  3. 💬 RFM69 Livolo 2 channels 1 way EU switch(VL-C700X-1 Ver: B8)
mysensorslivolo
100 Posts 14 Posters 49.8k Views 17 Watching
  • A
    antonholmstedt
    I suppose my question is a bit too early to ask, but what could the total price be for each complete switch? This is a truly awsome projekt, huge respect for your work!
    mtiutiuM 1 Reply Last reply
    • A antonholmstedt
      mtiutiuM
      mtiutiuM
      mtiutiu
      @antonholmstedt
      Thanks. Well the prices vary depending from where you're sourcing the components. I will update the BOM using EU prices as I'm from EU. But if you can source them from aliexpress from example you can get them at half the price - maybe even a quarter(this depends also on the fact that you trust the China suppliers from there). I bought components from aliexpress and I think I had one unfortunate incident until now: some L6920 chips that I bought were defective and/or fake.
      • MiKaM
        MiKaM
        MiKa
        I received Livolo switches from aliexpress but main board connector is 2x7pin with 2mm pitch not 2x6 pitch 2.54mm...
        • MiKaM MiKa
          mtiutiuM
          mtiutiuM
          mtiutiu
          #31
          @MiKa
          That's because you have another hw revision and maybe you bought a non-EU switch? I started this hw design using the EU variant because I'm from EU. I specified all these details in the project page too and for which hw revision of the board - quoting from there: "...the EU variant that I have(VL-C700X-1 Ver: B8)...". This hw revision of the board uses a 2x6 pin connector with 2.54mm pitch.
          But if you can give me a dxf file with the front plate outline, touch sensors copper pads and 2x7 connector locations I can transpose that over the current board and do the arrangements so that it will align with yours too. One other thing that's needed is the 12V and 3V assignments to the 2x7 pin board connector and the relays drive pins too. I see here https://forum.mysensors.org/topic/2775/livolo-glass-panel-touch-light-wall-switch-arduino-433mhz/72# that @Nca78 posted that configuration but maybe you need to double check??
          • Nca78N
            Yes I suggest a double check as mine is a US/AU format.
            • mtiutiuM
              mtiutiuM
              mtiutiu
              #33
              After a really long time I received the boards. I finished the assembly for one and uploaded some code to it. So far it seems to work but I need to perform some more tests. I attached some pictures of the finished product.0_1488214929606_IMG_20170227_163301.jpg .0_1488214943223_IMG_20170227_163325.jpg 0_1488214954367_IMG_20170227_163649.jpg
              The silkscreen text is a little bit blurry and it was a little bit too small for the fab to print it so in some places is not right...anyways this is not important but the functionality is.
              One note: the board round edges may be a little bit off the limits but that can be corrected by using some abrasive paper to remove the excess material(which I did in the above pictures and then the board fitted perfectly).
              jirmJ 1 Reply Last reply
              • mtiutiuM mtiutiu
                jirmJ
                jirmJ
                jirm
                @mtiutiu
                Wooow wooow !!
                Really a good job. Perfect looking and really accurate design board.
                Sure it´s a winner project.
                I only wait you can post us how can we get these wonders.
                My best wishes
                • mtiutiuM
                  mtiutiuM
                  mtiutiu
                  #35
                  I updated the project page on openhardware.io. Added instructions too. I hope that I didn't forget anything.
                  These are the modifications required for the power/relays board in order to work with this project:
                  0_1488279189050_IMG_20170228_085500.jpg 0_1488287333585_IMG_20170228_08553677.jpg
                  A capacitor is also needed in parallel with the light bulb otherwise the project board won't work as it doesn't get enough power from the standby circuit. I used a 470nF X2 type rated at 310Vac. I recommend using a light bulb of 10W or more(in my tests I used a 15W one.) I tested the setup with a 5W LED bulb but I got some instability from the livolo power supply board(it started to oscillate) - in this case maybe a bigger capacitor across the bulb might help(1uF one maybe). You don't need 2 capacitors in case of the 2 ways switch for each light bulb - one is sufficient across one of the bulbs.
                  Oh and please don't touch directly with your finger the sensor plates - use the plastics from the original board. I'm not responsible if you get an electric shock.
                  You can find more details in the project page on openhardware.io
                  Big thanks again to @jirm, @DJONvl and @Tigroenot and the rest of the community of course which contributed with the knowledge to make all this possible.
                  • tonnerre33T
                    tonnerre33T
                    tonnerre33
                    i don't find anymore the VL-C700X-1 on aliexpress.
                    Can you tel me which is equal ?
                    Is it https://fr.aliexpress.com/store/product/Free-Shipping-Livolo-Luxury-White-Crystal-Glass-Switch-Panel-EU-Standard-VL-C701-11-110-250V/500715_512886492.html?spm=2114.12010612.0.0.deb0F4 ?
                    Thx
                    • tonnerre33T tonnerre33
                      Thx
                      mtiutiuM
                      mtiutiuM
                      mtiutiu
                      #37
                      @tonnerre33
                      This one is: https://m.aliexpress.com/item/512770913.html
                      Please note that the board that I made is for the 2 channels model(VL-C702 series). Now I hope that they didn't changed the inside pcb hw revision meanwhile. The serial number that you mentioned and which I wrote about on openhardware project page is actually their pcb revision from inside the switch. I don't know for sure if that reflects the switch model which they advertise on AliExpress. But the link that I gave you is for the same switch which I bought some time ago because I took it from my orders list from my AliExpress account.
                      I see now that the price is bigger... it was 13$ when I bought it.
                      tonnerre33T jirmJ 2 Replies Last reply
                      • mtiutiuM mtiutiu
                        @tonnerre33
                        tonnerre33T
                        tonnerre33T
                        tonnerre33
                        wrote on last edited by hek
                        #38
                        @mtiutiu Thanks you for your anwser ;)
                        Did you test a two way switch (va et viens) ?
                        I think we can do this with 1 gang 2 way :
                        https://fr.aliexpress.com/item/Black-Crystal-Glass-Switch-Livolo-EU-Standard-VL-C701SR-12-1-Gang-2-Way-Remote-Control/32786281129.html
                          mtiutiuM
                          mtiutiuM
                          mtiutiu
                          @tonnerre33
                          No, I didn't tested a 2 way switch so I don't know how it behaves in that case. I don't have and I don't use switches with that setup.
                          • mtiutiuM mtiutiu
                            @tonnerre33
                            jirmJ
                            jirmJ
                            jirm
                            wrote on last edited by jirm
                            #40
                            @mtiutiu
                            Hi all
                            Can I suggest some improvements for that project?
                            For sure I agree with @tonnerre33 about make a version board for only one gang switch.
                            I buy regularly (once a month or so) some parts from livolo and from last 4 or 6 months I see that the switch plate boards (for the EU version) are the same on hardware specs at least from 6 or 9 month ago.
                            But we can expect that in near future (maybe few months) Livolo manufacturer make some changes and updates on his designs, because they regulary are doing that in past. So we need keep prepared for that and for make the propper updates to this project to mantain it working with the next version Livolo switchs.
                            1. -One gang switch I think is most common switch people have installed or at least I think is needed too with this two gang project version.
                            2.- Maybe will be better use (or make another plate board version) for the RFM69HW (high power), because the pinount on HW not match with RFM69CW you use, and HW type have same working specs but with the plus that HW type have high power possibilities and is most easy to find and both have similar price.
                            3.- How can be little better documented all the changes (wiring) we need do on the power relay plate board?
                            At least for me is hard to do correct wiring only seeing the photo and is easy to do some mistake trying to solder the wiring in the correct pins and places.
                            So I suggest trying to do some more work on that and maybe include some scheme and plan and take all best pic from each wiring bridge is needed to do that we can see without doubts the correct place to solder it.
                            PD: @tonnerre33 I think one or two way switch function not be affected with this project plate board, because that function only differ on the pic (MCU) Livolo switch firmware and litles changes on power relay plate board to wire the additional pic pin output two way function to the COM connector.
                            Nothing of that function should be affected by anything that this plate modifies on the Livolo switch.
                            My best wishes !
                            • jirmJ jirm
                              @mtiutiu
                              Hi all
                              My best wishes !
                              tonnerre33T
                              tonnerre33T
                              tonnerre33
                              #41
                              @jirm said in 💬 Livolo EU switch Mysensors integration:
                              I hope because i have many 2 way and the same for my futur home ;)
                              And what about NRF24L version ?
                              Many people are using RFM69 but 2.70$ RFM vs 1$ NRF ... Ok for command the sensitives nodes like roller shutters but why for the light ?
                              • mtiutiuM mtiutiu
                                @tonnerre33
                                jirmJ
                                jirmJ
                                jirm
                                #42
                                @mtiutiu
                                Of course all we are here to help you make all the proper test needed with all Livolo parts that we speak. One or two gang with/and one or two way, other plate hardware revisions, etc...
                                That all we need for do that is the avaibilitty to get your plate boards designs working on our houses.
                                Personally I'm so busy (and so lazy) to make all this project working from scratch trying to find plate board manufacturer, solder all (wooow smd) parts, etc... etc... and need if possible some at least "semi-mounted" plate boards printed and with the smd parts soldered.
                                  jirmJ
                                  jirmJ
                                  jirm
                                  @tonnerre33
                                  Personally I think that much better specs from RFM vs NRF and the working radio band (433, 868 Mhz vs 2,4 Ghz) are most than enough reasons to spend that 2 $ more on RFM.
                                  But...more always is better. So we can dream with another plate board version for NRF in the future...who knows
                                  • mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    Hi all,
                                    So after some time of testing I give you the final revision of this board which is 0.5. The latest files are available on the openhardware.io page but always the most recent are on my github repo of course(I'll try to keep both in sync anyways). By using good tantalum caps where required I got a good stability for the node. It will be kept for testing for one month still starting from this week(testing already started). So far I'm very satisfied with the results.
                                    As a final note for all of you there: when designing hardware always use good components - especially good filtering capacitors because most of the issues and instability happens because of that.
                                    I will try to design the pcb for the one channel variant of the switch too when I'll get my hands on it so stay tuned. I see that some people asked why RFM69 instead of NRF24L01: this is because the RFM69 module is superior in terms of performance/stability/range compared to the latter(trust me it worth the money difference as I tested both along time). And because it works in the sub-GHz band it's also less prone to interference compared to the 2.4GHz band which is used by all Wi-Fi equipment.
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      Wow, great. I guess there is no way to be able to buy these boards pre soldered w. components?
                                      • tonnerre33T
                                        tonnerre33T
                                        tonnerre33
                                        Hello, for information, the version has changed :( Here is the new board : https://fr.aliexpress.com/item/Free-Shipping-EU-Standard-Livolo-AC-110-250V-The-Base-Of-Wall-Light-Touch-Screen-Switch/1898648882.html
                                        But there is good news, 3V and 12V are directly accessible ;)
                                        Nca78N 1 Reply Last reply
                                          @tonnerre33 said in 💬 Livolo EU switch Mysensors integration:
                                          Might be bad news in the (very) short term, but it will soon be much better as it means after modification to adapt to the new version @mtiutiu board should not require any hardware modification on the main power/relay PCB as 12V is now available.
