  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    I'm amazed this hasn't got more attention. A superb contribution to the community and one which I'm sure has taken many hours... Thank you!
    Nca78N 1 Reply Last reply
    • U
      U
      user2684
      Thanks @Mark-Swift!
      By the way, if anybody is interested I've just fixed a few bugs and added some minor enhancements (for details: https://sourceforge.net/p/mynodemanager/tickets/milestone/v1.1/).
      The new version (v1.1) is available as always at https://sourceforge.net/projects/mynodemanager
      • Mark SwiftM Mark Swift
        @Mark-Swift said in NodeManager: plugin for a rapid development of battery-powered sensors:
        I agree with you, for a lot of beginners this is like the graal for sketch creation if I believe the many posts asking how to combine some sketches.
        • U
          U
          user2684
          Hi, I've made an update of NodeManager in case can be of interest. Latest version v1.2 is available on https://sourceforge.net/projects/mynodemanager/.
          Short changelog:
          • Added out-of-the-box support for BH1750 light sensor
          • Added out-of-the-box support for HTU21D temperature and humidity sensor
          • Added out-of-the-box support for MLX90614 contactless temperature sensor
          • Added a few examples to the documentation (https://sourceforge.net/p/mynodemanager/wiki/NodeManager/#examples)
          • Fixed a few bugs
          • U
            U
            user2684
            ...and I've moved the repository (including tickets and documentation) under the MySensors community on https://github.com/mysensors/NodeManager (thanks again for your help @hek!).
            I'll keep the Sourceforge project open to avoid broken links but I will upload only new releases there in sync with github.
            • R
              R
              Robbie_
              wrote on last edited by Robbie_
              Cool stuff! was looking for a way to do some configuration of mysensors remotely!
              Gonna give it a spin this week!
              • Ben CotonB
                Ben CotonB
                Ben Coton
                wrote on last edited by gohan
                I love the look of this setup. I am making my own slim nodes running at 8MHz with a basic 328P chip.
                I am starting with a basic Thermistor which is fine but when I try to compile the code I get the following error.
                exit status 1
                default argument given for parameter 3 of 'void PowerManager::setPowerPins(int, int, long int)' [-fpermissive]
                My code is as follows:
                // load user settings
                #include "config.h"
                // load MySensors library
                // load NodeManager library
                #include "NodeManager.h"
                // create a NodeManager instance
                NodeManager nodeManager;
                // before
                void before() {
                  Serial.begin(9600);
                  // instruct the board to sleep for 10 minutes for each cycle
                //  nodeManager.setSleep(SLEEP,10,MINUTES);
                  // register the sensors
                  nodeManager.registerSensor(SENSOR_THERMISTOR,A1);
                //  nodeManager.registerSensor(SENSOR_LDR,A2);
                   * Register below your sensors
                   * Register above your sensors
                  nodeManager.before();
                // presentation
                	sendSketchInfo("Battery Temp Sensor","1.0");
                  nodeManager.presentation();
                // setup
                  nodeManager.setup();
                // loop
                  nodeManager.loop();
                // receive
                  nodeManager.receive(message);
                Any help with sorting this out will be great.
                Cheers,
                Ben
                • U
                  U
                  user2684
                  Thanks for your comment @Ben-Coton! The error message tells me that I'm doing something wrong in the code (http://stackoverflow.com/questions/2545720/error-default-argument-given-for-parameter-1) but I wonder why it compiles without error or warning on my system.
                  Meanwhile I'll fix the problem (tracking it with https://github.com/mysensors/NodeManager/issues/30), in case you want to try a workaround, I share below my platform.txt file since I'm sure there must be some flag in mine which is somehow ignoring the error when I compile it:
                  # Arduino AVR Core and platform.
                  # For more info:
                  # https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.5-3rd-party-Hardware-specification
                  name=Arduino AVR Boards
                  version=1.6.17
                  # AVR compile variables
                  compiler.warning_flags=-w
                  compiler.warning_flags.none=-w
                  compiler.warning_flags.default=
                  compiler.warning_flags.more=-Wall
                  compiler.warning_flags.all=-Wall -Wextra
                  # Default "compiler.path" is correct, change only if you want to override the initial value
                  compiler.path={runtime.tools.avr-gcc.path}/bin/
                  compiler.c.cmd=avr-gcc
                  compiler.c.flags=-c -g -Os {compiler.warning_flags} -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects
                  compiler.c.elf.flags={compiler.warning_flags} -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections
                  compiler.c.elf.cmd=avr-gcc
                  compiler.S.flags=-c -g -x assembler-with-cpp -flto -MMD
                  compiler.cpp.cmd=avr-g++
                  compiler.cpp.flags=-c -g -Os {compiler.warning_flags} -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto
                  compiler.ar.cmd=avr-gcc-ar
                  compiler.ar.flags=rcs
                  compiler.objcopy.cmd=avr-objcopy
                  compiler.objcopy.eep.flags=-O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0
                  compiler.elf2hex.flags=-O ihex -R .eeprom
                  compiler.elf2hex.cmd=avr-objcopy
                  compiler.ldflags=
                  compiler.size.cmd=avr-size
                  # This can be overridden in boards.txt
                  build.extra_flags=
                  # These can be overridden in platform.local.txt
                  compiler.c.extra_flags=
                  compiler.c.elf.extra_flags=
                  compiler.S.extra_flags=
                  compiler.cpp.extra_flags=
                  compiler.ar.extra_flags=
                  compiler.objcopy.eep.extra_flags=
                  compiler.elf2hex.extra_flags=
                  # AVR compile patterns
                  ## Compile c files
                  recipe.c.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.c.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.c.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
                  ## Compile c++ files
                  recipe.cpp.o.pattern="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
                  ## Compile S files
                  recipe.S.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.S.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.S.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
                  ## Create archives
                  # archive_file_path is needed for backwards compatibility with IDE 1.6.5 or older, IDE 1.6.6 or newer overrides this value
                  archive_file_path={build.path}/{archive_file}
                  recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}"
                  ## Combine gc-sections, archives, and objects
                  recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {compiler.c.elf.flags} -mmcu={build.mcu} {compiler.c.elf.extra_flags} -o "{build.path}/{build.project_name}.elf" {object_files} "{build.path}/{archive_file}" "-L{build.path}" -lm
                  ## Create output files (.eep and .hex)
                  recipe.objcopy.eep.pattern="{compiler.path}{compiler.objcopy.cmd}" {compiler.objcopy.eep.flags} {compiler.objcopy.eep.extra_flags} "{build.path}/{build.project_name}.elf" "{build.path}/{build.project_name}.eep"
                  recipe.objcopy.hex.pattern="{compiler.path}{compiler.elf2hex.cmd}" {compiler.elf2hex.flags} {compiler.elf2hex.extra_flags} "{build.path}/{build.project_name}.elf" "{build.path}/{build.project_name}.hex"
                  ## Save hex
                  recipe.output.tmp_file={build.project_name}.hex
                  recipe.output.save_file={build.project_name}.{build.variant}.hex
                  ## Compute size
                  recipe.size.pattern="{compiler.path}{compiler.size.cmd}" -A "{build.path}/{build.project_name}.elf"
                  recipe.size.regex=^(?:\.text|\.data|\.bootloader)\s+([0-9]+).*
                  recipe.size.regex.data=^(?:\.data|\.bss|\.noinit)\s+([0-9]+).*
                  recipe.size.regex.eeprom=^(?:\.eeprom)\s+([0-9]+).*
                  ## Preprocessor
                  preproc.includes.flags=-w -x c++ -M -MG -MP
                  recipe.preproc.includes="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.includes.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}"
                  preproc.macros.flags=-w -x c++ -E -CC
                  recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{preprocessed_file_path}"
                  # AVR Uploader/Programmers tools
                  tools.avrdude.path={runtime.tools.avrdude.path}
                  tools.avrdude.cmd.path={path}/bin/avrdude
                  tools.avrdude.config.path={path}/etc/avrdude.conf
                  tools.avrdude.network_cmd={runtime.tools.arduinoOTA.path}/bin/arduinoOTA
                  tools.avrdude.upload.params.verbose=-v
                  tools.avrdude.upload.params.quiet=-q -q
                  # tools.avrdude.upload.verify is needed for backwards compatibility with IDE 1.6.8 or older, IDE 1.6.9 or newer overrides this value
                  tools.avrdude.upload.verify=
                  tools.avrdude.upload.params.noverify=-V
                  tools.avrdude.upload.pattern="{cmd.path}" "-C{config.path}" {upload.verbose} {upload.verify} -p{build.mcu} -c{upload.protocol} -P{serial.port} -b{upload.speed} -D "-Uflash:w:{build.path}/{build.project_name}.hex:i"
                  tools.avrdude.program.params.verbose=-v
                  tools.avrdude.program.params.quiet=-q -q
                  # tools.avrdude.program.verify is needed for backwards compatibility with IDE 1.6.8 or older, IDE 1.6.9 or newer overrides this value
                  tools.avrdude.program.verify=
                  tools.avrdude.program.params.noverify=-V
                  tools.avrdude.program.pattern="{cmd.path}" "-C{config.path}" {program.verbose} {program.verify} -p{build.mcu} -c{protocol} {program.extra_params} "-Uflash:w:{build.path}/{build.project_name}.hex:i"
                  tools.avrdude.erase.params.verbose=-v
                  tools.avrdude.erase.params.quiet=-q -q
                  tools.avrdude.erase.pattern="{cmd.path}" "-C{config.path}" {erase.verbose} -p{build.mcu} -c{protocol} {program.extra_params} -e -Ulock:w:{bootloader.unlock_bits}:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:{bootloader.high_fuses}:m -Ulfuse:w:{bootloader.low_fuses}:m
                  tools.avrdude.bootloader.params.verbose=-v
                  tools.avrdude.bootloader.params.quiet=-q -q
                  tools.avrdude.bootloader.pattern="{cmd.path}" "-C{config.path}" {bootloader.verbose} -p{build.mcu} -c{protocol} {program.extra_params} "-Uflash:w:{runtime.platform.path}/bootloaders/{bootloader.file}:i" -Ulock:w:{bootloader.lock_bits}:m
                  tools.avrdude_remote.upload.pattern=/usr/bin/run-avrdude /tmp/sketch.hex {upload.verbose} -p{build.mcu}
                  tools.avrdude.upload.network_pattern="{network_cmd}" -address {serial.port} -port {upload.network.port} -sketch "{build.path}/{build.project_name}.hex" -upload {upload.network.endpoint_upload} -sync {upload.network.endpoint_sync} -reset {upload.network.endpoint_reset} -sync_exp {upload.network.sync_return}
                  # USB Default Flags
                  # Default blank usb manufacturer will be filled in at compile time
                  # - from numeric vendor ID, set to Unknown otherwise
                  build.usb_manufacturer="Unknown"
                  build.usb_flags=-DUSB_VID={build.vid} -DUSB_PID={build.pid} '-DUSB_MANUFACTURER={build.usb_manufacturer}' '-DUSB_PRODUCT={build.usb_product}'
                  • Ben CotonB
                    Ben CotonB
                    Ben Coton
                    Thanks for the reply.
                    I have no idea about the platform.txt file so I will wait to see if someone much smarter than me can figure it out :)
                    If it helps, I am using the Arduino IDE V.1.81, compiling with a custom atmega328p board running at 8MHz with BOD disabled.
                    Ben
                    • U
                      U
                      user2684
                      wrote on last edited by user2684
                      Oh I see, when you have custom hardware sometimes you have different options set for the compiler, this is why with the default settings works here. Nevertheless it is an easy fix on my side, just wait for v1.3 to be out very soon and it should compile without issues.
                      • U
                        U
                        user2684
                        Hi, I've updated NodeManager to its 1.3 version. This should also solve your issue @Ben-Coton. Short changelog:
                        • Added support for BME280 temperature/humudity/pressure sensor
                        • Added option to measure battery level via a pin in addition to internal Vcc
                        • Added example sketches to the documentation
                        • Fixed a few bugs
                        Code and updated documentation (now with with four comprehensive examples including the full sketches at the end) on https://github.com/mysensors/NodeManager
                        • V
                          V
                          vikasjee
                          @user2684 , Thanks for the new version.
                          Are you planning to include Virtual Button and IOExpander(MCP23017) support too? Thst would really help especially adding consistent child-ids for the expander pins, just like multiple temp sensors on the SPI bus...
                          U 1 Reply Last reply
                          • V vikasjee
                            U
                            U
                            user2684
                            @vikasjee I'm very open to whatever can make the life of an average user easier, so far I've just pitched what were common requirements for me as a new user but I'm sure there is a lot more that I'm missing. Give me some more info or pointers regarding Virtual Button and IOExpander and how you are using it right now, I couldn't find much here on the forum and my knowledge is limited and I'll look into it for sure!
                            • BeniKB
                              BeniKB
                              BeniK
                              A long time reader and "lurker" here, but just registered today to thank @user2684 for this contribution to MYS Community! In my opinion NodeManager is really a great addition to MYS!
                              • EfflonE
                                EfflonE
                                Efflon
                                I just started playing with this and must say FANTASTIC! This makes things almost too simple.
                                I found a few small things´(bugs?)
                                • You refer to the sourforge page for the latest releases (nit pick)
                                • Baud in the config.h is default set to 9800, shouldn't this be 9600? However, setting it to whatever doesn't help, only 4800 outputs anything, this could be something on my setup as well ...
                                Again, thanks!
                                • soifS
                                  soifS
                                  soif
                                  It sounds absolutely terrific ! :+1:
                                  Thank you very much !
                                  • EfflonE Efflon
                                    Again, thanks!
                                    U
                                    U
                                    user2684
                                    @Efflon thanks for reporting these two issues, I'll track them down with https://github.com/mysensors/NodeManager/issues/34 and https://github.com/mysensors/NodeManager/issues/33 and fix asap!
                                    Thank you all for your comments!
                                    EfflonE 1 Reply Last reply
                                    • U user2684
                                      EfflonE
                                      EfflonE
                                      Efflon
                                      wrote on last edited by Efflon
                                      @user2684 Excellent!
                                      A question, I'm doing a simple door sensor
                                        nodeManager.setBatteryMin(1.8);
                                        nodeManager.setBatteryMax(3.2);
                                        nodeManager.setBatteryReportCycles(1);
                                        int door = nodeManager.registerSensor(SENSOR_DOOR,3);
                                        ((SensorDoor*)nodeManager.get(door))->setDebounce(500);
                                        nodeManager.setSleep(SLEEP,1,HOURS);
                                      Now, the node is constantly sending. It seems as if every wake-up triggers a sending, and a wakeup from the debounce sleep, then battery reporting etc.. Removing the debounce helps and lets the node sleep.
                                      AWAKE
                                      SEND D=0 I=200 C=1 T=48 S=AWAKE I=0 F=0.00
                                      BATT V=3.16 P=97
                                      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.16
                                      SWITCH I=1 P=3 V=0
                                      SEND D=0 I=1 C=1 T=16 S= N=0 F=0.00
                                      SLEEP 60s
                                      SEND D=0 I=200 C=1 T=48 S=SLEEPING I=0 F=0.00
                                      [here i "open" the door]
                                      WAKE P=3, M=1
                                      AWAKE
                                      BATT V=3.16 P=97
                                      SWITCH I=1 P=3 V=1
                                      SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
                                      SLEEP 60s
                                      [just a second wait]
                                      WAKE P=3, M=1
                                      AWAKE
                                      BATT V=3.16 P=97
                                      SWITCH I=1 P=3 V=1
                                      SLEEP 60s
                                      [repeated until closing "door"]
                                      Edit:
                                      I changed the sleep to a wait and now the behavior is correct (this line).
                                      // what do to during loop
                                      void SensorSwitch::onLoop() {
                                        // wait to ensure the the input is not floating
                                        if (_debounce > 0) wait(_debounce);
                                        // read the value of the pin
                                        int value = digitalRead(_pin);
                                      MY I=8 M=1
                                      SEND D=0 I=200 C=0 T=48 S=STARTED I=0 F=0.00
                                      SWITCH I=1 P=3 V=0
                                      SEND D=0 I=1 C=0 T=16 S= N=0 F=0.00
                                      SLEEP 60s
                                      [open]
                                      WAKE P=3, M=1
                                      AWAKE
                                      BATT V=3.16 P=97
                                      SWITCH I=1 P=3 V=1
                                      SLEEP 60s
                                      [close]
                                      WAKE P=3, M=1
                                      AWAKE
                                      BATT V=3.16 P=97
                                      SWITCH I=1 P=3 V=0
                                      SLEEP 60s
                                      • U
                                        U
                                        user2684
                                        Thanks for the hit @Efflon! I accidentally fixed that sleep() in the v1.4 dev branch this afternoon because of another issue. Is everything else now behaving correctly?
                                        I have a concern regarding battery level reports when operating with interrupts: right now I do not distinguish between a cycle because a full sleep has completed from a cycle interrupted by an interrupt like in this case. This may cause a lot more battery reports, depending on how often the sensor triggers. To avoid this unexpected behavior, in the dev branch the default behavior is now the opposite: waking up from an interrupt does not count as a cycle. The drawback though is that if the sensor triggers continuously, it will never report the battery to the controller since unable to complete a full sleeping cycle. This is why I've added the following so allow the user to pick up the policy he likes the most:
                                        // If true, wake up by an interrupt counts as a valid cycle for battery reports otherwise only uninterrupted sleep cycles would contribute (default: false)
                                        void setBatteryReportWithInterrupt(bool value);
                                        In case you want to give this a try, the dev branch is available at https://github.com/mysensors/NodeManager/tree/v1.4-dev. You just need to replace the existing NodeManager.cpp and NodeManager.h files, you can keep both your sketch and your config.h.
                                        • U user2684
                                          EfflonE
                                          EfflonE
                                          Efflon
                                          #21
                                          @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
                                          This is tricky. Myself uses the battery report as a heartbeat on top of checking the battery level, thus I only need the info once or twice a day. Not sending on wake-up is good since it will preserve battery. I guess a combination the right sleeping time and cycle count could end up quite ok. For a front door sensor, 4h sleep and 2 cycle count would report battery level after the night and then maybe one more time, max 3 times per day, which is more than enough. I'll test the dev branch after some sleep :smile:
                                          Btw, great work!! and yes, using wait works just fine, no other issues so far.
