  3. Display node: how to set up
33 Posts 6 Posters 11.6k Views 10 Watching
  • P Offline
    P Offline
    Petjepet
    wrote on last edited by Petjepet
    I would like to create a display node (1602 or 2004) with the possibility to show measurements of other node(s).
    How do I approach on this? What is the way to work with MySensors.
    I would like the display node to be available in the living room with the ability to show for example the data from my weather station (multi sensor node). On top af that this display node can act as repeater node.
    Will in such case this node receive data directly from the weather station node or do I have to retrieve the data for this node from the pimatic database?
    How do I implement this?
    Thanks for any suggestions :simple_smile:
    • P Petjepet
      @Petjepet have you looked at the display example? It shows time and temperature fetched from the controller. Seems quite similar to what you want to build.
      P cadetC 2 Replies Last reply
        P Offline
        P Offline
        Petjepet
        @mfalkvidd yes I did and believe it is showing the RTC data of that same node. It gets the time initially from the controller by a specific for the system time available function 'requestTime()'.
        How would I for example get the temperature from a particular node in this display node?
        So how to refer to that particular node and the temperature attribute in the sketch of the display node?
        Is there a kind of function 'requestValue(NodeId, SensorId)'?
          cadetC Offline
          cadetC Offline
          cadet
          @mfalkvidd
          Example show temp from DS3232 RTC
          • P Petjepet
            @Petjepet yes. See https://www.mysensors.org/download/sensor_api_20#requesting-data
            P 2 Replies Last reply
              P Offline
              P Offline
              Petjepet
              @mfalkvidd Thanks! I'll have a look.
                P Offline
                P Offline
                Petjepet
                @mfalkvidd to start right:
                The function 'void receive(const MyMessage &message)'
                This will catch all data being send from nodes?
                I will have to identify what type the data is and from which node and sensor the data came and if the node is correct use that data to update the display with?
                The function 'void request(uint8_t childSensorId, uint8_t variableType, uint8_t destination);'
                This function will request directly data from a particular node and sensor.
                Probably not the way to go when the sensors are battery nodes since this function will activate the battery nodes often.
                The receive function would fit better but I have to investigate how to determine the node and sensor the data received is coming from. Is there an example for this?
                • mfalkviddM Offline
                  the receive function will be called every time the node receives a message destined for that node.
                  The message object can be examined by checking the contents of the message. More information: https://forum.mysensors.org/topic/6351/interperating-messages-from-controller/4
                  Nodes that are sleeping will not be woken up. They are sleeping, so they can't know that they should wake up.
                  The easiest way is probably to either have the other nodes send the data to the display node, or have the other nodes send the data to the controller and let the display node query the controller.
                  This thread might give some more information https://forum.mysensors.org/topic/826/node-to-node-communication
                  P 1 Reply Last reply
                    P Offline
                    P Offline
                    Petjepet
                    @mfalkvidd thanks for the info.
                    I came up with this and verification of the sketch is ok in Arduino IDE:
                      // Explore message
                      if (message.sender == 38) // weatherstation node
                        switch (message.sensor)
                          case 0:  // Humidity sensor
                            lcd.setCursor ( 0, 1 );
                            lcd.print("Hum: ");
                            lcd.print(message.getFloat());
                            lcd.print("%");
                          case 1:  // Temperature sensor
                            lcd.setCursor ( 0, 0 );
                            lcd.print("Temp: ");
                            lcd.write(223); // Degree-sign
                            lcd.print("C");
                          case 2:  // Light sensor
                            lcd.setCursor ( 8, 1 );
                            lcd.print("L: ");
                            lcd.print(message.getUInt());
                            lcd.print("Lux");
                          case 3:  // Barometer sensor
                            lcd.setCursor ( 8, 0 );
                            lcd.print("P: ");
                            lcd.print("mBar");
                          case 4:  // Barometer Temperature sensor
                          case 5:  // Rain sensor
                    Is this the way to approach ?
                    I still have some questions about the concept:
                    • When I use the 'receive' function in this display node, will the message still be received by the gateway?
                    • In general: can messages sent by one node be receive and evaluated by multiple other nodes in parallel?
                    • P Petjepet
                        // Explore message
                              lcd.print("Hum: ");
                              lcd.print("%");
                              lcd.print("C");
                              lcd.print("L: ");
                              lcd.print("Lux");
                              lcd.print("P: ");
                              lcd.print("mBar");
                      @Petjepet yes that could be the right approach, assuming you have nodes 1-5 sending data to that display node.
                      Depending on you network setup, they gateway may receive and forward the message.
                      Broadcast messages are possible (by sending to destination node 255). I am not sure how they work though, I have never used them myself.
                        P Offline
                        P Offline
                        Petjepet
                        @mfalkvidd actually it is one node having 5 sensors.
                        My setup is one gateway with multiple nodes (4 PIRs, 1 Temperature, 1 Humidity and the weather station with 5 sensors).
                        These nodes just use the standard 'send' function. This is a broadcast, isn't it, since no destination node is provided in this function?
                        The gateway picks up these messages of the nodes (as I can see them in my controller Pimatic) and I hope the display node will pick the message up as well.
                        Or does the receive function only pick up dedicated sent messages from other nodes?
                        If this is the case I will have the display node to query the controller. No clue how to do that.
                        I'll build the display node tomorrow to test the sketch I have now and see if it receives the data of node 38 (weather station and its 5 sensors).
                        • P Petjepet
                          @Petjepet said in Display node: how to set up:
                          Yes, you're right. Sorry about the confusion.
                          No. The default destination for messages is the gateway, so they will only be received by the gateway.
                          No the display node will not receive the messages unless the messages have the node as destination (message.setDestination() )
                          Correct
                          Use the request function
                            Correct
                            P Offline
                            P Offline
                            Petjepet
                            @mfalkvidd I'm getting there in time :)
                            Thanks for all the patience you have in explaining.
                            Using the message.setDestination() function would then be an option to implement/add in the weather station node for each of the 5 sensors?
                            The drawback would be to reprogram the weatherstation which is fully operational now.
                            Using the resquest function in the display node would want to activate the weather station (being a battery node in my garden) which uses the sleep mode and that would not work as documented.
                            As said before I would also want to use the display node as a repeater.
                            This would make it a kind of gateway in passing through data.
                            Is there a possibility there to evaluate the weather station node data?
                            You also mentioned a way to get the data from the controller (Pimatic in my case).
                            How can I request data from the controller/gateway?
                            Or is there a way to let the controller/gateway send the data to the display node?
                            Maybe I'm looking at this issue in the wrong way.
                            All I would like to do is display data from a battery operated sensor node on another node.
                            • P Petjepet
                              Yes
                              Maybe. I don't know unfortunately.
                              I think you can just request the data from the gateway and the controller will respond but I am not sure.
                              Some controllers have the ability to do stuff when messages are received. I think Domoticz uses lua for that. I have not done anything similar myself though.
                              The pimatic area of the MySensors forum seems to be a very quiet place :(
                                Reprogramming the weather station it would only be a matter of adding the extra send commands to the display.
                                I was also thinking that this would be a case where mqtt would come handy, since you can get all the sensor data from pretty much anything that has an ip connection to the mqtt server.
                                • P Offline
                                  P Offline
                                  Petjepet
                                  @gohan I would like to leave the weather station reprogramming as the last option since it was built in the v1.5 period and calibrated. Never try to repair a working device :)
                                  In general I would like to develop a solution where display nodes can be added to the network not having to change other nodes for that. The independency of using display nodes without having to change sensor nodes would be great to achieve.
                                  @mfalkvidd I'll try to find out how to request data from the gateway/controller of a specific node. As long as the Pimatic controller is showing the data there must be a way to get it from there. Search the Pimatic forum for now.
                                  gohanG Boots33B 2 Replies Last reply
                                  • P Petjepet
                                    @Petjepet
                                    If you want more flexibility, I think mqtt is the best solution as you can add as many displays as you want, you could make an esp8266 mqtt gateway with display and nrf24 radio (if needed) or just an esp8266 with display with simple mqtt client (not mysensors) that subscribes to topics in the mqtt server and displays values.
                                    • P Offline
                                      P Offline
                                      Petjepet
                                        Did you try to add some serial print in order to check if that code in receive function is actually executed?
                                        • P Petjepet
                                          Boots33B Offline
                                          Boots33B Offline
                                          Boots33
                                          wrote on last edited by Boots33
                                          @Petjepet I have not done a lot with the request feature but here is how I understand it works.
                                          A node can make a request to the controller for information about its own child sensors by using request in its sketch. Typically this would be in the loop section of the sketch. The request is issued with the following line.
                                          request( sensorId, messageType)
                                          So if you had a binary switch sensor with a child id of 1 and you wanted to check on its status you would write it like this.
                                           request( 1,   V_STATUS);
                                          The request is then processed by your controller and the result is returned to the node that sent the request. You then need to have code on that node to do something with this information.
                                          As you have already noted this is where the void receive function is used.
                                          So for our example of a binary switch we could use something as simple as this
                                              //put code here to be executed when the return from the request arrives
                                          If you have more than one child sensor that you are expecting returns from you could extend the code using message.sensor to test for which sensor the return is for.
                                              switch (message.sensor) {
                                               case 1:                          //incoming message is for  sensor 1
                                                   // put code here to be executed when the message is for sensor 1
                                               case 2:                       //incoming message is for sensor  2
                                                   // put code here to be executed when the message is for sensor 2
                                          If you wanted to separate returns from a request from normal messages from your controller. You can use message.getCommand()
                                          If you look in the send and receive serial data for your node you will see the command type for a request shown as c=2 , so you just need to test for type 2 commands.
                                                 if (message.getCommand() == 2){
                                                   // put code here to be executed when the message is from a request
                                                 else {                                                             //process the message as per normal
                                          Making a direct request to another node is also possible. To do that you can use the optional third parameter in the request statement which is for the node id that you are requesting information from.
                                          The default is set to 0 which is the gateway but you can use the node id to select another destination.
                                          So if we wanted information from a binary switch sensor with an id of 1 which is on a node with an id of 20 we would do this
                                           request( 1, V_STATUS,  20);
                                          The gateway will rout this request to the desired node but it will be up to you to have code on that node to both read the request and then send a reply back to the node that asked for the information. Of course you will also need code on the sending node to process the request when it is returned
                                          P gohanG 2 Replies Last reply
