  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • R Rene046
    thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
    // Enable debug prints
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_BATTERY 4
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
    #define SKETCH_VERSION "2.1"                    // Your version
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
    #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
    #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
      present(CHILD_ID_HUM, S_HUM);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      batM();
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       if (batLoop > 2) {
       if (batteryPcnt > 100) {
         batteryPcnt=100;
           send(msgbatt.set(batteryPcnt ,2));
           batLoop = 0;
         batLoop++;
    Arnold ŠlepetisA
    Arnold ŠlepetisA
    Arnold Šlepetis
    wrote on last edited by Arnold Šlepetis
    #33
    @Rene046 what resistors do you use to measure battery. VBAT_PER_BITS is not just 4.2/1023. Personally I am using 1m and 300k it gives me up to 4.77V
    R 1 Reply Last reply
    • Arnold ŠlepetisA Arnold Šlepetis
      R
      R
      Rene046
      @Arnold-Šlepetis
      Hi im using at this moment what i had.
      270k-100k giving me 1.07 volt at 4.2 battery
      So i stay save , but ok reading is not giving my wanted 4.2 volt but around 3.92 volt
      My nano is feeded by an dc -dc boost converter giving me 5 volt from this 4.2 battery.
      @AWI
      Sorry im still a noob in this, just understood how to make a voltage diver using 3:1 divider
      Could you please give me a simple example how do this calculation.
      Arnold ŠlepetisA AWIA 2 Replies Last reply
      • R Rene046
        @Arnold-Šlepetis
        @AWI
        Arnold ŠlepetisA
        Arnold ŠlepetisA
        Arnold Šlepetis
        @Rene046
        As I understand correct VBAT_PER_BITS is not just 4.2/1032. This depends what resistors do you use. If you use 1m and 470k VBAT_PER_BITS=0.003363075 made from formula and it will never reads more 3.44v.
        #define VMIN and #define VMAX 4.2 used only for formula int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
        If you use 270k and 100k maximum is 4.07V so will be VBAT_PER_BITS=0.0039784946236559 and not like in your sketch 0.0041055718475073313782991202346
        AWIA 1 Reply Last reply
        • R Rene046
          @Arnold-Šlepetis
          @AWI
          AWIA
          AWIA
          AWI
          @Rene046 You making it complex. The steps)
          • Make sure that the input voltage is within the range of the reference. You did that with the voltage divider (max 1.07 V) :+1:
          • set vRefin the sketch to an expected value (4.2 / 1 , where 1 is the calibration value). You did (4.2/1.07) :+1:
          • Now you need to calibrate in the software:
          1. Measure the battery voltage (batteryVoltage) (not the voltage divider) with the multimeter. You did (4.2 Volt) :+1:
          2. Look at the voltage level reported by the sketch (reportedVoltage). You did (3.92 Volt) :+1:
          3. Calculate the calibration value and adjust vRef. It needs to report 4.2V now it reports 3.92V so you are off by 1.07. => (4.2/1.07) * 1.07 = 4.2 => set vRef to (4.2/ 1.0) and you will be fine.
          There are a few reasons why you need to calibrate:
          • The internal reference of the Arduino (1.1V) is not calibrated (can roughly vary from 1V to 1.2V)
          • Your voltage divider is not always precise.
          • Most multimeters are far more accurate...
            @Rene046
            AWIA
            AWIA
            AWI
            @Arnold-Šlepetis Purist physics ;-) : Although you calculation is probably correct for your use case. I associate a VBAT_PER_BITS=0.0039784946236559 with almost atomic precision. As where the internal (band-gap) reference has +- 10% offset and drift with temperature and Vcc (although it is pretty stable for MySensors purposes).
            0_1488182473299_upload-573a5ed3-04bf-44df-a0d5-a4b78bb505c5
            • R
              R
              Rene046
              What can i do to get a more stable reading now the voltage goes from 3.80 to 4.20 while feeding with an 4.20 volt
              R AWIA 2 Replies Last reply
              • R Rene046
                R
                R
                Rene046
                @Rene046 said in reporting battery to domoticZ:
                It seems like when the nano starts reading the voltage drops a bid.
                • R Rene046
                  AWIA
                  AWIA
                  AWI
                  @Rene046 Can you be a little more specific? i.e. post a log of voltage readings over time.
                  • R
                    R
                    Rene046
                    wrote on last edited by AWI
                    #41
                    vref: 4.20 V
                    sensorValue: 949 bit
                    219143 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.89
                    Battery voltage: 3.89 V
                    219151 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:48
                    Battery percent: 48 %
                    219158 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    219164 MCO:SLP:TPD
                    219166 MCO:SLP:WUP=-1
                    221699 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.2
                    H: 35.20
                    vref: 4.20 V
                    sensorValue: 951 bit
                    222708 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.90
                    Battery voltage: 3.90 V
                    222717 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:50
                    Battery percent: 50 %
                    222724 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    222731 MCO:SLP:TPD
                    222733 MCO:SLP:WUP=-1
                    225242 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.6
                    T: 20.60
                    225251 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:34.5
                    H: 34.50
                    vref: 4.20 V
                    sensorValue: 955 bit
                    226260 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
                    Battery voltage: 3.92 V
                    226269 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:52
                    Battery percent: 52 %
                    226276 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    226282 MCO:SLP:TPD
                    • R Rene046
                      AWIA
                      AWIA
                      AWI
                      #42
                      @Rene046 From your earlier postings I can see that you are using a boost converter. Speaking in general these things make a lot of noise on the power line and are certainly not a stable supply.
                      Just a few considerations:
                      • A nano is not well suited for battery operation. These tend to dissipate at minimum 5mA and will drown a one cell battery fast. Go for a 3.3V pro-mini and remove the led.
                      • Get rid of the Boost converter and power directly from the battery. The radio and pro-mini will work fine on 3.6V using a regulator (LDO). In this case you can measure battery directly from the Vcc pin without divider.
                      • R
                        R
                        Rene046
                        Last reading from multimeter battery voltage 4.204 volt now i measure A0 1,104 > gnd
                        • R Rene046
                          AWIA
                          AWIA
                          AWI
                          @Rene046 What is the output of the DC=DC converter measuring? Are you powering the nano on the Vcc or Vin pin?
                          • R
                            R
                            Rene046
                            Hi Awi i will build someday if i got it working this project on a pro-mini,.
                            im not measuring the voltage on the dc-dc booster but on the battery side feeding the converter.
                            I need this booster because i also feeding my DHT with 5 volt and in future other sensors.BH1750, BMP180, Soil moisture sensor
                            and im charging my battery in the future with an 6 volt solar panel.
                            So to see this is working during day time i should be able to read the charging voltage of 4.2 volt and during the night the voltage of battery dropping
                            • AWIA AWI
                              R
                              R
                              Rene046
                              @AWI
                              Im feeding the 5v pin with 5.14 volt coming from the dc-dc output not the vin
                              • R Rene046
                                AWIA
                                AWIA
                                AWI
                                @Rene046 A 3.6-4.2 V battery with 3.3V ldo is perfectly suited to power the sensors you mentioned . I would replace the DHT22 with a (much better) I2C sensor (si7021/ BME280 /... ).
                                If the measured voltage is not stable then in most cases the power supply or the measured voltage is unstable.
                                12.5k
