  3. How to convert received messages to integers? (MQTT)
6 Posts 3 Posters 3.6k Views 3 Watching
  • ikkeTI Offline
    ikkeTI Offline
    ikkeT
    I'm puzzled how message receive happens. I am building a infrared transmitter. I decoded the NEC signals from original remote, they look like this (hex): 0xF7C03F. This is power on command.
    Now I want to send those signals over MQTT, which mysgw transfers over NRF24L01+ to arduino. But how to convert messages so that they look alike at both ends? is that number too big to send (3 bytes)?
    As I send that exact command from arduino:
    #define CMD_ON        0xF7C03F
    send(msg_ir.set(CMD_ON));
    it looks like this on MQTT looking from mosquitto_sub:
    MySensorsGW/out/7/1/1/0/32 16236607
    When I send that back:
    mosquitto_pub -h droidcam.ikenet -p 1883 -t MySensorsGW/in/7/1/1/0/32 -m 16236607
    the code:
    uint32_t ircode;
    ircode = atoi( message.data );
            Serial.print( "V_IR_SEND data invalid: " );
            Serial.print( message.data );
            Serial.print( ", ircode: " );
            Serial.println( ircode );
    prints it out like this:
    V_IR_SEND data invalid: 16236607, ircode: 4294950975
    the numbers don't match. 16236607 is not the original CMD_ON code.
    This is the receive function:
    // IR remote command codes
    #define CMD_BRIGHTER  0xF700FF
    #define CMD_DIMMER    0xF7807F
    #define CMD_OFF       0xF740BF
    #define CMD_FLASH     0xF7D02F
    #define CMD_STROBE    0xF7F00F
    #define CMD_FADE      0xF7C837
    #define CMD_SMOOTH    0xF7E817
    #define CMD_RED       0xF720DF
    #define CMD_RED1      0xF710EF
    #define CMD_RED2      0xF730CF
    #define CMD_RED3      0xF708F7
    #define CMD_RED4      0xF728D7
    #define CMD_GREEN     0xF7A05F
    #define CMD_GREEN1    0xF7906F
    #define CMD_GREEN2    0xF7B04F
    #define CMD_GREEN3    0xF78877
    #define CMD_GREEN4    0xF7A857
    #define CMD_BLUE1     0xF7609F
    #define CMD_BLUE      0xF750AF
    #define CMD_BLUE2     0xF7708F
    #define CMD_BLUE3     0xF748B7
    #define CMD_BLUE4     0xF76897
      uint32_t ircode;
      Serial.print( "Received something of type: " );
      Serial.println( message.type );
    	if (message.type == V_IR_SEND) {
    		Serial.println( "V_IR_SEND command received..." );
        //ircode = message.data;
        switch (ircode) {
          case CMD_BRIGHTER:
          case CMD_DIMMER:
          case CMD_OFF:
          case CMD_ON:
          case CMD_FLASH:
          case CMD_STROBE:
          case CMD_FADE:
          case CMD_SMOOTH:
          case CMD_RED:
          case CMD_RED1:
          case CMD_RED2:
          case CMD_RED3:
          case CMD_RED4:
          case CMD_GREEN:
          case CMD_GREEN1:
          case CMD_GREEN2:
          case CMD_GREEN3:
          case CMD_GREEN4:
          case CMD_BLUE1:
          case CMD_BLUE:
          case CMD_BLUE2:
          case CMD_BLUE3:
          case CMD_BLUE4:
            Serial.print( "V_IR_SEND code received: ");
            Serial.println( message.data );
            send_ircode(ircode);
            ack_ir_to_controller(ircode);
          default:
    			  return;
      for (int i=0; i<5; i++) {
        digitalWrite(LED_PIN, HIGH);
        wait(100);
        digitalWrite(LED_PIN, LOW);
        wait(100);
    I suppose it has to do with data length and auto conversion of variables. It perhaps worked if I use smaller numbers to set the IR code value. But however, I'd like to understand how this is supposed to work?
    BR,
    -ikke
    PS, this is IR controlled LED light bulb from LIDL, and commands do work with the given codes.
    • hekH Offline
      hekH Offline
      It might help if you add a L to indicate long on the defines.
      Like this
      #define CMD_ON 0xF7C03FL
      • ikkeTI Offline
        ikkeTI Offline
        ikkeT
        Thanks, now it looks different, doesn't still work though. Perhaps the atoi doesn't do longs properly?
        Received something of type: 32
        that turns out to be:
        echo "obase=16;4294950975"|bc
        FFFFC03F
        How does it come up with that? Need to hurry to work now, later...
        • ikkeTI Offline
          ikkeTI Offline
          ikkeT
          The point in the above is, the Serial.print converts it correct, the atoi doesn't.
          A 1 Reply Last reply
          • ikkeTI ikkeT
            A Offline
            A Offline
            AWI
            wrote on last edited by AWI
            @ikkeT
            The ato.. functions are very basic and do only what they are supposed to do:
            • atoi parses to int
            • atof parses to float
            • atol parses to long
            You can also consider the str.... functions (e.g. strtoul()) as a more robust alternative.
            Replacing the defines by const will help with type checking.
            i.e. replace #define CMD_BLUE4 0xF76897ul (you can add UL to indicate a constant is unsigned long which can hold 4 bytes 0xFFFFFFFF) with const unsigned long CMD_BLUE4 = 0xF76897ul ;
            • ikkeTI Offline
              ikkeTI Offline
              ikkeT
              Excellent, thank you. It's too long since I've done serious coding, I didn't remember that. atoi -> atol fixed it.
