  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • R
    R
    Rene046
    wrote on last edited by AWI
    #28
    my serial monitor is now making a bit more cense voltage is about 0,10 volt off
    but maybe i do something wrong with calculation.
    percentage is still something wrong with
    by the way i'm not shure with the low voltage of an 16850 lipo at 3.6 volt ...
    20412 MCO:SLP:WUP=-1
    22921 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:17.8
    T: 17.80
    22929 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.4
    H: 35.40
    23939 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.53
    Battery voltage: 3.53 V
    Battery percent: -10 %
    23946 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23954 MCO:SLP:TPD
    23955 MCO:SLP:WUP=-1
    26465 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:36.1
    H: 36.10
    27473 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.52
    Battery voltage: 3.52 V
    Battery percent: -12 %
    27481 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    27489 MCO:SLP:TPD
    and here the latest sketch
    // Enable debug prints
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_BATTERY 4
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
    #define SKETCH_VERSION "2.1"                    // Your version
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
    #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
    #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
      present(CHILD_ID_HUM, S_HUM);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      batM();
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       send(msgbatt.set(Vbat ,2));
       Serial.print("Battery voltage: "); Serial.print(Vbat); Serial.println(" V");
       if (batLoop > 2) {
       if (batteryPcnt > 100) {
         batteryPcnt=100;
           batLoop = 0;
         batLoop++;
    R 1 Reply Last reply
    • R Rene046
      T: 17.80
      H: 35.40
      23954 MCO:SLP:TPD
      H: 36.10
      27489 MCO:SLP:TPD
      DHT dht;
      float lastTemp;
      float lastHum;
          if (!metric) {
            lastHum = humidity;
        batM();
         delay(500);
         delay(500);
         if (batLoop > 2) {
           batteryPcnt=100;
             batLoop = 0;
           batLoop++;
      R
      R
      Rene046
      #29
      @Rene046 said in reporting battery to domoticZ:
      im feeding with 3.60 volts at that moment.
      AWIA 1 Reply Last reply
      • R Rene046
        AWIA
        AWIA
        AWI
        #30
        @Rene046 The 1.1V internal reference is not calibrated and can be 10% off, So you need to do some calibration yourself.
        (b.t.w. I cleaned your postings a little. Please make sure you use the code markings in the right way, i.e. put them on a new line). To get you going I rewrote the battery routine. Changes:
        • no real need to average the readings if you give it time to stabilize.
        • got rid of the "volt per bit" constant
        • added a "reference value:" for calibration, you can calculate it from the measured voltage and reported voltage.
        // battery calculations
        void batM(){
        	const float vRef = 4.2/ 1.1 ;							// actual value for max reading, adjust with help of measured voltage
        	delay(500);
        	int sensorValue = analogRead(BATTERY_SENSE_PIN);   		// sensorValue is 0..1023 where 1023 == vRef
        	float vBat = sensorValue * vRef / 1024 ;
        	send(msgbatt.set(vBat ,2));
        	Serial.print("Battery voltage: "); Serial.print(vBat); Serial.println(" V");
        	int batteryPcnt = static_cast<int>(((vBat-VMIN)/(VMAX-VMIN))*100.);
        	sendBatteryLevel( batteryPcnt) ;
        • R
          R
          Rene046
          Thanks that looks way better.
          I just changed
          into
          const float vRef = 4.2/ 1.07 ;
          because this is what i measure with my multimeter with 4.2 volt battery and measuring my voltage divider i have 1.07 volt
          Giving me strange results something must be bad ..... my multimeter ?? it should be closer to 4.2 ? i guess
          Battery voltage: 3.92 V
          14842 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
          Battery percent: 53 %
          14850 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
          14856 MCO:SLP:TPD
          14858 MCO:SLP:WUP=-1
          17367 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.4
          T: 19.40
          17376 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:48.5
          H: 48.50
          17885 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
          17893 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
          17900 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
          17906 MCO:SLP:TPD```
          • R Rene046
            I just changed
            into
            14856 MCO:SLP:TPD
            T: 19.40
            H: 48.50
            AWIA
            AWIA
            AWI
            @Rene046 You should still compensate for the 1.1 offset. What you should do is calculate the vRef from the measured battery voltage and the real voltage.
            • R Rene046
              thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
              DHT dht;
              float lastTemp;
              float lastHum;
                  if (!metric) {
                    lastHum = humidity;
                batM();
                 delay(500);
                 delay(500);
                 if (batLoop > 2) {
                   batteryPcnt=100;
                     send(msgbatt.set(batteryPcnt ,2));
                     batLoop = 0;
                   batLoop++;
              Arnold ŠlepetisA
              Arnold ŠlepetisA
              Arnold Šlepetis
              wrote on last edited by Arnold Šlepetis
              #33
              @Rene046 what resistors do you use to measure battery. VBAT_PER_BITS is not just 4.2/1023. Personally I am using 1m and 300k it gives me up to 4.77V
              • Arnold ŠlepetisA Arnold Šlepetis
                R
                R
                Rene046
                @Arnold-Šlepetis
                Hi im using at this moment what i had.
                270k-100k giving me 1.07 volt at 4.2 battery
                So i stay save , but ok reading is not giving my wanted 4.2 volt but around 3.92 volt
                My nano is feeded by an dc -dc boost converter giving me 5 volt from this 4.2 battery.
                @AWI
                Sorry im still a noob in this, just understood how to make a voltage diver using 3:1 divider
                Could you please give me a simple example how do this calculation.
                Arnold ŠlepetisA AWIA 2 Replies Last reply
                • R Rene046
                  @Arnold-Šlepetis
                  @AWI
                  Arnold ŠlepetisA
                  Arnold ŠlepetisA
                  Arnold Šlepetis
                  @Rene046
                  As I understand correct VBAT_PER_BITS is not just 4.2/1032. This depends what resistors do you use. If you use 1m and 470k VBAT_PER_BITS=0.003363075 made from formula and it will never reads more 3.44v.
                  #define VMIN and #define VMAX 4.2 used only for formula int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
                  If you use 270k and 100k maximum is 4.07V so will be VBAT_PER_BITS=0.0039784946236559 and not like in your sketch 0.0041055718475073313782991202346
                  • R Rene046
                    @Arnold-Šlepetis
                    @AWI
                    AWIA
                    AWIA
                    AWI
                    @Rene046 You making it complex. The steps)
                    • Make sure that the input voltage is within the range of the reference. You did that with the voltage divider (max 1.07 V) :+1:
                    • set vRefin the sketch to an expected value (4.2 / 1 , where 1 is the calibration value). You did (4.2/1.07) :+1:
                    • Now you need to calibrate in the software:
                    1. Measure the battery voltage (batteryVoltage) (not the voltage divider) with the multimeter. You did (4.2 Volt) :+1:
                    2. Look at the voltage level reported by the sketch (reportedVoltage). You did (3.92 Volt) :+1:
                    3. Calculate the calibration value and adjust vRef. It needs to report 4.2V now it reports 3.92V so you are off by 1.07. => (4.2/1.07) * 1.07 = 4.2 => set vRef to (4.2/ 1.0) and you will be fine.
                    There are a few reasons why you need to calibrate:
                    • The internal reference of the Arduino (1.1V) is not calibrated (can roughly vary from 1V to 1.2V)
                    • Your voltage divider is not always precise.
                    • Most multimeters are far more accurate...
                      @Rene046
                      AWIA
                      AWIA
                      AWI
                      @Arnold-Šlepetis Purist physics ;-) : Although you calculation is probably correct for your use case. I associate a VBAT_PER_BITS=0.0039784946236559 with almost atomic precision. As where the internal (band-gap) reference has +- 10% offset and drift with temperature and Vcc (although it is pretty stable for MySensors purposes).
                      0_1488182473299_upload-573a5ed3-04bf-44df-a0d5-a4b78bb505c5
                      • R
                        R
                        Rene046
                        What can i do to get a more stable reading now the voltage goes from 3.80 to 4.20 while feeding with an 4.20 volt
                        R AWIA 2 Replies Last reply
                        • R Rene046
                          R
                          R
                          Rene046
                          It seems like when the nano starts reading the voltage drops a bid.
                          • R Rene046
                            AWIA
                            AWIA
                            AWI
                            @Rene046 Can you be a little more specific? i.e. post a log of voltage readings over time.
                            • R
                              R
                              Rene046
                              #41
                              vref: 4.20 V
                              sensorValue: 949 bit
                              219143 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.89
                              Battery voltage: 3.89 V
                              219151 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:48
                              Battery percent: 48 %
                              219158 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                              219164 MCO:SLP:TPD
                              219166 MCO:SLP:WUP=-1
                              221699 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.2
                              H: 35.20
                              vref: 4.20 V
                              sensorValue: 951 bit
                              222708 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.90
                              Battery voltage: 3.90 V
                              222717 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:50
                              Battery percent: 50 %
                              222724 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                              222731 MCO:SLP:TPD
                              222733 MCO:SLP:WUP=-1
                              225242 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.6
                              T: 20.60
                              225251 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:34.5
                              H: 34.50
                              vref: 4.20 V
                              sensorValue: 955 bit
                              226260 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
                              226269 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:52
                              Battery percent: 52 %
                              226276 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                              226282 MCO:SLP:TPD
                              • R Rene046
                                AWIA
                                AWIA
                                AWI
                                #42
                                @Rene046 From your earlier postings I can see that you are using a boost converter. Speaking in general these things make a lot of noise on the power line and are certainly not a stable supply.
                                Just a few considerations:
                                • A nano is not well suited for battery operation. These tend to dissipate at minimum 5mA and will drown a one cell battery fast. Go for a 3.3V pro-mini and remove the led.
                                • Get rid of the Boost converter and power directly from the battery. The radio and pro-mini will work fine on 3.6V using a regulator (LDO). In this case you can measure battery directly from the Vcc pin without divider.
                                • R
                                  R
                                  Rene046
                                  Last reading from multimeter battery voltage 4.204 volt now i measure A0 1,104 > gnd
                                  • R Rene046
                                    AWIA
                                    AWIA
                                    AWI
                                    @Rene046 What is the output of the DC=DC converter measuring? Are you powering the nano on the Vcc or Vin pin?
                                    • R
                                      R
                                      Rene046
                                      Hi Awi i will build someday if i got it working this project on a pro-mini,.
                                      im not measuring the voltage on the dc-dc booster but on the battery side feeding the converter.
                                      I need this booster because i also feeding my DHT with 5 volt and in future other sensors.BH1750, BMP180, Soil moisture sensor
                                      and im charging my battery in the future with an 6 volt solar panel.
                                      So to see this is working during day time i should be able to read the charging voltage of 4.2 volt and during the night the voltage of battery dropping
                                      • AWIA AWI
                                        R
                                        R
                                        Rene046
                                        @AWI
                                        Im feeding the 5v pin with 5.14 volt coming from the dc-dc output not the vin
                                        • R Rene046
                                          AWIA
                                          AWIA
                                          AWI
                                          @Rene046 A 3.6-4.2 V battery with 3.3V ldo is perfectly suited to power the sensors you mentioned . I would replace the DHT22 with a (much better) I2C sensor (si7021/ BME280 /... ).
                                          If the measured voltage is not stable then in most cases the power supply or the measured voltage is unstable.
                                          12.5k
