  3. Low power battery Door/Window sketch nrf24l01
21 Posts 7 Posters 11.9k Views 5 Watching
  • warmaniacW Offline
    warmaniacW Offline
    warmaniac
    wrote on last edited by warmaniac
    Hi there,
    I want to ask if somebody had already done a sketch for 2AA 1,5V battery powered arduino with nrf24l01 wireless radio based on interrupt pin detection ? I have done couple of hours searching and trying but I'm not very successful with it. The default sketch on this web https://www.mysensors.org/build/binary drains my batteries powered by power booster after 24 hours to 0,8 volts :cat:
    In advance, I really appreciate your support in this matter
    S 1 Reply Last reply
    • L Offline
      L Offline
      LastSamurai
      wrote on last edited by LastSamurai
      I have a door sensor running on my mini sensor platform. . I used this sketch from my github.
      Don't use any boosters and use external resistors, not the internal pullups. With that I get a pretty good runtime.
      The first part is expertimentation with older batteries, the steeper curve at the beginning was before I added the external resistors. Since then the voltage drop in about 2,5 months was around 100mV. With 3-1.8 = 1200mV that would be a runtime of about 12*2,5 = 30 months.
      PS The demo sketch doesn't seem to be using sleep. That means the power draw is way too high for the use of batteries.
        warmaniacW Offline
        warmaniac
        I'm not having problem with my hardware with other sensors which sleeps every 2 minutes. Same hardware lasts on 1 % battery for 2 weeks , it is good result for me . I only want to know if is better sketch for battery powered door sensor which is based on interrupts wake up from sleep. It will be much better for battery.
        L 1 Reply Last reply
          I remember one saying that was able to run for over a year, a mini pro with reed switch on a single cr123
          • warmaniacW warmaniac
            Hi there,
            @warmaniac - it should not be a problem running this for atleast a year (this is how I have build my PCB - EasyPCB).
            Do you use the sleep() function and did you remove the led and voltage converter on the arduino?
            Here is some more info: https://www.mysensors.org/build/battery
            If you check https://www.mysensors.org/build/motion you can see a binary sketch which use sleep()
            warmaniacW 1 Reply Last reply
            • S sundberg84
              warmaniacW Offline
              warmaniacW Offline
              warmaniac
              @sundberg84
              BOTH led was removed , as I said , this HW specs Im using on multiple sensors with sleep function and i dont have any problems with battery. Thanks for recommendation of using modified sketch from motion sensor. Im not expecting to remove voltage regulator because im powering my arduino with stepup booster which can be higher than 3.3 volts .
                @sundberg84
                @warmaniac - this is not optimal since the voltage regulater has a current drain and will use your batterypower to fast. Im using a DC-DC stepup booster which provide 3.3v and then you dont need a voltage regulator.
                • S sundberg84
                  warmaniacW Offline
                  warmaniacW Offline
                  warmaniac
                  @sundberg84
                  Yep I understand , but I ordered 10 pcs of step up boosters, all gives output voltage 3,7 -3,8V . without regulator is problem ,I think.
                    @sundberg84
                    @warmaniac - So maybe you can add a diode or something in series to drop the voltage until you get new stepups, because you will be disappointing with batterylife if you use this setup.
                      warmaniacW Offline
                      warmaniac
                      @sundberg84
                      I had barometer BMP180 powered on 2xAA 1,5V , in usage from 1.March 2017 , Start battery power was 85% (not new batteries, before used) and now after 14 days of usage is 84 % , Im very satisfied. Using only without LEDs ,with power regulator on arduino.
                        L Offline
                        L Offline
                        LastSamurai
                        @warmaniac said in Low power battery Door/Window sketch nrf24l01:
                        Then why don't you just use the sketch I linked to? Or simply add the parts you need (mainly sleep()) to your sketch?
                        • L LastSamurai
                          warmaniacW Offline
                          warmaniacW Offline
                          warmaniac
                          @LastSamurai
                          I tryied , many times and changes in sketch but im failed, not waking up on interrupts , im not programmer maybe if I know better C langauge. :( Im using DIGITAL PIN 3 for magnetic sensor input.
                            warmaniacW Offline
                            warmaniac
                            I don't know if this is correct sketch but now working on interrupts , take a look please
                             * Simple binary switch example
                             * Connect button or door/window reed switch between
                             * digitial I/O pin 3 (BUTTON_PIN below) and GND.
                             * http://www.mysensors.org/build/binary
                            #define CHILD_ID 3
                            #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                            Bounce debouncer = Bounce();
                            int oldValue=-1;
                              // Setup the button
                              pinMode(BUTTON_PIN,INPUT);
                              // Activate internal pull-up
                              debouncer.attach(BUTTON_PIN);
                              debouncer.interval(5);
                              present(CHILD_ID, S_DOOR);
                              debouncer.update();
                              // Get the update value
                              int value = debouncer.read();
                              if (value != oldValue) {
                                 // Send in the new value
                                 send(msg.set(value==HIGH ? 1 : 0));
                                 oldValue = value;
                            sleep(digitalPinToInterrupt(BUTTON_PIN)-2, CHANGE, 0);
                            A 1 Reply Last reply
                            • M Offline
                              M Offline
                              mortommy
                              I have some Door/window sensors, powered by a cr2032 coin battery and I was able to run them for 1 year. The sketch above it seems ok, but the secret it's not only the software, it depends on hardware too:
                              • remove voltage regulator and led from the arduino
                              • choose a ceramic decoupling capacitor for your radio module, and avoid electrolytic capacitors (they have a bigger leakage current)
                              • I don't use any step-up converter, and use the battery to power both the radio module and arduino (reported both to work at 3V)
                              • a capacitor (again ceramic) of 100uF across the cell’s terminals could sustain a peak current load.
                              It's also better to avoid messages sending in a short time, and put some sleep in the middle, but I don't see that situation in the sketch.
                              • M mortommy
                                warmaniacW Offline
                                warmaniacW Offline
                                warmaniac
                                @mortommy
                                Thanks for you reply !
                                Apologize me, if I mistaken , but ceramic capacitors in values 100 uF was only SMD? That can't I solder yet. :(
                                N 1 Reply Last reply
                                  #define CHILD_ID 3
                                  int oldValue=-1;
                                    // Setup the button
                                    debouncer.update();
                                       oldValue = value;
                                  A Offline
                                  A Offline
                                  AWI
                                  @warmaniac Using debounce with a sleeping node is rather useless. Sleep() halts the millis() timer which is used by debounce. You can just sleep(100) a few ms before entering the interrupt sleep.
                                  • A AWI
                                    warmaniacW Offline
                                    warmaniacW Offline
                                    warmaniac
                                    @AWI
                                    if I understand correctly you mean like this ?
                                      debouncer.update();
                                         oldValue = value;
                                    sleep(200);
                                    Wouldn't be delay(200) doing same function ?
                                      @AWI
                                        debouncer.update();
                                           oldValue = value;
                                      sleep(200);
                                      A Offline
                                      A Offline
                                      AWI
                                      wrote on last edited by AWI
                                      @warmaniac delay() does the same thing but does not turn down the power. You can just skip the debouncer stuff.
                                        @mortommy
                                        N Offline
                                        N Offline
                                        wrote on last edited by Nca78
                                        Honestly it's really not a problem to solder those, not long ago (just over a couple of months :) ) I was afraid of SMD soldering and now after only a bit of training it's very easy if you stick to "big" sized SMD components or radios with castellated pins.
                                        But even smaller size gets easy when you learn the right method, I soldered my first SMD atmega328 a few weeks ago and it is running fine :)
                                        • M Offline
                                          M Offline
                                          mortommy
                                          I want also to specify that my sensor was running under library 1.5.4. At the moment I'm experiencing an issue under the library 2.1.1 that makes the sensor continuously wake up, so the battery discharges itself after few hours. Better under library 2.0.0 but the initialization process has many transmissions failure that give to the battery a heavy blow.
