  3. 💬 RFM69 Livolo 2 channels 1 way EU switch(VL-C700X-1 Ver: B8)
mysensorslivolo
100 Posts 14 Posters 49.8k Views 17 Watching
  • mtiutiuM
    mtiutiuM
    mtiutiu
    #35
    I updated the project page on openhardware.io. Added instructions too. I hope that I didn't forget anything.
    These are the modifications required for the power/relays board in order to work with this project:
    0_1488279189050_IMG_20170228_085500.jpg 0_1488287333585_IMG_20170228_08553677.jpg
    A capacitor is also needed in parallel with the light bulb otherwise the project board won't work as it doesn't get enough power from the standby circuit. I used a 470nF X2 type rated at 310Vac. I recommend using a light bulb of 10W or more(in my tests I used a 15W one.) I tested the setup with a 5W LED bulb but I got some instability from the livolo power supply board(it started to oscillate) - in this case maybe a bigger capacitor across the bulb might help(1uF one maybe). You don't need 2 capacitors in case of the 2 ways switch for each light bulb - one is sufficient across one of the bulbs.
    Oh and please don't touch directly with your finger the sensor plates - use the plastics from the original board. I'm not responsible if you get an electric shock.
    You can find more details in the project page on openhardware.io
    Big thanks again to @jirm, @DJONvl and @Tigroenot and the rest of the community of course which contributed with the knowledge to make all this possible.
    • tonnerre33T
      tonnerre33T
      tonnerre33
      i don't find anymore the VL-C700X-1 on aliexpress.
      Can you tel me which is equal ?
      Is it https://fr.aliexpress.com/store/product/Free-Shipping-Livolo-Luxury-White-Crystal-Glass-Switch-Panel-EU-Standard-VL-C701-11-110-250V/500715_512886492.html?spm=2114.12010612.0.0.deb0F4 ?
      Thx
      mtiutiuM 1 Reply Last reply
      • tonnerre33T tonnerre33
        Thx
        mtiutiuM
        mtiutiuM
        mtiutiu
        #37
        @tonnerre33
        This one is: https://m.aliexpress.com/item/512770913.html
        Please note that the board that I made is for the 2 channels model(VL-C702 series). Now I hope that they didn't changed the inside pcb hw revision meanwhile. The serial number that you mentioned and which I wrote about on openhardware project page is actually their pcb revision from inside the switch. I don't know for sure if that reflects the switch model which they advertise on AliExpress. But the link that I gave you is for the same switch which I bought some time ago because I took it from my orders list from my AliExpress account.
        I see now that the price is bigger... it was 13$ when I bought it.
        tonnerre33T jirmJ 2 Replies Last reply
        • mtiutiuM mtiutiu
          @tonnerre33
          tonnerre33T
          tonnerre33T
          tonnerre33
          wrote on last edited by hek
          #38
          @mtiutiu Thanks you for your anwser ;)
          Did you test a two way switch (va et viens) ?
          I think we can do this with 1 gang 2 way :
          https://fr.aliexpress.com/item/Black-Crystal-Glass-Switch-Livolo-EU-Standard-VL-C701SR-12-1-Gang-2-Way-Remote-Control/32786281129.html
            mtiutiuM
            mtiutiuM
            mtiutiu
            @tonnerre33
            No, I didn't tested a 2 way switch so I don't know how it behaves in that case. I don't have and I don't use switches with that setup.
            jirmJ 1 Reply Last reply
            • mtiutiuM mtiutiu
              @tonnerre33
              jirmJ
              jirmJ
              jirm
              wrote on last edited by jirm
              #40
              @mtiutiu
              Hi all
              Can I suggest some improvements for that project?
              For sure I agree with @tonnerre33 about make a version board for only one gang switch.
              I buy regularly (once a month or so) some parts from livolo and from last 4 or 6 months I see that the switch plate boards (for the EU version) are the same on hardware specs at least from 6 or 9 month ago.
              But we can expect that in near future (maybe few months) Livolo manufacturer make some changes and updates on his designs, because they regulary are doing that in past. So we need keep prepared for that and for make the propper updates to this project to mantain it working with the next version Livolo switchs.
              1. -One gang switch I think is most common switch people have installed or at least I think is needed too with this two gang project version.
              2.- Maybe will be better use (or make another plate board version) for the RFM69HW (high power), because the pinount on HW not match with RFM69CW you use, and HW type have same working specs but with the plus that HW type have high power possibilities and is most easy to find and both have similar price.
              3.- How can be little better documented all the changes (wiring) we need do on the power relay plate board?
              At least for me is hard to do correct wiring only seeing the photo and is easy to do some mistake trying to solder the wiring in the correct pins and places.
              So I suggest trying to do some more work on that and maybe include some scheme and plan and take all best pic from each wiring bridge is needed to do that we can see without doubts the correct place to solder it.
              PD: @tonnerre33 I think one or two way switch function not be affected with this project plate board, because that function only differ on the pic (MCU) Livolo switch firmware and litles changes on power relay plate board to wire the additional pic pin output two way function to the COM connector.
              Nothing of that function should be affected by anything that this plate modifies on the Livolo switch.
              My best wishes !
              • jirmJ jirm
                @mtiutiu
                Hi all
                My best wishes !
                tonnerre33T
                tonnerre33T
                tonnerre33
                #41
                @jirm said in 💬 Livolo EU switch Mysensors integration:
                I hope because i have many 2 way and the same for my futur home ;)
                And what about NRF24L version ?
                Many people are using RFM69 but 2.70$ RFM vs 1$ NRF ... Ok for command the sensitives nodes like roller shutters but why for the light ?
                • mtiutiuM mtiutiu
                  @tonnerre33
                  jirmJ
                  jirmJ
                  jirm
                  #42
                  @mtiutiu
                  Of course all we are here to help you make all the proper test needed with all Livolo parts that we speak. One or two gang with/and one or two way, other plate hardware revisions, etc...
                  That all we need for do that is the avaibilitty to get your plate boards designs working on our houses.
                  Personally I'm so busy (and so lazy) to make all this project working from scratch trying to find plate board manufacturer, solder all (wooow smd) parts, etc... etc... and need if possible some at least "semi-mounted" plate boards printed and with the smd parts soldered.
                    jirmJ
                    jirmJ
                    jirm
                    @tonnerre33
                    Personally I think that much better specs from RFM vs NRF and the working radio band (433, 868 Mhz vs 2,4 Ghz) are most than enough reasons to spend that 2 $ more on RFM.
                    But...more always is better. So we can dream with another plate board version for NRF in the future...who knows
                    • mtiutiuM
                      mtiutiuM
                      mtiutiu
                      Hi all,
                      So after some time of testing I give you the final revision of this board which is 0.5. The latest files are available on the openhardware.io page but always the most recent are on my github repo of course(I'll try to keep both in sync anyways). By using good tantalum caps where required I got a good stability for the node. It will be kept for testing for one month still starting from this week(testing already started). So far I'm very satisfied with the results.
                      As a final note for all of you there: when designing hardware always use good components - especially good filtering capacitors because most of the issues and instability happens because of that.
                      I will try to design the pcb for the one channel variant of the switch too when I'll get my hands on it so stay tuned. I see that some people asked why RFM69 instead of NRF24L01: this is because the RFM69 module is superior in terms of performance/stability/range compared to the latter(trust me it worth the money difference as I tested both along time). And because it works in the sub-GHz band it's also less prone to interference compared to the 2.4GHz band which is used by all Wi-Fi equipment.
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Wow, great. I guess there is no way to be able to buy these boards pre soldered w. components?
                        • tonnerre33T
                          tonnerre33T
                          tonnerre33
                          Hello, for information, the version has changed :( Here is the new board : https://fr.aliexpress.com/item/Free-Shipping-EU-Standard-Livolo-AC-110-250V-The-Base-Of-Wall-Light-Touch-Screen-Switch/1898648882.html
                          But there is good news, 3V and 12V are directly accessible ;)
                          Nca78N 1 Reply Last reply
                            @tonnerre33 said in 💬 Livolo EU switch Mysensors integration:
                            Might be bad news in the (very) short term, but it will soon be much better as it means after modification to adapt to the new version @mtiutiu board should not require any hardware modification on the main power/relay PCB as 12V is now available.
                            • mtiutiuM
                              mtiutiuM
                              mtiutiu
                              #48
                              Well..I was expecting this to happen at some point in time. This is the nasty thing that may happen when you rely on some external board(s) to do your work. It is a good thing that the 12V line is now exposed..but the pcb needs to be recreated.
                              And who knows in the future when it might change again. So in the end the best solution would be to have all the boards made(including the power/relays one) so that no one needs to rely on the Livolo company. But for the moment I don't have enough knowledge/time - at least not too much regarding power electronics and creating live wire only power supplies(including testing/safety/etc).
                              A 1 Reply Last reply
                              • mtiutiuM mtiutiu
                                alexus
                                @mtiutiu Hello, I wanted to buy 2 devices. For sale? how much is?
                                • A alexus
                                  mtiutiuM
                                  mtiutiuM
                                  mtiutiu
                                  • mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    #51
                                    Because some people asked here: I don't have anything for sale unfortunately and I don't have time to produce and sell ready made boards. The project design files are available for free so anyone can build it. But be aware that you need to have the right livolo switches(as seen from the project pictures). Latest ones produced by the Livolo manufacturer use another hardware revision which is not compatible with the pcb that I've designed.
                                    Regarding BOM and total price for producing one board I didn't had time for that either and the thing is that the price varies depending from where you supply the components.
                                    • mtiutiuM mtiutiu
                                      alexus
                                      @mtiutiu Thanks for the quick response, can only eat PCBs without components? I can not make a PCB.
                                        shabba
                                        Hi @mtiutiu - Firstly nice work. I bought a few and sent on a little gratitude also.
                                        Is there a revision or something on the lenovo switches to make sure that I have the right one? I have quite a few now and a few more on the way so I just want to make sure I am all set.
                                        • A alexus
                                          jirmJ
                                          jirmJ
                                          jirm
                                          #54
                                          @alexus
                                          Few weeks ago I uploaded and shared to Oshpark pcb web service this @mtiutiu pcb design (but take care !!! I think this is not last one version @mtiutiu design), so anyone can easily find it there and order build some pcb if like.
                                          You can check it at https://oshpark.com/shared_projects , and easyly find it with only enter "livolo" word in the search case.
                                          Sadly I don't have enough time yet to involve more in this project, but in near future I'm going to that and test that awesome design that this project have.
                                          Regards
