsigned long SEND_FREQUENCY = 30000;   // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                          bool metric = true;                     //sets units to Metric or English TODO: move to void setup()
                          bool pcReceived = false;                //whether or not the gw has sent us a pulse count
                          bool autoDetect = false;                //true if the program is auto detecting Top and Bottom
                          bool rising = true;                     //whether or not a pulse has been triggered
                          bool safe = false;                      //whether or not it is safe to switch directions
                          unsigned long pulsecount = 0;           //total number of pulses measured ever
                          unsigned long oldPulseCount = 0;        //old total
                          double vpp = metric ? 0.160891193181 : 0.00568124219857;//Volume of gas per pulse
                          unsigned long lastSend = 0;             //time since last transmission - msec
                          double volume = 0;                      //Cumulative amount of gas measured
                          const int len = 3;                      //number of flow rate measurements to save
                          double flow [len];                      //array of previous gas flow rate measurements
                          double avgFlow = 0;                     //average of all elements in flow array
                          double oldAvgFlow = 0;                  //previous average flow
                          int y = 0;                              //magnetic field reading
                          int oldy = 0;                           //previous magnetic field reading
                          int newTop = -9000;                         //potential new Top
                          int newBottom = 9000;                  //potential new Bottom
                          int totDividers = 10;                   //Number of dividers
                          int increment = 0;                      //space b/w dividers
                          int counter = 0;                        //used to count pulses over periods longer than SEND_FREQUENCY
                          int topAddr = 0;                        //address of TOP in FRAM
                          int bottomAddr = topAddr + 2;           //address of BOTTOM in FRAM
                          MyMessage flowMsg(CHILD_ID,V_FLOW);
                          MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                          MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                          Adafruit_FRAM_I2C fram = Adafruit_FRAM_I2C();
                          void setup(){
                            //Initialize Serial, I2C, and FRAM communications
                            Serial.begin(9600);
                            Wire.begin();
                            fram.begin();
                            request(CHILD_ID, V_VAR1);
                            //Put the HMC5883 IC into the correct operating mode
                            Wire.beginTransmission(address); //open communication with HMC5883
                            Wire.write(0x02); //select mode register
                            Wire.write(0x00); //continuous measurement mode
                            Wire.endTransmission();
                            //get Top and Bottom from FRAM. addresses are hard-coded seeing as there are only 2
                            newTop = readInt(topAddr);
                            newBottom = readInt(bottomAddr);
                            updateBounds();
                            //WARNING: MAKE SURE GAS IS RUNNING ON FIRST RUNNING OF THIS PROGRAM!!!
                            if(top == 0 && bottom == 0){
                              autoDetect = true;
                              newTop = -9000;
                              newBottom = 9000;
                              //determine max and min magnetic field strength over a few minutes
                              Serial.println("FRAM has been cleared. Auto-detecting max and min magnetic field reading.");
                              Serial.println("WARNING: MAKE SURE GAS IS RUNNING!!");
                              lastSend = millis();
                              while(millis() - lastSend < 120000){
                                y = readMag();
                                detectMaxMin();
                                //display details
                                Serial.print("y: ");
                                Serial.print(y);
                                Serial.print("  Top: ");
                                Serial.print(newTop);
                                Serial.print("  Bottom: ");
                                Serial.print(newBottom);
                                unsigned long remainingTime = 120000 + lastSend - millis();
                                Serial.print("  Time remaining: ");
                                Serial.print(remainingTime / 60000);
                                Serial.print(":");
                                remainingTime = (remainingTime % 60000) / 1000;
                                if(remainingTime >= 10){
                                  Serial.println(remainingTime);
                                else{
                                  Serial.print("0");
                              updateBounds();
                              autoDetect = false;
                            y = readMag();
                            oldy = readMag();
                            while(abs(y - oldy) < increment / 2){ //wait until difference b/w y and oldy is greater than half an increment
                              y = readMag();
                            rising = (y > oldy);
                            Serial.println(rising ? "Magnetic field is rising" : "Magnetic field is falling");
                              sendSketchInfo("Gas Meter", "0.6 (2/24/17)");
                              // Register this device as Gas sensor
                              present(CHILD_ID, S_GAS);
                          void loop(){
                            if (!pcReceived) {
                              //Last Pulsecount not yet received from controller, request it again
                              return;
                            //detecting magnetic pulses - variable boundary method
                            while(millis() - lastSend < SEND_FREQUENCY){
                              //check if the signal has significantly increased/decreased
                              if(abs(oldy - y) > increment){
                                pulsecount ++;
                                //increment or decrement oldy by one increment based on direction
                                oldy += rising ? increment : -1 * increment;
                                safe = false;             //reset safe now that oldy has updated
                              //check if the signal has recently switched directions
                              else if(safe){                  //first make sure y has moved a significant distance from oldy
                                if((rising && y <= oldy) || (!rising && y >= oldy)){
                                  pulsecount ++;              //add one extra pulse
                                  rising = !rising;           //update direction
                                  safe = false;
                              //take another reading
                              y = readMag();
                              //check if y has moved a significant distance from oldy
                              if(abs(y - oldy) > tol / 2){
                                safe = true;
                              //update newTop and newBottom
                              detectMaxMin();
                            //shift all flow array elements to the right by 1, ignore last element
                            for(int idx = len - 1; idx > 0; idx--){
                              flow[idx] = flow[idx - 1];
                            //calculate newest flow reading and store it as first element in flow array
                            flow[0] = (double)(pulsecount - oldPulseCount) * (double)vpp * 60000.0 / (double)SEND_FREQUENCY;
                            //display flow array state
                            Serial.print("Flow Array State: [");
                            for(int idx = 0; idx < len - 1; idx++){
                              Serial.print(flow[idx]);
                              Serial.print("|");
                            Serial.print(flow[len - 1]);
                            Serial.println("]");
                            //calculate average flow
                            avgFlow = 0;                                //reset avgFlow
                            for(int idx = 0; idx < len; idx++){         //calculate weighted sum of all elements in flow array
                              avgFlow += (flow[idx] * (len - idx));
                            avgFlow /= (len * (len + 1) / 2);           //divide by triangle number of elements to get linear weighted average
                            Serial.print("Average flow: ");             //display average flow
                            Serial.println(avgFlow);
                            //send flow message if avgFlow has changed
                            if(avgFlow != oldAvgFlow){
                              oldAvgFlow = avgFlow;
                              send(flowMsg.set(avgFlow, 2));
                            //send updated cumulative pulse count and volume data, if necessary
                            if(pulsecount != oldPulseCount){
                              //calculate volume
                              volume = (double)pulsecount * (double)vpp / (metric ? 1000.0 : 1);
                              //send pulse count and volume data to gw
                              send(lastCounterMsg.set(pulsecount));
                              send(volumeMsg.set(volume, 3));
                              counter += (pulsecount - oldPulseCount);      //update counter
                              if(counter >= ((totDividers + 1) * 2)){
                                updateBounds();                 //update bounds if at least 1 cycle has been read
                                counter = 0;                    //reset counter
                              oldPulseCount = pulsecount;              //update old total
                            if (message.type==V_VAR1) {
                              unsigned long gwPulseCount=message.getULong();
                              pulsecount = gwPulseCount;
                              Serial.print("Received last pulse count from gw:");
                              Serial.println(pulsecount);
                              pcReceived = true;
                              //set magnetic field starting point
                              oldy = readMag();
                              y = readMag();
                          void updateBounds(){
                            if(((top + tol) != newTop) && ((bottom - tol) != newBottom)){   //check if anything has actually changed
                              //lock in Top and Bottom
                              top = newTop - tol;
                              bottom = newBottom + tol;
                              //recalculate increment to match new top and bottom
                              increment = (top - bottom) / totDividers;
                              //reset newTop and newBottom
                              newTop = -9000;
                              newBottom = 9000;
                              //store updated Top and Bottom in FRAM
                              writeInt(topAddr,top);
                              writeInt(bottomAddr,bottom);
                              newTop = -9000;
                              newBottom = 9000;
                              //display new bounds
                              Serial.println("NEW BOUNDARIES SET:");
                              Serial.print("Top = ");
                              Serial.println(top);
                              Serial.print("Bottom = ");
                              Serial.println(bottom);
                              Serial.print("Increment = ");
                              Serial.println(increment);
                          void detectMaxMin(){
                            if(y > newTop){
                                  newTop = y;                    //update newTop if new max has been detected
                            else if(y < newBottom){
                              newBottom = y;                     //update newBottom if new min has been detected
                          void writeInt(int addr, int val){       //write an int value to memory
                            byte b = highByte(val);
                            fram.write8(addr,b);
                            b = lowByte(val);
                            fram.write8(addr + 1,b);
                          int readInt(int addr){                  //read an int value from memory
                            int result = 0;
                            result += (int)fram.read8(addr);
                            result = result << 8;
                            result += (int)fram.read8(addr + 1);
                            return result;
                          int readMag(){
                            int x = 0, z = 0;
                            //Tell the HMC5883 where to begin reading data
                            Wire.write(0x03); //select register 3, X MSB register - was called Wire.send but the compiler had an error and said to rename to to Wire.write
                            //Read data from each axis, 2 registers per axis
                            Wire.requestFrom(address, 6);
                            if(6<=Wire.available()){
                              x = Wire.read()<<8; //X msb
                              x |= Wire.read(); //X lsb
                              z = Wire.read()<<8; //Z msb
                              z |= Wire.read(); //Z lsb
                              y = Wire.read()<<8; //Y msb
                              y |= Wire.read(); //Y lsb
                            if(!autoDetect){
                              //show real-time magnetic field, pulse count, and pulse count total
                              Serial.print(y);
                              Serial.print(rising ? "  Rising, " : "  Falling, ");
                              Serial.print("next pulse at: ");
                              Serial.print(rising ? oldy + increment : oldy - increment);
                              Serial.print("  Current Number of Pulses: ");
                              Serial.print(pulsecount - oldPulseCount);
                              Serial.print("  Last Total Pulse Count Sent to GW: ");
                              Serial.println(oldPulseCount);
                            return y;
                          I still have not verified the vpp with the meter but I know it's close. When the water heater is on it Domoticz says I'm flowing enough gas for 30,500 BTU/H. The water heater has an input rating of 28,000 BTU/H.
                          Hope this helps, please let me know if you have any questions. I will try to add some pics.
                          • dpcrD dpcr
                            int tol = 50;
                            void setup(){
                              Serial.begin(9600);
                              Wire.begin();
                              fram.begin();
                              updateBounds();
                                autoDetect = true;
                                newTop = -9000;
                                newBottom = 9000;
                                  y = readMag();
                                  detectMaxMin();
                                  //display details
                                  Serial.print(y);
                                  Serial.print(":");
                                  else{
                                    Serial.print("0");
                                updateBounds();
                                autoDetect = false;
                              y = readMag();
                              oldy = readMag();
                                y = readMag();
                            void loop(){
                              if (!pcReceived) {
                                return;
                                  pulsecount ++;
                                    safe = false;
                                y = readMag();
                                  safe = true;
                                detectMaxMin();
                                Serial.print("|");
                                //calculate volume
                                pcReceived = true;
                                oldy = readMag();
                                y = readMag();
                                top = newTop - tol;
                                newTop = -9000;
                                newBottom = 9000;
                                newTop = -9000;
                                newBottom = 9000;
                              if(y > newTop){
                              b = lowByte(val);
                              int result = 0;
                              return result;
                            int readMag(){
                              int x = 0, z = 0;
                              if(!autoDetect){
                                Serial.print(y);
                              return y;
                            markcame
                            wrote on last edited by markcame
                            #28
                            @dpcr I've tried the sketch but seems something is wrong, I've modified it for using my controller to store the top and bottom values and this function very well I'm able to check on the serial that the values are correctly retrieved and stored, but during the running after some cycles start counting pulse at every reading of magnetic field
                            M dpcrD 2 Replies Last reply
                            • M markcame
                              markcame
                              I've try to analyze the program on the old sketch everything are good except the flow rate, I've found an error when you perform the shift of the element on an index this is the reason because the number reported wrong to the gateway.
                              I want to use the new sketch but i have two question, the first is that i didn't understand the pulse count
                                   pulsecount ++;
                                   //increment or decrement oldy by oInsert Code Herene increment based on direction
                                     safe = false;
                                 y = readMag();Insert Code Here
                                 if(abs(y - oldy) > tol / 2){Insert Code Here
                                   safe = true;Insert Code Here
                                 detectMaxMin();
                              and the second is about the initialization of variables retrieved from the FRAM , i i have understand to start the "calibration" you need to put 50 and -50 on the memory otherwise the right condition was not triggered right ?
                              i didn't use the FRAM but I've coded to retrieve form the controller
                               //get Top and Bottom from controller***********************
                               Serial.println("Ask for top value @ controller");
                               //Get Last top
                               request(CHILD_ID, V_VAR2);
                               Serial.println("Ask for bottom value @ controller");
                               //Get Last bottom
                               request(CHILD_ID, V_VAR3);
                               wait(2000, 2, V_VAR1);
                               wait(2000, 2, V_VAR2);
                               wait(2000, 2, V_VAR3);
                               Serial.println("Variables Succesfully Retrived from GW");
                              • M markcame
                                dpcrD
                                dpcrD
                                dpcr
                                @markcame Not sure if I understand you. It still sounds like your not finding your top and bottom values. It works and still is working on my set up. The reason the top and bottom values are so important is the sketch takes those values and divides the difference into sections (totDividers). Those calculated values must be in the range of what the magnetometer is reading. If they don't the pulse counts will be all over the place or none at all. What are your top and bottom values and what are you top and bottom values received from the magnetometer?
                                • dpcrD dpcr
                                  markcame
                                  @dpcr They find corect top and bottom, and start to pulse but after first recalculation of bounds they statrs to count a pulse for every readings.
                                  • M markcame
                                    dpcrD
                                    dpcrD
                                    dpcr
                                    @markcame what is the "next pulse at" reading? This happened to me as well when I was testing it but we changed a few this and it worked OK.
                                    • dpcrD dpcr
                                      dpcrD
                                      dpcrD
                                      dpcr
                                      @dpcr Are you using VAR1 for the pulse count? The reason why we didn't store the top and bottom values on the GW was if the GW went down for any reason we could still keep a pulse count. But it should still work if you have a connection to your GW and controller.
                                      Here are some results from Domoticz. As you can see last Friday I had a spike. This was due to some of the same problems you are having. It has been running fine for the past several days since the last upgrade. I am using the same sketch that I posted.
                                      0_1488408954566_chart.png 0_1488408961804_chart (1).png 0_1488408967898_chart (2).png
                                      I haven't figure out how to remove the Energy (Wh) from the gas usage or the word Waterflow.
                                      As for the fixing of the excessive pulse counts I also at times had he same problem as well. But make sure that your top and bottoms are correct first. If they are and your "next pulse at" number is just being bypassed and the pulse count keeps going up the solution was to reorder the code. Not sure how that helped but it did. I'm not the software guy in this project, my son is. But I know most of what is going on with it. If it continues to give you problems let me know, post your code and I'll get him to look at it.
                                      The memory or GW numbers should be 0 but it not too critical if you are there to start it. It will recalculate the top and bottom values automatically after there has been 22 pulses within a send frequency. Just turn the stove or gas on so there is plenty of flow and download the sketch. It should either start reading the magnetic values and count pulses or start the time to find the top and bottom.
                                      What do you mean by not understanding the pulse count? Are you sending any flow or volume data? Sorry if this jumps around but I'm in the process of doing something else and I'm distracted. Thanks for you patience.
                                      • dpcrD
                                        dpcrD
                                        dpcr
                                        wrote on last edited by dpcr
                                        #34
                                        Here are some pics
                                        1_1489340820150_IMG_20170301_183630.jpg 0_1489340820148_IMG_20170301_183454.jpg
                                        I hopefully want to re-size the magnetometer enclosure and make the mounting more permanent.
                                        • dpcrD dpcr
                                          markcame
                                          #35
                                          @dpcr Yes I use var1 for pulse count Var2 for Top and Var3 for bottom
                                          if the retrieve of value from Gw/Controller is fine get the last Top and Bottom otherwise if retrieve fails after power cycle use locally hard coded, if the retrieve is 0 for TOP and BOTTOM starts auto-detect (gas must be flow) this happens on first run or if you want to manually starts a recalculation.
                                          I think that the problem of spike... maybe related to a non triggering of top or bottom after magnetic field change due to temperature so pulse count going up until new top and bottom was recalculated and applied, there are a control over max pulse for cycle ?
                                          for the count up probably there are a part of code time spending and the reading jump ?
                                          on version V3.6304 of domoticz m3/h are displayed fine if you select gas type counter .... for flow maybe is still water flow reported.
                                          for the pulse count i meaning looking at the code that you take a period then divide in division and trigger a pulse for every division is passed but i didn't understand if the metodology for counting pulse changed on the old and on the new code
                                          here the code i have modified is a mix of old and new code you have posted plus the support to store on controller and a chek for not count more than todividers on rising or falling , i want to test if i can improve the count or not...
                                           * Currently the autoDetectMaxMin in set to true which will find the TOP and BOTTOM of the wave, however if you want
                                           * to use it the gas must be flowing.
                                          #include <Wire.h>                       //I2C Arduino Library
                                          int TOP = 0;                            //highest magnetic field registered from meter (Ga)Initialize low if using AutoDetectMaxMin
                                          int BOTTOM = 0;                         //lowest magnetic field registered from meter (Ga) Initialize high if using AutoDetectMaxMin
                                          int NewTop=-9000;
                                          int NewBottom=9000;
                                          int tol = 50;
                                          bool autoDetectMaxMin = false;           //lets Arduino decide the values for TOP and BOTTOM
                                          bool inside = true;                     //whether the magnetic field is within TOP and BOTTOM limits
                                          double vpp = 0.12;                      //Volume of gas per pulse
                                          int divider = 1;                        //Current divider
                                          int increment = (TOP - BOTTOM) / totDividers;   //space b/w dividers
                                          int counter=0;
                                          MyMessage lastTopMsg(CHILD_ID,V_VAR2);
                                          MyMessage lastBottomMsg(CHILD_ID,V_VAR3);
                                          void setup(){
                                            //Initialize Serial and I2C communications
                                            Wire.begin();
                                            // Fetch last known pulse count , TOP and BOTTOM value from gw
                                            // Wait until timeout of 2 seconds for message from gw
                                            int y = 0;
                                            int oldy = 0;
                                            //WARNING: MAKE SURE GAS IS RUNNING IF USING THIS OPTION!!!
                                            if(TOP==0 && BOTTOM==0){
                                            autoDetectMaxMin = true;
                                                y = readMag();
                                                if(y > TOP){
                                                  TOP = y;                        //update TOP if new max has been detected
                                                else if(y < BOTTOM){
                                                  BOTTOM = y;                     //update BOTTOM if new min has been detected
                                              TOP -= tol;                         //nudge TOP and BOTTOM so that they have a chance of being triggered
                                              BOTTOM += tol;
                                              increment = (TOP - BOTTOM) / totDividers;    //recalculate increment to match new TOP and BOTTOM
                                              autoDetectMaxMin = false;           //finished determining TOP and BOTTOM
                                            Serial.println("Store on Controller TOP and BOTTOM found");
                                            send(lastTopMsg.set(TOP));
                                            send(lastBottomMsg.set(BOTTOM));
                                            oldy = readMag();
                                            y = readMag();
                                              y = readMag();
                                              sendSketchInfo("Gas Meter", "0.4");
                                          void loop(){
                                            if (!pcReceived) {
                                              return;
                                            //detecting magnetic pulses - Fractional Simple Method
                                              int y = readMag();
                                            if(y >NewTop ){
                                                  NewTop = y;                        //update TOP if new max has been detected
                                                else if(y < NewBottom){
                                                  NewBottom = y;                     //update BOTTOM if new min has been detected
                                              if(inside && rising && y > BOTTOM + divider * increment && divider < totDividers+1){
                                                divider++;
                                                pulsecount++;
                                              else if(inside && !rising && y < TOP - divider * increment &&  divider < totDividers+1){
                                                divider++;
                                                pulsecount++;
                                              if(inside && (y > TOP || y < BOTTOM )){        //switch directions once TOP or BOTTOM divider has been reached
                                                inside = false;                 //keep this from happening multiple times once signal exceeds TOP or BOTTOM
                                                Serial.println("OUTSIDE");
                                              else if(!inside && (y < TOP - increment / 2 && y > BOTTOM + increment / 2)){
                                                rising = !rising;
                                                divider = 1;
                                                inside = true;
                                                Serial.println("INSIDE");
                                              if ( (abs(TOP-NewTop)) > tol || (abs(BOTTOM-NewBottom)) >tol){
                                                TOP=NewTop-tol;
                                                BOTTOM=NewBottom+tol;
                                                //Send Top and Bottom to gateway
                                                newTop = -9000;
                                                newBottom = 9000;
                                                counter = 0;
                                                Serial.println(TOP);
                                                Serial.println(BOTTOM);
                                              Serial.print("|");
                                              //calculate volume
                                              volume = (double)oldPulseCount * (double)vpp / 1000.0;
                                              pcReceived = true;
                                            if (message.type==V_VAR2) {
                                              int gwStoredTOP=message.getInt();
                                              TOP = gwStoredTOP;
                                              Serial.print("Received stored TOP value from gw:");
                                            if (message.type==V_VAR3) {
                                              int gwStoredBOTTOM=message.getInt();
                                              BOTTOM = gwStoredBOTTOM;
                                              Serial.print("Received stored BOTTOM value from gw:");
                                          int readMag(){
                                            int x = 0, y = 0, z = 0;
                                            if(!autoDetectMaxMin){
                                              Serial.print(y);
                                              Serial.print(rising ? BOTTOM + divider * increment : TOP - divider * increment);
                                            else{
                                              //show real-time magnetic field, TOP, BOTTOM, and time left in auto-detect mode
                                              Serial.print(y);
                                              Serial.print("  TOP: ");
                                              Serial.print(TOP);
                                              Serial.print("  BOTTOM: ");
                                              Serial.print(BOTTOM);
                                              Serial.print(":");
                                              else{
                                                Serial.print("0");
                                            return y;
                                          I have another little problem that after a while the node stop to work i don't know but on the serial stop to print data and no more message is sent to the gateway if i close and re-open the serial monitor the data readed by magnetometer is displayed again but no data is sent,
                                          Can be related to radio issue ? or overbuffering serial ? do you have experienced similar problem?
