  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • Arnold ŠlepetisA Arnold Šlepetis
    @Rene046 what resistors do you use to measure battery. VBAT_PER_BITS is not just 4.2/1023. Personally I am using 1m and 300k it gives me up to 4.77V
    R
    R
    Rene046
    @Arnold-Šlepetis
    Hi im using at this moment what i had.
    270k-100k giving me 1.07 volt at 4.2 battery
    So i stay save , but ok reading is not giving my wanted 4.2 volt but around 3.92 volt
    My nano is feeded by an dc -dc boost converter giving me 5 volt from this 4.2 battery.
    @AWI
    Sorry im still a noob in this, just understood how to make a voltage diver using 3:1 divider
    Could you please give me a simple example how do this calculation.
    Arnold ŠlepetisA AWIA 2 Replies Last reply
    • R Rene046
      @Arnold-Šlepetis
      @AWI
      Arnold ŠlepetisA
      Arnold ŠlepetisA
      Arnold Šlepetis
      @Rene046
      As I understand correct VBAT_PER_BITS is not just 4.2/1032. This depends what resistors do you use. If you use 1m and 470k VBAT_PER_BITS=0.003363075 made from formula and it will never reads more 3.44v.
      #define VMIN and #define VMAX 4.2 used only for formula int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
      If you use 270k and 100k maximum is 4.07V so will be VBAT_PER_BITS=0.0039784946236559 and not like in your sketch 0.0041055718475073313782991202346
      AWIA 1 Reply Last reply
      • R Rene046
        @Arnold-Šlepetis
        @AWI
        AWIA
        AWIA
        AWI
        @Rene046 You making it complex. The steps)
        • Make sure that the input voltage is within the range of the reference. You did that with the voltage divider (max 1.07 V) :+1:
        • set vRefin the sketch to an expected value (4.2 / 1 , where 1 is the calibration value). You did (4.2/1.07) :+1:
        • Now you need to calibrate in the software:
        1. Measure the battery voltage (batteryVoltage) (not the voltage divider) with the multimeter. You did (4.2 Volt) :+1:
        2. Look at the voltage level reported by the sketch (reportedVoltage). You did (3.92 Volt) :+1:
        3. Calculate the calibration value and adjust vRef. It needs to report 4.2V now it reports 3.92V so you are off by 1.07. => (4.2/1.07) * 1.07 = 4.2 => set vRef to (4.2/ 1.0) and you will be fine.
        There are a few reasons why you need to calibrate:
        • The internal reference of the Arduino (1.1V) is not calibrated (can roughly vary from 1V to 1.2V)
        • Your voltage divider is not always precise.
        • Most multimeters are far more accurate...
          @Rene046
          AWIA
          AWIA
          AWI
          @Arnold-Šlepetis Purist physics ;-) : Although you calculation is probably correct for your use case. I associate a VBAT_PER_BITS=0.0039784946236559 with almost atomic precision. As where the internal (band-gap) reference has +- 10% offset and drift with temperature and Vcc (although it is pretty stable for MySensors purposes).
          0_1488182473299_upload-573a5ed3-04bf-44df-a0d5-a4b78bb505c5
          • R
            R
            Rene046
            What can i do to get a more stable reading now the voltage goes from 3.80 to 4.20 while feeding with an 4.20 volt
            R AWIA 2 Replies Last reply
            • R Rene046
              R
              R
              Rene046
              @Rene046 said in reporting battery to domoticZ:
              It seems like when the nano starts reading the voltage drops a bid.
              • R Rene046
                AWIA
                AWIA
                AWI
                @Rene046 Can you be a little more specific? i.e. post a log of voltage readings over time.
                • R
                  R
                  Rene046
                  wrote on last edited by AWI
                  #41
                  vref: 4.20 V
                  sensorValue: 949 bit
                  219143 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.89
                  Battery voltage: 3.89 V
                  219151 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:48
                  Battery percent: 48 %
                  219158 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  219164 MCO:SLP:TPD
                  219166 MCO:SLP:WUP=-1
                  221699 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.2
                  H: 35.20
                  vref: 4.20 V
                  sensorValue: 951 bit
                  222708 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.90
                  Battery voltage: 3.90 V
                  222717 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:50
                  Battery percent: 50 %
                  222724 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  222731 MCO:SLP:TPD
                  222733 MCO:SLP:WUP=-1
                  225242 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.6
                  T: 20.60
                  225251 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:34.5
                  H: 34.50
                  vref: 4.20 V
                  sensorValue: 955 bit
                  226260 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
                  Battery voltage: 3.92 V
                  226269 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:52
                  Battery percent: 52 %
                  226276 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  226282 MCO:SLP:TPD
                  • R Rene046
                    AWIA
                    AWIA
                    AWI
                    #42
                    @Rene046 From your earlier postings I can see that you are using a boost converter. Speaking in general these things make a lot of noise on the power line and are certainly not a stable supply.
                    Just a few considerations:
                    • A nano is not well suited for battery operation. These tend to dissipate at minimum 5mA and will drown a one cell battery fast. Go for a 3.3V pro-mini and remove the led.
                    • Get rid of the Boost converter and power directly from the battery. The radio and pro-mini will work fine on 3.6V using a regulator (LDO). In this case you can measure battery directly from the Vcc pin without divider.
                    • R
                      R
                      Rene046
                      Last reading from multimeter battery voltage 4.204 volt now i measure A0 1,104 > gnd
                      • R Rene046
                        AWIA
                        AWIA
                        AWI
                        @Rene046 What is the output of the DC=DC converter measuring? Are you powering the nano on the Vcc or Vin pin?
                        R 1 Reply Last reply
                        • R
                          R
                          Rene046
                          Hi Awi i will build someday if i got it working this project on a pro-mini,.
                          im not measuring the voltage on the dc-dc booster but on the battery side feeding the converter.
                          I need this booster because i also feeding my DHT with 5 volt and in future other sensors.BH1750, BMP180, Soil moisture sensor
                          and im charging my battery in the future with an 6 volt solar panel.
                          So to see this is working during day time i should be able to read the charging voltage of 4.2 volt and during the night the voltage of battery dropping
                          • AWIA AWI
                            R
                            R
                            Rene046
                            @AWI
                            Im feeding the 5v pin with 5.14 volt coming from the dc-dc output not the vin
                            • R Rene046
                              AWIA
                              AWIA
                              AWI
                              @Rene046 A 3.6-4.2 V battery with 3.3V ldo is perfectly suited to power the sensors you mentioned . I would replace the DHT22 with a (much better) I2C sensor (si7021/ BME280 /... ).
                              If the measured voltage is not stable then in most cases the power supply or the measured voltage is unstable.
                              12.5k
