  3. Low power battery Door/Window sketch nrf24l01
21 Posts 7 Posters 12.3k Views 5 Watching
    I remember one saying that was able to run for over a year, a mini pro with reed switch on a single cr123
    • warmaniacW warmaniac
      Hi there,
      I want to ask if somebody had already done a sketch for 2AA 1,5V battery powered arduino with nrf24l01 wireless radio based on interrupt pin detection ? I have done couple of hours searching and trying but I'm not very successful with it. The default sketch on this web https://www.mysensors.org/build/binary drains my batteries powered by power booster after 24 hours to 0,8 volts :cat:
      In advance, I really appreciate your support in this matter
      sundberg84S
      sundberg84S
      @warmaniac - it should not be a problem running this for atleast a year (this is how I have build my PCB - EasyPCB).
      Do you use the sleep() function and did you remove the led and voltage converter on the arduino?
      Here is some more info: https://www.mysensors.org/build/battery
      If you check https://www.mysensors.org/build/motion you can see a binary sketch which use sleep()
      warmaniacW 1 Reply Last reply
      • sundberg84S sundberg84
        warmaniacW
        warmaniacW
        warmaniac
        @sundberg84
        BOTH led was removed , as I said , this HW specs Im using on multiple sensors with sleep function and i dont have any problems with battery. Thanks for recommendation of using modified sketch from motion sensor. Im not expecting to remove voltage regulator because im powering my arduino with stepup booster which can be higher than 3.3 volts .
          @sundberg84
          sundberg84S
          sundberg84S
          @warmaniac - this is not optimal since the voltage regulater has a current drain and will use your batterypower to fast. Im using a DC-DC stepup booster which provide 3.3v and then you dont need a voltage regulator.
            warmaniacW
            warmaniacW
            warmaniac
            @sundberg84
            Yep I understand , but I ordered 10 pcs of step up boosters, all gives output voltage 3,7 -3,8V . without regulator is problem ,I think.
              @sundberg84
              sundberg84S
              sundberg84S
              @warmaniac - So maybe you can add a diode or something in series to drop the voltage until you get new stepups, because you will be disappointing with batterylife if you use this setup.
              • warmaniacW
                warmaniacW
                warmaniac
                @sundberg84
                I had barometer BMP180 powered on 2xAA 1,5V , in usage from 1.March 2017 , Start battery power was 85% (not new batteries, before used) and now after 14 days of usage is 84 % , Im very satisfied. Using only without LEDs ,with power regulator on arduino.
                  I'm not having problem with my hardware with other sensors which sleeps every 2 minutes. Same hardware lasts on 1 % battery for 2 weeks , it is good result for me . I only want to know if is better sketch for battery powered door sensor which is based on interrupts wake up from sleep. It will be much better for battery.
                  L
                  L
                  LastSamurai
                  @warmaniac said in Low power battery Door/Window sketch nrf24l01:
                  Then why don't you just use the sketch I linked to? Or simply add the parts you need (mainly sleep()) to your sketch?
                  • L LastSamurai
                    warmaniacW
                    warmaniacW
                    warmaniac
                    @LastSamurai
                    I tryied , many times and changes in sketch but im failed, not waking up on interrupts , im not programmer maybe if I know better C langauge. :( Im using DIGITAL PIN 3 for magnetic sensor input.
                    • warmaniacW
                      warmaniacW
                      warmaniac
                      I don't know if this is correct sketch but now working on interrupts , take a look please
                       * Simple binary switch example
                       * Connect button or door/window reed switch between
                       * digitial I/O pin 3 (BUTTON_PIN below) and GND.
                       * http://www.mysensors.org/build/binary
                      #define CHILD_ID 3
                      #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                      Bounce debouncer = Bounce();
                      int oldValue=-1;
                        // Setup the button
                        pinMode(BUTTON_PIN,INPUT);
                        // Activate internal pull-up
                        debouncer.attach(BUTTON_PIN);
                        debouncer.interval(5);
                        present(CHILD_ID, S_DOOR);
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue) {
                           // Send in the new value
                           send(msg.set(value==HIGH ? 1 : 0));
                           oldValue = value;
                      sleep(digitalPinToInterrupt(BUTTON_PIN)-2, CHANGE, 0);
                      AWIA 1 Reply Last reply
                        mortommy
                        I have some Door/window sensors, powered by a cr2032 coin battery and I was able to run them for 1 year. The sketch above it seems ok, but the secret it's not only the software, it depends on hardware too:
                        • remove voltage regulator and led from the arduino
                        • choose a ceramic decoupling capacitor for your radio module, and avoid electrolytic capacitors (they have a bigger leakage current)
                        • I don't use any step-up converter, and use the battery to power both the radio module and arduino (reported both to work at 3V)
                        • a capacitor (again ceramic) of 100uF across the cell’s terminals could sustain a peak current load.
                        It's also better to avoid messages sending in a short time, and put some sleep in the middle, but I don't see that situation in the sketch.
                        • M mortommy
                          warmaniacW
                          warmaniacW
                          warmaniac
                          @mortommy
                          Thanks for you reply !
                          Apologize me, if I mistaken , but ceramic capacitors in values 100 uF was only SMD? That can't I solder yet. :(
                          Nca78N 1 Reply Last reply
                            #define CHILD_ID 3
                            int oldValue=-1;
                              // Setup the button
                              debouncer.update();
                                 oldValue = value;
                            AWIA
                            AWIA
                            AWI
                            @warmaniac Using debounce with a sleeping node is rather useless. Sleep() halts the millis() timer which is used by debounce. You can just sleep(100) a few ms before entering the interrupt sleep.
                            • AWIA AWI
                              warmaniacW
                              warmaniacW
                              warmaniac
                              @AWI
                              if I understand correctly you mean like this ?
                                debouncer.update();
                                   oldValue = value;
                              sleep(200);
                              Wouldn't be delay(200) doing same function ?
                                @AWI
                                  debouncer.update();
                                     oldValue = value;
                                sleep(200);
                                AWIA
                                AWIA
                                AWI
                                wrote on last edited by AWI
                                @warmaniac delay() does the same thing but does not turn down the power. You can just skip the debouncer stuff.
                                  @mortommy
                                  wrote on last edited by Nca78
                                  Honestly it's really not a problem to solder those, not long ago (just over a couple of months :) ) I was afraid of SMD soldering and now after only a bit of training it's very easy if you stick to "big" sized SMD components or radios with castellated pins.
                                  But even smaller size gets easy when you learn the right method, I soldered my first SMD atmega328 a few weeks ago and it is running fine :)
                                    mortommy
                                    I want also to specify that my sensor was running under library 1.5.4. At the moment I'm experiencing an issue under the library 2.1.1 that makes the sensor continuously wake up, so the battery discharges itself after few hours. Better under library 2.0.0 but the initialization process has many transmissions failure that give to the battery a heavy blow.
                                    • M mortommy
                                      warmaniacW
                                      warmaniacW
                                      warmaniac
                                      wrote on last edited by warmaniac
                                      #21
                                      @mortommy
                                      YES !!! That's it !!! But it is fatal error , because i use step up booster and when battery goes down , It caused that arduino start / shutdown quickly , it spams my Gateway I must disconnect it .
