  3. why mysensors is based on nrf24?
65 Posts 13 Posters 21.9k Views 11 Watching
  • R Reza
    thank you friends for answer.
    about channel? MY_RF24_CHANNEL
    can we use several channel with RFM ?
    generally RFM work better than NRF ?
    AnticimexA
    AnticimexA
    Anticimex
    @Reza how about you read MyConfig.h?
    R 1 Reply Last reply
    • R Reza
      C
      C
      chbla
      @Reza it depends on the use case I think, peope are using both, both are working. NRF24 is easier to set up and seems to have more support. Just try it :)
      • R
        R
        Reza
        wrote on last edited by Reza
        #29
        for help to my friends that use NRF. i test several model. but most are not really range.this model was best of NRF. with this model i have connect with 60cm wall and 10meter distance.
        if you want have a good connection, so use this model:
        but i think NRF is not worthy mysensors and efforts of mysensors team :pray:
        • AnticimexA Anticimex
          R
          R
          Reza
          #30
          @Anticimex said in why mysensors is based on nrf24?:
          i am weak in english sorry i know repeater feature is in mysensors library, but i think about channel i think this is just for nrf. is that right ?
          @chbla i am very happy with mysensors. i have very sensors and relay and every day i am try to build a new sensor and a new devices :) if there was a stronge and good and easy connection so this was very more intresting
          AnticimexA 1 Reply Last reply
          • tbowmoT
            tbowmoT
            tbowmo
            I think you have missed a couple of details @Reza
            When mysensors started out, the cheapest / best approach was to use the nRF24L01, rfm69hw was not available. So the project evolved around this radio. The RFM69 came in at a later time.
            Unfortunately a lot of Chinese saw easy money, with counterfeit chips, and started to create less than optimal fake versions. That will probably also happen to rfm69hw (and are probably already there).
            So we keep nrf, as it is there in the core.. It's up to you and other hackers, to decide what you want to use
              hey dear friend,
              be like water ;)
              • R Reza
                AnticimexA
                AnticimexA
                Anticimex
                @Reza If you read MySensors.h you will find what configuration possibilities the various radios have. Try looking for information instead of just begging for it all the time.
                • tbowmoT tbowmo
                  R
                  R
                  Reza
                  @tbowmo
                  oh thank you for explain :pray: and thank you all mysensors team. really thank you. mysensors is intresting really. i try to found best and easy and without any trouble of solution for connection . we are easy to build all sensors and relay(with mysensors library) so this is intresting more to easy , very easy connection between rooms... :)
                  again thank you all mysensors team and hero members :pray:
                  • R Reza
                    @tbowmo
                    @Reza so, topic closed?
                      R
                      R
                      Reza
                      @Anticimex dear friend , i am trying for learn and work well with mysensors library , arduino and radios...
                      believe me i trying every days. now for 1.5 years. i am trying every days. but some time i dont know where found my problem and my question. i start learn arduino with mysensors library. because i am Interested very very. now i can write each sketch for sensors and relay. this is for your help .thank you
                      • R Reza
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Reza have a look in the file. It's designed to offer clear understanding of the various configuration options. And gives you a good overview of what settings you can place in your sketch to configure the library to your needs (what radio to use, what channel, transmit/receive power, pin assignments, etc.)
                        • YveauxY Yveaux
                          R
                          R
                          Reza
                          @Yveaux said in why mysensors is based on nrf24?:
                          so, topic closed?
                          hi. yes thank you. i see forum and site every days and read new topics and Newest Articles and Recently Updated :)
                          i hope mysensors development every days in all of world , and the team be healthy always.
                          thank you
                            R
                            R
                            Reza
                            thank you dear friend . i will see and read and translate .thank you
                            • K
                              K
                              kimot
                              And do not forgot about law restrictions in some countries, EU and etc.
                              For example with 868 Mhz your device can transmitting max 1% of time per one hour.
                              Maybe problem for gateway node?
                              2,4 GHZ is relatively free all over the world.
                              Page 7 here
                              • K kimot
                                Page 7 here
                                R
                                R
                                Reza
                                @kimot this is true . but also about 2.4 Ghz i think there is better modules.what module is using in raspberry pi 3 ( without antenna) or wifi router or milight modem or etc ... !? These are 2.4 Ghz . But working for more distance without any problem . i dont test esp8266 (12-12E and very new models) but Don`t you think this is work better ? I didnot work with any radio. Just nrf and a sender with receiver 433 .
                                • R
                                  R
                                  Reza
                                  Now for a wifi gateway mysensor used NodeMCU with a esp8266. Then connect a Nrf to NodeMCU . sensor network is with nrf and connection between router and gateway is with esp8266. If esp8266 work good , can we use esp8266 module for each node ? I did not work with esp and this is just a idea
                                  • R
                                    R
                                    Reza
                                    Now for RGB controller i use this module with domoticz. This modem dont have any external antenna... But work in a good distance without problem and need to a repeater...
                                    AWIA 1 Reply Last reply
                                    • R Reza
                                      AWIA
                                      AWIA
                                      AWI
                                      @Reza In order to diagnose your problems with the nrf24. Can you make a photo on how it is wired?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Reza
                                        Have you checked power consumption on esp8266 (and other wifi modules) compared to nrf24? You will probably be surprised..
                                        Some friends of mine are using esp8266 for their sensors (not mysensors related), battery life is below 1 month (if I remember right), even when the esp8266 is sleeping most of the time. I have 4 sensebender micros (with nrf24l01+) running of batteries for 2 years now, so yes you can use wifi etc. but the battery life will be lower..
                                        • R
                                          R
                                          Reza
                                          dear @AWI i dont have problem with wired and NRF and i know i dont have problem with power for NRF. i have a good connection with 5-6 meter with a for example 20cm wall ( i think this is the best of distance for usual NRF . but Whatever increase distance , so increase lost paket...
                                          now i use this modules and wire for NRF :
                                          use regulator and 2 capacitor 100u and 10n
                                          i mean just about connection. all mysensors library feature is excellent . really perfect . just connection is weak by NRF.
