  3. Moisture sensing + relay. Please help with software.
13 Posts 4 Posters 3.5k Views 6 Watching
  • Fat FlyF
    Fat FlyF
    Fat Fly
    wrote on last edited by Fat Fly
    My skill in programming is low. I make something for last 2.x library but some errors. Moisture sensors A0-A5 and if possible add relays from relay sketch.
    https://pastebin.com/VRXyT8Ut
    I want to add same harware these two components.
      Sure, just copy code from the relay and add it to the sketch you are using, just change child ID for relay so it doesn't conflict with the other from the sensor you are using already.
      • Fat FlyF
        Fat FlyF
        Fat Fly
        I try but without luck.
          Ok, but what is the problem you are experiencing? You need to provide code and errors if you want some help
          • Fat FlyF
            Fat FlyF
            Fat Fly
            Arduino/libraries/MySensors/MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
            I want this for Arduino Nano.
            and code is here
            #define MY_GATEWAY_SERIAL
            #define CHILD_ID_BATTERY 0
            #define SLEEP_TIME 600000 // Sleep time between reads (in milliseconds)
            #define STABILIZATION_TIME 500 // Let the sensor stabilize 0.5 seconds before reading
            #define BATTERY_FULL 3000 // 3,000 millivolts when battery is full (assuming 2xAA)
            #define BATTERY_ZERO 1700 // 1,700 millivolts when battery is empty (reqires blown brownout detection fuse, use 2,800 otherwise)
            // This sketch assumes power from 2xAA on Vcc (not RAW). Remove the power led and the voltage regulator for better battery life.
            // Sensors shall be connected to GND and their analog pin. Throw away the middle chip, just use the pitchfork.
            // Number of analog pins for each Arduino model can be seen at https://www.arduino.cc/en/Products/Compare
            // A5 and A6 on most Arduinos cannot be used because they don't have internal pullups
            const int SENSORS[] = {A0, A1, A2, A3, A4, A5}; // Remove the pins that you don't want to use
            #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
            long oldvoltage = 0;
            #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            #define RELAY_ON 1 // GPIO value to write to turn on attached relay
            MyMessage moisture_messages[N_ELEMENTS(SENSORS)];
            void before()
            for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
            //gw.begin();
            sendSketchInfo("Plants moisture w bat", "1.2");
            present(CHILD_ID_BATTERY, S_CUSTOM);
            sendSketchInfo("Relay", "1.0");
            for (int sensor = 0; sensor < N_ELEMENTS(SENSORS); sensor++) {
            moisture_messages[sensor].sensor = sensor + 1; // Battery uses child ID 0 so sensors start at 1
            moisture_messages[sensor].type = V_HUM;
            delay(250);
            gw.present(sensor + 1, S_HUM);
            for (int i = 0; i < N_ELEMENTS(SENSORS); i++) {
            pinMode(SENSORS[i], OUTPUT);
            digitalWrite(SENSORS[i], LOW);
            // Change relay state
            digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
            // Store state in eeprom
              pinMode(SENSORS[sensor], INPUT_PULLUP); // "Power on" the sensor and activate the internal pullup resistor
              analogRead(SENSORS[sensor]); // Read once to let the ADC capacitor start charging
              sleep(STABILIZATION_TIME);
              int moistureLevel = (1023 - analogRead(SENSORS[sensor])) / 10.23;
              // Turn off the sensor to conserve battery and minimize corrosion
              pinMode(SENSORS[sensor], OUTPUT);
              digitalWrite(SENSORS[sensor], LOW);
              send(moisture_messages[sensor].set(moistureLevel));
            long voltage = readVcc();
            if (oldvoltage != voltage) { // Only send battery information if voltage has changed, to conserve battery.
              send(voltage_msg.set(voltage / 1000.0, 3)); // redVcc returns millivolts and set wants volts and how many decimals (3 in our case)
              sendBatteryLevel(round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO)));
              oldvoltage = voltage;
            sleep(SLEEP_TIME);
            long readVcc()
            // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
            #if defined(AVR_ATmega32U4) || defined(AVR_ATmega1280) || defined(AVR_ATmega2560)
            #elif defined (AVR_ATtiny24) || defined(AVR_ATtiny44) || defined(AVR_ATtiny84)
            #elif defined (AVR_ATtiny25) || defined(AVR_ATtiny45) || defined(AVR_ATtiny85)
            uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
            result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.110231000
              The include mysensors.h needs to go after the defines, otherwise it can not know how you want the gateway to behave
              • Fat FlyF
                Fat FlyF
                Fat Fly
                Line 84 a function-definition is not allowed here before '{' token
                I put these 2 line with include after defines.
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  https://pastebin.com/zSb0hPNK
                    I think you forgot to close a parenthesis in the receive function. If you like a more helping programming interface, you can install visual studio and the extension Visual Micro that are much better than Arduino IDE and help you also visually with parenthesis and auto completion of functions and variables names.
                    • Fat FlyF
                      Fat FlyF
                      Fat Fly
                      @gohan said in Moisture sensing + relay. Please help with software.:
                      I use linux. Ubuntu. For linux what software ?
                        Maybe eclipse, but I'm not much into Linux, sorry.
                        • O
                          O
                          ominicw
                          • alowhumA
                            alowhumA
                            alowhum
                            Here is some code that does exactly what was asked for:
                            https://github.com/createcandle/Devices/tree/master/Plant_health
