  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.9k Views 65 Watching
  • Jose SimoesJ
    Jose SimoesJ
    Jose Simoes
    hey @Aproxx, nice project, do you think a current sensor could be added to the PCB to monitor electrical consumption. the idea of adding triact to the circuit by @overlordt seems to work theoretically.
    • SensibleHeatS
      SensibleHeatS
      SensibleHeat
      My parts are on the way and I"m looking forward to trying this one out. Thanks for sharing this project!!
        stray
        If you create a new version, could you connect the other 2 5V and GND holes next to D6 so these can easily be used as power output?
          https://www.openhardware.io/view/77/AC-DC-double-solid-state-relay-module
          Marco Lo Grasso
          wrote on last edited by Marco Lo Grasso
          #166
          I can't understand (scrub here) how to wire the regular light switch to the board.
          Supposing I want to use only one relay, I have to wire the switch to the 7 PIN and GND right?
          • M Marco Lo Grasso
            tonnerre33T
            tonnerre33T
            tonnerre33
            #167
            @Marco-Lo-Grasso said in 💬 AC-DC double solid state relay module:
            Yes you have to do this, but i don't know if the sketch is working fine with the light switch ;) I haven't tested this feature yet.
            Caution, the light switch don't be connected to the 230V !
            • J
              J
              Joe Barneson
              Any suggestions for front panels on the light switches? I've connected mine to normal switches to control the relays, but I'd really like a 4-8 soft button front panel that I could also wire into GPIO's on an ESP for "scene" control outside of the local relays. Auy suggestions or experience would be great
              • Nca78N
                Hello, I'm not sure exactly of what you want to to, but you could use software i2c on those two pins and connect and i2c keypad. You can search mpr121 keypad on google or aliexpress.
                But be careful you should add an isolating cover on top of it if you connect to this board as the crepage/cleatance between main voltage and 5V/3.3V is not sufficient in some part of the board and it could end up with low voltage circuit at main voltage...
                • J
                  J
                  Joe Barneson
                  good to know clearence isn't there ... something i could correct though
                  An i2c and capacity touch could work great.. but i can't find any cleanly designed front panel that I could use in place of my light switches.
                    Misna
                    So if I understanded right the device needs also neutral to work? That's a problem because here in Finland we only circulate the phase through light switches. Neutral goes straight to the lamps.
                    Nca78N 1 Reply Last reply
                    • M Misna
                      @Misna said in 💬 AC-DC double solid state relay module:
                      Yes it does. Same problem for most people, even here in Vietnam it's the same.
                      Solution is to put it in ceiling connected directly to the lights, and use radio switch to control it.
                      • H
                        H
                        hugch
                        first of all you had an great idea to user a small layout with this functions.
                        The protection at the AC site is very good I think.
                        Today I get ten boards with your current gerber files (v3.3.2).
                        But I think it does not work as expected:
                        • Using a 5 V Arduino and the NRF without a level switcher with 3.3 V it will be break in the future.
                        • The big relay routes have no protection (I don't know if solder resist is the correct word).
                        • Maybe as pulldown resistor to the relay input could be useful.
                        • The three GND and Vcc Pins are not connected to each other.
                        • Maybe it could usefull to use fuse sockets for the not resetable fuse.
                        For the voltage problem we could use an 3.3 V Arduino mini pro with 8 MHz crystal.
                        In this case we don't need the LDO and could use LDO from the Arduino board.
                        • H
                          H
                          hugch
                          Sorry I forgot something.
                          For a 3.3 V Arduino we need a MOSFET or so to drive the SSR.
                          But there are cheep and small SMD packages available.
                          • H hugch
                            @hugch no you don't need MOSFET for those SSR, the high level of input is below 3.3V. I've made a board with those and a 3.3V Arduino and didn't have any problem.
                            For this board it's missing fuses on the SSRs, if they fail and shortcut nothing will stop the short circuit at the moment.
                            H 1 Reply Last reply
                            • Nca78N Nca78
                              H
                              H
                              hugch
                              @Nca78 My SSRs are with 5 V level but one with 3.3 V level would be better. You are right.
                              And the fuses are important but i think the step down have an over current protection, but a PTC could useful.
                              But a MOSFET or equal is also required:
                              It is not a good idea to drive current intensive peripheral directly with an micro controller.
                              The absolute maximum ratings for an ATmega328p is 40 mA. And a SSR is using 25 mA or so.
                              The better choice is using a driver or a simple transistor circuit.
                              To drive the SSR directly would not damage the controller at this moment, but your are decrease the lifetime.
                              And the lifetime for an in wall module or so is very important.
                              • A
                                alex1510
                                Hello!!, my name is Alejandro, I'm from Spain and I have been working on something quite similar to this project. I would like to contribute to reach a final design. What I have done until now is a prototype board similar than yours and I would like to add a top board with touch buttons to fit into Livolo glass panel switch.
                                https://es.aliexpress.com/store/product/Free-Shipping-Livolo-Luxury-White-Pearl-Crystal-Glass-151mm-80mm-EU-standard-Double-Glass-Panel-VL/500715_1684198410.html?spm=2114.12010608.0.0.6cyWwJ
                                And try to do something like this also including ws2812 rgb led for touchpad and a small speaker just to sound someting when touch the button.
                                https://z-uno.z-wave.me/projects/sensor-wall-switch-based-on-livolo-glass/
                                My development is based on ESP8266 without rf communication but as I have progressed I have checked that Wifi connection is a complex system compared to rf so I am thinking to change to arduino or esp + nrf.
                                • johnym30J
                                  johnym30J
                                  johnym30
                                  Hi everyone . I managed to create my first module and it seems to working but why at my domoticz only one switch appears as new device???
                                  • johnym30J
                                    johnym30J
                                    johnym30
                                    I solved my last problem, but now i see that although both of the switches in Domoticz show off, i have power on the second one. What could be the problem? Faulty ssr?
                                    • Nca78N
                                      What's happening if you switch it on then off in domoticz ?
                                      • johnym30J
                                        johnym30J
                                        johnym30
                                        Either pressing on or off in domoticz, i have always power on the second outpout.
                                        S 1 Reply Last reply
                                        • johnym30J johnym30
                                          stray
                                          @johnym30 Can you post your sketch?
