  3. Code for beta-testing?
33 Posts 10 Posters 20.3k Views 2 Watching
  • A
    andriej
    wrote on last edited by andriej
    So it's time to start learning python, I guess. ;-)
    (I've written some basics scripts ages ago.)
    I'll help whenever I will be able to.
    @wannabee - have you tried starting node with gw.begin(some_number)?
    W 1 Reply Last reply
    • A andriej
      W
      W
      wannabee
      @andriej Yes, tested that, Even if the python gw handles to assign RAIDO_ID. Also cleared the EEPROM to be sure it didn't conflict between the versions. The interesting part is that it doens't even write to the serial line. Time to sleep and see if I cand find a few hours on Wednesday to get it working again.
      jkaJ 1 Reply Last reply
      • L
        L
        lasso
        wrote on last edited by lasso
        Try comment this line: metric = gw.isMetricSystem();
        • W wannabee
          jkaJ
          jkaJ
          jka
          wrote on last edited by jka
          @andriej
          Hi, I had problem using the main branch mysensors/Raspberry, that because of the bit-field struct (header_s) in Sensor.h They will get packed in different order on the arduino compared to the RPi (at least with my compiler, gcc). In order to fix this I created the 1.4dev branch. It uses full bytes instead of the bit-fields, but you need (of cause) to compile both the sensors (arduino) and the gateway (RPi) using the 1.4dev branch.
          We need to fix this in the main branch later on (and use the same files as in mysensors/Arduino/libraries/MySensors)
          A B 2 Replies Last reply
          • jkaJ jka
            @andriej
            andriej
            @jka I can't (or I don't know how) to compile the 1.4-dev code. I've tried everything I guess.
            $ make RadioGateway
            make -C librf24
            make[1]: Wejście do katalogu `/home/pi/mysensors/Raspberry-1.4dev/librf24'
            g++ -shared -Wl,-soname,librf24.so.1 -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s  -o librf24.so.1 compatibility.o gpio.o spi.o RF24.o
            make[1]: Opuszczenie katalogu `/home/pi/mysensors/Raspberry-1.4dev/librf24'
            make -C /home/pi/mysensors/libraries/MySensors
            make[1]: Wejście do katalogu `/home/pi/mysensors/libraries/MySensors'
            make[1]: Nie ma nic do zrobienia w `all'.
            make[1]: Opuszczenie katalogu `/home/pi/mysensors/libraries/MySensors'
            g++ -o RadioGateway RadioGateway.o -Wall -Ofast -mfpu=vfp -DDEBUG -DRPI -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -I./librf24 -I/home/pi/mysensors/libraries/MySensors /home/pi/mysensors/libraries/MySensors/Gateway.o 			/home/pi/mysensors/libraries/MySensors/Relay.o /home/pi/mysensors/libraries/MySensors/Sensor.o ./librf24/librf24.so.1
            RadioGateway.o: In function `main':
            /home/pi/mysensors/Raspberry-1.4dev/RadioGateway.cpp:103: undefined reference to `Gateway::begin(unsigned char)'
            collect2: error: ld returned 1 exit status
            make: *** [RadioGateway] Błąd 1
            pi@domoticzpi ~/mysensors/Raspberry-1.4dev $
            • A andriej
              $ make RadioGateway
              make -C librf24
              jkaJ
              jkaJ
              jka
              @andriej
              OK, there where a few glitches in the Makefile, you can update it now.
              A 1 Reply Last reply
              • jkaJ jka
                @andriej
                andriej
                @jka
                I seem to have new problem then, guess it's with g++?
                pi@domoticzpi ~/mysensors/Raspberry $ make
                make -C librf24
                make[1]: Wejście do katalogu `/home/pi/mysensors/Raspberry/librf24'
                g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c RF24.cpp
                In file included from /usr/include/unistd.h:203:0,
                             from spi.h:13,
                             from RF24_config.h:23,
                             from RF24.cpp:10:
                /usr/include/arm-linux-gnueabihf/bits/posix_opt.h:131:3: error: #error "Never use <bits/syscall.h> directly; include <sys/syscall.h> instead."
                /usr/include/arm-linux-gnueabihf/bits/posix_opt.h:20:0: error: unterminated #ifndef
                In file included from RF24.cpp:11:0:
                RF24.h: In constructor ‘RF24::RF24(std::string, uint32_t, uint8_t)’:
                RF24.h:52:12: warning: ‘RF24::spispeed’ will be initialized after [-Wreorder]
                RF24.h:50:11: warning:   ‘uint8_t RF24::ce_pin’ [-Wreorder]
                RF24.cpp:241:1: warning:   when initialized here [-Wreorder]
                make[1]: *** [RF24.o] Błąd 1
                make[1]: Opuszczenie katalogu `/home/pi/mysensors/Raspberry/librf24'
                make: *** [RF24] Błąd 2
                • B
                  B
                  Bmlsx
                  dont know if this should be on new subject but spare me this one
                  i recompiled both arduino and rpi part with 1.4 branch
                  but i get on the RPi side CRC errors
                  Starting Gateway...
                  Sensor-1Gateway created...
                  SPI device = /dev/spidev0.0
                  SPI speed = 8000000
                  CE GPIO = 25
                  STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                  RX_ADDR_P0-1 \0 = 0xabcdabc000 0xabcdabc000
                  RX_ADDR_P2-5 \0 = 0xff 0xc4 0xc5 0xc6
                  TX_ADDR = 0xabcdabc000
                  RX_PW_P0-6 \0 = 0x20 0x20 0x20 0x00 0x00 0x00
                  EN_AA = 0x3f
                  EN_RXADDR \0 = 0x07
                  RF_CH = 0x4c
                  RF_SETUP \0 = 0x07
                  CONFIG = 0x0f
                  DYNPD/FEATURE \0 = 0x3f 0x04
                  Data Rate = 1MBPS
                  Model = nRF24L01+
                  CRC Length = 16 bits
                  PA Power = PA_MAX
                  Radio setup complete-0;0;4;11;Arduino startup complete.
                  Begin called
                  Dynamic payload size=12
                  Received: from=9, to=0, childId=255, mtype=0, type=17, crc=47, '1.4'
                  Message crc error.
                  header.type=17, header.to=0, radioId=0
                  Dynamic payload size=10
                  Received: from=9, to=0, childId=255, mtype=4, type=7, crc=115, '0'
                  Message crc error.
                  header.type=7, header.to=0, radioId=0
                  Received: from=9, to=0, childId=0, mtype=0, type=7, crc=15, '1.4'
                  Message crc error.
                  Received: from=9, to=0, childId=1, mtype=0, type=6, crc=187, '1.4'
                  Message crc error.
                  header.type=6, header.to=0, radioId=0
                  Dynamic payload size=13
                  Received: from=9, to=0, childId=1, mtype=1, type=0, crc=228, '20.5'
                  Message crc error.
                  header.type=0, header.to=0, radioId=0
                  Received: from=9, to=0, childId=0, mtype=1, type=1, crc=118, '50.3'
                  Message crc error.
                  while on the arduino just the failed send
                  Started sensor.
                  Relay=0, distance=1
                  Relaying message back to gateway.
                  Tx: fr=9,to=0,la=9,ne=0,ci=255,mt=0,ty=17,cr=47: 1.4
                  Send failed.
                  Tx: fr=9,to=0,la=9,ne=0,ci=255,mt=4,ty=7,cr=115: 0
                  Send failed.
                  Tx: fr=9,to=0,la=9,ne=0,ci=0,mt=0,ty=7,cr=15: 1.4
                  Send failed.
                  Tx: fr=9,to=0,la=9,ne=0,ci=1,mt=0,ty=6,cr=187: 1.4
                  Send failed.
                  Tx: fr=9,to=0,la=9,ne=0,ci=1,mt=1,ty=0,cr=228: 20.5
                  Send failed.
                  T: 20.50
                  Tx: fr=9,to=0,la=9,ne=0,ci=0,mt=1,ty=1,cr=118: 50.3
                  Send failed.
                  H: 50.30
                  Tx: fr=9,to=0,la=9,ne=0,ci=1,mt=1,ty=0,cr=195: 20.6
                  Send failed.
                  T: 20.60
                  Tx: fr=9,to=0,la=9,ne=0,ci=0,mt=1,ty=1,cr=81: 50.0
                  Send failed.
                  H: 50.00
                  also changed the Data Rate = 1MBPS on arduino to match the RPI preet
                  any ideas?
                  thanx a mil
                    wrote on last edited by hek
                    You are experiencing the problem @jka describes above. When the message header bitfield is packed (by the compiler) if differs on the Arduino and RPI which result in garbled header and CRC-check-errors.
                    We have to introduce our own bit manupilation when adding/extracting stuff from the (bit-field)-header to overcome this cross platform problems.
                    B 1 Reply Last reply
                      B
                      B
                      Bmlsx
                      @hek ooooooh, I thought it was already done in the 1.4 branch... Silly me.
                      Thanx
                        You could do like @jka did and modify header to only use full bytes for all fields temporarily (on the sensor side as well). This way you will be able to communicate until we fix the problem properly.
                        • B
                          B
                          Bmlsx
                          please excuse the frivolity
                          u mean like this both on arduino and Pi?
                          // The message structure
                          typedef struct {
                          unsigned char crc; // uint8_t crc; // 8 bits crc
                          unsigned char version; // (3 bits) protocol version
                          unsigned char binary; // (1 bit). Data is binary and should be encoded when sent to sensor net gateway
                          unsigned char from; // 8 bits. RadioId of sender node
                          unsigned char to; // 8 bits. RadioId of destination node
                          unsigned char last; // 8 bits. RadioId of last node this message passed
                          unsigned char childId; // 8 bits. Up to MAX_CHILD_DEVICES child sensors per radioId
                          unsigned char messageType; // (4 bits). Type of message. See messageType
                          unsigned char type; // 8 bits. variableType or deviceType depending on messageType
                          } header_s;
                          hekH 1 Reply Last reply
                          • B Bmlsx
                            typedef struct {
                            } header_s;
                            @Bmlsx
                            Yes. :)
                            • W
                              W
                              wannabee
                              @andriej and @jendrush, I commited some code to my repository for the python gateway with half (oneway) Domoticz integration. It also support Openhab, The Openhab integarion is what I think I will integarate for my self and continue to develop. Domoticz needs provide a proper API that I can use without spending a lot of time trying to figure out how it works. My code is at https://github.com/wbcode/ham. You can try it out if you want. The installation part and configuration is missing a lot of instructions.
                              Will create my own thread for my gateway code when I have a name for it and I have spent the time to do a proper update to the wiki and better a presenation on what you cand do.
                              Please note that iit's not a full replacment for a Vera and it's my first time codeing python...
                                @Bmlsx
                                Yes. :)
                                B
                                B
                                Bmlsx
                                wrote on last edited by Bmlsx
                                @hek
                                hi there,
                                nagging time ...did all that (unsigned char on both ends arduino and rpi) but all i get in my rpi is below
                                any ideas?!!
                                thanx
                                G
                                Starting Gateway...
                                SPI speed = 8000000
                                CE GPIO = 25
                                RX_ADDR_P0-1 \0 = 0xe7e7e7e7e7 0xc2c2c2c2c2
                                TX_ADDR = 0xe7e7e7e7e7
                                RX_PW_P0-6 \0 = 0x00 0x00 0x20 0x00 0x00 0x00
                                EN_AA = 0x3f
                                EN_RXADDR \0 = 0x07
                                RF_CH = 0x4c
                                RF_SETUP \0 = 0x07
                                CONFIG = 0x0c
                                Data Rate = 1MBPS
                                Model = nRF24L01+
                                PA Power = PA_MAX
                                Begin called
                                Dynamic payload size=11
                                Received: from=16, to=18, childId=0, mtype=50, type=49, crc=120, '.7'
                                Message crc error.
                                header.type=49, header.to=18, radioId=0
                                Received: from=16, to=2, childId=1, mtype=54, type=53, crc=231, '.2'
                                Message crc error.
                                header.type=53, header.to=2, radioId=0
                                • jkaJ jka
                                  @andriej
                                  B
                                  B
                                  Bmlsx
                                  Hi there again
                                  A quick question @jka I used the 1.4 branch on both arduino and rpi and all I get o rpi are messed up messages with crc errors, can u point me a direction on what I do wrong?
                                  Thanx
                                  G
                                  • B Bmlsx
                                    Hi there again
                                    Thanx
                                    G
                                    B
                                    B
                                    Bmlsx
                                    Can anyone pls help on this ...I'm about to eat the raspberry
                                      Sorry, I don't know why you are experiencing problem. We will soon have a look at the RPI stuff again and make a usable version.
                                      The last week all our mysensors-time has been spend on server infrastructure (prod/stage environment etc) to prepare for the new services.
                                      Getting this right took more time that we initially anticipated.
                                      In the meantime. Anyone having a good low footprint node-database-candidate for storing sensor data in the RPI?
                                      The purpose is having a local backup of all historic data and to keep a record of which data has been sent to cloud-service.
                                      There won't be much local querying, mostly storing.
                                      Right now I'm considering:
                                      NeDB/NEDBLogger (https://github.com/louischatriot/nedb)
                                      Levelup/Leveldb (https://github.com/rvagg/node-levelup)
                                      • T
                                        ToSa
                                        Code Contributor
                                        wrote on last edited by ToSa
                                        #23
                                        The "Message crc error." is a bit misleading. The code in the validate() routine actually checks the crc as well as the protocol version. Looking at the Arduino and the RPi 1.4 branch the versions don't match. I've adjusted the library and protocol version in the Sensor.h file on the Rpi to:
                                        LIBRARY_VERSION "1.4"
                                        PROTOCOL_VERSION 2
                                        and the crc error disappeared.
                                        While changing the data rate from 2M to 1M in line 30 of the Arduino Sensor.cpp, I had to fix a syntax error to recompile successfully in line 361: a missing "}" to close the do/while. The full line should be "} while (--retry);"
                                        With these two fixed the RPi and the Arduino now communicate - but I get a lot of "Send failed" messages on the Arduino and a lot of "Error looking up radioIds" on the RPi now:
                                        RPi output:
                                        Received: from=255, to=0, childId=255, mtype=4, type=5, crc=139, ''
                                        139, 2, 0, 255, 0, 255, 255, 4, 5
                                        Message crc ok.
                                        header.type=5, header.to=0, radioId=0
                                        Got message
                                        Message type: 4
                                        msgTypeId=4 int=4
                                        ...and so on...
                                        Android in DEBUG mode:
                                        Started sensor.
                                        Relay=0, distance=1
                                        No radio id found in EEPROM fetching one from sensor net gateway
                                        Tx: fr=255,to=0,la=255,ne=0,ci=255,mt=4,ty=5,cr=139:
                                        Send failed.
                                        Send failed.
                                        ...and so on...
                                        • T
                                          ToSa
                                          Code Contributor
                                          Changing the mongo database URL in the dbDetails,js file
                                          mongodb://mysensors:27017/pi
                                          to:
                                          mongodb://localhost:27017/mysensors
                                          fixed the "Error looking up radioIdo" issue on the RPi. Now the Rpi generates a new radioId but the attempt to send this to the Arduino fails:
                                          RPi output:
                                          Message crc ok.
                                          Got message
                                          Message type: 4
                                          msgTypeId=4 int=4
                                          Sending data 255;255;4;5;1
                                          Writing back messageWe have input
                                          Nread=14
                                          INP:255;255;4;5;1
                                          INGOT radioId=255, childId=255, messageType=4, type=5, value=1
                                          Sending data to GATEWAYRelaying message back to gateway.
                                          Sending: from=0, to=255, childId=255, mtype=4, type=5, crc=193, '1
                                          ', sent via 0
                                          193, 2, 0, 0, 255, 0, 255, 4, 5
                                          radioId: Inserted id=1
                                          Send failed. No ack received.
                                          Sent to JS
                                          Dynamic payload size=9
