  3. Including "MySensors.h" in multiple files
9 Posts 5 Posters 3.7k Views 5 Watching
  • U
    U
    user2684
    Hi, maybe this is a very silly question but how can I include MySensors.h in multiple files (if it is possible)? The scenario is the following: my sketch includes MySensors.h but it also includes another .h header which needs to include MySensors.h since the corresponding .cpp file is using some functions of the MySensors engine. Something like:
    Sketch -> MySensors.h
                 -> file.h -> MySensors.h
    Compiler is ok with it but the linker is complaining about multiple definitions of functions (e.g. (.text+0x0): multiple definition of `wakeUp1()'). I can guess the reason why since MySensors.h is including cpp files and not just defining functions so the two objects created have the same functions twice.
    I couldn't find a workaround different than defining as extern the functions I need in my file.h but it would be endless since I would need to re-define almost anything. Any other reasonable workaround?
    • U user2684
      @user2684 isn't it sufficient to place the MySensors.h include in your sketch before the file.h include, and not include MySensors.h from file.h at all?
      • pansenP
        pansenP
        pansen
        wrote on last edited by pansen
        You can use include guards (just learned that expression myself ;) )
        https://en.wikipedia.org/wiki/Include_guard
        So just put
        #ifndef MYSENSORS_H
        #define MYSENSORS_H
        instead of just
        you might also try #pragma once not sure if the arduino compiler understands it.
        Weird that MySensors.h does not have that in there...
        edit: it actually does...
         * @file MySensors.h
         * MySensors main interface (includes all necessary code for the library)
        #ifndef MySensors_h
        #define MySensors_h
        Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
          Do not include MySensors.h ... include the specific headers you need under /core
          • U
            U
            user2684
            Thanks for all the answers guys! @mfalkvidd unfortunately without including a mysensors header, file.cpp cannot not compile (e.g. 'sendSketchInfo' was not declared in this scope).
            @pansen to you point include guards do not solve the problem here since the error is coming from the linker, not from the compiler.
            @hek, you are absolutely right! How could I miss such a simple solution! With this in file.h, everything seems working fine:
            #include <core/MySensorsCore.h>
            pansenP 1 Reply Last reply
            • U
              U
              user2684
              On this same topic, as far as I've understood "file.h" which includes "core/MySensorsCore.h" still needs the same define of the main sketch to work because that configuration cannot jump across files. Probably better would be to create another header file with all the "define" and include it in both the main sketch and file.h. Am I heading to the right direction?
              Thanks again
                @user2684
                Sounds like a viable solution.
                • U user2684
                  pansenP
                  pansenP
                  pansen
                  @user2684 said in Including "MySensors.h" in multiple files:
                  Ah right, thanks!
                    stray
                    You can also set
                    #pragma once
                    as the fist line of a header file to prevent multiple inclusions.
