  3. Prevent Relay from triggering on power loss or broker reboot
22 Posts 8 Posters 10.4k Views 8 Watching
  • rhuehnR
    rhuehnR
    rhuehn
    Hey guys:
    I'm currently using a relay to control a garage door opener, but when the MQTT broker reboots, or the Arduino reboots, the relay's click on and off, of course opening / closing the garage door. Is there a way to have the relay's remember state and NOT click on and off in case of power or broker restart? I am not much of a coder, and combled this together, so if anyone can help it would be greatly appreciated!
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 50
    #define CHILD_ID_TEMP 11
    #define CHILD_ID_HUM 10
    #define CHILD_ID_MOT 3   // Id of the sensor child
    #define HUMIDITY_SENSOR_DIGITAL_PIN 7
    #define RELAY_PIN  4
    #define CHILD_ID_REL 1
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define TOGGLE_INTERVAL 350  //Tells how many milliseconds the relay will be held closed
    #define CHILD_ID_SW 2
    #define BUTTON_PIN_2  2  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    bool state = false;
    bool initialValueSent = false;
    Bounce debouncer2 = Bounce();
    int oldValue2=-1;
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
    MyMessage msg(CHILD_ID_REL, V_STATUS);
    MyMessage msgSW(CHILD_ID_SW,V_TRIPPED);
      sendSketchInfo("Temp/Hum/Mot", "1.3");
      delay(100);
      delay(100);
      present(CHILD_ID_HUM, S_HUM);
      delay(100);
      present(CHILD_ID_MOT, S_MOTION);
      delay(100);
      present(CHILD_ID_REL, S_BINARY);
      delay(100);
      present(CHILD_ID_SW, S_DOOR);
        // Setup the button
      pinMode(BUTTON_PIN_2,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_2,HIGH);
      debouncer2.interval(5);
      pinMode(RELAY_PIN, OUTPUT);
      if (SLEEP_TIME <= dht.getMinimumSamplingPeriod()) {
    //  metric = getConfig().isMetric;
      delay(100);
      send(msgTemp.set("0"));
      delay(100);
      send(msgHum.set("0"));
      delay(100);
      send(msgMot.set("0"));
      debouncer2.update();
      // Get the update value
      if (value2 != oldValue2) {
         // Send in the new value
         send(msgSW.set(value2==HIGH ? 1 : 0));
         oldValue2 = value2;
      if (!initialValueSent) {
        Serial.println("Sending initial value");
        send(msg.set(state?RELAY_ON:RELAY_OFF));
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID_REL, V_STATUS);
        wait(2000, C_SET, V_STATUS);
      if (debouncer.update()) {
        if (debouncer.read()==LOW) {
          state = !state;
          // Send new state and request ack back
          send(msg.set(state?RELAY_ON:RELAY_OFF), true);
      // Read digital motion value
      Serial.println(tripped);
      send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        #ifdef MY_DEBUG
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
      sleep(INTERRUPT,CHANGE, SLEEP_TIME); //sleep a bit
      if (message.isAck()) {
          Serial.println("Receiving initial value from controller");
          initialValueSent = true;
        // Change relay state
        state = (bool)message.getInt();
        digitalWrite( RELAY_PIN, RELAY_ON );
        //Keep the relay on for the amount of time defined by TOGGLE_INTERVAL
        delay( TOGGLE_INTERVAL );
        digitalWrite( RELAY_PIN, RELAY_OFF );
        //Added this to tell the controller that we shut off the relay
         // Store state in eeprom
    Boots33B 1 Reply Last reply
      I noticed that too, it's quite annoying
        wrote on last edited by hek
        You can use load/saveState to save the state the local EEPROM. Then at startup you set the relay in the last known state.
          It is something that is triggering a pulse in some pins during startup, because I tried to set all pins to low during setup, but that was happening anyway so my guess is something else is pulsing before the setup is executed.
          • rhuehnR
            rhuehnR
            rhuehn
            @hek Thanks for the reply, but I'm not 100% sure as I am still somewhat new to mysensors and arduino. Is there any chance you could possibly show an example using the above sketch I pasted previously?
              https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/RelayWithButtonActuator/RelayWithButtonActuator.ino
                That's not very different from the code I used in setup, but the issue I noticed it was just in a couple of pins that were triggering the relay, not all of them.
                • rhuehnR rhuehn
                  Hey guys:
                  #define RELAY_PIN  4
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  bool state = false;
                  int oldValue2=-1;
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                    delay(100);
                    delay(100);
                    delay(100);
                    delay(100);
                    delay(100);
                      // Setup the button
                    delay(100);
                    delay(100);
                    delay(100);
                       oldValue2 = value2;
                        state = !state;
                      if (!metric) {
                      #ifdef MY_DEBUG
                        lastHum = humidity;
                        #ifdef MY_DEBUG
                  Boots33B
                  Boots33B
                  Boots33
                  wrote on last edited by Boots33
                  @rhuehn I think the problem may be in the implementation of your initialValueSent code.
                  at the start of your code you set state and initialValueSent to false
                  bool state = false;
                  bool initialValueSent = false;```
                  So when the loop first runs your code is executed
                      send(msg.set(state?RELAY_ON:RELAY_OFF));                  /* here you send the off state to the controller */
                      request(CHILD_ID_REL, V_STATUS);                                      /* you then request the status of the relay  you just turned off ?*/
                  When the request returns yo use the status to turn off the relay but then you immediately turn the relay on and off again. that may cause the problem you have encountered.
                        initialValueSent = true;        /* you set to true so initial code will no longer  be executed
                      digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);                                                  /* You set the relay to the current state, which is off */
                      digitalWrite( RELAY_PIN, RELAY_ON );        /* you then switch the relay back on  ?  /*
                      delay( TOGGLE_INTERVAL );        /* then a delay */
                      digitalWrite( RELAY_PIN, RELAY_OFF );        /* then back off
                  you seem to have a lot happening at the startup of your node, you have already turned the relay off in your setup code so do you need to bother with the rest?
                    pinMode(RELAY_PIN, OUTPUT);           /* I think normally you would set pinmode before writing so you may want to move this line up one */
                  • rhuehnR
                    rhuehnR
                    rhuehn
                    @Boots33 Thanks very much for the reply, and I know this is late in my response so I apologize about that....
                    So this sketch does the following. A Replay that momentarily interrupts the garage door button to simulate a press of the control button, has a PIR and a DHT for motion and temp / hum, and also has a reed switch that can determine if the door is open or closed. I've been playing none stop with the sketch, and have tweaked it to the best of my ability, but STILL on power loss, the relay always clicks... therefore opening or closing the door...... Based on these changes, is there any way I can clean this up ( I'm at a loss unfortunately ) so that on power loss the relay remains as it was "state"? I've tried a few combinations without any luck to this point. My revised sketch is below, and I really appreciate any help.
                    #define RELAY_PIN  4
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    #define CLOSED 0
                    #define OPEN 1
                    #define BUTTON_PIN_1  2
                    #define SENSOR_TEMP_OFFSET 1
                    int oldValue=-1;
                    bool state = false;
                    byte StatePIR=0;
                    byte oldStatePIR=0;
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    bool StateREL=0, StateREL1=0;
                      sendSketchInfo("Garage Multi Sensor", "1.0");
                      delay(100);
                      delay(100);
                      delay(100);
                      delay(100);
                      delay(100);
                      // Setup the button
                      pinMode(BUTTON_PIN_1,INPUT);
                      digitalWrite(BUTTON_PIN_1,HIGH);
                      debouncer.attach(BUTTON_PIN_1);
                      debouncer.interval(5);
                      digitalWrite(RELAY_PIN, StateREL1);
                        debouncer.update();
                      int value = debouncer.read();
                      if (value != oldValue) {
                         send(msgSW.set(value==HIGH ? 1 : 0));
                         oldValue = value;
                      StatePIR=digitalRead(DIGITAL_INPUT_SENSOR);
                      if (StatePIR != oldStatePIR) {
                        oldStatePIR=StatePIR;
                        send(msgMot.set(StatePIR ? 1 : 0));
                          state = !state;
                        if (!metric) {
                        #ifdef MY_DEBUG
                          lastHum = humidity;
                          #ifdef MY_DEBUG
                    • rhuehnR rhuehn
                      #define RELAY_PIN  4
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      #define CLOSED 0
                      #define OPEN 1
                      int oldValue=-1;
                      bool state = false;
                      byte StatePIR=0;
                      byte oldStatePIR=0;
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                        delay(100);
                        delay(100);
                        delay(100);
                        delay(100);
                        delay(100);
                        // Setup the button
                          debouncer.update();
                           oldValue = value;
                            state = !state;
                          if (!metric) {
                          #ifdef MY_DEBUG
                            lastHum = humidity;
                            #ifdef MY_DEBUG
                      Boots33B
                      Boots33B
                      Boots33
                      @rhuehn Can you explain in more detail how your project is meant to work? How and when is the relay meant to be triggered, what is the motion sensor used for?
                      In the code below what are you trying to achieve.
                      Your node is a repeater as well as expecting to receive messages so you should not be using sleep or delay in your code, use wait instead
                      What is the saveState for in your message receive code?
                      Try this and see if it stops your relay from activating
                      else {
                      • rhuehnR
                        rhuehnR
                        rhuehn
                        Hey @Boots33 Thanks very much for the reply. I apologize I should have elaborated further.
                        My home automation platform is Home Assistant. I am using a few mysensors around the house for temp, motion etc, and the purpose of this very sensor / sketch is to be used as a garage door opener. I am using an Uno, with the following PINS:
                        PIR - PIN 3
                        DHT - PIN 7
                        Relay - PIN 4
                        Reed switch - PIN 2
                        The PIR and the DHT are just fun addon sensors that might trigger an action based on motion or temp.
                        The Reed switch can tell when the garage door is open or closed based on contact, and the relay's purpose is to provide a momentary "press" of the garage door wall control, ( I have it wired into the opener and relay ).
                        It currently works great, but on loss of power at the house ( The arduino is plugged in ), the relay trips on reload, causing the garage door to open / close, and well, if we are away from the house, this is obviously not good. ;)
                        I just tried implementing your change you recommended, and unfortunately on reboot, the relay still triggers. Ideally, if I could have the relay not trigger on reboot, then I would consider it safe. I'm sure it's possible, I just can't figure out how to not have it reset / trigger on AC power fail. The interface appears as follows:
                        0_1488935309554_upload-d5417f76-6875-4689-bc03-2fa7f45d760c
                        I did make the modification, but the results are the same, so I won't re paste the code block.
                        Thanks very much for the help @Boots33 if there are any other code mods I could make, I really would appreciate it.
                        • rhuehnR rhuehn
                          PIR - PIN 3
                          DHT - PIN 7
                          Relay - PIN 4
                          Reed switch - PIN 2
                          Boots33B
                          Boots33B
                          Boots33
                          @rhuehn
                          could you please explain the code shown below.
                          Why do you send this initial value
                          Why do you need to request the relay status.
                          Why does the reed switch status effect the relay status.
                                state = !state;
                          The code to receive an on signal from your controller could be as simple as shown below but I am not sure how the above code will work with that.
                          /*  if (message.isAck()) {
                           if (message.type == V_STATUS && message.sensor == CHILD_ID_REL && message.getBool == true) {
                              digitalWrite(RELAY_PIN, RELAY_ON);
                              wait( TOGGLE_INTERVAL );
                              digitalWrite( RELAY_PIN, RELAY_OFF );               //turn relay off
                              send(msg.set(false), false);                       // send off state to controller, no ack requested
                          • Daniel OliveiraD
                            Daniel OliveiraD
                            Daniel Oliveira
                            I'm not an expert and honestly I didn't read all the comments, but to avoid the relay to change status on reboots would not be a simpler solution to add a "flip-flop" mechanism that will "save" the last sate for some minutes?
                            Best regards
                            MySensors rules my home :)
                            • rhuehnR
                              rhuehnR
                              rhuehn
                              Hello @Boots33
                              The Reed switch should NOT have any effect on the relay. ( It shouldn't anyways, it only senses open / closed
                              From my understanding here:
                              https://home-assistant.io/components/mysensors/
                              It needs to be done in the loop function:
                              Present the sensor’s S_TYPE.
                              Send at least one initial value per V_TYPE. In version 2.0 of MySensors this has to be done in the loop function. See below for an example in 2.0 of how to make sure the initial value has been received by the controller.
                              Below is an example from that page:
                               * http://www.mysensors.org/build/relay
                              #define MY_NODE_ID 1
                              #define RELAY_PIN  5
                              #define BUTTON_PIN  3
                              #define CHILD_ID 1
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              bool state = false;
                                pinMode(BUTTON_PIN, INPUT_PULLUP);
                                debouncer.attach(BUTTON_PIN);
                                debouncer.interval(10);
                              void presentation()  {
                                sendSketchInfo("Relay+button", "1.0");
                                present(CHILD_ID, S_BINARY);
                                  request(CHILD_ID, V_STATUS);
                                    state = !state;
                              I was just following some guidelines to use HASS+ My Sensors together.
                              • rhuehnR rhuehn
                                Hello @Boots33
                                #define RELAY_PIN  5
                                #define CHILD_ID 1
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                bool state = false;
                                      state = !state;
                                Boots33B
                                Boots33B
                                Boots33
                                @rhuehn Ahh... I use Domoticz so was unaware of HA's need for the extra code to register the node.
                                So the problem you face is then likely the code below the registration code.
                                This code is using the bouncer instance which you have connected to your reed switch and then sends a message to change the state of your relay.
                                      state = !state;
                                So if you could can you try these 2 changes to your code and see if we are any close to the desired result :)
                                I have changed the initial code slightly to just sen an off state for the switch. It should make no difference as all you are needing is an initial response from the sensor.
                                I have also commented out the bouncer code
                                    //send(msg.set(state?RELAY_ON:RELAY_OFF));
                                    send(msg.set(RELAY_OFF));
                                      state = !state;
                                Then change your receive code to
                                /*    // Change relay state
                                else if (message.sensor == CHILD_ID_REL && message.getBool == true) {
                                • BrydenB
                                  BrydenB
                                  Bryden
                                  What type of relay are you using?
                                  My guess is a LOW TRIGGER relay, which is bad for this task.
                                  If you are using a low trigger relay the fault is in the hardware not the code.
                                  The microcontroller takes time to reboot and enable a high to keep the relay open.
                                  When you loose power, your microcontroller is going to take time to reboot,
                                  But I bet your power supply is going to instantly give power to your relay board,
                                  hence there is a small period in time where there is a ground on your pin before the initial setup of the pin to high in the microcontroller, causing your relay to trigger.
                                  This is why I hate low trigger relays, they are useless when it comes to power interrupts and you're trusting your house security to them.
                                  My suggestions to test my theory, then you will know where your fault lies.
                                  throw an LED on your relay out to light up when switched high, Apply power to your microcontroller and see how long it takes for the relay to turn on.
                                  Why do people use low level relays?
                                  Output pins are generally 3.3v, that's not enough voltage to trigger most high level relays, using a low level trigger overcomes this.
                                  Use a high level relay, but you will need a transistor circuit to feed it 5v as the 3.3v generally wont trigger the relay with a high output.
                                  hopefully my rant helps
                                  • BrydenB
                                    BrydenB
                                    Bryden
                                    I noticed on my ESP8266-01b that it does power surge a voltage during initial power up as well, also bad for a high level relay
                                    • BrydenB Bryden
                                      Boots33B
                                      Boots33B
                                      Boots33
                                      @Bryden thanks for your input. In the code the relay is switched high for on and low for off so it should not be the type of relay to cause problems . Worth checking though.
                                      • BrydenB
                                        BrydenB
                                        Bryden
                                        check to see if the output pins are having any voltage applied on initial boot as well.
                                        As mentioned I had an esp8266-01b on my desk here, and when power was applied I saw voltage on one of the gpio's intermittently.
                                        • rhuehnR
                                          rhuehnR
                                          rhuehn
                                          Hey guys! Thanks so very much for all the great comments. I haven't replied in a few days as I wanted to go back to the drawing board..... I didn't like that sketch, the sleep functions, etc etc.... It didn't also make sense clearly based on everyone's feedback ( Sorry I am just getting started with IDE... ) So, based on that, I've come up with the following, and if you could comment, modify where I messed up, it would be greatly appreciated. This sketch seems to work, and keep state on power LOSS. There's a relay for the garage door ( trigger, PIN 4 ), a reed switch to detect if the door is open or closed ( PIN 2 ), a DHT for Temp / Humidity ( PIN 7 ), and a PIR ( PIN 3 ) for motion activated events. Below is the sketch, and would really appreciate any great feedback.
                                          Thanks again!
                                          #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                          #define BUTTON_PIN  2  // Arduino Digital I/O pin for button/reed switch
                                          static const uint64_t UPDATE_INTERVAL = 60000;
                                          float lastTemp;
                                          float lastHum;
                                          uint8_t nNoUpdatesTemp;
                                          uint8_t nNoUpdatesHum;
                                          bool metric = true;
                                          #define SENSOR_TEMP_OFFSET -1
                                          #define CHILD_ID_PIR 3
                                          #define PIR_PIN 3
                                          byte StatePIR=0;
                                          byte oldStatePIR=0;
                                          int oldValue=-1;
                                          MyMessage msgSw(CHILD_ID_SW,V_TRIPPED);
                                          MyMessage msgHum(CHILD_ID_HUM, V_HUM); // 1
                                          MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); // 0
                                          MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
                                          DHT dht;
                                          void before()
                                                  pinMode(pin, OUTPUT);
                                            dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // set data pin of DHT sensor
                                            pinMode(PIR_PIN, INPUT_PULLUP);
                                            // Setup the button
                                            pinMode(BUTTON_PIN,INPUT);
                                                  present(sensor, S_BINARY);
                                                  present(CHILD_ID_PIR, S_MOTION);
                                          StatePIR=digitalRead(PIR_PIN);
                                              send(msgPir.set(StatePIR ? "ON" : "OFF"));
                                            dht.readSensor(true);
                                              if (!metric) {
                                              // Reset no updates counter
                                              nNoUpdatesTemp = 0;
                                              #ifdef MY_DEBUG
                                              nNoUpdatesTemp++;
                                              lastHum = humidity;
                                              nNoUpdatesHum = 0;
                                              #ifdef MY_DEBUG
                                              nNoUpdatesHum++;
                                            debouncer.update();
                                               send(msgSw.set(value==HIGH ? 1 : 0));
                                               oldValue = value;
                                              if (message.type==V_STATUS) {
                                                  digitalWrite( RELAY_1, RELAY_OFF );
